[Plugin] FredoTools - v4.0a - 17 May 20
Re: [Plugin] FredoTools - v2.2a - 19 Oct 14
Postby fredo6 » Mon Oct 20, 2014 7:16 am
guanjin,
Can you open the Ruby console and see if there are errors displayed.
Do you get this problem with the English version or the Chinese version
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby guanjin » Mon Oct 20, 2014 10:28 am
fredo6 wrote:guanjin,
Fredo
Without prompting any errors.
There are Chinese characters display dislocation, English normal
This problem has continued for several versions of this
Earlier versions without problems
Thank you fredo6
guanjin
I come from China, is to learn
guanjin
Postby fredo6 » Mon Oct 20, 2014 11:46 am
@guanjin
I can have a look.
But could you send me the FredoTools_ZH.lang file that you use. Currently, I don't have one updated for EdgeInspector.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Oct 20, 2014 2:03 pm
@guanjin,
If you wish to make a test, could you replace the following attached files in the Fredo6_!LibFredo6 subfolder
body_Lib6G6.rb
body_Lib6Palette.rb
This should normally take into account the natural width of Chinese characters
Thanks for your feedback
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thevzitor » Wed Oct 22, 2014 1:18 am
Hello to all,
I don't know where to post this problem but as it is related to downloading FredoTools, I post it here.
It's probably a SketchUcation script problem, I cannot download the extension. Same problem with others extensions.
Clicking the download link gives me a blank window and nothing happens. (screenshot enclosed)
Is there any other place where to download it?
Otherwise I installed LibFredo through the Extension warehouse in SU, restarted SU and still got the same old library... A bit annoying.
Otherwise a big thank to Fredo for his extensions !
All the best
thevzitor
Premium Member
Premium Member
Postby TIG » Wed Oct 22, 2014 10:39 am
That 'Download' is just an image to show the relevant text below it, that's why it opens as an image.
It is NOT a link.
Most Plugins are available from the SketchUcation PluginStore.
The FredoTools is here: http://sketchucation.com/pluginstore?pln=FredoTools
Clicking that red 'Download' button gets you the RBZ archive.
You can then use the Preferences > Extensions > Install... button to auto-install it into your Plugins folder.
If you get/install the SketchUcation Toolset currently v2.6.1 [install it from its RBZ, downloadable from the Resources menu http://sketchucation.com/resources/plug ... e-download ] you'll then get a PLugins > SketchUcation submenu and SketchUcation toolbar, all within SketchUp itself.
This toolset has many useful items - the relevant one in this case is the PluginStore dialog.
Its dialog interface is similar to the SketchUcation PluginStore, but in this case the 'Download' button is replaced with a red 'AutoInstall' button.
So simply find the required Plugins and click its AutoInstall button.
It is automatically downloaded and installed for you in one step.
There are other tabbed options to Update and make Bundles to use across SUp-versions or different computers etc... Save those till you get proficient in AutoInstalling... ;)
Why make life more complex than it needs to be ?
Global Moderator
Re: [Plugin] FredoTools - v2.4a - 17 Nov 14
Postby fredo6 » Mon Nov 17, 2014 4:55 pm
NEW RELEASE: FredoTools v2.4a - 17 Nov 14
FredoTools 2.4a is a release for AngleInspector v1.0, which is a small tool to measure angles anywhere in the model in one click.
Note: it requires to install LibFredo6 v6.4a
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby micione » Mon Nov 17, 2014 5:57 pm
Fredo,
The tool does not seem to appear.
Windows 7 - SU2015
micione
Postby TIG » Mon Nov 17, 2014 8:18 pm
micione wrote:Fredo,
Windows 7 - SU2015
Did you also install the updated LIB and then restart SketchUp ?
Global Moderator
Postby micione » Mon Nov 17, 2014 9:08 pm
Tig,
yes I installed the new library, restarted Sketchup,
but the tool does not appear.
