[Plugin] Sketchup Ivy 0.6.3 20110513Re: [Plugin] Sketchup Ivy 0.6.3 20110513Hi,
I've recently experimented a bit to produce a Wisteria. Unfortunately I was not so successful. Then I have reinstalled the "0.63 beta". The result is now that no Ivy texture appears and Wisteria leaves also still appears. What is wrong? Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I do have a couple of those installed as well. But I think it due to the sketchy physics, I installed this lately and before that it was always working. But I got it to work again after changes to lines of code (see tomasz's tips) there's one doneside on that. I hardly renders leaves know!? So I think I need to take a closer look now.
What's also weird is that io never got your version to work in iether su7 or 8, I would only work in su6.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Charley,
are the Materials showing up in the browser when you launch Ivy? and does the script have Tigs mod?? john
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Hi John,
no, only the material for the tribe. Yes I have installed the "TIG mod". Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513did you try it without the mod... john
Re: [Plugin] Sketchup Ivy 0.6.3 20110513John,
yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here? Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that... john
I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy! Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Dear members,
I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Problem solved. The png was saved in my template.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update.
THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Hi Rombout,
Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513You seem to be going round in circles.
This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files... Replace those in the Textures folder... Retry... Please, register (free) to access all the attachments on the forums. TIG
Re: [Plugin] Sketchup Ivy 0.6.3 20110513TIG,
I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum. Charly More dangerous than ignorance is the illusion of knowledge
Re: [Plugin] Sketchup Ivy 0.6.3 20110513you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
Did you mean, "it would be nice with" or "Could you please"? Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.) Thomas Thomassen — SketchUp Monkey & Coding addict
Now you do some work resetting your values manually... TIG
Re: [Plugin] Sketchup Ivy 0.6.3 20110513sorry for my english at first. not my native - in russian i mean that this option will be very usefull. and of course thanks for that plugin. sorry if i offend somehow someone of developers. sorry please
ps. in russian it's a little bit more words need to be said of simple -you need to make- Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513No worries.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513still not on the wall ((( picture above. where's my mistake?
I don't even have this tool installed ! The default adhesion seems to be 50 in the code I posted... Why is yours 0.2 [20?] ?? Presumably the higher the adhesion value the more it sticks to the wall ??? TIG
that's it ) maybe i know english - but no so good till that time. and 0.5 become working not from next ivy, from third. But problem is solved - thx. better to rename adhesion to -sticking-
Re: [Plugin] Sketchup Ivy 0.6.3 20110513it won't work properly again, with -adhesion- 0.5 it's still grow in every direction. what's wrong with me? please help me to understand.
ps. it's skp file in archive, my model in wich ivy goes crazy. maybe problem it it? Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Wow Ivy Generator is great, but im having a problem importing the file back into SU, i can export my model from SU into Ivy Gen but when i import it to SU it freezes SU and never recovers, im using free version of SU and using obj importer, any suggestions would be great
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I dropped file into plugins folder but it is not showing up in sketchup...I noticed the file is .rar, not a rb file. What is the secret?
Doh! A .rar file is a compressed file - like a .zip file - just made by another application. So, like with a zip file you must extract its contents - i.e. the .rb file and intact subfolder[s] of miscellaneous files that then go into the Plugins folder. There's a sticky-post in the Plugins Forum about installing tools from zip files - read that - substituting 'rar' when it says 'zip'... TIG
Re: [Plugin] Sketchup Ivy 0.6.3 20110513momentary lapse of reason....got it.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I tried all 3 versions, none worked properly, but after reading all 25 pages of forum, and about an hour and a half of loading and re-loading plugins,
it's FINALLY working well for me, hope it stays that way. Rendering in Thea,but the alpha channels do not import, but no big deal, I do it manually, and renders just fine. Thank you Pierreden.
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
