SketchUcation Plugin Store
[Plugin] Sketchup Ivy 0.6.3 20110513
Re: [Plugin] Sketchup Ivy 0.6.3 20110513
Postby Rodrigonotor » Tue Jul 31, 2012 1:45 am
thanks, now it´s working
Rodrigonotor
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Postby thomthom » Tue Jul 31, 2012 8:31 am
:thumb:
Global Moderator
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby pibuz » Tue Jul 31, 2012 12:07 pm
..I still can't figure out how to install and make this plugin properly work :lol:
I've downloaded the new addition by Pejman, but same error message when loading (something about not being able to insert an empty component..).
Moreover, no toolbar shows up.....
I'm no noob, but I really can't figure this out :lol:
visit my blog! (italian language)
www.filipposcarso.blogspot.com
pibuz
Postby Krisidious » Tue Jul 31, 2012 12:28 pm
delete your LiveIvy folder in side your plugins folder. make sure you have no plugins for liveivy inside your plugins folder.
reinstall by opening the last zip folder and dragging the plugin and folders into your plugins folder.
you'll need to restart sketchup. go to toolbars and turn on the liveivy toolbar.
should work. make sure that there are ivy components in your "Plugins\LiveIvy\Textures" folder.
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
Krisidious
SketchUp version: 8
License type: Pro
Postby charly2008 » Tue Jul 31, 2012 12:28 pm
HI
I installed the "LiveIvy 1" but there are generated only strains and no leaves. Am I doing something wrong? In the Ruby Console is displayed, see below.
Problem solved: I had forgotten to press the ctrl key.
Charly
More dangerous than ignorance is the illusion of knowledge
charly2008
SketchUp version: 7
License type: Pro
SketchUp use: historical reconstruction
Postby Krisidious » Tue Jul 31, 2012 12:34 pm
look at tips in the console. you'll have to grow the ivy branches and then hit ctrl click to put leaves on. you'll see green markers where leaves are going to be located. then hit shift click to finish.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby charly2008 » Tue Jul 31, 2012 12:40 pm
Hi Krisidious,
Thank you for your help
Charly
charly2008
SketchUp version: 7
License type: Pro
Postby Krisidious » Tue Jul 31, 2012 12:43 pm
no problem I guess you figured it out before I even got my response in. have fun and feel free to post some examples. and settings to go with them.
would love to add some presets to this plugin.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby charly2008 » Tue Jul 31, 2012 12:52 pm
Maybe you can help me again. Now the leaves are not transparent! The problem was treated in an earlier post but I could not find it until now.
Charly
charly2008
SketchUp version: 7
License type: Pro
Postby Krisidious » Tue Jul 31, 2012 1:11 pm
I had to go in and edit each component and it's material. each material source needs to be a .png file for transparency. and then I hid the line edges and saved the component. let me see if I can upload mine.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby Krisidious » Tue Jul 31, 2012 1:17 pm
ok here are 3 of them transparent with hidden edges. be warned they are saved in version 8 so that may affect lower versions running this plugin.
Ivy_leaves_Transparent.zip
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby pibuz » Tue Jul 31, 2012 2:43 pm
Krisidious wrote:delete your LiveIvy folder in side your plugins folder. make sure you have no plugins for liveivy inside your plugins folder.
I did exactly like this, last time. Just to make sure, I re-did that and it's just the same: "can't insert empty component" (I'm translating the message from italian). Under "View->toolbars" there is no option to turn on the LiveIvy toolbar. If I choose the tool manually, I can generate the red lines and leaves, but generating the actual geometry leads to no real geometry but a simple black line over the first stem's position (no leaves and no additional stems).
..your latest post also makes me wonder if these problems could be generated by base components saved in SU8 format..If so, could anybody convert them to the previous version, to maximize compatibility?
pibuz
Postby Rodrigonotor » Tue Jul 31, 2012 2:50 pm
charly2008 wrote:Maybe you can help me again. Now the leaves are not transparent! The problem was treated in an earlier post but I could not find it until now.
Charly
Hi Charly, he`re others
viewtopic.php?f=323&t=36882&p=409877&hilit=sketchup+ivy#p409877
regards
Rodrigonotor
SketchUp version: 8
Postby charly2008 » Tue Jul 31, 2012 3:34 pm
Hi Kristoff,
thank you for your friendly help. With your files, it works fine. Thanks also to the others.
I've tried similar to your example to do this with the Wisteria flowers and leaves. But the old leaves are still present, although only the Wisteria pngs are in the Texture directory.
I probably have not understood how it works or I'm too stupid.
Charly
charly2008
SketchUp version: 7
License type: Pro
Postby ehitel » Fri Aug 17, 2012 7:05 pm
How can i make to them from more close to de wall?
ehitel
Postby Thiago Luz » Sat Sep 15, 2012 2:55 pm
When I SHIFT + CLICK nothing happens ... creates just one line ends and not the creation of branches and leaves ... what's wrong??