This happens in SU2014 and SU2105.
micione
Postby fredo6 » Mon Nov 17, 2014 9:13 pm
@micione,
Could you open the Trace Log file (in Windows > LibFredo6 Settings...) and check if FredoTools was loaded (or export as txt and send it to me).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby micione » Mon Nov 17, 2014 9:57 pm
Ok Fredo,
mail sent .
micione
Postby fantoosh420 » Tue Nov 18, 2014 9:44 am
I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
Sketchup 14.0.4900
Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
fantoosh420
Postby micione » Tue Nov 18, 2014 6:28 pm
Problem solved.
(today re-downloaded and installed).
Works wonders.
thanks
micione
Postby Oxer » Thu Nov 20, 2014 11:42 am
New Spanish Language file v2.4a
FredoTools_ES.lang.zip
http://www.oxervision.blogspot.com/
Oxer
Postby fredo6 » Thu Nov 20, 2014 11:48 am
Oxer,
Thanks very much. This will go in next update
Fredo
fredo6
PluginStore Author
PluginStore Author
fredotools or libfredo visibility issue
Postby mcjoiner » Thu Nov 20, 2014 7:28 pm
Unsure if the following issue is me (likely), or related to FredoTools or LibFredo.
When using actively using thrupaint the tool works great. As soon as I double-click out, the changes are not visible. If I re-activate the tool, the previous changes are visible again.
I'm currently using sketchup pro 8.
Suggestions?
mcjoiner
Postby fredo6 » Fri Nov 21, 2014 10:35 am
It is probably related to the style for displaying Edges.
To see the colors you need to set up the style by material in your model
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v2.5a - 10 Jan 15
Postby fredo6 » Sat Jan 10, 2015 2:26 pm
NEW RELEASE: FredoTools v2.5a - 10 Jan 15
FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
Note: it requires to install LibFredo6 v6.6a
Fredo
3
fredo6
PluginStore Author
PluginStore Author
Postby cotty » Sat Jan 10, 2015 2:46 pm
Thank you for another great addition to your toolbox!
cotty
Top SketchUcator
Postby JClements » Sat Jan 10, 2015 7:10 pm
Another home run.
Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
JClements
Premium Member
Premium Member
Postby Oxer » Sat Jan 10, 2015 7:41 pm
Thanks for this new update!! :thumb:
Spanish Language Fredo Tools v2.5a
Oxer
Re: [Plugin] FredoTools - v2.5b - 18 Jan 15
Postby fredo6 » Sun Jan 18, 2015 10:42 pm
NEW RELEASE: FredoTools v2.5b - 18 Jan 15
FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v2.5c - 19 Jan 15
Postby fredo6 » Mon Jan 19, 2015 11:29 am
NEW RELEASE: FredoTools v2.5c - 19 Jan 15
FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby schnydix » Thu Jan 22, 2015 3:22 pm
Hello Fredo Thank you for the great work
All Other Translations following soon.
Roland F. Swiss
Translatet by Hand very carefully
Please Do not put my name into the plugins There is only space for the Author (Your name)
Save any Space for drawing.
FredoTools 2.5a
schnydix
Postby KrisM » Thu Jan 29, 2015 6:13 pm
Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
KrisM
KrisM
Premium Member
Premium Member
Postby massimo » Thu Jan 29, 2015 7:07 pm
If you mean painting both front and back faces at once then
massimo
Postby KrisM » Thu Jan 29, 2015 7:32 pm
Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
KrisM
KrisM
Premium Member
Premium Member
Re: [Plugin] FredoTools - v2.6a - 25 Feb 15
Postby fredo6 » Wed Feb 25, 2015 11:11 pm
NEW RELEASE: FredoTools v2.6a - 25 Feb 15
FredoTools 2.6a is a release for
Note: it requires to install LibFredo6 v6.7a
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby hajasulthan » Thu Mar 05, 2015 8:31 am
hi how to fix the problem with thrupaint. its says more than 4 edges.
hajasulthan
PreviousNext
Return to Plugins
Users browsing this forum: cboy1980, guer2900, IRVANALAZIZ, Jim and Frida, naseer8, timoxy and 22 guests
