by yad2000 » Thu Apr 26, 2012 10:18 am
guanjin wrote:yad2000 wrote:irwanwr wrote:if the plugin will be available in English version and shared here too. if it is true.
this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
未命名.jpg Finally downloaded, loaded error
in the file that you changed - Error! you must: "沿线 管道 目录 列表, replaced by "沿线 管道 目录 列表", should work
yad2000
- Name: Denis
- Operating system: Windows
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: engineering and mechanical design
by guanjin » Thu Apr 26, 2012 1:33 pm
I come from China, is to learn
guanjin
- Name: XIAOLONG
- SketchUp use: interior design
by yad2000 » Thu Apr 26, 2012 5:17 pm
Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
yad2000
- Name: Denis
by guanjin » Thu Apr 26, 2012 7:25 pm
yad2000 wrote:Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
I do not know that you mean ,the file is a common indoor plumbing components
guanjin
- Name: XIAOLONG
by yad2000 » Fri Apr 27, 2012 5:20 am
I also do not understand what you want)))
yad2000
- Name: Denis
by yad2000 » Fri Apr 27, 2012 6:20 am
I will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
yad2000
- Name: Denis
by yad2000 » Mon May 21, 2012 8:37 am
who knows how to use the database MongoDB in Ruby for SketchUP here...
yad2000
- Name: Denis
by yad2000 » Mon May 21, 2012 10:17 am
Time is now developing a new interface for plug-in. Here is a screenshot I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database. Who share the standards DIN / EN / ISO / API / ASTM / ASME?
yad2000
- Name: Denis
by yad2000 » Mon Oct 01, 2012 1:38 pm
Who shares the standards DIN / EN / ISO / API / ASTM / ASME? For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options.
Google Translator gives terrible translations)))
In Russia, the translation is: "Your - my not understand"))))
yad2000
- Name: Denis
by ken » Fri Feb 01, 2013 1:56 am
Hello
I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown.
So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work.
So thanks in advance for your help.
Ken
ken
- Premium Member
- Name: Ken
- SketchUp version: 2021
- License type: Pro
- Level of SketchUp: Advanced
by driven » Fri Feb 01, 2013 2:05 am
Ken wrote:Hello
Ken
Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error.... I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so john
driven
- PluginStore Author
- Name: driven
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
by Frederik » Fri Feb 01, 2013 11:49 am
Looks like a very interesting plugin... Unfortunately I seem to share the same issue as Ken... I've never had any issue installing a plugin - before now... I even tried to copy the iconv.so to the plugins folder, but to no avail...
Cheers Kim Frederik
Frederik
- Thea Render Support
- Name: Kim Frederik
- License type: Pro
by Frederik » Fri Feb 01, 2013 12:14 pm
OK... Tried to see if I could see something in the coolpipe_Start.rb (yep - it's dangerous when having a very limited knowledge when it comes to coding... )The original code looked like this: - Code: Select all
#encoding: utf-8 ################################################################################################## ################################################################################################## # Cool Pipe Engine 2011-2012 # Cool Pipe Engine 2011-2012 to the SketchUp interface # version 1.2 # Software Author: Borisov Denis Vladimirovich (yad2000@rambler.ru) # Design: Borisov Denis Vladimirovich (yad2000@rambler.ru) # ©2012 by Borisov Denis Vladimirovich (yad2000@rambler.ru) #История версий #-v1.2.1 #-Мультиязычность проекта (русский,английский,французский,итальянский,испанский,немецкий), возможность выбора языка в процессе работы с плагином #-Расчет массы отвода (стального), расчитыватеся по геометрическим параметрам (может не соответствовать с заводским изделиям) #-Структура кода измененена: отсутствует изменение стандартных классов, весь код объединен в классы и модули #-внесено исправление по загрузке iconv.so: на MAC не загружать, только на Windows #-редактирование элементов вынесено за пределы Observer при выделении на отдельную командную кнопку #-исправлен принцип сортировки элементов спецификации на стандартный .sort (для избежания утечки памяти в процессе подсчета и зависаний SketchUP)
