[Plugin] FredoTools - v4.0b - 06 Dec 20Re: [Plugin] FredoTools - v1.7a - 15 Feb 14thansk fredo that you looked into it!
i hope that this can be solved somewhere in the future... for now the su native paint tool does just fine... what i find interesting however that with thruhpaint if you hold the mouse button down the texture shows right and flips just after the release of the mouse button?! maybe thats a hint ?! anyways thanks again!
Re: [Plugin] FredoTools - v1.8a - 17 Apr 14NEW RELEASE: FredoTools v1.8c - 17 Apr 14
FredoTools 1.8c is a release for MoveAlong v1.0. See main post of this thread for Download. Fredo
Re: [Plugin] FredoTools - v1.8c - 17 Apr 14You soooo rock...
Re: [Plugin] FredoTools - v1.8d - 20 Apr 14NEW RELEASE: FredoTools v1.8e - 20 Apr 14
FredoTools 1.8d is a release fixing a problem in MoveAlong v1.0. The issue was about moving a selection containing a huge number of entities, as signaled by rv1974. See main post of this thread for Download. Fredo
Re: [Plugin] FredoTools - v1.8e - 20 Apr 14Thanks for the new version and new tool Move Along
![]() I have made a new Spanish Language (Spain) file to include the new tool. Re: [Plugin] FredoTools - v1.8e - 20 Apr 14Oxer,
Thanks. I will integrate in the next release. Also, for info, all the tooltips for inferences in MoveAlong are actually defined in LibFredo6, not in FredoTools. This is why they won't appear in Spanish. Fredo
Re: [Plugin] FredoTools - v1.8e - 20 Apr 14Thanks for the info Fredo. I have made the new Spanish Language (Spain) file to LibFredo6, do you want that i upload it here or in LibFredo6 topic?
Re: [Plugin] FredoTools - v1.9a - 15 May 14NEW RELEASE: FredoTools v1.9a - 15 May 14
FredoTools 1.9a is a release for - DrawAlong 1.0, - MoveAlong 1.1, See main post of this thread for Download of FredoTools. Fredo
Re: [Plugin] FredoTools - v1.9a - 15 May 14New Spanish Language File for FredoTools - v1.9a - 15 May 14
P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP Re: [Plugin] FredoTools - v1.9a - 15 May 14Oxer,
Thanks very much. This will go in the next update. Fredo
Re: [Plugin] FredoTools - v1.9b - 17 May 14NEW RELEASE: FredoTools v1.9b - 17 May 14
FredoTools 1.9b is a release for - DrawAlong 1.0b, - MoveAlong 1.1b, It includes: - a fix for VCB inputs in architectural units in DrawAlong and MoveAlong - an updated translation in Spanish-Spain (ES) by Oxer See main post of this thread for Download of FredoTools. Fredo
Re: [Plugin] FredoTools - v2.0a - 18 Jun 14NEW RELEASE: FredoTools v2.0a - 18 Jun 14
FredoTools 2.0a is a release for MoveAlong v1.2, DrawAlong v1.1. See main post of this thread for Download. Fredo
Re: [Plugin] FredoTools - v2.0b - 07 Jul 14NEW RELEASE: FredoTools v2.0b - 07 Jul 14
FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin) See main post of this thread for Download. Fredo
Re: [Plugin] FredoTools - v2.0b - 07 Jul 14Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
I come from China, is to learn
What do you mean exactly? Fredo
Re: [Plugin] FredoTools - v2.0b - 07 Jul 14I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
Error Loading File Fredo6_!LibFredo6.rb Error: #<ArgumentError: invalid byte sequence in UTF-8> C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in `match' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in `block (2 levels) in load_from_config' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in `each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in `block in load_from_config' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in `foreach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in `load_from_config' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in `block in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in `each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in `load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in `load_from_config' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:in `startup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in `<module:LibFredo6>' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>' Re: [Plugin] FredoTools - v2.0b - 07 Jul 14Have you updated the actual LibFredo version?
Looks like something in the 'set' is NOT updated to me ![]() TIG
Re: [Plugin] FredoTools - v2.0b - 07 Jul 14I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8. Fredo
Re: [Plugin] FredoTools - v2.0b - 07 Jul 14I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
Fredo6 Tools icon tollbarGreetings,
I am not able to mange to get the illustrated Fredo6 Tools icon toolbar appeared as shown on this page. When I call a Fredo6 Tools toolbar I have got only the first icon in the toolbar, ie lancher one. Any helpful suggestion will be deeply appreciated.
Re: Fredo6 Tools icon tollbar
Go to the Default Parameters dialog (or click on yellow wrench) and enable the icons you wish. You can also read the main post. Fredo
Re: [Plugin] FredoTools - v2.1a - 12 Oct 14NEW RELEASE: FredoTools v2.1a - 12 Oct 14
FredoTools 2.1a is a release for: EdgeInspector v1.2: more accurate and relevant detection of fixing for Tiny Edges, Lost Junctions and Tiny Gaps DrawAlong 1.2 v1.2: fixes for inferences on construction points and drawing construction points (avoid doubling) See main post of this thread for Download. Fredo
Show incomplete, occasionally show I come from China, is to learn
Re: [Plugin] FredoTools - v2.2a - 19 Oct 14NEW RELEASE: FredoTools v2.2a - 19 Oct 14
FredoTools 2.2a is required for the support of usernames with non-ascii characters in Sketchup 2014 See main post of this thread for Download. Fredo
When I first opened sketchup, click Edge Inspector icon, a pop-up dialog box blank and click on the other icon again, and then click will display correctly。 I come from China, is to learn
