SketchUcation Premium Membership
[Plugin] VisTools
Re: [PLUGIN] Utilities
Postby ishboo » Sat Jul 23, 2011 5:12 am
pptoppto wrote:thanks!
3dita wrote:AWESOME utility!!! working just like a 3ds max fundamental tool!!
Must have, congrats :sketchstatic:
You're both welcome! Glad you like it!
SketchUp plugin marketplace: http://extendsketchup.com/
ishboo
Re: [Plugin] Utilities
Postby Dan Rathbun » Tue Aug 23, 2011 11:55 pm
Version 2.x is coming .....
Language translators, and proofreaders needed.
I did the German (de) and Spanish (es) files, and they need proofing. (It's been 35 years since I took Spanish in high school, and I only 'dabble' in German when doing genealogy research.)
The files need to be Unix line endings (EOL) and UTF-8 encoded. They are named "basic_utf8_XX.hash" and "debug_utf8_XX.hash", where XX is replaced by the lowercase language code. (ie: 'en', 'es', 'pl', 'fr', etc...)
The plugin will "auto" find these files, or the user can choose a specific lang from those that are present. (In 'en' mode, the hash files are not actually loaded... as the Ruby code knows what the English strings are.)
<----<<<< PM me if you'd like to do a certain Language translation, or proofread/correct the 'de' or 'es' files.
If a debug hash file is not available for a certain language (but the UI strings in a basic hash file are present,) then the UI will be in that local language, and console output will be in English (if the user has turned it ON.)
So... the priority is on the 'basic' hash files, in order to show the UI elements in the local language.
replaceable parameters
%s will be replaced by a number, like: 34
'%s' will be replaced by an entity flag, like: '#<Sketchup::Face:0x624452c>'
words.txt
NOTE! The above file, and the hash file in the next post, will be used with ver 2.x,... they do NOT work with ver 1.0 (if that's why y'all are downloading, but not volunteering to translate.)
Translator links: Google Translate : MicroSoft Translator
Dan Rathbun
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: education
Level of SketchUp: Advanced
Postby Dan Rathbun » Wed Aug 24, 2011 12:48 am
OK.. here's the basic hash template file:
The 'XX' in the name needs to be replaced with a 2 char. language code.
Within the file, change the "XX" hash values to the local translation.
Please use parenthesis ( ) as I have, and punctuation periods, or '...' where I have, in the translations.
Also repeat the use of capitalized words, as they are in the English keys.
The %s params can be moved in the translated strings, to where they are more appropriate for the particular language.
basic_utf8_XX.hash.txt
Here is the template file for the debug strings.
The technical terms should match those in the localized editions of Sketchup.
debug_utf8_XX.hash.txt
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Wed Aug 24, 2011 2:01 am
    I did the German (de) ..., and they need proofing.
    Good news... Aerilius has volunteered to proof / edit the 'de' German files.
    UPDATE: Aerilius finshed proofing / editing the German 'de' files... great job!
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby Dan Rathbun » Wed Aug 24, 2011 10:20 pm
    Thanks go to Tomot, for knocking out a first edition of the basic Polish 'pl' hash file !!
    UPDATE: We will need a proofreader, who's first language is polish.
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby Dan Rathbun » Thu Aug 25, 2011 3:14 am
    ishboo wrote:
    Jim wrote:Just a note - Toolbar image sizes are 24x24 px for the large size and 16x16 px for the small size. SketchUp does a poor job of resizing your 32x32 icons on the toolbar which is why they don't look as nice as they should. Tool cursors are expected 32x32.
    You're right Jim, I'll have to get around to changing them for the next release.
