[Plugin] FredoTools - v4.0a - 17 May 20
Re: [Plugin] FredoTools - v2.6a - 25 Feb 15
Postby Dave R » Thu Mar 05, 2015 11:46 am
hajasulthan wrote:hi how to fix the problem with thrupaint. its says more than 4 edges.
It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
Global Moderator
Postby massimo » Thu Mar 05, 2015 1:30 pm
Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
massimo
Re: [Plugin] FredoTools - v2.7a - 26 Apr 15
Postby fredo6 » Mon Apr 27, 2015 1:06 am
NEW RELEASE: FredoTools v2.7a - 26 Apr 15
FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Mon Apr 27, 2015 7:51 am
Thanks Fredo
Rich O Brien
Administrator
Re: [Plugin] FredoTools - v2.7c - 27 Apr 15
Postby fredo6 » Mon Apr 27, 2015 11:07 pm
NEW RELEASE: FredoTools v2.7c - 27 Apr 15
FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby srx » Tue Apr 28, 2015 7:07 am
Now it works perfect! :thumb:
www.saurus.rs
srx
Postby srx » Tue Apr 28, 2015 9:36 am
:? It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
www.saurus.rs
srx
Postby fredo6 » Tue Apr 28, 2015 12:49 pm
Thanks for signaling.
This is actually not related to small faces.
I will republsih soon with the fix
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v2.7d - 28 Apr 15
Postby fredo6 » Tue Apr 28, 2015 2:46 pm
NEW RELEASE: FredoTools v2.7d - 28 Apr 15
FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JClements » Tue Apr 28, 2015 8:38 pm
Should this appear in your update log?
JClements
Premium Member
Premium Member
Postby fredo6 » Tue Apr 28, 2015 9:09 pm
This should be OK now.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JClements » Tue Apr 28, 2015 9:16 pm
Looks to be operating properly now. Thank you.
JClements
Premium Member
Premium Member
Re: [Plugin] FredoTools - v2.7e - 29 Apr 15
Postby fredo6 » Wed Apr 29, 2015 9:23 pm
NEW RELEASE: FredoTools v2.7e - 29 Apr 15
FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby ptma2008 » Mon May 04, 2015 9:02 am
thank you
ptma2008
Postby arquimecho » Tue Jun 09, 2015 3:17 am
great plugin, complete and really functional
arquimecho
Re: [Plugin] FredoTools - v2.8a - 09 Jul 15
Postby fredo6 » Thu Jul 09, 2015 2:47 pm
NEW RELEASE: FredoTools v2.8a - 09 Jul 15
FredoTools 2.8a is a minor release for:
  • SolidVolume, which now accepts solids with holes
  • ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Thu Jul 16, 2015 3:32 pm
Warning:
Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
Sorry for inconvenience
Fred
fredo6
PluginStore Author
PluginStore Author
Postby pbacot » Thu Jul 16, 2015 3:40 pm
Thanks Fredo!
Top SketchUcator
Postby elvirem » Wed Sep 09, 2015 6:17 pm
Hello Fredo, je viens de passer sur skp 2015. J etais sur 2008 et tout allait bien et voici ce qui m'arrive malgré pas mal de tentatives.. ça fait 15 jours que c'est comme ça... et moi SKP sans libfredo, c'est comme si on me coupait un bras...tu saurais ce que je pourrais faire pour telecharger ton plugin et qu il fonctionne ? je suis sous mac yosemite ( non de Dieu que Mavericks me manque!!!)
Merci de tes lumières.... si tu en as !
Elvirem
Erreur de chargement du fichier Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in `match'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in `block (2 levels) in load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in `each'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in `block in load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in `foreach'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in `load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in `block in load_all_plugins'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in `each'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in `load_all_plugins'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:786:in `load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in `startup'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:338:in `<module:LibFredo6>'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
elvirem
Postby BIANI patrick » Sun Sep 13, 2015 10:04 am
Where downloading Move along ???????
BIANI patrick
Postby cotty » Sun Sep 13, 2015 10:38 am
BIANI patrick wrote:Where downloading Move along ???????
