[Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
Re: [PLUGIN] Hatchfaces!
Postby sergey2402 » Thu Jul 14, 2011 10:27 pm
TIG wrote:We are helping him... [sometimes in the background ;) ] :D
:thumb:
:berserk:
sergey2402
Postby jolran » Fri Jul 15, 2011 8:29 am
About added features:
To put hatches in a layers(newly created OR selected) is possible, at least create a new layer. I was thinking of adding that anyway.
If you do two hatches of the same face, is it possible to get both hatches in the same group.
It is a good idea, looking at how the plugin works right now. But it's risky business adding geometry inside groups, and you probably have to select the created hatchgroup before running. Wich in turn will not add that much improvement in workflow?
But if you really, REALLY want that feature... It won't hurt testing..
My personal view is that I should rather investigate the possibilitie to improve the plugin with a "pattern library" instead. No promises can be made in that regard though. It seams difficult.
TIG, kyyu, please do not leave jolran alone
:D
TIG's been helping me a LOT! Through PM's and more, otherwise this plugin would not exist. KYuu fixed the spacing and that was mucho importante.
jolran
PluginStore Author
PluginStore Author
Postby TIG » Fri Jul 15, 2011 8:55 am
The layer part is easy. Add some code to make/refer to the layer
hatch_layer=model.layers.add("HATCH")
If it doesn't exist it's made...
Then after the group is made use...
group.layer=hatch_layer
Done :D
You could add a 'crosshatch' option to the main dialog, because most of the time that's what's wanted anyway - "Crosshatch? " >> "Yes|No" [you'd need to insert a 3rd ['','',["Yes|No"]] in inputbox moving the title over to 4th place] - default would be 'No'. If results[3]=='Yes' you'd repeat the line drawing steps within the same group entities, but at +/-90 degrees, so there would be twice as many edges overlaid etc... :idea:
How are the 'holes' going... :?:
Global Moderator
Postby jolran » Fri Jul 15, 2011 9:42 am
He he! As easy as that, huh? :D Well there you have it guys!
I will work on those things. And put an option of angle on second hatching. That would give you as much flexibility as
needed for linehatching I presume?
The "holes"... Hmm difficult. I have been searching posts about that subject(Don't just want to add anything unless I actually understand what is going on). If I understood it right, holes are somewhat problematic in Sketchup. One have to
use both face.outer_loops AND face_loops to get to the face hole geometry? Where face_loops is innerloop? Or include.all loops? That is a big difference.
In API it says: Face outer_loops retrieves a "face loop object" But what does that mean?
Edges, vertices? Both? Is it an array?
For a newbie like me to interprate the API is quite difficult.
The posts in here are very helpful, but it takes time to search specific posts. There are currently around 146 pages * 25 * (number replies) in just the developper section. :D
So with that said, I am very greatful for your help TIG.
jolran
PluginStore Author
PluginStore Author
Postby TIG » Fri Jul 15, 2011 9:57 am
all_loops=face.loops i.e. its is an array of all loops including the outer one
outer_loop = face.outer_loop
inner_loops = all_loops - [outer_loop]
Although some of this is of academic interest as we only need all_loops...
As I said before [in a PM]... you simply iterate through all loops and add a face for each loop using its vertices.
all_loops.each{|loop|gents.add_face(loop.vertices)}
You have the main face drawn... but with its holes filled in with other faces.
We can erase these by testing to see if each face in gents has an edge with only one face [i.e. it's NOT in a hole], if not then we'll erase it...
Code: Select all
faces2go=[]
gents.each{|face|
  next if face.class!=Sketchup::Face
  face.edges.each{|e|
    if not e.faces[1]
      break
    faces2go << face
gents.erase_entities(faces2go)
[this code is untested and might have typos !]
Now you should have a perfect clone of the face inside the group with any holes reproduced too.
Do your intersecting of the hatch lines etc just as before and then when you erase 'faceless edges' the ones now crossing these 'holes' will be erased too :D
Global Moderator
Postby jolran » Fri Jul 15, 2011 10:16 am
Great info! Will work on that.
Do you mean {|loop|gents.add_face
or {|loop|ents.add_face ?
Thank you TIG. Got me some homework :)
jolran
PluginStore Author
PluginStore Author
Postby TIG » Fri Jul 15, 2011 10:18 am
The 'gents' refers to the group.entities where we are replicating the face ?
Global Moderator
Postby jolran » Fri Jul 15, 2011 10:30 am
Yes that make sence. I had already put a similar code from your pm in my editor where I had used ents.
That was wrong then from my part. Makes thing clearer. Thanks! :D
jolran
PluginStore Author
PluginStore Author
Postby jolran » Fri Jul 15, 2011 6:16 pm
Strange. Should work, but no innerface is created.
Hatch gets created over whole face. I tried different combinations with
these new lines added, but get errors then..
