SketchUcation Premium Membership
[Plugin] SketchUpBIM: Building Modeling made easy!
Re: [Plugin] SketchUpBIM: Building Modeling made easy!
Postby d_e_x » Thu May 24, 2012 8:15 pm
eccowboy wrote:I tried downloading SUBim, but when I was done the plugin wasn't in my SU toolbar,
I'm working in pro7, does this plugin only work with Pro8.
Thanks....
Eccowboy,
SketchUpBIM works with SketchUp 7 and 8, both Free and Pro Versions.
Please browse to "C:\Program Files (x86)\Google\Google SketchUp 7\Plugins"
on your computer, and see if the following files exist inside this folder: (i) SketchUpBIM.rbs file (ii) SketchUpBIM sub-folder. If not, then please re-install the software using the installation file. If you still cannot see the SketchUpBIM files even after re-installation, then you might not have admin privileges to install softwares into your "Program Files" folder or you might have multiple versions of SketchUp installed on your computer. If this is the case, please send me an email at support@sketchupbim.com. I can send you a link to the zip package of the plug-in (otherwise discouraged to facilitate installation upgrades). The zip package can be easily un-zipped, and the files can be copied to the SketchUp plug-ins folder.
d_e_x
Postby d_e_x » Thu May 24, 2012 8:20 pm
brookefox wrote:Thank you, d_e_x, for sharing this set of integrated tools.
Any plans for wall intersection corner clean-up?
Hi Brookefox,
clean-up of wall corners, and other intersections has been requested by a number of users. it's on our list of things-to-do. Hopefully, we'll do so in one our future releases. I will notify as and when it is added to SketchUpBIM.
Dex
d_e_x
Postby etong » Wed Jun 13, 2012 5:52 am
Tried to make this plug-in work but I really can't.
I already reinstalled my SUPro 8.0.3117 to scratch, installed only SUBIM as plugin but still no luck.
Running in Win7 64bit.
I have SketchUpBIM.rbs and subfolder SketchUpBIM in my Plug-in Folder.
Also did Preferences/Extensions but didn't find any SketchUpBIM there... I only have: Ruby Script Examples, Ocean Modeling, Utilities Tools, Dynamic Components, Sandbox Tools, Solar North Toolbar, Photo Textures as choices.
I just dunno what else to do now.
etong
Postby thomthom » Wed Jun 13, 2012 8:28 am
etong wrote:SUPro 8.0.3117
I recommend you update to the latest service release of SU8 - got lots of bug fixes.
As for the plugin, can you post a screenshot of your plugin folder?
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby etong » Wed Jun 13, 2012 4:22 pm
Ok, already downloaded the latest SU. Unfortunately still the same issue.
Here's my Screenshot of my SU8 Plugins Folder
Folders:
Examples
Ocean
SketchUpBIM
SU_Podium_V2
Utilities
Ruby Scripts:
examples.rb
ocean_extension.rb
SketchUpBIM.rbs
SU_Podium_Browser.rbs
SU_Podium_V2.rbs
SU_Podium_V2_Render_All.rbs
utilities.rb
Didn't made a screenshot as there's only a few of ruby plug-ins as I am trying to eliminate the probable rb in conflict with SUBIM.
Thanks!
etong
Postby micione » Wed Jun 13, 2012 6:22 pm
SketchupBIM not allow "LightUp" to work well. It seems that the conflict concerns the layers. Has anyone noticed this problem?
micione
License type: Pro
Postby Pixero » Wed Jun 13, 2012 7:27 pm
micione wrote:SketchupBIM not allow "LightUp" to work well. It seems that the conflict concerns the layers. Has anyone noticed this problem?
Yes, this was the reason I uninstalled SketchUpBIM.
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Postby micione » Wed Jun 13, 2012 7:40 pm
Thank you. I uninstalled. pity ...
micione
License type: Pro
Postby d_e_x » Wed Jun 13, 2012 9:21 pm
Pixero wrote:Yes, this was the reason I uninstalled SketchUpBIM.
