[Plugin]SOLID QUANTIFY v2.5.1 (20131215)
Re: [Plugin]SOLID QUANTIFYv2.0b update Apr08,2012.
Postby HenkW » Sat Sep 01, 2012 3:25 pm
This plug-in is great, but I found an error that renders the results unusable. Some of the material areas are doubled while most are correct in the generated reports. Secondly, in the the web dialogue there is a minor error that the volume is shown as "m" only in stead of "m³", while the distances are shown as "m³" in stead of just "m". If the first error regarding the incorrect doubling of areas could be fixed this plug-in would be perfect. Attached are a screen shot of the report as well as the SU model used to generate the report.
HenkW
Postby HenkW » Sat Sep 01, 2012 4:15 pm
Screenshot of error report with wrong areas indicated.
HenkW
Postby tak2hata » Mon Sep 03, 2012 5:28 pm
HenkW wrote:Screenshot of error report with wrong areas indicated.
Hi,Henk.
Thanks for your helps.
I will fix the problem in few days and update here.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby tak2hata » Tue Sep 04, 2012 4:36 pm
Hi,All and Henk.
I update this.
There are two Bugfix.
Surface area calculated double,when that face do not have back-material.
And mistaked about units when report rendered in webdialog.
This problem fixed.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]SOLID QUANTIFYv2.0C update Sep05,2012.
Postby HenkW » Thu Sep 06, 2012 9:40 pm
TAK2HATA, you have done an awesome job with this plug-in! Thanks for the fix, we are pushing its abilities to the limit. It requires a lot of discipline to keep everything clean and tagged properly to get the required results. For those who are using this as well, when models get really big and you can't seem to find why there are still errors... Make sure that the axes of all groups in a multi-level component are identically aligned. Use in conjunction with the plug-in “Solid Inspector” for quick results.
HenkW
Postby camilozunga » Thu Sep 06, 2012 11:44 pm
Hello and thanks for your plugin, I just find it a few days ago and it's just perfect for what I need... Unfortanetly in my MAC is not working well, don't let me export xml, don't let me apply solid materials, JUST LET ME VIEW IN WEBDIALOG and the most of the measures of elements oriented in Y axis appears in 0.00, did you or anyone mac users who are using this plugin can help?
thanks.
camilozunga
Postby QS3D » Thu Sep 20, 2012 5:45 am
Excellent Plug-in!! How to I change the quantities to SF and CY (ft^2 & yards^3)??
QS3D
Premium Member
Premium Member
Postby tak2hata » Fri Sep 21, 2012 3:55 pm
Hi,camilozunga.
I will test the problem on mac.
Please wait. ;)
Hi,QS3D.
I made this plugin be using simply.
So there are only "meter" or "inch".
I will add selecting quantities units.(maybe units in Sketchup).
Please wait. ;)
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby QS3D » Sun Sep 23, 2012 2:01 am
Looking forward to it. Thanks!
QS3D
Premium Member
Premium Member
Postby camilozunga » Wed Sep 26, 2012 12:30 am
tak2hata wrote:Hi,camilozunga.
Please wait. ;)
Hi,QS3D.
Please wait. ;)
Thanks.
Thanks a lot for your answer, I'll be waiting.:)
camilozunga
Re: [Plugin]SOLID QUANTIFYv2.2 update Sep27,2012.
Postby tak2hata » Thu Sep 27, 2012 4:27 pm
Hi,All.
I update to version2.2.
Add Menu ,"Change Units" for reports.
You can select every units of length , area , volume, cost.
Hi,camilozunga.
I tested solid quantify on mac.
I could not found problem you sayed.
Green line in this picture is Y-Axis.
The entity was placedalong Y-Axis.
Webdialog is fine.
Please upload here skp file had problem and Screen capture of Webdialog.
Or send it to me by message.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby ken » Thu Sep 27, 2012 10:15 pm
tak2hata
Great plugin. I have two questions, the COUNT(pc) what does this field indicate. And the cost, how do you get the cost field to reflect cost.
As for the COUNT(pc) I have made duplicate's of solid, and the COUNT(pc) stays at 1, however it show each duplicate on a separate line.
As for the COST, I have enter cost when I change the unit, as an example, 1.00 for each sq/in and the COST does not change.
So I must be making a mistake just can't seem to track it down.
Thanks you help and plugins.
Ken
ken
Premium Member
Premium Member
Postby tak2hata » Sun Oct 28, 2012 12:26 pm
Ken wrote:tak2hata
Ken
Hi,Ken.
I improves count(pc) of component whitch have volumes.
Now,The components have volumes is counted the figures up.
And I add function to select the components want to be quantified.
Look video in top thread of this.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Souto » Fri Nov 30, 2012 5:46 pm
camilozunga wrote:Hello and thanks for your plugin, I just find it a few days ago and it's just perfect for what I need... Unfortanetly in my MAC is not working well, don't let me export xml, don't let me apply solid materials, JUST LET ME VIEW IN WEBDIALOG and the most of the measures of elements oriented in Y axis appears in 0.00, did you or anyone mac users who are using this plugin can help?
thanks.
Great plugin however such as "Camilozunga" i' m not be able using it because won't let me export xml or cvs. I' m been trying with a simple file with a single cube with a basic material.
