[Plugin] Voxelize - Updated 2011-04-04
Re: [Plugin] Voxelize - Updated 2011-04-04
Postby TheDro » Sat Jun 11, 2011 2:11 pm
I might eventually get to adding that feature but it's hard to say when. I've been pretty busy this summer and plan to be until September so I might not get to programming any time soon. I just checked out some of the methods of components (instance and definition) and there is a "bounds" method (not found in the api documentation...) which I could use to run my script. This means it should be possible to make it work for components but I might not get to it any time soon.
Have a great summer :D .
TheDro
Postby TIG » Sat Jun 11, 2011 2:20 pm
Of course you could always explode the component-instance and immediately group the highlighted geometry that results... now you have a group to process...
Global Moderator
Postby Dave R » Sat Jun 11, 2011 2:25 pm
That's true, TIG. I guess for no more often than I would use the plugin, that wouldn't be too much trouble.
Global Moderator
Re: Voxelize
Postby leminilab » Sun Jun 12, 2011 2:56 pm
Rich O'Brien wrote:This screams out for Sketchy Physics to drop all those cubes.
:thumb: That's what I thought too!
Can't wait to see that! :bounce:
- "Live every day as if it were your last and then some day you'll be right."
- "ThomThom rules!!!"
leminilab
Premium Member
Premium Member
Postby octopus2 » Thu Jun 23, 2011 11:32 pm
Is there a way of knowing how many cubes were generated?
octopus2
Postby Dave R » Fri Jun 24, 2011 1:18 am
Since the plugin creates the cubes as instances of a component, select one of them and look at the Entity Info box. It'll tell you how many there are.
Global Moderator
Postby TheDro » Fri Jun 24, 2011 1:33 am
If you open up Window>>Ruby Console, before running the plugin, the debug information will tell you how many cubes were created, among other things. The other things are the amount of time each step takes to run. This is probably more helpful to me than to you but remember, this is still in beta :D.
TheDro
Postby Flashhawk » Tue Aug 02, 2011 10:54 pm
You are kidding me right? I mean you must kid me!! I did this by hand last week!!! I was totally not aware of your script and i made a voxelized soldier for a 3d Print project (3mm or 1/600 scale infantry) by overlaying a 3d-warehouse model with a matrix of 30x30x30 voxel and then deleting everything that was not used... (like in Michelangelos "I chipped off everything that did not look like a lion") Man i will so much use this next time!!!! Thanks alot!
Flashhawk
Flashhawk
Postby Dan Rathbun » Wed Aug 03, 2011 4:01 am
TheDro wrote: I just checked out some of the methods of components (instance and definition) and there is a "bounds" method (not found in the api documentation...)
Yes it is.
bounds() is defined in class Drawingelement
Group, ComponentDefinition, ComponentInstance are all subclasses of Drawingelement, so they inherit their superclass' instance methods.
At the console:
Sketchup::Group.superclass()
>> Sketchup::Drawingelement
Sketchup::Drawingelement.superclass()
>> Sketchup::Entity
.. so they also have all Sketchup::Entity instance methods. And Sketchup::Entity is a subclass of Object so they have all of those instance methods, and module Kernel is mixed into Object, so they will have of those methods.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby pilou » Mon Mar 11, 2013 7:41 pm
    Try Qubicle :)
    Speedy Galerie
    Top SketchUcator
    Postby Anton_S » Mon Mar 11, 2013 7:57 pm
    :lol: Does anyone play Minecraft? -- everything is made of cubes
    Anton_S
    PluginStore Author
    PluginStore Author
    Postby Oxer » Thu Nov 28, 2013 12:56 pm
    Thanks for the plugin, I have made an icon for the plugin but I don't know ruby code to create the toolbar for the plugin, if you are insterested here the icons.
    Voxelize Icons.zip
    http://www.oxervision.blogspot.com/
    Oxer
    Postby iasef25 » Tue Dec 03, 2013 11:42 am
    How can I count the the boxes (cubes) after voxelization? Is there any automatic method to count it?
    Thank you.
    Iasef.
    iasef25
    Postby Dave R » Tue Dec 03, 2013 12:00 pm
    iasef25 wrote:Hi,
    Thank you.
    Iasef.
    The answer to your question is just a few posts above yours. It's amazing what you'll see if you spend a few seconds looking. ;)
    Global Moderator
    Postby Box » Tue Dec 03, 2013 12:28 pm
    You can say that again.
    Postby iasef25 » Tue Dec 03, 2013 2:16 pm
    Hi Dave R,
    Thank you so much !
    Iasef.
    iasef25
    Postby pilou » Mon Apr 14, 2014 11:03 am
    Qubicle 2 soon! :D
    Speedy Galerie
    Top SketchUcator
    Postby fionmacool » Sun Aug 31, 2014 11:51 pm
    Cool plugin. Cheers.
    Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
    fionmacool
    Premium Member
    Premium Member
    Previous
    Return to Plugins
    cron
    Users browsing this forum: No registered users and 11 guests
