SketchUcation Plugin Store
[Plugin] QuadFaceTools (0.7.0b) — 08 February 2012
Re: [Plugin] QuadFaceTools (0.7.0b) — 08 February 2012
Postby thomthom » Mon Jul 16, 2012 11:08 am
UV Toolkit will allow you to transfer front <-> back. viewtopic.php?t=18992
I'll make a note to add an option in QuadFace Tools.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby ivreich » Mon Jul 16, 2012 1:19 pm
Thanks guys. I'll give them both a go.
On a separate note, is there a way that quadfacetools, JPP and kirill's new LSS tools can come together to make a proper (precise) panelising tool for SU? I'm no scripting guru but it seems like a lot of plugins out there already come quite close. I've been asking around about this a lot but no one seems to be interested. here's what i thought:
1. Create quadface mesh (with EEby, curviloft etc.)
2. Use JPP to turn each quad into a 3d "cell" with definable offset thickness
3. Use LSS "stick group to mesh" to map a selected component neatly into each cell, breaking/distorting along the diagonals to fill the entire surface.
I originally posted this idea and some example images here:
viewtopic.php?f=323&t=39992
Didn't get very far, some suggestions to use TGI3D but it's a lot of money to fork out for just one little part of it's functionality. I'll keep pushing the idea periodically.
Joel
ivreich
SketchUp version: 8
License type: Pro
Postby tedvitale » Fri Aug 31, 2012 9:10 pm
HELP! Im freakin out! I installed TT_Lib2 and TT_QuadFaceTools to my plugins folder. TT_Lib2 gave me a copy and replace option when I went to place it in the plugins folder. Since I already have a number of TT's other tools installed I assumed it would be no problem. But I just opened Sketchup and bam, NONE of my plugins show up. Nothing in my tool pallet selection, nada! Their all still there in the plugins folder but nothing works in sketchup now! What happened? Suggestions?
When I open sketchup I get an error that reads:
C:Program Files (x86)/Google/Google Sketchup 8/Plugins/Makfaces.rb
The files listed below could not be loaded:
Sketchup.rb
no such file to load -- TT_Lib2/core.rb
progrsee bar.rb
Contact the developer of this script address: toddb@sumstard.com
Anybody else ever have this happen?!
tedvitale
SketchUp version: 8
License type: Pro
Postby TIG » Fri Aug 31, 2012 11:58 pm
It seems that TT is not here right now... so I'll try to help...
Reading past your typos... :roll:
TT's tools probably include their own 'progressbar' method, loaded by one of his 'helpers' in the required TT Lib folder.
ToddBurch [smustard.com] wrote the original code for a similar 'helper'.
When TT's fails to load error messages fly around and the auto-load of all sorts of scripts gets awry.
This says to me that you have NOT installed the QuadFace tools and/or the required helper files in the TT Lib correctly.
I suspect that some files that ought to be inside a subfolder are loose inside the Plugins folder and thereby mis-loading and throwing a wobbly...
Can you post screen-shots of your Plugins folder, and the subfolders associated with the tool and TT Lib...
If you re-read the download pages for the tool AND the TT Lib you should have little doubt about what should and shouldn't be in the Plugins folder and the appropriate [sub]folders...
Please reaffirm this to yourself, retry and come back... :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sat Sep 01, 2012 11:02 am
I'm guessing you placed the content of the TT_Lib2 folder in the ZIP files directly into the root of the plugins folder. Instead you should have preserved the path footprint - as described next to the download link.
Alternatively, I would recommend, you install plugins with this utility which ensures they are correctly installed:
viewtopic.php?t=42315#p375454
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby pbacot » Thu Sep 13, 2012 5:53 pm
I looked at the online list of features but for some tools I can't easily associate the icon to the tool. I don't see icons for every tool noted. When I hover on the QFT icons I don't get a description either. Is there more on this, eg a pdf?
User avatar
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
Level of SketchUp: Intermediate
Postby thomthom » Thu Sep 13, 2012 6:44 pm
pbacot wrote:I looked at the online list of features but for some tools I can't easily associate the icon to the tool. I don't see icons for every tool noted. When I hover on the QFT icons I don't get a description either. Is there more on this, eg a pdf?
Yea - it's need better documentation and it's still in beta shape. I need to make some videos as well.
All I got is the Wiki: https://bitbucket.org/thomthom/quadface-tools/wiki/Home
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby pbacot » Thu Sep 13, 2012 7:08 pm
Thanks for the reply TT. At the speed I am learning-- NO hurry. I realize you have a few other things to do like some sort of bezier surface modeler. Oh, and I assume you have a life beyond our petty desires?
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby wind-borne » Thu Sep 13, 2012 7:23 pm
Toolbar orientation?
Horizontal toolbar icons seldom reveal themselves on Mac's?
Hover over vertical toolbar maybe.
"To read between the lines was easier than to follow the text."OSX 10.8.3 _ _ _ _ _ SU 8.0.16845 pro
User avatar
wind-borne
Premium Member
Premium Member
Postby pbacot » Thu Sep 13, 2012 7:36 pm
Doesn't work for me. I just figured out if I leave the Ruby window open I can get some info when clicking on the icons.
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Sep 13, 2012 8:29 pm
hmm... so are you getting no tooltips at all when you hover over the buttons? Because there are tooltips...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby pbacot » Thu Sep 13, 2012 9:10 pm
OK they're back. After restart. I know this has happened before... Sorry for the bother. I've been getting somewhere with it now.
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Ruck » Tue Oct 02, 2012 8:49 am
Hi!
I can't load a plug-in on the first page. It because of new design of a site?
Win7 x64, Chrome.
Ruck
Postby thomthom » Tue Oct 02, 2012 8:53 am
Ruck wrote:Hi!
:shock: :?