Hi Micione, Pixero,
LightUp / SketchUpBIM conflict has been reported by some other users as well. We will investigate this issue, and get in touch with the LightUp team to fix this issue. Apologies for the inconvenience. We'll have this fixed in the upcoming release.
Dex
d_e_x
Postby etong » Fri Jun 15, 2012 4:01 am
Folders:
Examples
Ocean
SketchUpBIM
SU_Podium_V2
Utilities
Ruby Scripts:
examples.rb
ocean_extension.rb
SketchUpBIM.rbs
SU_Podium_V2.rbs
utilities.rb
Thanks!
Still not working for me :(.
etong
Postby Ineshtine » Fri Jun 15, 2012 5:06 pm
d_e_x wrote:LightUp / SketchUpBIM conflict has been reported by some other users as well. We will investigate this issue, and get in touch with the LightUp team to fix this issue. Apologies for the inconvenience. We'll have this fixed in the upcoming release.
Dex
The problem is usually with your global variables. If you use $pluginDir = "c:/BIM" and another plugin uses $pluginDir = "c:/Other" then the last one who load will change the variable $pluginDir in all loaded plugins. So make sure you name your global variables accordingly. For example, use $bim_pluginDir instead of $pluginDir
What? you haven't tried Raylectron yet?
Ineshtine
Raylectron
Postby thomthom » Fri Jun 15, 2012 5:13 pm
Ineshtine wrote:The problem is usually with your global variables. If you use $pluginDir = "c:/BIM" and another plugin uses $pluginDir = "c:/Other" then the last one who load will change the variable $pluginDir in all loaded plugins. So make sure you name your global variables accordingly. For example, use $bim_pluginDir instead of $pluginDir
No - the best thing is to not use global variables! Ever! Play nice with the environment your plugin live in and wrap everything in your own unique namespace module. No global variables and no global methods or constants that gets added to the Object class and inherited throughout every other class.
I wrote down some guidelines for avoiding clashes with other plugins etc: http://www.thomthom.net/thoughts/2012/0 ... velopment/
Global Moderator
License type: Pro
Postby Ineshtine » Fri Jun 15, 2012 6:46 pm
thomthom wrote:No - the best thing is to not use global variables! Ever! Play nice with the environment your plugin live in and wrap everything in your own unique namespace module. No global variables and no global methods or constants that gets added to the Object class and inherited throughout every other class.
TT, I was pointing out the possible problem and a simple fix using search/replace rather then changing the whole code!
Ineshtine
Raylectron
Postby thomthom » Mon Aug 20, 2012 9:28 am
It appear that this plugin doesn't work that well when installed to a location to anything other than the Plugins folder. Toolbar icons, webdialogs.
Usually when I see this behaviour it's because the plugin uses Sketchup.find_support_file to build the paths to the resources. A better practice is to build the path relative to the file itself, using __FILE__. I see all the files are rbs files - where __FILE__ will not work. But You can instead create an unscrambled loader which stores the path it's installed to for later use by the scrambled files. That way users can install the plugin to any location.
The reason people install to other locations is that they want to share plugins between SketchUp versions or computer. It's become popular to install plugins to a shared Dropbox folder. That's why it's a good thing to write plugins that work from any location.
Global Moderator
License type: Pro
Postby Phil Rader, AIA » Mon Aug 20, 2012 6:26 pm
I notice an odd behavior when I have SketchupBIM installed.
IF I activate layer 0 in the layers dialog all layers are turned on, The camera view is changed to Isometric, and The camera is zoomed to extents:
see this video:
http://www.nvizeon.com/su/ZOOM_ISSUE.mp4
This behavior only happens when SketchupBIM is installed.
Is this a know bug or is this a "feature" built-into the plugin?
Phil Rader, AIA
Premium Member
Premium Member
Name: Phil Rader, AIA
Postby Phil Rader, AIA » Sat Aug 25, 2012 3:28 am
I have disabled this plugin as it is too invasive of the user interface. It forced a zoom extents and isometric view and all layers on when a file is opened instead of opening the file to the last saved view.
