[Plugin] VisTools
Re: [Plugin] VisTools
Postby Dan Rathbun » Sat Jan 05, 2013 7:09 am
    UPDATE v1.3.2
    Pushed update into a forked GitHub online repository at:
    https://github.com/DanRathbun/sketchup-vistools
    :ugeek:
    Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
      I'm not here much anymore. But a PM will fire email notifications.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Sun Jan 06, 2013 2:03 am
        UPDATE v1.3.3
        Added Asian language support:
        • Chinese Simplified (zh-CN) language support by Xiao Long (guanjin)
        • Other Asian language support files (preliminary):
          • Chinese Traditional (zh-TW)
          • Japanese (ja)
          • Korean (ko)
        THANK YOU to :
        • Xiao Long (guanjin)
            Chinese Simplified (zh-CN) language file.
        :ugeek:
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby risoto1978 » Tue May 20, 2014 1:42 pm
          Hi ishboo, the plugin is great but unfortunately "isolate selected layers", "isolate selected entities" and "freeze" and "unfreeze" does work."Hide selected layers" and "show all layers and entities" work perfectly. I formerly used the hide tool within the SCF selector toolbar but unfortunately this toolbar is not available fro SU 2014. I work with SU 2014. Can you help?
          risoto1978
          Postby Dan Rathbun » Tue May 20, 2014 4:28 pm
          This has not been tested under SU2013 nor SU2014.
          WHAT commands DO NOT work ????
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby josephkim626 » Tue Mar 08, 2016 11:37 am
            Dan Rathbun wrote:
              UPDATE v1.3.3
                • Japanese (ja)
                • Korean (ko)
              THANK YOU to :
              :ugeek:
              what, I didn't know you speak korean Dan. :D
              I don't mind helping out the language review, but I want to avoid installing another version of SketchUp in Korean :/
              josephkim626
              Postby Dan Rathbun » Sat Mar 12, 2016 12:22 am
              josephkim626 wrote:what, I didn't know you speak korean Dan.
              I don't. I used Google Translator and Bing Translator. I have no idea if my translations are cussing a ppl, or not.
              josephkim626 wrote:I don't mind helping out the language review, but I want to avoid installing another version of SketchUp in Korean.
              You can load the files in a code editor.
              I use Notepad++ on Windows.
              The files must be saved in UTF-8 encoding.
              The Vistools loader ruby in the "Plugins" folder has the descriptions in it, and the korean setting is this:
              @@plugin.description = %q{VisTools:(비전 도구) 몇 가지 유용한 엔터티를 추가 하 고 표시 도구에 Sketchup 에서 레이어: 숨기기, 표시, 동결 및 해 동}
              In the plugins' folder is a "VisTools_ko.rb" file with the other UI strings which looks like:
              Code: Select all
              # encoding: UTF-8
              #  THIS FILE MUST BE SAVED IN ENCODING:  "UTF-8 WITHOUT BOM"
              module IntrepidBear  # <--<< Dana Woodman's proprietary toplevel namespace
                module VisTools    # <--<< THIS plugin's nested namespace
                  #{# MODULE VARIABLE LANGUAGE HASHES
                    # --====  KOREAN  ====-- #
                    @@menutext = Hash[
                      :plugin_name,      "비전 도구",
                      :hide_layers,      "레이어 숨기기",
                      :isolate_layers,   "분리 레이어",
                      :hide_entities,    "엔티티 숨기기",
                      :isolate_entities, "엔터티를 분리",
                      :freeze_entities,  "고정 그룹 및 구성 요소",
                      :unfreeze_all,     "고정 취소 모두",
                      :show_all,         "모두 표시",
                      :debug_mode,       "디버그 모드"
                    @@tooltips = Hash[
                      :hide_layers,      "선택한 레이어 숨기기",
                      :isolate_layers,   "선택 된 도면층 분리",
                      :hide_entities,    "선택한 엔티티 숨기기",
                      :isolate_entities, "선택 된 엔터티가 분리",
                      :freeze_entities,  "그룹 및 구성 요소 동결",
                      :unfreeze_all,     "모두 고정 취소",
                      :show_all,         "모든 레이어 및 엔터티 보기"
                end # module VisTools
              end # module IntrepidBear
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby josephkim626 » Tue Mar 22, 2016 12:51 pm
                @@plugin.description = %q{VisTools:(VisTools) 스케치업에 레이어와 객체 제어를 돕는 숨기기, 표시, 동결 및 해동 등의 기능을 추가.}
                @@menutext = Hash[
                :plugin_name, "Vistools",
                :hide_layers, "레이어 숨김",
                :isolate_layers, "레이어 분리",
                :hide_entities, "객체 숨김",
                :isolate_entities, "객체 분리",
                :freeze_entities, "객체 동결",
                :unfreeze_all, "모든 레이어 및 객체 해동",
                :show_all, "모든 레이어 및 객체 표시",
                @@tooltips = Hash[
                :hide_layers, "선택 된 레이어 숨기기",
                :isolate_layers, "선택 된 레이어 분리",
                :hide_entities, "선택 된 객체 숨김",
                :isolate_entities, "선택 된 객체 분리",
                :freeze_entities, "선택 된 객체 동결",
                :unfreeze_all, "모두 레이어 및 객체 해동",
                Above is the parts of the code that you have included perhaps better explains your plugin.
                I have short experience in translating programs/documents. I think this would do.
                The description of Vistools didn't really mean anything as the sentences were in shuffled order. I've kept the name in English as I am not sure direct translation really gives you any benefit.
                Just so you know, you didn't really offend anyone :-P
                Dan Rathbun wrote:The Vistools loader ruby in the "Plugins" folder has the descriptions in it, and the korean setting is this:
                Code: Select all
                # encoding: UTF-8
                      @@menutext = Hash[
                        :show_all,         "모두 표시",
                      @@tooltips = Hash[
                josephkim626
                Postby Dan Rathbun » Wed Mar 30, 2016 4:01 am
                josephkim626 wrote:Above is the parts of the code that you have included perhaps better explains your plugin.
                Okay, thank you Joseph. You have been entered in the halls of VisTools fame !
                The patch RBZ for your Korean language strings has been posted in the OP of this thread:
                viewtopic.php?f=323&t=49662&p=446865#p446865
                You just install it in the normal manner, and it should overwrite the old "VisTools_ko.rb" file.
                You need to restart SketchUp to load the new strings.
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby josephkim626 » Fri Apr 01, 2016 11:14 pm
                  Thank Dan,
                  I prefer English in most cases, but honored to be on the halls of fame!
                  josephkim626
                  Previous
                  Return to Plugins
                  Users browsing this forum: Talond, xudognik_rus and 16 guests
