by fredo6 » Fri Nov 01, 2013 9:27 am
parsleybrain wrote:Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
There is no 'uninstallation' of my plugins (as these are just files in folders). So You can safely install the new versions 1) I would suggest that you first install the SCF Plugin Store plugin, if not already done. This is the safest and easiest way to install plugins. 2) Install LibFredo6 first, then the other plugins 3) Once you have installed, you can go to Windows > LibFredo6 Settings... > Purge Obsolete files and delete the files and folders related to the previous versions Purge Obsolete Files.png Fredo
fredo6
- PluginStore Author
- Name: Fredo6
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: interior design
by parsleybrain » Fri Nov 01, 2013 10:42 am
Thank you very much, I got it. Also thanks for all your great tools and plugins. I just start to learn and appreciate your tools since I'm beginner but nevertheless I can see the greatness.
parsleybrain
- Name: Denise Goldau
- SketchUp version: 2013
- License type: Free/Make
- SketchUp use: architecture
- Level of SketchUp: Beginner
by Aris » Tue Nov 05, 2013 5:15 pm
stair.jpg Hello everybody! I'm trying to make a bent stair, so I created the stair's "profile" and intended to bend it using radial bending and then joint push pull in order to give it width. in order to do that, I made the steps as simple as possible and turned slicing off (so that the shape would be bent only at the vertical edges. unfortunatelly, bending screwed up the normals and when I tried to use the JPP faces were extruded weirdly. Is there something I can do about it? I know that a solution would be to extrude first and bend later, but because of reasons of repetition and workflow It would serve me better to do it this way
Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
Aris
- Premium Member
- Name: Aris
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by Nph92 » Wed Nov 13, 2013 6:11 am
When i install this plugin it tells me, you need the version 5.2 libfredo and so on, and i have that, or even a later one, so after ive installed it nothing happens? the same thing happened to fredoScale but for some reason that got installed, and im using it without a problem? any quick solution ?
Nph92
- Name: Nikola
- SketchUp use: hobby
by TIG » Thu Nov 14, 2013 2:30 pm
Instead of using soften/smooth on the vertical almost-coplanar edges try making them just 'hidden' ??
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by fredo6 » Wed Nov 27, 2013 9:42 pm
NEW RELEASE: FredoTools v1.5a - 27 Nov 13FredoTools 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes. See main post of this thread for Download. Fredo
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Fri Jan 24, 2014 11:04 am
NEW RELEASE: FredoTools v1.6g - 24 Jan 14FredoTools 1.6g is a release for EdgeInspector v1.0. See main post of this thread for Download. Fredo
fredo6
- Name: Fredo6
- License type: Pro
by Ben Ritter » Fri Jan 24, 2014 3:30 pm
Fredo, thank you, again. You are generous, and talented.
Ben Ritter
- Name: Ben Ritter
- SketchUp version: 8
- License type: Pro
by Oxer » Fri Jan 24, 2014 4:48 pm
Thanks Fredo for this new useful tool !! I have updated the Spanish Language (Spain) to include EdgeInspector. FredoTools_SP.lang.zip
Oxer
- Name: Oscar
- Operating system: Mac
- SketchUp version: 2017
- SketchUp use: illustration, cartoons
by fredo6 » Fri Jan 24, 2014 4:59 pm
Oxer,
Thanks for that. This is a piece of work. Will go into the next release, so very soon.
Fredo
fredo6
- Name: Fredo6
- License type: Pro
by Orthogon » Sat Jan 25, 2014 7:28 pm
I now get this error: FredoTools 1.6g: Error starting up plugin (creating menus and icons) undefined method 'values' for nil:NilClass [in FredoTools.rb - #'startup(): line 210] ...Lib6Core.rb:580in 'effective_load_part2'
Then an error message with a Trace Log... Am using LibFredo v5.5g.
Orthogon
- Name: Steve Ins
- Operating system: Linux
- SketchUp use: engineering and mechanical design
by fredo6 » Sat Feb 15, 2014 1:04 am
NEW RELEASE: FredoTools v1.7a - 15 Feb 14FredoTools 1.7a is a release for EdgeInspector 1.1a, which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes. See main post of this thread for Download of FredoTools. Fredo
fredo6
- Name: Fredo6
- License type: Pro
by cotty » Sat Feb 15, 2014 9:43 am
Thank you for this great update!
cotty
- Top SketchUcator
- Name: Carsten
- SketchUp version: 2020
- License type: Pro
by dedmin » Sun Feb 16, 2014 1:11 pm
Su 2013 Pro, Win 7 64 bit
dedmin
by rv1974 » Sun Feb 16, 2014 2:18 pm
dedmin, how do you grab into .wmv?
