[Plugin] QuadFaceToolsRe: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Sensational, TT. Now I can make my Arch texturing tutorial #3!
![]() Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011
Looking forward to it! Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011thank you very much for this excellent update. is excellent.
unfortunately I have a problem:). sketchup generates the following error: Error al cargar archivo C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb undefined method `to_l' for nil:NilClassError al cargar archivo tt_quadface.rb undefined method `to_l' for nil:NilClass how I can fix this? Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011
When do you get this error? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011What version of TT_Lib2 do you have?
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011is odd. install this plugin yesterday and worked well.
Today I went back to start and generated that error sketchup Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Can you check exactly what version you have to be sure? Type TT::Lib::VERSION into the Ruby Console. I just want to make sure as I've had cases before where users thought they had the latest, but turned out that they didn't. Does it give you that error every time? If so, after you started SU, can you open the Ruby Console and type: load 'tt_quadface.rb' and post back any errors if there is any. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011TT::Lib::VERSION 2.5.8
When I write load 'tt_quadface.rb' , ruby console generates the following message: load 'tt_quadface.rb' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:20: warning: already initialized constant PLUGIN C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:21: warning: already initialized constant PLUGIN_ID C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:22: warning: already initialized constant PLUGIN_NAME C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:24: warning: already initialized constant PLUGIN_VERSION C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:27: warning: already initialized constant PATH_ROOT C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:28: warning: already initialized constant PATH C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:29: warning: already initialized constant PATH_ICONS Error: #<NoMethodError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:51:in `[]': undefined method `to_l' for nil:NilClass> (eval) C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:90:in `set_default' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb:45 C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in `require' C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in `load' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:41:in `register_extension' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:41 (eval):0:in `load' (eval):0 ---- I use Sketchup 8 in Spanish y windows xp sp3 Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011thom thank you very much for your time.
but. re-install the program sketchup, and now the plugin works fine. I can not have that problem occurred but works fine ![]() Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011It works? Good - glad it does.
That last error you posted guides me to where to look. I'll look at the code and see what I can do to avoid it. Thomas Thomassen — SketchUp Monkey & Coding addict
![]() Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Has anyone gotten around to try the UV mapping feature?
I know it has some issues and the UI needs improving. What worked and what didn't work? What's unclear and what is not? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011I did some quick tests.
When using "Unwrap Picked Grid" it'd be nice if it used inferencing. Sometimes the texture reverses though I haven't reproduced this regularly. Other than that it's nomnomnomnomnomnomnomnomnomnomnom There's a frontroom and a backroom....reverse faces
For placing the grid?
O'RLY? o_O Let me know if you can reproduce it. And even if you can't, post the result? Btw, that UV test tile you got there... ? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011What about my UV test tile? You don't like it?
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011yes for placing the grid
Yea I do. I gives a larger illustration of the UV flow.
![]() ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Hmm, for some reason I'm having trouble selecting the V direction.
(Especially if I try to click on an outer edge.) Usually, selecting the U direction works. Then for V it doesnt select what I'm clicking on. ![]() When I click the edge on the other side of the selected U edge, "mirrored from the first", it works more often, but the texture isn't applied as I would like. ![]() I'm having this problem with every model I tried. SU 8, Windows 7 64. Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Hello, I noticed a error when opening a a second SU instance (if I have one already opened and I want a second one), you can see it here.
Thank you. DESIGNER AND ARTIST DEREI.UK
Screenshots? Video? Thomas Thomassen — SketchUp Monkey & Coding addict
Does that happen every time? After you've gotten such an error, what do you get if you open the Ruby Console and type load 'tt_quadface.rb'? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Here's a little library of 10 UV maps.
Here's the pretty one you like... There's a frontroom and a backroom....reverse faces
It does every time. If I load it from console, it happens this: DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Thanks - will look into it.
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011great to see a video and what amazing work you put into this forum. really well done.
I'm trying this out for the first time and am having some trouble, the problem is that i can put a texture in but then cant change it to a new one Its basically only works once and you can't map anything else to that shape. or i've missed something. - I'm on a mac (suggestion - is there a roll over help pop up that can be used that when you leave the curser ove an icon a pop up help describes the function?)
Re: [Plugin] QuadFaceTools (0.4.0b) — 04 October 2011Tom,
Here is the model where I have problem (I get the UV axes, but the texture does not appear). Fredo