#-v1.2 #-Изменение структуры работы с базой данных элементов #-Рисование и редактирование трубопроводов #-Рисование и редактирование отводов #-Рисование и редактирование переходов #-Рисование и редактирование тройников #-Рисование заглушек #-Рисование фланцев #-Создание спецификации #-Функция копирования свойств (слой+материал) для объектов CoolPipe и групп #v1.1 #-Следующие публикации по адресу: http://coolpipe.ru/load #-Кардинально изменен дизайн диалога с пользователем #-Дополнена база ГОСТов трубопроводов #-Рисование трубопроводов мышью #-Накладывание слоев, собственный редактор "быстрых" слоев #-Накладывание материалов (боевая раскраска трубопроводов) #-Накладывание теплоизоляции + редактор стандартных толщин изоляции #-Функция "Прилепить отвод" #-Функции редактирования трубопроводов (задание уклона или отметок трубопровода) #-Функции редактирования отводов при выделении самих отводов мышью (экранное меню) #-Функция "Составление спецификации" #--разработка прервана #v1.0 #Пробный плагин (в виде тулбара) рисующий трубы, отводы, переходы, тройники, заглушки, фланцы по известным ГОСТам #Первая публикация по адресу: http://forum.abok.ru/index.php?&showtopic=30806&st=160 ################################################################################################## ################################################################################################## require 'sketchup.rb' require 'CoolPipe/cp_Lang.rb' require 'CoolPipe/Service_proc.rb' require 'CoolPipe/PipeTool.rb' require 'CoolPipe/ElbowTool.rb' require 'CoolPipe/ReducerTool.rb' require 'CoolPipe/TeeTool.rb' require 'CoolPipe/CapTool.rb' require 'CoolPipe/FlangeTool.rb' require 'CoolPipe/cpCSVBase.rb' require 'CoolPipe/CopyOptionsTool.rb'
pform = (Object::RUBY_PLATFORM =~ /mswin/i) ? :windows : ((Object::RUBY_PLATFORM =~ /darwin/i) ? :mac : :other) platform = pform.to_s if platform == "windows" require 'CoolPipe/iconv.so' # применяем iconv elsif platform == "mac" # не применяем end CoolPipe_number_version = "1.2.1" # Текущая версия плагина ################################################################################################## coolpipe_plugin = CoolPipePluginApp.new coolpipe_plugin.run
So I deleted the two spaces in line 62 in front of "require" - Code: Select all
Now I get this Load Error message:
Cheers Kim Frederik
Frederik
- License type: Pro
by yorik1984 » Fri Mar 01, 2013 3:56 pm
Copy iconv.co to C:\Windows\system32
yorik1984
- Name: Yurij
- License type: Pro
- SketchUp use: architecture
by Dan Rathbun » Sat Mar 02, 2013 12:06 am
yorik1984 wrote:Copy iconv.so to C:\Windows\system32 NO.. DO NOT !It does not belong in the OS system directory !
I'm not here much anymore. But a PM will fire email notifications.
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
- SketchUp use: education
by yorik1984 » Sat Mar 02, 2013 3:46 pm
- Code: Select all
if platform == "windows" require 'CoolPipe/iconv.so' # применяем iconv elsif platform == "mac" # не применяем end Frederik has WINDOWS!
yorik1984
- Name: Yurij
- License type: Pro
by driven » Sat Mar 02, 2013 5:42 pm
yorik1984 wrote:Frederik has WINDOWS!
and Dan is saying "DON'T" move the file into the C:\Windows\system32 system path, it won't be found and doesn't belong there... @ Fredrick if you suspect the require is not working test it in 'Ruby Console'. e.g. - Code: Select all
should return windowsthen try - Code: Select all
should return trueif it does it's not the problem, if it doesn't, check permissions on that file... 'CoolPipe/iconv.so' in that Directory, don't move it... john
driven
- Name: driven
- License type: Pro
by Frederik » Sun Mar 03, 2013 7:48 pm
Thanks for the heads up... Much appreciated... I don't dare to copy any files into the C:\Windows\System32 folder... It seem strange that I would need to copy a file to a OS system folder...  From the videos this plugin looks very interesting... I'm working as Project Manager and my job is to make 2D and 3D drawings, mechanical design, building design, surface calculation, volume calculation, walk through in buildings, equipment layout in control/engineering rooms, piping design, piping and equipment support design, of the cooling systems we're going to be working on... On a daily basis I'm using the 3skeng plugin, which suits my needs well... Since this is also related to the piping industry I wanted to check it out, but as long as I can't get it to work, I will stick to the 3skeng plugin...
Cheers Kim Frederik
Frederik
- License type: Pro
by Frederik » Sun Mar 03, 2013 7:55 pm
driven wrote:@ Fredrick if you suspect the require is not working test it in 'Ruby Console'. e.g. - Code: Select all
It sure does... driven wrote:then try - Code: Select all
A bit strange... It seem to only allow me to write - Code: Select all
I don't seem to be able to insert the remaining text...
Cheers Kim Frederik
Frederik
- License type: Pro
by driven » Sun Mar 03, 2013 8:02 pm
Frederik wrote:I don't seem to be able to insert the remaining text... :?