I' m a Mac user also.
Can you help me on this?
Regards
Souto
Souto
Re: [Plugin]SOLID QUANTIFYv2.3 update Oct28,2012.
Postby mickath » Sat Dec 08, 2012 12:06 pm
Hi All,
I think this is a very useful plugin, but I do not understand how to use it despite after watching the videos, it will be more meaningful if those video include narration & explanation in sound.
Mickath
mickath
Re: [Plugin]SOLID QUANTIFYv2.4 update Apr 28,2013.
Postby tak2hata » Sun Apr 28, 2013 3:26 am
Hi,All.
I update this to ver 2.4 in Apr28,2013.
Add Short/Full report for Webdialog.
Bug fix about surface area in scaled component.
Including area of back_face material.
deal with instance name as priority to definition name when the name applied to instance.
Hi,Camilozunga and Souto.
It can work with the model including no solid.
Thanks for the ideas from Goga63.
Thanks! :D
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]SOLID QUANTIFYv2.4.2 update MAy 16,2013.
Postby tak2hata » Thu May 16, 2013 3:22 pm
I update this to version 2.4.2. in May 16,2013.
New function"SHOW CHART".
Showing charts on browser with JAVASCRIPT INFOVIS TOOL KIT(http://philogb.github.io/jit/)
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby ken » Fri May 17, 2013 2:30 am
OK, there is a problem with this version.
The older version has a plugin called,solid_quatify2.rb and this upgrade has a plugin called, solid_quantify2.rb. So when you install this upgrade you don't over write the old version.
Ken
ken
Premium Member
Premium Member
Postby tak2hata » Sat May 18, 2013 9:01 am
Ken wrote:OK, there is a problem with this version.
Ken
The older file name was mistake.
Remove solid_quatify2.rb
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]SOLID QUANTIFYv2.4.2 update MAy 18,2013.
Postby bagatelo » Tue Sep 10, 2013 7:26 pm
I found this plugin simply fantastic! Wonderful!
But...
If some component have several copies, with several scales from outside,is presented in the report as if everyone had the same size, and this is not desirable to me.
Also would like to know if is possible to organize the report by displaying objects by layer, and if we can disable to make report to hidden layers.
Thank you!
bagatelo
Postby bagatelo » Wed Sep 11, 2013 12:24 pm
You could take a look at these things I asked here?
viewtopic.php?f=323&t=54080
bagatelo
Postby tak2hata » Thu Sep 12, 2013 4:32 am
bagatelo wrote:I found this plugin simply fantastic! Wonderful!
But...
Thank you!
Hi,bagatelo.
I will fixe the first problem about scaled component.
but I'm sorry ,Now I am too busy.So wait this weekend.
I think the component in hidden layer is not included in report.
In the case of the faces in component are placed in hidden layer,
that faces are not included,but the number of that component are counted.
I think finding that case is difficult.
Please place the components on hidden layers.
And I will read your ask topic,
but I do not know I can create the function for the request.
Thanks!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]SOLID QUANTIFY v2.5.0 (20130915)
Postby tak2hata » Sun Sep 15, 2013 3:17 pm
Hi,I updated this to version2.5.0
Bugfix::Calculate correctly volume of the solid in scaled group.
Thanks!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby bagatelo » Sun Sep 15, 2013 3:40 pm
Hello tak2hata , this is an important update. Thanks.
I think it would be very interesting if we could add in a particular component some items few who would not be modeled in 3D, but we could assign cost values​​. So when should copy such items automatically additional items would be added in the report.
It would also be interesting if our selves just set things like:
Set up a special layer, and for each item (component or group) (only those who were at the root of the outliner) additional other items would be included, which would not be modeled in 3d.
Thanks again for your efforts.
bagatelo
Postby hebeijianke » Mon Oct 07, 2013 6:32 pm
SOLID MATERIAL CHANGER error
Code: Select all
Error: #<NoMethodError: undefined method `entities' for #<Sketchup::Edge:0x5f77d44>>
E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2141:in `selectVolumetrics2'
E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2130:in `each'
E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2130:in `selectVolumetrics2'
E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2094:in `select_bySOLIDMAT'
E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2009:in `wd_solid_material_changer'
E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2141:in `call'
hebeijianke
Postby tak2hata » Sun Dec 15, 2013 12:44 pm
Hi,hebeijianke.
I fix the problems in using Solid Material Changer.
Sorry for keep you waiting long time.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
Postby jorgeeparra » Sat Sep 27, 2014 2:40 am
IMPRESSIVE PLUGIN VERY USEFUL :thumb:
jorgeeparra
Postby jorgeeparra » Thu Oct 09, 2014 2:19 pm
Nice plugin ..I Like it a lot it will be nice to be able to use Tag and profile columns just like you do with Materials
jorgeeparra
Postby cadmunkey » Wed Nov 12, 2014 1:48 pm
It would be great if you could add the IFC classifier type to the quantities list.
For example IFC_footings = 300m3.
cadmunkey
Postby gudio83 » Tue Jun 16, 2015 5:47 pm
is there a version compatible with sketchup 2015 x64?
gudio83
PreviousNext
Return to Plugins
Users browsing this forum: delight2423, GD3Design, Lardus, laxman011222, Muheeb456, Passion123, sheilly and 24 guests
