[Plugin] QuadFaceTools
Re: [Plugin] QuadFaceTools
Postby optimaforever » Wed Dec 07, 2016 11:27 am
Hello Thomas,
Perhaps has it been asked before, but is there a way to tweak the bydefault colors for the analysis tool? Not that I don't understand your wise choice of colors, but I'd prefer more contrasted colors like white-red...
And I agree, it's a pity one can't replace a default sketchUp view mode (like monochrome or x-ray that I don't use often) with this analyse view mode, to keep the textures/UVW mapping.
Otherwise, good job! :thumb:
optimaforever
Premium Member
Premium Member
Postby thomthom » Wed Dec 07, 2016 2:18 pm
No color options as of yet. But it's something I wanted to add. The current version was a quick and dirty tool - turns out to be more useful than expected.
PluginStore Author
PluginStore Author
Postby eneroth3 » Tue Dec 20, 2016 1:40 pm
I've just discovered the UV Mapping Tool in this plugin and it's so incredible useful. Not finding it earlier is definitely a Doh Moment for me. I'm a quad fan now! :P
eneroth3
PluginStore Author
PluginStore Author
Postby thomthom » Wed Dec 21, 2016 1:41 pm
eneroth3 wrote:I'm a quad fan now! :P
whohoo! :D
PluginStore Author
PluginStore Author
Postby cmoreink » Tue Jan 17, 2017 3:31 pm
How do you import an .obj file?
It crashes every time I try ---> file, import, select .obj file "oops, an error occurred :(" a message displays (box) askes me if I want to send a report.
The tool bar displays ok
Any idea why?
cmoreink
Postby jo-ke » Sun Jan 29, 2017 11:25 am
I would like to use this plugin to texture a curtain.
https://3dwarehouse.sketchup.com/model. ... e42ea057c5
I tried to convert the mesh but it doesn't work.
What did I wrong?
same with that one:
https://3dwarehouse.sketchup.com/model. ... 51a521b687
jo-ke
Premium Member
Premium Member
Postby jo-ke » Thu Feb 02, 2017 8:05 am
I really don't know how to convert the mesh, to let the texturing tool work.
anybody has got an idea?
jo-ke
Premium Member
Premium Member
Postby alamin » Sun Feb 05, 2017 3:44 am
any pdf manual?
alamin
Postby Box » Mon Feb 13, 2017 1:47 pm
Thomthom, any chance of adding a selection option where you can step the ring/loop selected?
So, instead of adding or subtracting, each click moves the selection one loop over and deselects the one you are on.
Edit: I'll just add this gif to help explain what I mean,I have a workaround but it would be helpful to have.
3
Postby pilou » Thu Mar 02, 2017 3:05 am
No French UI version :?:
Speedy Galerie
Top SketchUcator
Postby thomthom » Thu Mar 02, 2017 9:58 am
cmoreink wrote:How do you import an .obj file?
Any idea why?
Can you share this obj file please? (You can PM me if you don't want to share the file publicly)
PluginStore Author
PluginStore Author
Postby thomthom » Thu Mar 02, 2017 10:00 am
Box wrote:Thomthom, any chance of adding a selection option where you can step the ring/loop selected?
That's a good idea. Logged it in the issue tracker: https://bitbucket.org/thomthom/quadface ... shift-loop
PluginStore Author
PluginStore Author
Postby thomthom » Thu Mar 02, 2017 10:01 am
pilou wrote:No French UI version :?:
No. ...not yet that is... I just set up a Crowdin project for this extension. ;)
But give me some time to localise SUbD and move to my new home. :)
PluginStore Author
PluginStore Author
Postby pilou » Thu Mar 02, 2017 10:13 am
Thx for the info, i had believed that i Miss something! :fro:
About the Crowdin, seems you must save after every new each line item input
else seems that is not save as general input for several items! :?:
Speedy Galerie
Top SketchUcator
Postby thomthom » Thu Mar 02, 2017 11:51 am
pilou wrote:About the Crowdin, seems you must save after every new each line item input
I'm sorry, I don't follow..?
PluginStore Author
PluginStore Author
Postby pilou » Thu Mar 02, 2017 2:16 pm
No problem it's just for the use of Crowdin who seems curious with the Save of new translation! :)
Speedy Galerie
Top SketchUcator
Postby cmeed » Wed Apr 19, 2017 2:54 pm
Hi Thom Thom
I'm getting an error box when ever I open SU heres and image of the box that appears.
its seems to run ok though when i close the window.
cheers in advance
chris
cmeed
Premium Member
Premium Member
Postby mae_fierros » Sun Jul 16, 2017 3:44 am
How come the "Offset Loop" under my Quadface tools seems not to work/function in SU 2017 ? what is the most compatible extension for the 2017 version? thank you in advance
mae_fierros
Postby Rich O Brien » Sun Jul 16, 2017 12:07 pm
Offset Loop is still a work in progress.