Code: Select all
gp=ents.add_group()
      gp.name=name
      gents=gp.entities
      face=gents.add_face(face.outer_loop.vertices) # adds a faceclone from outer vertices loop
      faces2go=[]  # was faces2gp? Typo? array for innerloups faces
      face.loops.each{|loop|gents.add_face(loop.vertices)}   # creates inner loop
      gents.each{|face|
      face.edges.each{|e|
      if not e.faces[1]
      break
    faces2go << face
      gents.erase_entities(faces2go)                #erase the faces in the holes
jolran
PluginStore Author
PluginStore Author
Postby TIG » Fri Jul 15, 2011 6:39 pm
Try first adding the faces for the 'inner_loops' - each using loop.vertices in turn [i.e. face.loops-[face.outer_loop]], then add the face from face.outer_loop.vertices...
This might work... To see what you are getting stop the code temporarily before the inner faces are erased and before any hatching is done - add a line 'return nil' in the code so that it stops... You should get the faces reproduced in the group. Then try with the inner face erase bit to see if they go [sans hatching...] :?
Global Moderator
Postby sergey2402 » Fri Jul 15, 2011 6:57 pm
Perhaps the thickness of the hatch lines should not be equal to the thickness of the edges? Like dimension lines.
sergey2402
Postby jolran » Fri Jul 15, 2011 7:11 pm
Not noow Kato!! :knockout: :D
I don't understand Sergey. Do you want line weight? That is only possible
through styles in Sketchup. But it's a global feature. I am afraid I can't do anything about that. Maybe if thin rectangles are grouped with materials
like TIG,s dashed lines. But that is further on in developement.
Look at my last minitut for an example how you can use differnt styles, with edge profiles for ex.
Thanks for input Sergey! MUST CODE ON!! :thumb:
And yes TIG. I'm trying! :bounce:
jolran
PluginStore Author
PluginStore Author
Postby jolran » Fri Jul 15, 2011 8:15 pm
This code gives me a face with holes. If I stop after this code.
But cannot Hatch faces with holes in full script.
Get an error :?
Normal (square faces) works fine in full script with the changed code, strange enough.
Code: Select all
gp.layer=hatch_layer    # group to Hatching layer
      gp.name=name
      gents=gp.entities
      faces2go=[]
      gents.each{|face|
      face.edges.each{|e|
      if not e.faces[1]
      break
      faces2go << face
jolran
PluginStore Author
PluginStore Author
Postby TIG » Fri Jul 15, 2011 8:21 pm
Why not?
How are you hatching?
Stop at each stage with a temporary 'return nil' and see what you get or error messages etc... :?
Global Moderator
Postby linea » Fri Jul 15, 2011 10:53 pm
Tig this is brilliant, wanted this for so long.
linea
Postby sergey2402 » Sat Jul 16, 2011 3:03 am
Whether not too much I want? :oops:
sergey2402
Postby kyyu » Sat Jul 16, 2011 4:02 am
jolran, a few suggests for you to consider.
1) Seperate out the code that draws the line pattern, into it's own method. That will make your main program simpler to understand. It will look more like an outline. Check out my later example code snippet. I just premade the line pattern, by hand, which would represent simply calling a method to make it. Also, you can reuse the draw_lines method, say if you want to draw a 2nd set in the criss cross direction.
2) Might want to consider a rethink. The program will become more complicated, if you just keep adding stuff on top of exsiting. Here's a possible new way, shown below. And the way I test stuff quickly, is to use the "Ruby Web Console" plugin by Jim Foltz. I often check parts of my program, like this, as snippets of code; before adding it to the plugin. You simply undo <ctrl+z>, change the line(s) of code and execute the code again, by hitting the "eval button".
Code: Select all
#This snippet puts the face,lines & hatch into 3 seperate groups.  Face is simply grouped, not copied.
#The "lines" group is premade and named "lines", so the script can find it.
#You need to select the face, before running script
#No need to delete seperate edges, just delete the lines group when done.
model = Sketchup.active_model
ent = model.entities
sel = model.selection
f = sel[0]
face = ent.add_group(f)
lines = (ent.to_a.select {|e| e.is_a?(Sketchup::Group) and e.name=="lines"})[0]
puts lines
hatch = ent.add_group
hent=hatch.entities; lent=lines.entities; fent=face.entities
htr=hatch.transformation; ltr=lines.transformation; ftr=face.transformation
fent.intersect_with(true, ftr, hent, htr, false, lines)
lines.erase!
face.explode
test_hatch_RubyWebConsole.skp
kyyu
Postby Jim » Sat Jul 16, 2011 8:58 am
This is very useful, jolran. Thanks for making it happen.
Jim
Global Moderator
Postby kaas » Sat Jul 16, 2011 2:22 pm
wonderful!! This kind of plugin (hopefully someday with some extra hatch options) is really what I was missing in SU.
Many thanks to those involved! :berserk:
kaas
Postby jolran » Sat Jul 16, 2011 6:59 pm
Sergey, thanks for your suggestions :thumb: I will probably go for something like the picture, first time around.
Unless I'm wrong you have to use webdialog for checkboxes, and I'll put that on hold for now.
More important issues to deal with first.
Hi Kyyu. Many thanks for your input and experimenting. Really appreciate it :thumb:
I got a strong impression from reading this forum, that making groupes from selection is a bad choice? :?