Yes - that's a big fail on account of the new site. I'll let the admins know.
Meanwhile - download here: https://bitbucket.org/thomthom/quadface ... i/Download
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Ruck » Tue Oct 02, 2012 9:01 am
thomthom wrote:Meanwhile - download here: https://bitbucket.org/thomthom/quadface ... i/Download
Thanks for the fast help!
Also forgive my English :oops:
Ruck
Postby dickorama » Fri Jan 25, 2013 2:28 pm
Okay, I'm seriously confused here. Only managed to get this work once and all other attempts to repeat the process failed ever since. What do I do wrong?
1. Creating a sandbox plane. 50x50 meters, if size matters anyhow.
2. Converting sandbox to QuadTools quads.
3. Copying the plane nearby.
4. Texturing original plane. Texture is set to 50m, so it does not repeat.
5. Entering original plane group and copying UV coordinates.
So far so good, paste button is now active.
6. Entering copied plane group and pasting UV coordinates.
7. Nada.
I tried all kinds of various methods for conversion - exploded, grouped, did whatnot. Something I noticed is sometimes sandbox quads are turned into triangles when converted and sometimes they are not?!
Help :(
dickorama
Postby daforum » Fri Feb 15, 2013 10:17 am
Do the tools work with SketchUp V7?
Do I need any other plugins/ scripts for them to work?
Thank you. :?:
User avatar
daforum
SketchUp version: 7
License type: Free
SketchUp use: other
Level of SketchUp: Beginner
Postby thomthom » Fri Feb 15, 2013 10:47 am
Yes.
Just follow the instructions on the page that appear when you click the Download button and you'll be all set.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Fri Feb 15, 2013 10:52 am
A quad face property is when the diagonal edge on a non planar 4 sided object has soften and smooth property on and the cast shadow property off.
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Rich O Brien » Fri Feb 15, 2013 10:53 am
Ok, so I replied to a post that has now disappeared so it looks like I just blurted out random crap.
But for that mystery guy see above....;)
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Feb 15, 2013 11:03 am
dickorama wrote:Okay, I'm seriously confused here. Only managed to get this work once and all other attempts to repeat the process failed ever since. What do I do wrong?
7. Nada.
Help :(
Didn't notice this until now. Still having problems?
Got a sample model?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby daforum » Fri Feb 15, 2013 3:26 pm
Unfortunately I get this error message when SU7 starts:
"can't convert nil into StringError Loading File tt_quadface.rb
can't convert nil into String"
I don't know what this means so I can't use it.
User avatar
daforum
SketchUp version: 7
License type: Free
SketchUp use: other
Postby Rich O Brien » Fri Feb 15, 2013 3:29 pm
Have tt_quadface.rb in the root of the plugins folder?
It should not reside in a folder within the plugin folder as per the footprint in the first post.
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Feb 15, 2013 3:33 pm
Open the Ruby Console (Window > Ruby Console) and enter: load 'tt_quadface.rb'. Report back the whole error.
(Btw, can you post a screenshot of your Plugins folder?)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby daforum » Mon Feb 18, 2013 5:15 pm
DELETED: new post (see below)
User avatar
daforum
SketchUp version: 7
License type: Free
SketchUp use: other
Postby thomthom » Mon Feb 18, 2013 6:16 pm
Code: Select all
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:20: warning: already initialized constant PLUGIN
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:21: warning: already initialized constant PLUGIN_ID
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:22: warning: already initialized constant PLUGIN_NAME
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:23: warning: already initialized constant PLUGIN_VERSION
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:24: warning: already initialized constant PLUGIN_AUTHOR
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:27: warning: already initialized constant PATH_ROOT
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:28: warning: already initialized constant PATH
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:29: warning: already initialized constant PATH_ICONS
Error: #<LoadError: no such file to load -- TT_Lib2/core.rb>
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_QuadFaceTools/core.rb:9:in `require'
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/extensions.rb:36:in `require'
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/extensions.rb:36:in `load'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_quadface.rb:41:in `register_extension'
(eval):540:in `load'
(eval):540
Error: #<LoadError: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_QuadFaceTools/core.rb:9:in `require': no such file to load -- TT_Lib2/core.rb>
(eval):540
(eval):540
It appear that you do not have the required TT_lib2 installed.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby daforum » Mon Feb 18, 2013 6:34 pm
Apologies, I have included it - TT_lib2 - then taken a screenshot of the plugins folder (see attached)
and another report of the whole error (see attached txt file)
many thanks.
User avatar
daforum
SketchUp version: 7
License type: Free
SketchUp use: other
Postby thomthom » Mon Feb 18, 2013 7:18 pm
daforum wrote:Apologies, I have included it - TT_lib2
Are you sure it's installed correctly?
Do you by any chance have a TT_Lib2 folder inside an TT_Lib2 folder?
Can you post a screenshot of where the core.rb file inside TT_Lib2 lies? (Screenshot that includes the full path.)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby daforum » Wed Feb 20, 2013 2:28 pm
Here's a screenshot of the TT_Lib2 folder (can't display it all as my screen isn't big enough)
and I haven't got the folder inside another TT_Lib2 folder.
The full file path is this:
Macintosh HD/ Library/ Application Support/ Google Sketchup 7/ Sketchup/ plugins/ TT_Lib2/ core.rb
User avatar
daforum
SketchUp version: 7
License type: Free
SketchUp use: other
Postby thomthom » Wed Feb 20, 2013 2:34 pm
That is very strange. I have no idea what is going on here.
...I've noticed lately there's been lots of OSX users with problems due to not sufficient permissions to the plugins folder. Though I'm not really familiar with what they did or what errors they where getting...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: chrislbj, Gernreich, Hieru, juanjo, Ken, mlippiatt, usertx and 11 guests
