[Plugin] TextureTools
Re: [Plugin]TextureTools v1.5 20110520
Postby CadFather » Tue May 21, 2013 7:37 am
the plugin only works on front faces (not sure why) - so, check that your texture is painted facing front and then try again. perhaps TIG can make it work on back face as well in the future.
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Tue May 21, 2013 1:47 pm
These tools only works on front-faces... because that's where textured-material ought to be applied.
Applying a material onto a back-face is just bad practice.
Back-faces should never be visible.
Modeling with reversed faces can lead to many problems when pushpulling, applying cutting components etc, and when the SKP is exported, used in many rendering applications etc, etc...
The native context-menu Texture tool will adjust front/back-face textures, depending on which side of the face you are seeing... use that if you insist on sloppy modeling.
BUT I deliberately discourage the application of materials on back-faces.
So these tools will only ever adjust textured-materials applied onto front-faces.
Use Monochrome mode, with a contrasting back-face default-material in the Style, to check that you are not modeling 'inside out' :?
The context-menu items Reverse and Orient are useful to fix reversed faces as you model - shortcut keys is highly recommended. Also use Monochrome as you model to check the correctness of the faces' orientation. Only start applying materials and texturing once the geometry is pretty much resolved... :roll:
-1
Global Moderator
Postby CadFather » Tue May 21, 2013 6:09 pm
yes, i understand, though i guess that's only if you are using a rendering package, if you use SU for render, than back faces are just as good - and of course when you paint both you don't get those pesky flickering edges.
CadFather
PluginStore Author
PluginStore Author
Postby Arc » Tue Sep 24, 2013 3:29 am
Eneroth Texture Positioning Tools
http://extensions.sketchup.com/en/conte ... ning-tools
Is this same plugin?
Arc
Postby TIG » Tue Sep 24, 2013 9:39 am
Arc wrote:Eneroth Texture Positioning Tools
No, mine is the original one...
Global Moderator
Postby Mafalda_Melo_Oliveira » Wed Oct 16, 2013 11:37 am
How do I install?
Postby TIG » Wed Oct 16, 2013 4:45 pm
Mafalda_Melo_Oliveira wrote:How do I install?
Find the tool in the SCF PluginStore [Resources menu first item], get the RBZ and install it with Preferences > Extensions > Install... button in v2013 or v8...
OR get the SketchUcation Plugin Store toolset [second item in that menu or in the first item - under most popular...] - that lets you AutoInstall Plugins from within SketchUp itself...
You need to ensure you have FULL security permissions to your Plugins folder - there are several post covering that...
-1
Global Moderator
Re: [Plugin] TextureTools
Postby TIG » Sat Dec 14, 2013 2:39 pm
New version available at the PluginStore viewtopic.php?p=329765#p329765
Global Moderator
Postby anesalesayi » Tue Apr 29, 2014 3:52 pm
thanx man
anesalesayi
Postby CadFather » Thu Nov 13, 2014 12:21 pm
great plugin - would be fantastic if it worked on back faces too
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Thu Nov 13, 2014 1:30 pm
CadFather wrote:great plugin - would be fantastic if it worked on back-faces too
But why is any textured material applied to back-faces ?
They should never be seen !
However, I have PM'd you a version to test called TextureTools_BACK ! which works like TextureTools but only on back-faces... It's a separate toolset and toolbar [it has similar icons but with a blue-gray background]
Please test and see it it's what you expected...
Global Moderator
Postby CadFather » Thu Nov 13, 2014 2:04 pm
Thank you TIG, that works great! :D :thumb:
basically since often i don't photo-render my drawings, the front-back issue doesn't arise.
should i change my mind later i could always swap and even reverse faces with the su4you materials plugin: http://sketchucation.com/pluginstore?pln=S4U_Material
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Thu Nov 13, 2014 3:52 pm
If anyone else wants to try the 'TextureTools_BACK', please ask and I'm PM it to you...
Global Moderator
Postby CadFather » Thu Nov 13, 2014 4:35 pm
btw TIG, i tried unifying the 2 plugins, but i might as well work out the quantum/relativity problem first....... :ugeek:
if you do join both scripts into one, PM me first please!
CadFather
PluginStore Author
PluginStore Author
Postby oip » Sun Nov 16, 2014 7:58 pm
oip
Postby YuriNikolai » Mon Feb 13, 2017 11:56 pm
Will you ever release a 2016-compatible version of TextureBaker?
YuriNikolai
Previous
Return to Plugins
Users browsing this forum: alperci, Anton A, Google Bot, m13266, namrfb and 9 guests