    This action item is complete: Here's the corrected images, for those of you who want to use them right away with ver 1.0
    Unzip into your "Plugins/SU_Utils" directory (folder) [you can rename the current "images" folder to "images_bak" first if you desire.]
    images.zip
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby thomthom » Thu Aug 25, 2011 7:29 am
    You can try the translaters I used: http://www.thomthom.net/software/vertex ... anslations
    Global Moderator
    SketchUp version: 8
    License type: Pro
    SketchUp use: architecture
    Postby Dan Rathbun » Thu Aug 25, 2011 6:24 pm
    Thanks go out to Defisto for proofing and editing the Spanish 'es' files !!! :berserk:
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby Dan Rathbun » Thu Aug 25, 2011 6:35 pm
    Added the "debug" string template file in the post above...
    see: viewtopic.php?f=323&t=36465&p=350210#p350210
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby ishboo » Thu Aug 25, 2011 6:49 pm
    Great to see all this activity!
    ishboo
    Postby Pilou » Thu Aug 25, 2011 8:55 pm
    I am on the road for the French language! ;)
    Speedy Galerie
    Pilou
    Top SketchUcator
    SketchUp version: 6
    License type: Free
    SketchUp use: hobby
    Postby Gaieus » Thu Aug 25, 2011 9:29 pm
    I can do some Hungarian - need to install the plugin and see what it exactly does so that I understand why the expressions are what they are.
    Administrator
    SketchUp version: 8
    License type: Pro
    SketchUp use: historical reconstruction
    Postby ishboo » Thu Aug 25, 2011 9:33 pm
    Pilou wrote:I am on the road for the French language! ;)
    Excellent!
    ishboo
    Postby Pilou » Thu Aug 25, 2011 9:42 pm
    limit=%s
    I have translated the word "limit" by "limite" in French : must or not ? (I suppose yes :)
    Not yet tested :oops:
    you must rename them ...utf8_fr.hash.txt I suppose?
    Speedy Galerie
    Pilou
    Top SketchUcator
    SketchUp version: 6
    License type: Free
    SketchUp use: hobby
    Postby Dan Rathbun » Fri Aug 26, 2011 1:27 am
      Looks good... Thank you.
      But... we need the Plugin Description in Francais, Si vous plaît:
      "Adds some useful tools within SketchUp, like Hide / Show entities and layers, Freeze / Unfreeze for components, and Show / Unfreeze all."
      Combination of Google & Microsoft Translators:
      "Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Gel / Dégel pour des composants, et de Montrer / Dégeler tous."
      Sound OK ??
      Dan Rathbun
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Postby Pilou » Fri Aug 26, 2011 2:18 am
      Quasi perfect ;)
      "Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Geler / Dégeler pour des composants, et Montrer / Dégeler tous."
      Speedy Galerie
      Pilou
      Top SketchUcator
      SketchUp version: 6
      License type: Free
      SketchUp use: hobby
      Postby Dan Rathbun » Fri Aug 26, 2011 4:14 am
      OK.. thanks Pilou ... got and updated the file.
      FEI (For Everyone's Information): I finally quit "fiddling" and sent Dana the "FreezeTools" ver 2.0.0 package, so he can have a first look. He'll likely put the package up on Github, until we are satisfied, that there are no major issues. Then he or I, will put the package on the EXTENDSketchup site.
      Known "to do":
      1. Reformat and expand the Help html file.
      2. Tweak the "All" commands so they are correctly walking the nested groups / components, and performing their tasks the way they should.
      3. Make sure if possible we do not have strange behavour during Undo and Redo operations.
      Dan Rathbun
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Postby Dan Rathbun » Fri Aug 26, 2011 8:07 pm
      Note: Dana will be away till late next week (Thursday or so,) and will not be able to begin reviewing the new version til then.
      Your patience is appreciated.
      Dan Rathbun
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Postby ishboo » Fri Aug 26, 2011 9:54 pm
      Actually, I'll be back around the 5th of September :/
      ishboo
      Postby bimboombang! » Tue May 15, 2012 10:27 pm
      THE ISOLATE LAYER DOESN'T WORK. i'M RUNNING SKETCHUP 8 PRO.
      Here's the ruby console errors.
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SU_Utils/Utilities.rb:241
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SU_Utils/Utilities.rb:45:in `call'
      Is there a fix or version 2.0 for skecthup 8 pro?
