[Plugin] FredoTools - v4.0a - 17 May 20
Re: [Plugin] FredoTools - v3.0c - 13 Feb 17
Postby bharralure » Mon Feb 13, 2017 5:26 pm
Non, la boîte de dialogue n'est pas redimensionnable.
bharralure
Postby fredo6 » Mon Feb 13, 2017 5:26 pm
NEW RELEASE: FredoTools v3.0c - 13 Feb 17
FredoTools 3.0c fixes sizing issues for some dialog boxes in SU2017
See main post of this thread for Download.
Fredo
3
fredo6
PluginStore Author
PluginStore Author
Postby vlad_s » Mon Mar 06, 2017 1:37 pm
Good day, does not work markvertex with fredolib 7.3 and 7.5 in windows xp. In fredolib 6.4 worked.
Sorry for the English language, computer translation from Russian.
vlad_s
Postby cadmunkey » Fri Jun 30, 2017 3:11 pm
Hi Fredo, any reason the Sold Volume calculator would report a solid back as a minus figure?
I took volume calc from my marble model and thought something was strange with the result. So checked individual pieces and some are reporting a minus figure, which of course deducts itself from the final overall result.
cadmunkey
Postby Dave R » Fri Jun 30, 2017 3:39 pm
Cadmunkey, is it possible the faces are reversed on the volume?
Global Moderator
Postby cadmunkey » Fri Jun 30, 2017 4:02 pm
Dave R wrote:Cadmunkey, is it possible the faces are reversed on the volume?
Hi Dave, no I did check for this. I cant see a reason for it at all.
cadmunkey
Postby Dave R » Fri Jun 30, 2017 4:55 pm
How about copying and pasting that volume into a new file and sharing it so we can see it?
Global Moderator
Postby bharralure » Fri Jun 30, 2017 5:29 pm
Bonjour Dave
Je confirme que "Volume Solides" affiche une valeur négative pour toute instance crée en miroir.
Ce problème n'est pas spécifique à SU 2017, l'ayant déjà constaté sous SU 2016 et SU 2015.
Je joint un Gif crée sous SU 2017.
bharralure
Postby cadmunkey » Fri Jun 30, 2017 6:42 pm
Dave R wrote:How about copying and pasting that volume into a new file and sharing it so we can see it?
Dave, happy to send it to you privately for a look? its a 12mb file.
cadmunkey
Postby fredo6 » Sat Jul 01, 2017 6:44 am
@cadmunkey
You are right. Actually, the result is correct mathematically. In the algorithm, negative volumes are normally used for holes in solids. But intuitively, we are not used to negative volumes.
So, I fixed it, and it will go in the next release.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby cadmunkey » Sat Jul 01, 2017 1:15 pm
fredo6 wrote:@cadmunkey
Fredo
These are not holes in solids, if you want I can email you my model for analysis.
Its a marble stone cut list, and some of the stones are reporting back as negative volumes.
cadmunkey
Postby fredo6 » Sat Jul 01, 2017 8:09 pm
I mean that when you flip along a group or component instances, you actually transform their axes and mathematically, this gives a negative volume, as it does for holes in the solid.
Anyway, many thanks for signalling the problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Sat Jul 01, 2017 11:12 pm
I wish Curvishear could be become way more usable by
letting user 'in-vivo' move a vertex (and thus setting desired height and slope direction)
rv1974
Re: [Plugin] FredoTools - v3.1a - 09 Jul 17
Postby fredo6 » Sun Jul 09, 2017 11:51 pm
NEW RELEASE: FredoTools v3.1a - 09 Jul 17
Requirement: LibFredo6 v7.7a
FredoTools 3.1a introduces a new plugin, called DivideEdges. It also supports hi-resolution screens and fixes some bugs.
See FredoTools home page for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JClements » Tue Jul 11, 2017 9:38 pm
Divide Edges (DE) is a nice new addition to your toolset. Thank you!
Perhaps a version of DE could be adapted to produce dashed lines? When selected only an ODD number of segments would be available, then every-other-segment after the first segment would be deleted or hidden (not sure which would be the best to go). Maybe it could be "parametric" in the sense that the user could restore the original at later time and apply and different number of segments.
JClements
Premium Member
Premium Member
Re: [Plugin] FredoTools - v3.1b - 11 Jul 17
Postby fredo6 » Tue Jul 11, 2017 10:21 pm
NEW RELEASE: FredoTools v3.1b - 11 Jul 17
FredoTools 3.1b fixes a bug in FredoTools::SolidVolume, as signaled by Alex37550. See this post.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Sat Aug 12, 2017 8:33 pm
MoveAlong question:
How difficult would it be to implement
a Multiple objects move (rotate?) by their local axes?
rv1974
Postby fredo6 » Sat Aug 12, 2017 9:34 pm
rv1974 wrote:MoveAlong question:
Should be a dedicated tool.
