SketchUcation Premium Membership
[Plugin] Sketchup Ivy 0.6.3 20110513
Re: [Plugin] Sketchup Ivy 0.1 20110427
Postby Lobster » Wed Apr 27, 2011 1:53 pm
Replaced the tool as suggested,
Ruby Window output on activating plug in is
Error: #<ArgumentError: wrong number of arguments (0 for 1)>
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in `activate'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in `select_tool'
When clicking to grow it is this
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in `add'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in `getExtents'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in `refresh'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in `onLButtonDown'
Regards
Sam
Lobster
Operating system: Mac
SketchUp version: 8
License type: Free
SketchUp use: other
Re: [Plugin] Sketchup Ivy 0.1 20110428
Postby Dave R » Wed Apr 27, 2011 1:58 pm
Pierreden wrote:@Dave: Uploaded a new version in the Top post. Try that one :thumb:
C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
(20.7643", 4.678738", 0")
#<Sketchup::Face:0x8a963e0>
Faces: 1
10 / Branches: 1 / Live Branches: 1 / 0.016
Nor red lines or branching either. :(
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby Oxer » Wed Apr 27, 2011 2:00 pm
Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n]/SketchUp/plugins (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
http://www.oxervision.blogspot.com/
Oxer
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Pierreden » Wed Apr 27, 2011 2:05 pm
Sorry Guys! The file i updated 10 minutes ago was actually a downdate :roll: Sorry for the inconvenience. The new one should work.
Pierreden
Postby robert111 » Wed Apr 27, 2011 2:07 pm
andre51
how to make leaves with this plugin plzzzzzzzzzzz
i like you ivy very nice
can you make tutu for your ivy setting plz
robert111
Postby Pierreden » Wed Apr 27, 2011 2:13 pm
robert111 wrote:andre51
Thats from the original standalone plugin foud here
Leaves will soon be available in this plugin too, but isnt at the moment ;)
Pierreden
Postby Oxer » Wed Apr 27, 2011 2:13 pm
I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
Oxer
SketchUp version: 8
License type: Pro
Postby TIG » Wed Apr 27, 2011 2:31 pm
The Tool class activate doesn't have arguments (initialize can)
Code: Select all
def activate(view)
  puts view
line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
It could be
Code: Select all
def activate
  puts Sketchup.active_model.active_view
with little use??
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby andre51 » Wed Apr 27, 2011 2:39 pm
Hi Robert111
Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
Regards
Andre
andre51
Postby Pierreden » Wed Apr 27, 2011 2:47 pm
TIG wrote:The Tool class activate doesn't have arguments (initialize can)
Code: Select all
def activate(view)
  puts view
It could be
Code: Select all
def activate
with little use??
Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
Pierreden
Re: [Plugin] Sketchup Ivy 0.1.5 20110428
Postby Oxer » Wed Apr 27, 2011 5:14 pm
On mac the plugin still does not work, now the Ruby Console appears in blank.
Oxer
SketchUp version: 8
License type: Pro
Postby Fletch » Wed Apr 27, 2011 10:03 pm
Thanks for sharing this plugin. :) I have been waiting a while to see someone implement the ivy generator with SketchUp.
Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. :(
Fletch
Twilight Render
Postby maxosmedia » Thu Apr 28, 2011 9:38 am
Does not work on Mac
maxosmedia
Name: Maxim Zheleznyakov
SketchUp version: 8
License type: Pro
SketchUp use: film and stage
Postby mukul.ar » Thu Apr 28, 2011 7:40 pm
This seems like the beginning of something big... glad to have caught on early..:) will definitely follow this post... all the best..!
mukul.ar
Postby andre51 » Thu Apr 28, 2011 10:02 pm
Really like the plug-in and cant wait for further tweaking!
Thanks again!
andre51
Postby robert111 » Thu Apr 28, 2011 11:17 pm
thnaks andre51
i use fur with this plugin but i haven't nice leaf with fur
can you show your leaf setting with fur plugin plz
robert111
Postby andre51 » Thu Apr 28, 2011 11:41 pm
Hi Robert
I use a leaf component that came with the plants from Solo so I cannot share it here but you can find a lot of ivy on 3D Warehouse. Just load the component somewhere in the drawing and select "make from component" in fur plug-in - you'll see your component listed there. Hope this helps!