It was a experimental feature Thom added a few versions ago.
Sometimes it works ok other times it fails. Always send crash reports when it fails.
Rich O Brien
Administrator
Postby Kuu » Mon Sep 11, 2017 10:39 pm
I've recently started learning to do quad modelling in other apps but these tools are great for doing stuff in sketchup! However there's a couple of tools I feel are missing which would be great to roundout QuadFaceTools:
1. Offset with edges. Basically just an offset tool but that builds all the connecting lines so you don't have to draw them in manually to preserve the quad topology, which is a drag. I tried looking at all offset plugins but none seems to do this relatively simple thing:
Above offset with edges; below regular offset. (I'm not sure how the intersections would be though, but at least for simple offsets it would be easy)
2. Quadify N-gon. Basically automatically divide any convex polygon into quads, being able to preview and choose division type before finalizing.
1st row is edge splitting but works with any N-gon, i suppose it would be nice to also make the extra loops.
2nd row is central but only works with N-gons divisible by two above N = 6
3rd row is grid splitting which is the best solution for large N values to avoid nasty poles.
4 and 5 provide other alternatives...
If these things could be added that would be awesome! Or if other plugins I don't know about already do this that would be nice too...
Kuu
Postby rtd » Thu Sep 14, 2017 4:23 pm
I hope that this is the best place for this question.
What is the relationship, if any, between 'vertexTools', 'subD', and quadFaceTools?
Are they independent or is one or more required for the other(s) to function?
Thank you
rtd
Postby Box » Thu Sep 14, 2017 4:46 pm
They are independent tools that work together. None are needed for others to work but they are authored by the same magician and therefore help you to pull a rabbit out of your hat or a hare out of your ....
Postby thomthom » Sat Sep 16, 2017 11:35 am
SUbD do work best with quad topology - and for that you would be better of using QFT to author the mesh.
PluginStore Author
PluginStore Author
cmeed wrote:Hi Thom Thom
cheers in advance
chris
Sorry man - I haven't visited this thread for a while. Do you still have this issue?
What version of QFT and TT_Lib do you have installed?
PluginStore Author
PluginStore Author
Postby thomthom » Sat Sep 16, 2017 11:43 am
Kuu wrote:I've recently started learning to do quad modelling in other apps but these tools are great for doing stuff in sketchup! However there's a couple of tools I feel are missing which would be great to roundout QuadFaceTools:
That's for the details suggetsions. I logged it in the issue tracker.
https://bitbucket.org/thomthom/quadface ... with-edges
Meanwhile you can try out TIG's Split Tools: viewtopic.php?t=43376
PluginStore Author
PluginStore Author
Postby Kuu » Sat Sep 23, 2017 3:03 am
thomthom wrote:That's for the details suggetsions. I logged it in the issue tracker.
https://bitbucket.org/thomthom/quadface-tools/issues/109/offset-with-edges
Meanwhile you can try out TIG's Split Tools: http://sketchucation.com/forums/viewtopic.php?t=43376
Awesome. I did find TIG's tools a few days after I made that post, and it sure does the job but too many clicks breaks the sketchup flow: need to do the offset, escape the tool, pick the face and then another command... getting it done with just one command would be glorious since I offset a lot. An additional efficiency I thought of was if the tool ended with the new offset ring selected so it's ready to manipulate, because after using TIG's tool curves get destroyed and you need to pick the edges and select loop which adds even more commands...
Kuu
Postby thomthom » Mon Oct 23, 2017 7:36 pm
Version 0.13.0
  • Improved OBJ importer.
    • Handle different encodings.
    • Also look in "map" and "maps" directories when searching for textures.
    • Handle files referring to materials without a .mtl companion file.
    • Fix line segment import.
    • Support OBJ files with negative indicies.
  • Add a Quad-Edge Tool to mark edges as Quad Edges.
  • Unhide the experimental Offset Loop Tool
  • Dropped compatibility for SketchUp 2013 and older.
5
PluginStore Author
PluginStore Author
Postby kenancakir » Mon Oct 23, 2017 8:13 pm
Thank you..
kenancakir
Postby duanekemp » Mon Oct 23, 2017 9:01 pm
Thomthom, You are too cool. Thank you for the newly added work on the plugin. Bravo!
Duane Kemp
Kemp Productions
Puidoux, Switzerland
Gallery:
https://duanekemp.artstation.com/
duanekemp
Postby thomthom » Tue Oct 24, 2017 12:05 pm
Version 0.13.1
  • Improved OBJ import - handles OBJ files with unexpected W value for its UVW coordinates.
4
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: hdn973, isha6879, just rafa, Tawakul and 14 guests
