[Plugin] Drop Vertices
Re: [Plugin] Drop Vertices v1.2 20110807
Postby TIG » Wed Aug 10, 2011 1:33 pm
I have checked and there is 'a rabbit away' !
Watch out for fixed code soon :roll:
Global Moderator
Re: [Plugin] Drop Vertices v1.3 20110810
Postby TIG » Wed Aug 10, 2011 2:05 pm
Here's v1.3 viewtopic.php?p=346754#p346754
It fixes a last minute typo in my code that affected Lowest/Highest/Middle results - it should now work as advertised - feedback please...
Global Moderator
Postby wyatt » Wed Aug 10, 2011 2:52 pm
The high/low/middle work correctly now. Thank you for this script.
wyatt
Postby MartinK » Wed Aug 10, 2011 3:21 pm
That seems to have done the trick. Many thanks. :thumb:
MartinK
Postby simon le bon » Fri Aug 12, 2011 2:57 pm
Thank you so much Dear TIG for this brand new tool.
("to middle" and "to average" options don't work for me with su6_free and su7_pro)
Coming back to the thread which had (re)initiated the need for such a tool: What's the best way to flatten some geometry lines
I'm trying the old problem (not solved by SandboxTools/stamp)to achieve to drop vertices of a 3d path onto a 3d terrain. (I would like start with a path "melted up an down", "included" with/into the terrain)
I have made my road/path triangulated (with Sandboxtools/from contour)
Tip: I use [Plugin] Select Outer Edges v1.0 by Chris Fullmer to select outer edges :roll:
But Whatever the option I choose with Drop Vertices I got aberrant result :?
to nearest object , to nearest below..
Any Idea ??
(Alternatively, I have tried "Drape CPoints" + "Triangulate Points" and also "Artisan"€ and this one gives the better results for me from now, using "Crease Selection" Edges+vertices on the total path face .
Cheers
simon.
_ _ _
Re: thank you dear Tig for your [Plugin] Work Plane v2.3 by TIG on Sat Sep 25, 2010 I'm using for long >>referencing to "this"
simon le bon
Postby TIG » Fri Aug 12, 2011 4:59 pm
Simon
DropVertices isn't Drape
Global Moderator
Postby simon le bon » Fri Aug 12, 2011 7:18 pm
Bonjour TIG :)
OK, I was confused on the concepts Drape/Drope.
I have discovered that the kind of subdivision is important. Until now I was trying to drape with some classical triangulated shapes and that's why the result wasn't working.
As I have seen with your example above it was possible, I have discovered that shapes must be subdivided by real tin subdivision.(as far)
(I see we can't obtain this way something like we can do with sandboxtool/Stamptool but with a 3D path.)
Anyway This DropVertices brings so much !!!!+++ Thank you one more time and bravo!! TIG
simon.
simon le bon
Postby EarthMover » Fri Aug 12, 2011 8:20 pm
Here is another method to do what you are looking for Simon.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby simon le bon » Fri Aug 12, 2011 11:58 pm
Dear Adam,
your videos are invaluable to understand easily how things work and as reminders.
I have watched your previous a number of times.
I'm studying your propositions (soapskin&buble _ instant road (which makes the deal :thumb: :thumb: ) and I'm thinking to others. It's for tomorrow now.
Cheers,
simon.
simon le bon
Postby pilou » Mon Aug 22, 2011 1:47 pm
Maybe use of Ferrari can also gives some cool results ;)
Speedy Galerie
Top SketchUcator
Postby ktslambieng » Fri Jan 06, 2012 4:18 am
oh .thank u verry much
but ruby SplitUp I can find where, who can help me, please
i saw on Youtube
http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related
ktslambieng
Postby TIG » Fri Jan 06, 2012 10:43 am
ktslambieng wrote:oh .thank u verry much
i saw on Youtube
Like 'On Screen Rolling Reel' - 'SplitUp' has never been published.
It's in beta testing with a select group [Rich O'B].
The bugs are now ironed out... I'll speak with the other[s] to see what we should do next...
Global Moderator
Postby Rich O Brien » Fri Jan 06, 2012 11:03 am
Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
Rich O Brien
Administrator
Postby peter_shaw » Fri Jul 05, 2013 1:23 pm
great plugin, used it to fix a f-ed up model
peter_shaw
Postby cotty » Wed Apr 22, 2015 4:21 pm
What did I wrong here?
cotty
Top SketchUcator
Postby TIG » Wed Apr 22, 2015 5:11 pm
Scant on what you've tried...
arcs/curves do not drop unless they are exploded first...
but see this example...
Global Moderator
Postby TIG » Wed Apr 22, 2015 5:43 pm
Here is v2.0
Download
It now overcomes the curve issue.
All edges in a dropped curve are now treated as separate edges.
Global Moderator
Postby cotty » Mon May 04, 2015 8:39 pm
Thank you, nice update!
cotty
Top SketchUcator
Postby pilou » Tue May 05, 2015 2:10 am
Does it possible to imagine a "drop" on X or Y direction ?
(sure I can rotate all before but...)
Speedy Galerie
Top SketchUcator
Postby mariocha » Fri May 27, 2016 9:05 pm
Hi TIG,
I found that To Middle and To average do not work.
Console indicates that line 93 z=z.to_s.to_l if z is faulty; cannot convert to length.
I changed it to z=z.to_f if z . (float) They now work.
Is this right ?
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby mariocha » Sun May 29, 2016 6:10 pm
pilou wrote:Does it possible to imagine a "drop" on X or Y direction ?
In this port are functions for the 3 axis.
I tried to stick to the actual extension standards.
Re-named it since it does more than just drop.
Added LanguageHandler, french. And a contextual menu for the most frequent ones I use.
Mario C.
mariocha
Premium Member
Premium Member
Previous
Return to Plugins
Users browsing this forum: No registered users and 16 guests
