by alsomar » Thu Nov 09, 2017 6:09 pm
Is there any way to quantify how many quads a component has? Thank you!
alsomar
- Premium Member
- Name: Alejandro Soriano
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Rich O Brien » Thu Nov 09, 2017 7:22 pm
Tools > QuadFace Tools > Analyse > Count Polygons
Rich O Brien
- Administrator
- Name: Rich O'Brien
- SketchUp version: 2017
- License type: Pro
- SketchUp use: engineering and mechanical design
by alsomar » Thu Nov 09, 2017 7:45 pm
Rich O Brien wrote:Tools > QuadFace Tools > Analyse > Count Polygons
Thank you Rich! I was sure there was a way
alsomar
- Premium Member
- License type: Pro
by Oxer » Fri Nov 17, 2017 2:06 am
Hi, is QuadFaceTools compatible with Sketchup 2018? I don't know what plugins are or not compatible with Sketchup 2018, for this reason I will wait to update to SU2018.
Oxer
- Name: Oscar
- Operating system: Mac
- License type: Free/Make
- SketchUp use: illustration, cartoons
by HornOxx » Fri Nov 17, 2017 12:11 pm
Oxer wrote:...for this reason I will wait to update to SU2018.
...nevertheless you could always install any new version in parallel, as long as you didn't make the mistake of deinstalling an existing and running version  hopefully I'm not wrong - there will be no more SU 2018 Make version (??) - so better keep your SU 2017 Make.
never trust a skinny cook
HornOxx
- Name: HornOxx
- SketchUp version: 2019
- License type: Pro
by Oxer » Fri Nov 17, 2017 1:27 pm
Thanks for the info!!
Oxer
- Name: Oscar
by optimaforever » Wed Jan 17, 2018 5:54 pm
Hello Thomas, I can't find a good value for quadding a helix staircase made thanks to Eneroth's Upright extruder. Do you know a solution? I tried max angles of 1-10° but this produces awkward triangulated meshes. I already asked Julia if she could update her plugin to automatically generate QFT quads but I'm in a hurry (as usual)...  Thanks in advance,
optimaforever
- Premium Member
- Name: optimaforever
- License type: Pro
by HornOxx » Wed Jan 17, 2018 7:07 pm
...even though I can't say anything constructive about your interesting question - this staircase is so amazing!
HornOxx
- Name: HornOxx
- License type: Pro
by Box » Thu Jan 18, 2018 2:36 am
Have you tried Convert Triangulated mesh to quads?
- Name: Box
- SketchUp version: 2020
- License type: Pro
- SketchUp use: other
by HornOxx » Thu Jan 18, 2018 7:31 am
 that's impressive again Box - how did you get the "triangled mesh to quad's" operation work on the entire model after selecting these few entries only then? I try to reproduce this but unfortunately without success so far
HornOxx
- Name: HornOxx
- License type: Pro
by Box » Thu Jan 18, 2018 7:37 am
That is how it works, you need to only select two faces and an edge then hit the button and wait. It should work through all connected faces. Look in the bottom left corner and watch it do its job. How long depends on your pc and the complexity of the model.
- Name: Box
- License type: Pro
by optimaforever » Thu Jan 18, 2018 7:47 am
Box wrote:That is how it works, you need to only select to faces and an edge then hit the button and wait. It should work through all connected faces. Look in the bottom left corner and watch it do its job. How long depends on your pc and the complexity of the model.
ahah I didn’t know that. I was wondering how the script worked but your explanation makes sense, thanks! What max angle value do you use?
optimaforever
- Premium Member
- License type: Pro
by optimaforever » Thu Jan 18, 2018 2:48 pm
Jeez I can't get it to work right... Is there a trick? I always end up with some diamond shapes instead of rectangles... even though my geometry is perfectly rational... I tried the one diagonal edge + 2 adjacent triangles selection technique (once on the border, next in the middle, then on the upperface) but without luck.
Is there a video explaining how the make quad function works?
optimaforever
- Premium Member
- License type: Pro
by HornOxx » Thu Jan 18, 2018 7:59 pm
optimaforever wrote:Jeez I can't get it to work right...
First - thank you Box for demonstrating this Quad Face Tool feature - I've never understood how it works so far  ( just like some other buttons here as well  ) @ Optimaforever - Like you, I couldn't get it to work. But now I've found a way to do it too - with one more simple step than in Box´s demonstration. Before I use QFT like Box did, I unsmoothed the entire geometry first. This worked !!  so please give this way a try as well ... ( not a video though but my very first GIF here  )
HornOxx
- Name: HornOxx
- License type: Pro
by optimaforever » Fri Jan 19, 2018 4:11 pm
Ok I've found the problem. I was using "convert wireframes to quads" instead of "convert triangulated mesh to quads"
Jeeez... doh!
optimaforever
- Premium Member
- License type: Pro
by gudio83 » Mon Mar 12, 2018 10:13 pm
Hi everybody, is anyone else who have a problem with importing .obj files? When I convert .obj to skp with simlab composer, this take me a seconds. When I try with SU (Quad FaceTools) take me over 30min. I've tried on my laptop too, but the same result. Is it normal?
gudio83
- Name: gudio83
- License type: Pro
by pilou » Mon Mar 12, 2018 11:39 pm
Have you tried with an another OBJ Importer like the Tig One ? And there is not native Import OBJ file with the SU Pro version ? Can you post your OBJ file ?