It's part of this collection and you can download it at the first post or with the Plugin store.
Make sure that you have installed LibFredo too.
cotty
Top SketchUcator
Postby JClements » Tue Nov 03, 2015 5:12 am
VOLUME Calculator.
I am getting a very large difference in calculated volumes between what SU displays in the Entity Info and what the volume calculator comes up with. I suspect it is due to a small sized object with many very small facets.
Can I send you the model to look it over?
Model created in SU2015, 64-bit. Windows 7.
JClements
Premium Member
Premium Member
Postby fredo6 » Tue Nov 03, 2015 12:19 pm
Yes. Please send the model.
By the way, do you already know which result is the correct one?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JClements » Tue Nov 03, 2015 1:18 pm
Please see your messages. Thanks.
JClements
Premium Member
Premium Member
Re: [Plugin] FredoTools - v2.9a - 13 Nov 15
Postby Elster32 » Mon Aug 15, 2016 5:36 pm
Is it possible to increase the size of the dialog box? On my screen it is so small it is almost impossible to see the buttons! I wondered whether there was an option but because of the small size I was unable to see it? Thank you
Elster32
Re: [Plugin] FredoTools - v3.0a - 20 Oct 16
Postby fredo6 » Thu Oct 20, 2016 9:05 pm
NEW RELEASE: FredoTools v3.0a - 20 Oct 16
FredoTools 3.0a is a release mainly related to FredoTools::ThruPaint with the introduction of a Purge feature.
Fredo
-1
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.0b - 31 Oct 16
Postby fredo6 » Mon Oct 31, 2016 10:21 pm
NEW RELEASE: FredoTools v3.0b - 31 Oct 16
FredoTools 3.0b fixes a major bug bug preventing FredoTools to load properly for SU versions < 2014. So, if you run SU6, SU7, SU8 or SU2013, please upgrade to v3.0b.
Fredo
-1
fredo6
PluginStore Author
PluginStore Author
Postby SpookyChick1013 » Sun Dec 18, 2016 10:10 pm
Hi Fredo,
Thanks for continuing to update your tools.
I'm having an issue with ThruPaint where I invoke the tool and it promptly does nothing. Nothing shows in the error console, it just refuses to come up.
EDIT:]Woops! Mybad. There is something in the Ruby console.
(eval):1: warning: already initialized constant T7
Hope this helps.
It was working fine for me prior to me updating things over the last two days. I'm using the latest downloads of FredoTools, and FredoLib, right out of the SU Plugin store.
I have double-checked the plugin footprint, and it looks like it should look.
Still on SU7.1.6860, Win7Prox64
Second update.
I have no idea why this worked but I unchecked Fredo Tools in the extensions, restarted and now Thrupaint is working just fine, as is everything else. The weird thing is, I did not re-enable The Fredo6 Fredo Tools extension, yet things are working fine. :shock: :?
Update weirdness makes my head hurt, :lol:
I guess there's nothing to worry about after all.
Thanks in advance,
Cathryn
https://kuromatsudriveyards.com
Fo-su to tomo ni aran koto o...
SpookyChick1013
Postby bharralure » Mon Feb 13, 2017 4:41 pm
Bonjour Fredo
Puisque c'est ma journée "réclamations", après LibFredo6, je reviens avec FredoTools.
Depuis un certain temps, je ne me souviens plus trop quand d'ailleurs (peut-être depuis ma migration vers Windows 10, il y a seulement quelques mois), la fenêtre qui s'affiche à l'écran après avoir lancé l'outil "Étiqueter les Surfaces" se trouve réduite en hauteur tel que montré sur la capture d'écran qui suit.
Ce n'est pas un gros problème, mais dans sa taille d'origine, je suis pas obligé de jouer de l'ascenseur.
bharralure
Postby fredo6 » Mon Feb 13, 2017 5:12 pm
This is due to SU2017, which is messing up dimensions in web dialogs.
Can you tell me if you can resize the dialog box?
Fred
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: imran rabbi, Kartz_11, quannguyen10893hp and 7 guests
