[Plugin] Pen Tool +
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)
Postby TIG » Mon May 23, 2011 9:05 pm
The 'edge' tools doesn't form faces like the 'pen' tool [or for that matter the other line drawing tools].. The 'pen' tool is like native 'Line'... BUT it has some different inferencing etc... Try the different ones to see what I mean... :geek:
Global Moderator
Postby utiler » Mon May 23, 2011 9:20 pm
Hey, I've missed this so far!!!!! haven't you got enough to do, Rich?
Well done mate!
utiler
Top SketchUcator
Postby driven » Mon May 23, 2011 10:22 pm
hi Rich,
this is great, works on the mac except the
Code: Select all
 ###new_toolbar.show ### ONLY show if was visible before...
    new_toolbar.restore if new_toolbar.get_last_state==TB_VISIBLE
[this may be due to the slightly different RUBY_VERSION i.e. 1.8.5]
however it does work if I cut and paste it to line 1175, directly under
Code: Select all
new_toolbar = UI::Toolbar.new("Pen Tool +")
tooltips, custom menu items and the tools themselves all work as advertised...
well done
john
driven
PluginStore Author
PluginStore Author
Postby Rich O Brien » Mon May 23, 2011 10:27 pm
Thanks for the Mac feedback John. Glad you got it to work :thumb:
Rich O Brien
Administrator
Postby yellow peril » Thu May 26, 2011 12:18 am
I have just downloaded your pen tool, i am working on mac, it appears to workfine but with no icons.....any ideas?
yellow peril
Postby driven » Thu May 26, 2011 12:31 am
hi,
if the icons folder named, rob_hsltool is in your plugins folder, then you might just need to turn on the menu in View >> Tool Palettes >> Pen Tool +
john
driven
PluginStore Author
PluginStore Author
Postby boofredlay » Thu May 26, 2011 8:38 pm
BTW, TIG solved my problem stated earlier in this thread. Thanks TIG.
It turns out if you click the "Compatibility Files" button between Burn and New Folder it showed up.
boofredlay
Global Moderator
Postby hungnguyenpham » Mon Jun 06, 2011 4:40 am
Thank you!
hungnguyenpham
Postby Panga » Fri Jun 10, 2011 7:52 am
Thanks a lot for this usefull plugins !! :thumb:
Panga
Premium Member
Premium Member
Re: [Plugin] Pen Tool + v1.3 (Update 18/5/2011)
Postby jgb » Wed Jun 15, 2011 6:52 pm
Dave R wrote:Comes of drinking American beer at high elevations for a week when you're not used to either. :D
Canadian beer will do that at sea level in less than a day. :roflmao:
__________________
jgb
jgb
Postby mitcorb » Thu Jun 16, 2011 12:35 pm
Hi:
Just trying out Pen Tool last night, I noticed that occasionally for one click I got 2 Cpoints. Also, one or two of the other pen settings doubled the endpoints which were placed short distances apart in a series of quick clicks randomly in the model space. Hard to explain. I did not save the file. This was in Sketchup 7. This mouse has shown no other misbehavior in other applications.
Has anyone else seen this?
mitcorb
Top SketchUcator
Postby TIG » Thu Jun 16, 2011 1:02 pm
Mitcorb I think this is down to you keeping the mouse-button pressed and dragging.
Most of this kind of line tools allow for you to press+hold+drag+release to make the line, as well as more usual click+click to provide two ends.
There's a short timer delay built-in to spot a real button-hold as that - obviously you're on the top limit time-wise and it's assuming a drag is wanted...
Is your mouse-button sticky?
For the cpoint tool if you don't do a clean click. but do more of a press. then it assume a drag and places a second cpoint at the release point - which might be only a short distance away if the mouse moves slightly.
So to avoid this ensure a clean click with no holding down of the mouse button with a drag unless you want two points...
Global Moderator
Postby mitcorb » Thu Jun 16, 2011 4:37 pm
Yes, thanks, TIG:
It is obvious from only one test that I wasn't tuned in to the appropriate procedure. I am not usually what you would call a fast clicker, partly because of my system response, and partly because of my own internal wiring. :mrgreen:
A salute to you and Rich for this excellent concept.
mitcorb
Top SketchUcator
Postby nanfar » Sat Jul 02, 2011 6:47 pm
thank you for you plugin.
nanfar
Postby austin457 » Sun Jul 10, 2011 1:32 am
Awesome. I joined this site specifically to get this plug-in. It's been a bane in my rear end that Sketchup couldn't simply draw dashed (or construction lines) that didn't go into infinity. Couldn't make a clean diagram that way. (And I know SU is more for 3D than CAD- but it makes sense to model something and then CAD it out in the same app. I also know Layout can draw them, but that gets messy too).
