I invite for acquaintance with Russian plug-in
• Page 1 of 3 • 1, 2, 3
I invite for acquaintance with Russian plug-inI invite for acquaintance with Russian plug-in CoolPipe for drawing of pipelines. Operation only has begun. The site is fulfilled in Russian, but there is a possibility of transfer of pages from Google
Development of the next version of the process Last edited by yad2000 on Tue Apr 21, 2015 8:08 am, edited 6 times in total.
Re: I invite for acquaintance with Russian plug-inHi,
had a look at your site, you have been busy. can the plugin be downloaded? john learn from the mistakes of others, you may not live long enough to make them all yourself...
I have answered your question, I'm probably asleep when you wrote all the same difference in time ![]() Re: I invite for acquaintance with Russian plug-inPosted on the site a new build 1.1.370. With the ability to edit the pipeline. And to be precise: editing marks on the height and slope. The plugin is aimed to work with millimeters. (In Russia inches as it is not very used to design, hoping for understanding.)
I apologize in advance for my English, because I shall translate for "translate Google". Re: I invite for acquaintance with Russian plug-inThis looks like an incredible plug in, particularly for mechanical engineers. But I can see a lot of other uses as well.
Great work. Just monkeying around....like Monsanto
Re: I invite for acquaintance with Russian plug-inI apologize to the community sketchucation.com, that does not load a plugin in this topic, because he is not ready yet. The plugin itself is available on the site - indicated in the header topic. Development is underway, and as soon as the plugin will release the status of the candidate - will spread everywhere where there is a discussion of plugins for SketchUP. Maybe I'm wrong I argue, but for today I have just such an opinion.
![]() (translation carried out by means Translate Google) Re: I invite for acquaintance with Russian plug-inWow!
Very nice plugin indeed! I noticed in incorporates all kinds of round pipe standards. Does it also support profiles like I and U... like in Profile Builder? Are you working on an English version? ![]() Re: I invite for acquaintance with Russian plug-inGood day! I am glad that the plug-like. While the plug-in supports only the pipes and taps, the profiles are not supported. The English version will be developed later, when the ideas will be fully realized (native language). Everything is just beginning - the next version will appear: transitions, tees, flanges, plugs. It also will be able to define their own norms and standards.
Thanks to all who follow the updates. Re: I invite for acquaintance with Russian plug-in
what you had in mind ![]() Re: I invite for acquaintance with Russian plug-in
if the plugin will be available in English version and shared here too. if it is true. Re: I invite for acquaintance with Russian plug-in
this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind Re: I invite for acquaintance with Russian plug-inIt would be nice to have in addition to the standard diameters an option for user defined diameters, either that the user adds his own diameters or his own library, or a simple type at the keyboard, just like when you draw a simple circle.
"Profile builder" has a nice interface for adding user defined shapes, and has the ability to add whole standard libraries. Nice Work! I just showed your plugin at work to a Russian speaking fellow worker and he's already sending links to friends of his, who may find your plugin very useful... ![]() Re: I invite for acquaintance with Russian plug-in
Ability to edit a list of items will be in the next version. Now just working on a new interface that will provide such opportunities. The new version will have several elements of drawing, the announcement of the new version features expected in 2-3 months Re: I invite for acquaintance with Russian plug-inSee the next version
#-Changes in the structure of the database elements #-Drawing and editing lines #-Drawing and editing taps #-Drawing and editing transitions # Drawing and editing-tees # Drawing-caps # Drawing-flange # Create spec- #-Copy function properties (layer / material) for the objects and groups CoolPipe Re: I invite for acquaintance with Russian plug-inthanks for the update. very interesting.
a query: The plugin generates the following error: Error: # <ArgumentError: Not enough-at least 3 edges required> C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in `add_face ' C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in `cp_create_pipe_geometry ' C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb: 110: in `OnLButtonDown ' you can fix that? thank you very much Re: I invite for acquaintance with Russian plug-inhi,
it looks great but doesn't run on mac. what does the .dll and .so contain, is there a mac equivalent? john learn from the mistakes of others, you may not live long enough to make them all yourself...
What are you trying to do when there was this error?
. dll and. so standard libraries contain Iconv, to work with different encodings. The plugin was created for the Russian language for Windows, unfortunately for MAC to configure the plugin I have no technical ability (I hope to understand.) Iconv needed to process W-1251 encoding in UTF from time to time by the return webdialog Re: I invite for acquaintance with Russian plug-intry to draw a pipe, and just draw a vertical line and generates the error
very strange ... probably something with the settings of the sketchup or platform or something else)) Re: I invite for acquaintance with Russian plug-inI tested plugin. If you have in your plugin directory this plugin:
viewtopic.php?t=41840 http://rhin.crai.archi.fr/rld/plugin_details.php?id=219 SU shutdown with error! Re: I invite for acquaintance with Russian plug-inplug-in works correctly on a 32 - x bit Windows, sometimes there is an incompatibility with some third-party plug-ins
Hi, I had to change all the Sketchup:: require'' to require '' to return true and see the Toolbar. If I comment out all 'Iconv' references in all the files, Webkit on mac appears to handle the Cyrillic encoding without any issues. Is
If I change ini.rb to "Lang=en", on start I get a message box Did not load RB script: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb if I start with Lang=ru and then change ini.rb and reload, I get Error: #<TypeError: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb:81:in `add_item': can't convert nil into String> I can't get much further without English, but will keep trying. john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: I invite for acquaintance with Russian plug-inOMG! WHAT A PIECE OF CRAP.
Denis .. you MUST wrap all your code inside a module. You are defining class veriables and all your methods within Object, and they propagate into everyone else's classes and modules. I do not recommend anyone use this plugin until it is fixed, and properly module wrapped !!
Re: I invite for acquaintance with Russian plug-inWARNING !!
This "plugin" (term used loosely,) does very bad things to SketchUp's Ruby environment ! It includes Math module into Object, which will propagate into EVERYTHING else. Also it modifies Integer, Float and Fixnum baseclases, by including Math (again), and defining plugin specific methods (that are not really needed anyway.)
Work on the multi-language version is started, the news wrote about this on your site. Much more needs to be done (not without some help users of course). The plugin is provided as is and use it to recommend your own risk.
Please calm down! I am not a programmer proffessionalny Ruby, do what learned. I do not claim to uniqueness and correctness of their decisions. Your comment will take into consideration and try to make changes with the next version. As the saying goes do not like do not eat, and you should not call all the crap. Re: I invite for acquaintance with Russian plug-in#-v1.2.1
# Multi-project choice of language in the process of working with the plugin # Calculation of the mass-removal (steel), raschityvatesya of geometrical parameters (may not fit with factory products) #-The structure of the code changes: there is no change in the standard classes, all of the code integrated into classes and modules #-correction made for loading iconv.so: The MAC does not load, only on Windows # edit-elements located outside the Observer in the allocation of a separate command button #-fixed principle of sorting elements of the standard specification. sort (to avoid memory leaks in the process of counting and hangs SketchUP)
