[Plugin] View Parts (1.2) — Sept 13 2011
Re: [Plugin] View Parts (1.2) — Sept 13 2011
Postby Jim » Mon Oct 10, 2011 12:48 am
dannyver wrote:is there no one ho has a solution for this problem :cry: . this can make this plugin very useful :D
You need to explode the top-level Group or Component. The plugin is not designed to work when in the context of Component.
Jim
Global Moderator
Postby dannyver » Wed Oct 12, 2011 6:44 pm
driven wrote:hi dannyver,
I don't use SU 6 and I'm on a mac so it's hard to know what issues your having.
maybe you could re-cast your question to target your setup better.
e.g. "I've tried this plugin using SU6 on this skp and it doesn't seem to function, can someone check if it's my skp?
or "can someone post a skp that works with this plugin in SU6 so I can check my setup..."
With the first example you'll likely find out if your skp works or with the second you'll eliminate a wrongly setup skp...
sorry I can't be of more help. Personally I know it 'basically' works on mac using SU8, but I only tested the functionality for future use.
other than that I suggest checking you've got the latest version, and re-read any instructions or posts.
also, if you no longer use SU6 update your User Settings.
john
i update my user settings right away ;)
dannyver
Postby dannyver » Thu Oct 13, 2011 6:23 pm
it is not that it is not working, but it dos not work in site a components/group.
it while make this plugin much more useful when it while work in site a component. maybe there is someone that can make it work :sketchstatic:
dannyver
Postby samyell » Fri Feb 15, 2013 3:49 pm
:thumb: Just wanted to say a big thank you for this Plugin. Downloaded it a while ago and use it several times a week - saves me HOURS. Thanks!! :thumb:
samyell
Postby Jean-Franco » Wed May 01, 2013 11:00 pm
would it be possible to create automatically layers with scene's name and visibility on, for each scene, instead of hiding unwanted parts ?
Maybe as an option > "create layers ?" YES/NO.
Thanks.
Jean-Franco
Jean-Franco
Postby pilou » Sat Jul 06, 2013 11:27 am
Will be very cool with the Radial Move by CPlassais ! ;)
And with the "tricky one liner" for the ruby console by TIG (which makes each faces selected as a component)! :enlight:
Code: Select all
m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup::Face}
Speedy Galerie
Top SketchUcator
Previous
Return to Plugins
Users browsing this forum: A Doctor Who, faust07 and 5 guests