- Top SketchUcator
- Name: Pilou
- SketchUp use: hobby
by gudio83 » Tue Mar 13, 2018 12:03 pm
pilou wrote:Have you tried with an another OBJ Importer like the Tig One ? And there is not native Import OBJ file with the SU Pro version ? Can you post your OBJ file ?
No, I've never tried Tig One, but will try. I have the same problem with all obj files. I've downloaded a lot of models, created on max or cinema4d and i've tried to convert them directly in sketchup, but its very slow.
gudio83
- Name: gudio83
- License type: Pro
by Hieru » Tue Mar 13, 2018 3:13 pm
HornOxx wrote:Like you, I couldn't get it to work. But now I've found a way to do it too - with one more simple step than in Box´s demonstration. Before I use QFT like Box did, I unsmoothed the entire geometry first. This worked !!  so please give this way a try as well ... ( not a video though but my very first GIF here  )
Isn't that just softening the triangulation? Box's demo seems to be removing the triangulation altogether and that's certainly something I can't replicate.
Hieru
- Premium Member
- Name: David Hier
- License type: Pro
by gudio83 » Fri Mar 16, 2018 6:37 pm
Hieru wrote:HornOxx wrote:Like you, I couldn't get it to work. But now I've found a way to do it too - with one more simple step than in Box´s demonstration. Before I use QFT like Box did, I unsmoothed the entire geometry first. This worked !!  so please give this way a try as well ... ( not a video though but my very first GIF here  )
How and where you unsmooth the geometry, when the problem its loading model? With simlab composer its easy, but out of sketchup
gudio83
- Name: gudio83
- License type: Pro
by HornOxx » Mon Mar 26, 2018 7:51 pm
Hi All - I can't get the two functions Build Corners and Build Ends to run. Hopefully someone can tell me what I'm doing wrong  Thanks!
HornOxx
- Name: HornOxx
- License type: Pro
by pilou » Mon Mar 26, 2018 9:43 pm
Works for me!  in any orientations of the "plane"! (your is vertical) mine horizontal  Post your file! (V6) for a more large audience!  I suspect some overlaped lines or hidden lines trimed or not or... GIF_corner.gif GIF_corner2.gif
- Top SketchUcator
- Name: Pilou
by HornOxx » Tue Mar 27, 2018 7:49 am
thanks Pilou - it´s running like yours on my SkUp 2016 Pro (in the company) but sadly not on my private SkUp 2015, 2016 or 2017 Make which is my Quad-SubD-things computer  ...
HornOxx
- Name: HornOxx
- License type: Pro
by pilou » Tue Mar 27, 2018 8:38 am
If you are sure of your drawings that is a big mystery!
- Top SketchUcator
- Name: Pilou
by optimaforever » Tue Mar 27, 2018 10:46 am
Hornoxx, what's sure is you only need to preselect an edge, not the surfaces along the edge. You also need to be sure that the rim edges are continuous and not splitted, otherwise the quad making is impossible.
optimaforever
- Premium Member
- License type: Pro
by optimaforever » Wed Aug 01, 2018 11:14 am
hi Thom!
Is there a neat way of doing a offset of a loop towards the outside of a mesh? I know your "hidden" offset loop function indeed offset loops but only inside an alreay defined mesh. So long I use R Wilson's "extrude along path" and then delete the unneeded faces but it can quickly become a mess if the path is complex and not in an horizontal plane.
Is it difficult to program an offset of a loop along a predefined XY/YZ/XZ plane (each point of the loop is offset along a horizontal or vertical plane and then relinked to form an offset loop) ?
optimaforever
- Premium Member
- License type: Pro
by optimaforever » Wed Aug 29, 2018 9:50 pm
Hi Thom,
I'm testing RizomUV (a powertool for UV unwrapping) and I have problems when importing QFT's quads OBJ. The geometry is correct but it seems that 90% of the quads are detached.
I asked the developer if RizomUV was able to reattach the quads but it's not possible. This must be done on the modeling app side.
I tried to export the OBJ to 3dsmax first but max (while displaying the imported mesh as quads) seems to handle the geometry as tris and when I export the mesh as fbx or obj, the imported geometry in RizomUV is all tris.
I tried all the params when exporting my mesh from sketchup+QFT's export options but I never got attached quads in RizomUV.
Do you know how to export ATTACHED quads from SU? Thanks in advance,
optimaforever
- Premium Member
- License type: Pro
by rv1974 » Thu Aug 30, 2018 9:03 am
in Max, import (dire straits) skp file, select all, attach all selected (script), detach by material (script)
rv1974
- Name: rv1974
- License type: Pro
by optimaforever » Thu Aug 30, 2018 9:12 am
I can be wrong but when you import skp directly in Max, the geometry is handled as tris by default and not in quads. Quadify modifier doesn’t work as I expect as well. The difficulty here is to keep the thomthom quads when exporting.
optimaforever
- Premium Member
- License type: Pro
by rv1974 » Thu Aug 30, 2018 12:01 pm
jugging by RizomUV promo video, it works with tris like a beast. Doesn't it?
rv1974
- Name: rv1974
- License type: Pro
- Robot
Return to Plugins