I literally just used the plug-in, but something I noticed right off I want to ask about:
I see that drawing the Construction lines flags to SU they are indeed construction lines. When I "Delete Guides" they are deleted as well. I tried grouping them and locking, but they still get deleted if I use the command. Is there a way to makes these lines unique to SU so they won't get deleted when cleaning up my drawings with the Delete Guides command?
Thanks again. This will cut down on a lot of cursing 'round here! ;)
Win XP, SU 7
austin457
Postby Gaieus » Sun Jul 10, 2011 1:55 am
Unfortunately no. Guides are deleted even in locked groups. I'd call this a bug but officially it is called a "feature".
I am not really sure but as if in some earlier versions construction lines hadn't been deleted if they were in a group and you were outside that context. Just like how "unhide all" works now.
You can always put these guides into a component (along with something else) however then right click and "Save as..." Later when you clean up your guides, right click on this component again and "Reload".
I know it's a poor workaround but should do it.
Postby TIG » Sun Jul 10, 2011 1:45 pm
There are several tools knocking around that I and others made ages ago...
Mine erases only those guide-lines or guide-points or both in the active context or current selection or 'all' if there's no selection - see here viewtopic.php?p=341048#p341048 [I just modernized it a bit]
Global Moderator
Postby boilingsnow » Sun Nov 13, 2011 3:45 am
Thank you Rich O'Brien!
But the weld draw doesnt work by me.
It always start from the origin point so I can't draw the line I want.
Can you tell how to fix it?
boilingsnow
Postby irwanwr » Sat Dec 24, 2011 9:14 pm
:thumb: i am going to use this often
thank you
irwanwr
Postby eyein12 » Fri Dec 30, 2011 9:29 pm
:thumbd: all pens draw from origin and thats it. is there something i'm missing
eyein12
Postby Rich O Brien » Fri Dec 30, 2011 10:15 pm
:roll:
It works fine for me. So, you must be missing something.
Rich O Brien
Administrator
Postby Gaieus » Fri Dec 30, 2011 10:17 pm
:lol:
Postby massimo » Fri Dec 30, 2011 10:35 pm
:roflmao:
massimo
Postby Gaieus » Fri Dec 30, 2011 10:43 pm
Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
Postby Rich O Brien » Fri Dec 30, 2011 10:48 pm
I was nice :roll:
Rich O Brien
Administrator
Postby Gaieus » Fri Dec 30, 2011 10:54 pm
I know. Me too. I was even happy! (And Massimo even happier) :)
Postby eyein12 » Sat Dec 31, 2011 2:19 am
Gaieus wrote:Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
Lol I see you guys have a good sense of humor. I'm sorry for the harsh post. I model 3d trains for railworks 2012 train simulator and was interested in this pen tool. But for some reason it draws an edge from the origin everytime instead of a series like the pencil tool. do you guys know what is wrong? I have sketchup 8 pro. the newest patch too. Thanks for the help! :D
eyein12
Postby Gaieus » Sat Dec 31, 2011 2:42 am
OK, now we are talking.
I cannot even imagine what may be going on there. Which tool are you actually using? (There are a bunch of them in here) Where are you starting the lines? I also have the latest SU build and have no issues at all.
Postby eyein12 » Sat Dec 31, 2011 2:51 am
Gaieus wrote:OK, now we are talking.
well I got this pen tool+ v1.4 found here http://rhin.crai.archi.fr/rld/plugin_de ... hp?id=854; is this the same as the one in this thread?
I start my line just from the origin of SU to practice using this tool. but using the pen tool there are 6 different types of which only the guide pen works correctly. when i draw, it starts from the origin and ends at the endpoint, then it starts again from the origin rather than from the endpoint, unlike the pencil tool.
eyein12
Postby mitcorb » Sat Dec 31, 2011 3:53 am
Is your Template or Style setting part of the problem? Or is your precision set too high? Or are you modeling some really tiny items? I don't know, just trying to shake some ideas.
mitcorb
Top SketchUcator
PreviousNext
Return to Plugins
cron
Users browsing this forum: akarka, Arnold017, Erdy_Arch, izigower, yeroya1867 and 12 guests