Thats why I neglected my original idea and went for TIG's "face.clone iterating stuff". Don't you get splats doing it like that? Have you tried this inside a group? I got constant splats doing almost exactly as you did.
However grouping the edges before doing an intersect_with might be a good idea. That might actually be an easier method than iteration the edges for erasing? Depends on how "splat-prone" the method is.
About separating to 3 groups. Don't know if that is necessary? Doesent it suffice to add the hatches to a new layer? (Which is already implemented in my current code). This grouping In my opinion does no good for the workflow. Need more feedback about that, please :)
Yeah, I know code's a bit messy, but doing a second hatching that is probably a must anyway.
I'm using AS ruby code editor. It's the same as Jim's no?
Thank you Jim and Kaas! And TIG's been helping me a LOT, that goes without saying.
jolran
PluginStore Author
PluginStore Author
Postby jolran » Sat Jul 16, 2011 7:32 pm
YES!!!! Faces with holes are hatching now. Will update tomorrow, hopefully.
Stupid newbie-mistake. I did not create "@face" object. So for ex bb=face.bounds
did not have anything to refer to since face was in Faces2go's scope. At least that is what I think happend. :D
Will test more before I celebrate too much...
Sorry TIG, I missed your post from yesterday. I wasent using return nil. I used =begin and =end. That works equally good?
jolran
PluginStore Author
PluginStore Author
Postby jolran » Sat Jul 16, 2011 7:41 pm
Testing.
jolran
PluginStore Author
PluginStore Author
Postby Bob James » Sat Jul 16, 2011 7:46 pm
Looking Good :thumb:
Bob James
Premium Member
Premium Member
Postby kyyu » Sat Jul 16, 2011 11:32 pm
jolran, looks like you got it working well. :thumb: So no need to change anything. I will answer the questions, anyways.
Yes, it's to be avoided. But you can do it, under certain circumstances. Grouping loose geometry is ok, especially a single edge or face. In my example, I grouped a face at the very beginning. And it do it, just once. I've written plugins, like this, before. You can't do it what an entitiy, already inside a group. I'm assuming it has to be in the current active_entities.
If, I am just testing a quick snippet of code, I certainly will just group the face instead of writing a bunch of lines to clone it.
You only need to consider doing all this, if you didn't make the entitiy. If you want your lines in a group, then you would make an empty group 1st, and then create the lines directly in the group (gents.add_line instead of ents.add_line).
It all depends on how you are doing stuff. My thoughts on 3 groups is as follows: Group1 is your cloned face group. If you decide to group your line pattern, then that's group2. When you use intersec_with, you can choose where the new lines go. You can't put them in group1 or group2. They would merge and you have to clean them up. So you put them in group3. Then you only need to delete group1 & group2. No need to find and delete any edges. That's what my example does. Except, I just explode group1, becasue I don't make a clone.
Should be the same. Just suggesting an editor that can execute the code, if you aren't using one. I use Notepad++ for that and reload using Jim's Ruby Toolbar. But Jim's Ruby Web Console does the undo automatically. And very easy to test small bits of code. I still use his older version.
-Kwok
kyyu
Postby kyyu » Sat Jul 16, 2011 11:55 pm
Sorry, disregard, was trying to edit the previous post.
kyyu
Postby sergey2402 » Sat Jul 16, 2011 11:58 pm
jolran wrote:YES!!!! Faces with holes are hatching now. Will update tomorrow, hopefully.
So when will come tomorrow? I am looking forward!
I am sure - in the new version of SketchUp this plugin should become a standard feature.
sergey2402
Postby sergey2402 » Sun Jul 17, 2011 12:10 am
Looking to the future, I regret to foresee, this plugin will be not freeware.
sergey2402
Postby Rich O Brien » Sun Jul 17, 2011 12:12 am
Do you have a crystal ball or some sixth sense? Will I be able to cut the grass tomorrow or will it rain?
Rich O Brien
Administrator
Postby sergey2402 » Sun Jul 17, 2011 12:37 am
Rich O'Brien wrote:Do you have a crystal ball or some sixth sense?
The really good thing can not be free. It understandable without a crystal ball and without sixth sense. ;)
Rich O'Brien wrote:Will I be able to cut the grass tomorrow or will it rain?
Good question, but a great pity to spend my magical powers to answer it. :fro:
sergey2402
Postby jolran » Sun Jul 17, 2011 8:05 am
Kyyu! Thank you so much for your detailed explanation. Now I understand better. Much apreciated.
I think your intersect method is worth experimenting with for upcoming features. And or what features is possible.
No one in here needs to worry this will become a comersial plugin.
Yes, of course I need to make money. But I have gotten so much help from TIG and Kyyu, Jim and others, so going comers. would be HIGHLY unethical! If even legal? This is a great learning experience for me, and I will try too remain humble and listen to
advice and suggestions being made.
Hatches, yes. So this work might be for nothing :D Although, it is possible only Layout will be the program that get hatches.
jolran
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: AmazingAloo, verasak2520gmailcom and 17 guests