      Thanks. :(
      bimboombang!
      Postby Dan Rathbun » Wed May 16, 2012 12:39 am
      First of all, the Active Layer cannot be hidden, so if you expected that, it will not happen.
      Isolate Layer seems to work OK in my v2.0.0 ...
      I had sent it to Dana for his approval, but he had just started a new job, and was heavily working on the ExtendSketchup plugin... so nothing has happened.
      Dana.. how about if we have TIG and/or ThomThom take a look ??
      Dan Rathbun
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Postby TIG » Wed May 16, 2012 10:35 am
      If you have v1... zip downloaded from the direct link, then it doesn't contain the begin..rescue..end protection of the newer version that you can download manually from the site that is linked to :?
      However, as even this could also jump out of the layer manipulation loop prematurely you can fix the tool's code thus...
      Edit the Utilities.rb file in the SU_Utils subfolder, using Notepad or a similar plain text editor like Notepad++...
      Use its 'Find and Replace' tool to change the two lines of code that say
      l.visible = false
      with this
      l.visible = false unless l == @model.active_layer
      This will stop you trying to make the active layer invisible which is disallowed...
      Save it and restart Sketchup.
      Now the two layer tools that try to switch layers 'off' should work without errors...
      Global Moderator
      SketchUp version: 8
      License type: Pro
      Postby ishboo » Wed May 16, 2012 10:40 pm
      Thanks Dan/TIG for replying! You guys rock.
      ishboo
      Postby dbehrens9000 » Wed Sep 26, 2012 10:27 pm
      Ishboo,
      I use this utility alot with large projects and it no longer works with sketchup 8.0.15158. Could you please check why it does not load? Was there a change in the sdk that conflicts with your ruby scrpit?
      Many thanks,
      David
      dbehrens9000
      Postby ishboo » Thu Sep 27, 2012 9:57 pm
      dbehrens9000 wrote:Ishboo,
      Many thanks,
      David
      Hi David, I will look into and get back to you. I've been working on re-writing the application recently. Will update!
      ishboo
      Postby ishboo » Thu Sep 27, 2012 11:22 pm
      I've finished a new release of the plugin. I've renamed it to VisTools so it's not so confusing and ambiguous.
      ishboo
      Re: [Plugin] VisTools
      Postby Dan Rathbun » Fri Sep 28, 2012 2:18 am
      So you are settling on "IntrepidBear" as your toplevel namespace and filespace, then ?
      Dan Rathbun
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Postby utiler » Wed Oct 24, 2012 11:23 pm
      Hi Dana, nice clean set of Utilities.. well done and thank you on behalf of everyone who has downloaded it!!
      I had a think about the Isolate Entitles: its great to be able to isolate something particularly in a large model when you want to just work on that specifically however it would is just as important to be able to revert back to the entities that were visible. The same applies to the Hide Entities tool: mostly I would think that once you've finished with the hiding what you need you'd want the option to revert back....
      Just a thought
      Thank you again. :thumb:
      utiler
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Postby ishboo » Sat Oct 27, 2012 11:52 pm
      utiler wrote:Hi Dana, nice clean set of Utilities.. well done and thank you on behalf of everyone who has downloaded it!!
      Just a thought
      Glad you like the tool!
      If I understand correctly, you're asking for the ability to "unhide all" which is actually a button on the menu, so you should be able to do that already. I apologize if I'm misunderstanding what you're looking for.
      ishboo
      Postby utiler » Sun Oct 28, 2012 11:54 pm
      Thanks for the reply, Dana.
      I see you have an 'unhide all' botton in the toolset but what I was thinking was if I isolate selected entities I would like to then go back to what I had shown before I did so, not necessarily unhiding all.
      utiler
      Top SketchUcator
      SketchUp version: 8
      License type: Pro
      Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
      Next
      Return to Plugins
      Users browsing this forum: blajnov, dariusdarkelf, Krisidious, slave, Stesosaso and 9 guests