rv1974
- Name: rv1974
- License type: Pro
by fredo6 » Sun Feb 16, 2014 5:23 pm
@dedmin Thanks for signaling. This is actually a bug concerning Curvizard, not FredoTools. I fixed it and republished as Curvizard 1.7b. Fredo
fredo6
- Name: Fredo6
- License type: Pro
by guanjin » Mon Mar 03, 2014 6:08 am
fredo6 wrote:@dedmin Thanks for signaling. This is actually a bug concerning Curvizard, not FredoTools. I fixed it and republished as Curvizard 1.7b. Fredo
111111111111111111111111111111111.gif The latest version, the pop-up dialog box displays a blank。 Be sure to activate the other tools, and then activate it to appear. Earlier versions without problems
I come from China, is to learn
guanjin
- Name: XIAOLONG
by fredo6 » Mon Mar 03, 2014 7:48 am
guanjin,
This may be related to the Chinese translation. Do you get the error if you switch to English? Also, could you check if there is no error displayed in the Ruby console
Fredo
fredo6
- Name: Fredo6
- License type: Pro
by guanjin » Mon Mar 03, 2014 9:56 am
fredo6 wrote:guanjin,
Fredo
Also, like switching to English,The same problem。 After activation texture tool display properly activated, see the movie. wenti9999999999999999999999999999.gif
guanjin
- Name: XIAOLONG
by Fcharly24h » Sat Mar 08, 2014 11:41 am
On SU 2014 Make the tool bar don't ok for: Fredo tools curvizard
Thanks.
Fcharly24h Mon site: Fcharly24h.perso.sfr.fr
Fcharly24h
- Name: Fcharly24H
- SketchUp version: 2016
by cotty » Sat Mar 08, 2014 11:48 am
Fcharly24H wrote:On SU 2014 Make the tool bar don't ok for: Fredo tools curvizard
Thanks.
Why not?
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by babak » Sat Mar 08, 2014 2:58 pm
cotty wrote:Fcharly24H wrote:On SU 2014 Make the tool bar don't ok for: Fredo tools curvizard
Thanks.
Why not?
I think what Fcharly24H means is that the tool palette doesn't appear everytime you click on Fredo's toolbars icons with sketchup 2014. For me it happens very often with thrupaint. When I click on the icon, it only triggers sketchup native paint bucket and if I zoom in and out while clicking on and off the tool palette might appears but not necessary. I haven't noticed any problem with other tools though. Thank you Fredo06 for your plugins !
babak
- Name: babak
- License type: Pro
by Fcharly24h » Sat Mar 08, 2014 4:32 pm
I don't know! I no problem in verification update, no problem with other plugin of Fredo6 in C:\Users\Fcharly24h\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins I have: test20130308-01-01.jpg test20130308-01-02.jpg in SU make 2014 no icon bar for: Fredo tools curvizard in SU make 2013 ok test20130308-01-03.jpg
Fcharly24h
- Name: Fcharly24H
by dedmin » Wed Mar 26, 2014 12:35 pm
Object disappears when hitting Esc two times while using ThruPaint SU 2014 Pro, Win 7 64bit SP1 Ultimate Video_2014-03-26_132637.wmv
dedmin
by fredo6 » Wed Mar 26, 2014 1:17 pm
dedmin wrote:Object disappears when hitting Esc two times while using ThruPaint SU 2014 Pro, Win 7 64bit SP1 Ultimate Video_2014-03-26_132637.wmv
Escape performs an Undo. So this may be related to making sure it does not go to far back in the Undo stack. I'll check this problem. Fredo
fredo6
- Name: Fredo6
- License type: Pro
by dedmin » Wed Mar 26, 2014 2:20 pm
See the video. Video_2014-03-26_151418.wmv
dedmin
by fredo6 » Wed Mar 26, 2014 10:14 pm
That's a consequence of enabling 'Auto-Exit' when there is a pre-selection (which is not the default).
Maybe I will use this fast-mode only for Make Curve and Explode Curve, and ignore it for other Tools.
Fredo
fredo6
- Name: Fredo6
- License type: Pro
by tetrochuan » Fri Apr 04, 2014 8:26 am
thrupaint problems :/
hi there,
i have for a few times now encountered problems with thrupaint and some of my models..
i have attached a simple box which was part of a greater model. the attached geometry was grouped, part of a geometry and most probably often exploded, scaled rotaed and mirrored and so on... but i have copied it out of the old project.
still the problem persists... thrupaint in natural mode cant accomplish to paint the orthogonal shape orthogonally as is does with a newly created shape - and i cant fix my geometry?! or dont now how because i dont now whats wrong with it!
i would love if fredo could take a look at this. maybe there is a simple solution!
thanks in advance
ai- one thing i forgot to mention - when holding the mouse button down while painting one gets somekind of preview where the texture sits properly, but on releasing it flips?!
tetrochuan
by fredo6 » Sun Apr 06, 2014 10:34 am
There must be a bug somewhere, but in general, painting boxes correctly in continuity on all its faces is very tricky.
Trying with your model, I noticed the flipping and I'll have a look at it.
What I suggest is that you just paint the last face directly, instead of extending it from adjacent faces.
Fredo
fredo6
- Name: Fredo6
- License type: Pro
- Robot
Return to Plugins