Cheers
andre51
Postby Pierreden » Fri Apr 29, 2011 2:57 am
@Mac Users: Really sorry about the plugin not working. I have absolutely no clue what the issue is, but I will borrow a mac this weekend and see what i can work out ;)
@Andre: Thank you! Those renders looks great. What plugin do you use? Im currently looking at the distribution of leaves, and that lookes great :thumb:
I dont know when the next update will be released, but heres a little teaser of whats to come.
cheers
Pierreden
Postby kalu » Fri Apr 29, 2011 4:03 am
Hi Guys:
I read all the comments and when select the plugin and I create the Ivy there is not setup so where is the setup? Can I change something or just grow and grow and that's it?
I place an Image of the plugin installed:
I missing the "Plugins/SketchupIvy/setup.rb" Is an awesome plugin already see the near future.... Thank you for the great design and comments. :thumb:
THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
kalu
SketchUp version: 8
License type: Pro
Postby andre51 » Fri Apr 29, 2011 9:51 am
Hi Pierreden
I use the fur plug in to distribute the leaves.
Cheers
andre51
Postby kalu » Sun May 01, 2011 3:26 am
Can someone respond my question?...
Thanks.
kalu
SketchUp version: 8
License type: Pro
Postby mukul.ar » Sun May 01, 2011 7:25 am
Have you tried sending a PM to Pierreden...? he is best suited to answer your queries... Be a little patient... :)
mukul.ar
Postby Gaieus » Sun May 01, 2011 10:20 am
mukul.ar wrote:Have you tried sending a PM to Pierreden...?
The forums (this topic) is even better as we can all learn from it.
kalu wrote:Can someone respond my question?...
mukul.ar wrote:Be a little patient... :)
Indeed. The plugin is still in an early phase of coding and what we see is just a preliminary "proof of concept". Somewhere Pierre even wrote that he has not made the settings dialogue yet.
(I am also eagerly looking forward to the development...)
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby Pierreden » Thu May 05, 2011 7:25 pm
Thanks.
Im sorry for my late reply. I have uploaded a new version which includes a gui!
@everyone: Realy hope version 0.3 solves some of yout issues. It feels both faster and more stable on my computer, but if/when you experience problems, bugsplats or bugs, please pm me or write here. I will answer you as quick as possible.
Also, f you have any suggestions regarding further development i would love to here them! :thumb:
Regards
Pierre
Pierreden
Re: [Plugin] Sketchup Ivy 0.3 20110505
Postby solo » Thu May 05, 2011 7:48 pm
Cool UI.
One issue, if you close it you cannot open it again.
My site
Quod gratis asseritur, gratis negatur.
solo
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Pierreden » Thu May 05, 2011 8:01 pm
solo wrote:Cool UI.
Thanks for your reply... could you elaborate? I cant recreate it on my system... Are you on a mac? Sketchup 8? And how do you close it?
Regards
Pierreden
Postby solo » Thu May 05, 2011 8:16 pm
Sure.
I opened the UI (from plugin menu) I started creating ivy but decided my ball (wanted it to grow over ball) was too big, so I exited by clicking the close X, resized the ball and tried to start Ivy again, it was checked in menu by no matter what I did the UI did not show again.
My site
solo
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby pugz1983 » Thu May 05, 2011 8:41 pm
solo wrote:Sure.
Same here,
I do like the way this Ivy plugin is going. Nice interface, and I thank you are on the right track. Simple Ivy can be made, and i did a few testrenders with indigo and the results are nice. But for large walls covering Ivy you have to make several seperaty ivy bushes I think because of bugsplat when going over 150 branches. But thanxs for the hard work so far, Keep it up and this wil be a very welcome plugin :D
Greetz Pugz
pugz1983
Postby lele_poggi » Thu May 05, 2011 10:29 pm
Great work!!! :sketchstatic:
Gabriele Sacchi
V+S architetti
http://www.vsarchitetti.it
lele_poggi
Postby esteromx » Fri May 06, 2011 2:18 am
reported the same problem as Solo, this problem appears only when you try to put leaves on the vine
esteromx
SketchUp version: 8
License type: Pro
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Plugins
Users browsing this forum: arklandesign, Arty2, Google Bot, PatrickVinther, Renderiza, sm501212 and 7 guests