Thiago Luz
Postby smooge » Wed Sep 26, 2012 10:50 am
i can not get this to work at all! on mac with su8 have looked thro forum and still no help? is thare sumthing rong with what im doing?
smooge
Postby thomthom » Wed Sep 26, 2012 11:01 am
smooge wrote:i can not get this to work at all! on mac with su8 have looked thro forum and still no help? is thare sumthing rong with what im doing?
You'll have to explain more detailed what "isn't working".
No menus? Error messages? Unexpected results?
Global Moderator
SketchUp version: 8
License type: Pro
Postby smooge » Wed Sep 26, 2012 12:59 pm
sorry! when i click on an object in the space it dos nothing at all i can see all the plugin and looks like it will wurk but wen i click nuthing happens?
smooge
Postby thomthom » Wed Sep 26, 2012 1:00 pm
smooge wrote:sorry! when i click on an object in the space it dos nothing at all i can see all the plugin and looks like it will wurk but wen i click nuthing happens?
If you keep the Ruby Console open, do you get any error messages?
Global Moderator
SketchUp version: 8
License type: Pro
Postby smooge » Wed Sep 26, 2012 1:03 pm
yes!
MX: unloading Fire data
MX: load => plan 12-09-11
smooge
Postby smooge » Wed Sep 26, 2012 1:07 pm
sorry no that is from maxwell i think!
smooge
Postby craigcampbell66 » Wed Oct 03, 2012 5:19 am
Some help with Sketchup Ivy appreciated. I have downloaded/installed and run the plugin fine although there was an error message at installation and each time I start the plugin(capture). My issues are that The leaf 2 and 3 have a white background displayed in model and when rendered. see image capture1. The material editor in Sk8 has leaf 1 as a .tif and 2 and 3 as .jpg's. I thought I could just go into the folder in plugins find the images and convert them to tifs to give a see through background but therein lies my problem. I can't find the plugin or folder where I extracted it to nor in any of the sub folders of sketchup. I have tried to reinstall (both extract to and copy from a separate location) but it says the file is already there and would I like to overwrite it?? Given I can't find it I can't remove it to try and re-install again in case the initial was corrupted ie the white backgrounds. Thanks to Pierre though for what looks like a great plugin once I get it sorted.
Thanks also to whoever is able to assist
craigcampbell66
Postby gilles63 » Sun Oct 21, 2012 12:18 am
it works actually quite well for me, at least on windows . A few things are a bit mind boggling , like for example why it generate ghost leaves components that appears in textures and components editors, but once you replace the awfull leaves in the folder textures with decent ivy leaves components ( be sure to give them the same name, ivyleaf_1 etc, it looks as good as the original plugin . More, you can always reload the components with others to create climbing roses, bougainvillea etc . I ll post some of my components tomorrow .
gilles63
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby gilles63 » Sun Oct 21, 2012 12:33 am
gilles63
SketchUp version: 8
License type: Pro
Postby gilles63 » Sun Oct 21, 2012 7:46 pm
ok, here are new more realistic ivy leaves and components for a climbing rose . Just delete everything in the plugin's texture folder except the branch texture and replace them with the ivy leaves components you ll find in the Zip file ( ivyleaf_1 . 2 . 3 ) et voilà , you can now grow your ivy . If you want to make a climbing rose, grow an ivy then reload the ivy leaves with the roses components contained in the zip file
gilles63
SketchUp version: 8
License type: Pro
Postby Oxer » Mon Oct 22, 2012 3:37 pm
gilles63 wrote:ok, here are new more realistic ivy leaves and components for a climbing rose . Just delete everything in the plugin's texture folder except the branch texture and replace them with the ivy leaves components you ll find in the Zip file ( ivyleaf_1 . 2 . 3 ) et voilà , you can now grow your ivy . If you want to make a climbing rose, grow an ivy then reload the ivy leaves with the roses components contained in the zip file
Thanks, very useful!! :thumb:
http://www.oxervision.blogspot.com/
Oxer
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby gilles63 » Mon Oct 22, 2012 5:12 pm
you are welcome , and myself i must thank Pierre for a great plugin . This textures can be improved, especially the roses, and i realise that some axis should be changed, the leaves tend to hang in the same direction, but i ll work on it and post a better version in the next days .
gilles63
SketchUp version: 8
License type: Pro
Postby gilles63 » Sun Oct 28, 2012 4:12 pm
like promised, i worked on the components . My apologies by the way, i realised that the leaves components for the roses was seriously so underscaled that it became invisible . Anyway, here is a better one with a 3d flower and components to create a bougainvillea . I think it looks quite good . My advice would be to manually edit the model by removing blooms or leaves where necessary . Besides, the model can be quite heavy, lets say around 5 Mb for an average climbing rose .
gilles63
SketchUp version: 8
License type: Pro
Postby gilles63 » Sun Oct 28, 2012 4:23 pm
quick render
gilles63
SketchUp version: 8
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to Plugins
Users browsing this forum: antoniovelludo, dan19936, McGyver, nabou, neda and 11 guests
