[Plugin]Export Collada with texture names 1.2b [30/9/11]
Re: [Plugin]Export Collada with texture names 1.2b [30/9/11]
Postby McGyver » Wed Sep 05, 2012 5:33 pm
I'm curious if anyone has found out if it is possible to keep the material names (by that I mean the SketchUp "color only type materials" not image textures) when exporting using DAE... Has this been determined to be impossible?
McGyver
Postby rraallvv » Tue Oct 16, 2012 5:40 am
Could someone add an option to swap Y and Z axis, please
I am using Collada2POD to import my models into my application, but Y and Z axis appears swapped
I'd appreciate it a lot
rraallvv
Postby electrician » Sun Dec 09, 2012 7:25 pm
I have problem, i use this plug in but still texture names comes like texture0.bmp, texture01.bmp ect... What is possibly happening? I use File > "Export collada with texture names"
electrician
Postby MKumar » Thu Dec 27, 2012 10:44 am
Even when i use this exporter it creates lot of textures, instead of one. the above comments are too technical for me. can you professional give me a simple solution or an updated exporter which works.
MKumar
Postby TIG » Fri Dec 28, 2012 1:22 pm
MKumar wrote:Even when i use this exporter it creates lot of textures, instead of one. the above comments are too technical for me. can you professional give me a simple solution or an updated exporter which works.
The native exporter works fine, except that material-names get changed [even worse in older versions], hence the attempt here to 'fix' the names, the exported DAE format is no different... :?
Here's my analysis...
When you get lots of texture files relating to something that appears to be the same texture it is because most exported file formats rely on triangulated mesh faces and therefore only have three vertex normals to map the UVs of the textures [i.e. to work out how the texture is positioned exactly on each facet]. Now, if a texture has been simply positioned on a face [i.e. slid around], or rotated or scaled, then these three points are sufficient to determine what the texture should be like on the related exported facet. However, if you have a 'skewed/perspective-like' texture [even slightly distorted like this] - perhaps by moving one corner inadvertently whilst positioning/rotating it, or somehow projecting it - then to UV map that texture in the exported format successfully would need four vertices, and of course as explained before we only ever get three to use !
So to overcome this many exporters will spot these distortions and create a unique distorted texture-map of that particular texture and save it as another 'similar' image-file... and then apply that without any other UV mapping as the texture - so that it then looks the same in the exported version; but of course it has to use this other image-file. Thus, is you have lots of weirdly distorted textures in a SKP that you export it can include many of these distorted image-files... Some Pro exporters try to reuse distorted image-files for several matching facets, others like my OBJexporter have a built-in tolerance and if the distortion is very slight the undistorted standard version of the image-file is still used to avoid zillions of slightly different files/textures getting made...
So, in conclusion... I suspect your SKP has many distorted textures that cannot be easily exported without distorted image-files being created. :cry:
Global Moderator
Postby Mra » Thu Mar 07, 2013 2:31 am
Nice plugin,
but it seems this does not support the exporting of instances/symbols/components etc?
I import in Maya and SketchUp components are no longer instances.
However if I export using regular Collada DAE exporter, maya reads SketchUp components as instances.
Mra
Postby sbht » Mon Nov 11, 2013 10:20 am
Aerilius wrote:This plugin allows to export the whole model or the selection to Collada file format while preserving/restoring the the texture's original file and the material's screen names.
This is useful since SketchUp's Collada exporter creates generic names which don't allow to identify materials anymore when you want to use the file in another software.
SketchUp also creates new textures images for each face with distorted texture coordinates; however these won't receive the original material's name.
If you need specific export options (from SketchUp's options dialog), feel free to edit the options_hash.
Unfortunately, SketchUp also creates generic material names (<auto>1) when you import Collada files into SketchUp.
Version: 1.2b
Date: 30.09.2011
Usage:
(Menu) File -> 'Export Collada with texture names'
:thumb: it works for my pc
Aerilius, thanks a lot your helps
sbht
Previous
Return to Plugins
cron
Users browsing this forum: Bing [Bot] and 10 guests