I think that's the windows single line 'Ruby Console' thing... mac is multiline, and mines actually full page as well, sorry.. just use the require and see if it returns true - Code: Select all
might need the rest of path if nothing else has loaded.. john
driven
- Name: driven
- License type: Pro
by driven » Sun Mar 03, 2013 8:06 pm
I think single line looks like this - Code: Select all
if platform == "windows"; require 'CoolPipe/iconv.so'; elsif platform == "mac"; end
but I never need it so... john
driven
- Name: driven
- License type: Pro
by Frederik » Sun Mar 03, 2013 8:12 pm
Cheers, John...! I believe I will just leave it as is for the time being... Like I wrote I don't like to copy anything to any system folder, so until they come up with an alternative plugin, I will stick to 3skeng...
Cheers Kim Frederik
Frederik
- License type: Pro
by ken » Sun Mar 03, 2013 11:59 pm
I have tried each and every suggestion trying to get this plugin to work. The error is the same, can not find iconv.so.
Is there anyone that has this plugin working on a Windows machine?
And if you do have it working on a Windows machine, what size is your iconv.so. My iconv.so file is 24661 Date 2008-08-12-14:18.
I can't believe it is so hard to get this plugin to work.
Anyway thanks in advance. I am surprised the author doesn't offer any help.
Ken
ken
- Premium Member
- Name: Ken
- License type: Pro
by driven » Mon Mar 04, 2013 2:06 am
@Ken & @Fredrick, I had a look on the russian forum the authors reply to your issue is Has already been written about it many times. Find the folder with the plugin file iconv.dll and throw it in the folder C: \ Windows \ System32 without this dll can not run so .... and no magic
I don't know windows at all, but he is saying to move the iconv.dll not the iconv.so as suggested in this thread. I don't know if adding .dll is wise, maybe dan will comment... john
driven
- Name: driven
- License type: Pro
by Dan Rathbun » Mon Mar 04, 2013 2:14 am
Ken wrote:Is there anyone that has this plugin working on a Windows machine? ... I can't believe it is so hard to get this plugin to work. This plugin (in it's current state,) needs to go on the Plugins Quarantine list ! It needs a major overhaul.Ken wrote:The error is the same, can not find iconv.so. ... And if you do have it working on a Windows machine, what size is your iconv.so. ANY compiled Ruby binary file used, should match the Ruby version and platform of the currently loaded Ruby interpreter. So.. it is a BAD IDEA to distribute so ("shared object",) dll ("dynamic linked library",) or any binary files WITH PLUGINS. Users should just install the PROPER full Ruby edition, and use a load path script to push the paths to the standard Ruby library directories, into the global array $LOAD_PATH, which is used by the global methods load() and require() to find external files. On SketchUp v 8.x PC this is Ruby v1.8.6-p287Ruby v1.8.6-p287 Windows One-Click InstallerTHEN ... after the above is done, the call to load the PROPER iconv.so file, from the platform specific sub-dir ("/i386-mswin32"), of the standard Ruby lib dir, .. is simply: require("iconv")(The line " Sketchup::require 'CoolPipe/iconv.so'" about 13th in "coolpipe_Start.rb" needs to change.) Ken wrote:I am surprised the author doesn't offer any help.
He is Russian and does not speak English. He likely does not read English, and cannot read the Programming Ruby book, because his code violates many rules and corrupts the SketchUp Ruby environment. Sorry .. avoid using this plugin until it is fixed.
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by ken » Mon Mar 04, 2013 2:43 am
Dan
Thank you. There for awhile I just assumed I was the only one having trouble.
So thanks for taking the time to answer my request.
Ken
ken
- Premium Member
- Name: Ken
- License type: Pro
by Stephlez » Mon Feb 10, 2014 2:51 am
I am trying to use this plugin, i followed the 3 steps installation on their site: 1) unzip the file to a folder Plugins installed SketchUp 2) Copy the file iconv.dll to the System32 folder or SysWoW64 3) Reboot It loads without errors. However it seems i am not getting any pipe models from the database (database looks empty)
Stephlez
- Name: Stephan
by Se7ven » Thu Mar 27, 2014 7:31 am
From his site it seems that he will very soon be releasing version 2.0.
Se7ven
- Name: se7ven
- SketchUp use: hobby
- Level of SketchUp: Beginner
by djRuska » Fri Apr 11, 2014 12:27 pm
djRuska
- Name: Ruslan
- SketchUp version: 2013
by driven » Sun Apr 13, 2014 12:17 am
@djRustka
that is a lot of very cool coolPipe...
john
driven
- Name: driven
- License type: Pro
- Robot
Return to Plugins