I'll try it out again though as it definitely has potential to be very useful.
Phil Rader, AIA
Premium Member
Premium Member
Postby Ricalbur » Sat Aug 25, 2012 4:06 pm
Thank you, I will try it
Ricalbur
Postby Edson » Sat Sep 08, 2012 6:40 pm
I am not sure the points I am about to make have not been made before. in that case, I apologize for the repetition. here they go.
1. one of the first lessons one learns about good modeling practices is: keep layer 0 the active layer ALWAYS. SketchupBIM puts not only all entities modeled on a given elevation on a specific named layer – which is good – but also puts all the geometry (edges and faces) in that layer.
2. all the elements created are solid groups – again initially a good thing – but if one needs to create 20 columns SketchupBIM creates 20 groups whereas any good modeling practice would indicate those columns were components, for obvious reasons.
3. the tool forces one to model everything from a center line alignment. I, for one, would welcome the possibility of choosing the alignment that suits me best.
4. wall segments always overlap. an autoclean feature would be very nice.
5. why can't a new segment wall start from a corner or from the surface of a wall? they tend to all grab the center line of the wall.
6. pardon me, but the standard way to view the model is awful. one of the great things about designing in 3D is to be able to simulate what the object will be like when viewed in real life. what is the point in viewing the model in a distorted way in which what is far away looks bigger than what is close to you? I really do not care for the fact that it replicates some engineering apps. who is this tool meant for? the developers should be clear about that.
all in all, a promising tool but still needs to have more built-in flexibility. as it is it tends to force one to work in a specific way and not a better one.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
License type: Pro
Postby d_e_x » Tue Sep 11, 2012 11:16 am
Phil Rader, AIA wrote:IF I activate layer 0 in the layers dialog all layers are turned on, The camera view is changed to Isometric, and The camera is zoomed to extents: see this video: http://www.nvizeon.com/su/ZOOM_ISSUE.mp4
Phil Rader, AIA wrote:It forced a zoom extents and isometric view and all layers on when a file is opened instead of opening the file to the last saved view. I'll try it out again though as it definitely has potential to be very useful.
Hi Phil,
Thank you for your feedback. We will make the following changes to the upcoming version of SketchUpBIM:
1. Prevent "Zoom Extents" when a file is re-opened. The new version will retain the original camera position.
2. When "Layer0" is clicked, the automatic display shall apply to only those layers with SketchUpBIM elements. The other layers shall retain their default display toggle.
Dex
d_e_x
Postby Phil Rader, AIA » Wed Sep 12, 2012 4:51 am
Hi Phil,
Dex
1.Good Plan...I don't like "plugins" or other software that "makes" decisions for me without my permission.
2.Why would you alter the behavior of the standard SketchUp layers dialog...IE: if your plugin is installed or NOT when I click on layer 0 in the standard SketchUP dialog window the behavior should be the same. If you want a user to implement your tools create your own layer dialog or create a new layer called SUBIM that when clicked gives you the desired effects from your plugin. I do not expect anything to change when I activate layer 0...nada...nothing except that layer 0 becomes the active layer, unless layer 0 is turned off in which case all objects on layer 0 will now be visible...if clicking the activate radio button on layer 0 in your new version will change the "standard" out of the box SU behavior than I would still consider that invasive and not a desired result. Just my opinion.
Phil Rader, AIA
Premium Member
Premium Member
Postby thomthom » Wed Sep 12, 2012 8:21 am
I agree with Phil. I don't like it when a plugin takes over and changes the SketchUp environment.
Global Moderator
License type: Pro
Postby Pixero » Wed Sep 12, 2012 12:04 pm
I agree. Thats why I've uninstalled it.
There should at least be settings so that the user can choose IF he wants the plugin to do such things.
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
PreviousNext
Return to Plugins
cron
Users browsing this forum: alexpacio2013, Flippie123, gjgychen, Google Feedfetcher, iantyson, jeanluc_16, limaque, mojtaba, qwerslay, show32167, TheGetGo and 8 guests