MoveAlong is already complex, and I did not add the move along local axes (there are inferences however), as I did in Animator.
That's not a matter of programming ; Putting too many features in a plugin defeats the purpose, as then it is judged cluttered with options that nobody really uses.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.1c - 18 Aug 17
Postby fredo6 » Fri Aug 18, 2017 8:24 pm
NEW RELEASE: FredoTools v3.1c - 18 Aug 17
FredoTools 3.1c fixes problems with non-ascii usernames and provides verious bug fixing.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.1d - 28 Sep 17
Postby fredo6 » Thu Sep 28, 2017 10:03 pm
NEW RELEASE: FredoTools v3.1d - 28 Sep 17
FredoTools 3.1d fixes potential bugsplat in ThruPaint. Thanks to report if you have any.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby ecati » Sat Sep 30, 2017 11:15 am
For Msphysics, I used "Convexify" to divide the object shown in the figure into convex pieces, but I did not create the division process. What would be the reason?
ecati
Postby fredo6 » Sat Sep 30, 2017 12:28 pm
ecati wrote:For Msphysics, I used "Convexify" to divide the object shown in the figure into convex pieces, but I did not create the division process. What would be the reason?
I tried, and it's probably too much for the algorithm.
And on a portion of it, the convexification won't give you something 'nice as expected', because the the triangulation makes most individual edges concave, with relatively large angles.
I guess you have to find another way to generate the shape directly into small bits.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.1e - 01 Oct 17
Postby fredo6 » Sun Oct 01, 2017 10:33 pm
NEW RELEASE: FredoTools v3.1e - 01 Oct 17
FredoTools 3.1e fixes a major bug preventing the correct load under Mac OSX High Sierra. So you really need to upgrade if you have upgraded or plan to upgrade to High Sierra.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mariocha » Sat Oct 14, 2017 4:47 pm
Hi Mac users. A litlle survey.
Lately I'm having a small annoyance with this extension.
If I open the pane for the tools (see image) once in a session, then SU cannot quit normally. Beachball.
I removed all the other extension leaving only it and the Lib. Still bug.
Anyone else ?
update: Just did it with Curvizard.
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby Mousa_SA » Tue Oct 17, 2017 9:23 pm
fredo6 wrote:NEW RELEASE: FredoTools v3.1d - 28 Sep 17
Fredo
Hello Fredo,
Firstly, thanks for all of your plugins.
I get a bugsplat when I enable Thrupaint, please check the attachment to see the bug report.
Mousa_SA
Postby fredo6 » Wed Oct 18, 2017 8:11 am
Mousa_SA wrote:I get a bugsplat when I enable Thrupaint, please check the attachment to see the bug report.
Yes, there are cases of bugsplat, and for what whatever reason, they may occur systematically for some users. I did not find the reason and fix yet, but I am trying...
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Mousa_SA » Wed Oct 18, 2017 1:05 pm
fredo6 wrote:Yes, there are cases of bugsplat, and for what whatever reason, they may occur systematically for some users. I did not find the reason and fix yet, but I am trying...
Fredo
I have made some tests and found that this issue occur when Profile builder 2 and SubD is enabled, but I installed SketchUp 2017, Profile Builder 2 and SubD on another machine and Thrupaint worked fine!
Mousa_SA
Postby Oxer » Fri Nov 03, 2017 5:37 pm
Hi, I found a minor issue with Thrupaint on OS X 10.11.6 & SU2017, when you make click to enter in Visual edition, the gizmo and the options window disappear immediately but "right click ->Contextual menu->Enter in Visual edition" or "Enter" work fine, for this reason for me is a minor issue.
http://www.oxervision.blogspot.com/
Oxer
Postby fredo6 » Fri Nov 03, 2017 7:07 pm
I think the problem was already signaled, and it seems this happens only on MacOS.
Note that you can also type Enter to activate / deactivate the gizmo.
Difficult for me to troubleshoot as I don't have a Mac. I made a modif blindly, just in case this improves.
Fredo6_FredoTools - v3.1f - 03 Nov 17 - certified - encrypted.rbz
Could you check if you still have the problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Fri Nov 03, 2017 7:39 pm
I installed that version but the issue persists.
Fredo like I said to you before, for me it's a minor issue.
Oxer
PreviousNext
Return to Plugins
Users browsing this forum: bassmanemi, jejo303, simuuz and 4 guests
