Any plugin to evenly space objects?
Postby thomthom » Mon Mar 21, 2011 10:51 am
Is there no plugin to evenly space objects?
PluginStore Author
PluginStore Author
Re: Any plugin to evenly space objects?
Postby pilou » Mon Mar 21, 2011 10:54 am
An exemple?
Speedy Galerie
Top SketchUcator
Postby TIG » Mon Mar 21, 2011 10:55 am
My old 'Matrix' tool allows you to matrix copy components in 3d with set spacings in XYZ, and also individual rotation/scaling/handing, randomness etc... look for 'MatrixProximity' [craie?]
Global Moderator
Postby Dave R » Mon Mar 21, 2011 10:57 am
Copy along path?
(pathcopy.rb)
Global Moderator
Postby thomthom » Mon Mar 21, 2011 10:59 am
I don't want to copy anything - just space out existing objects along a vector.
Really thought something like this would have existed already...
PluginStore Author
PluginStore Author
Postby Dave R » Mon Mar 21, 2011 11:02 am
If it does, I don't know. If it really doesn't, it might soon. :)
Global Moderator
Postby TIG » Mon Mar 21, 2011 11:06 am
Like an 'align tool' that aligns ['spaces'] existing objects onto a set 'grid' or along a linear spacing ?
Global Moderator
Postby thomthom » Mon Mar 21, 2011 11:19 am
TIG wrote:Like an 'align tool' that aligns ['spaces'] existing objects onto a set 'grid' or along a linear spacing ?
Yes - like any align and distribute function in graphic applications like Indesign, Inkspace etc...
http://livedocs.adobe.com/en_US/InDesig ... -6ef3.html
PluginStore Author
PluginStore Author
Postby Dave R » Mon Mar 21, 2011 11:27 am
That would be interesting for when you have a bunch of different, unrelated components to deal with.
Global Moderator
Postby thomthom » Mon Mar 21, 2011 11:31 am
Dave R wrote:That would be interesting for when you have a bunch of different, unrelated components to deal with.
Exactly - like I have now.
Since it's such a common feature in other application I thought it would have existed by now. There is an align plugin (only by X,Y,Z axis AFAIK) and no distribute.
I imagine a tool, where you clicked in the model to set the align direction would be good. Object would be sorted along that vector and spaced out evenly.
PluginStore Author
PluginStore Author
Postby Dave R » Mon Mar 21, 2011 11:42 am
So the line would define the line of alignment and distance over which the components would be spaced? Components placed by their origins? How would alignment be determined? Aligned to global axes? In Pathcopy the alignment can be tricky so sometimes for my use it is a bit of trial and error.
Global Moderator
Postby Didier Bur » Mon Mar 21, 2011 12:22 pm
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
Postby Dave R » Mon Mar 21, 2011 12:45 pm
Didier rides to the rescue wearing a white hat! :thumb:
How hard would it be to add an option to space the components evenly along the line?
Global Moderator
Postby pilou » Tue Jul 17, 2012 10:16 am
Speedy Galerie
Top SketchUcator
Postby CadFather » Tue Jul 17, 2012 4:22 pm
no such thing exists (yet) - 'js align' is the closest i've seen to play with the position of objects but of course does not space them. the fact that master Thom himself is asking, is unreasonably worrying... it really is needed.
with all the trickery, surely this can't be too difficult..?
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Tue Jul 17, 2012 6:32 pm
CadFather wrote:the fact that master Thom himself is asking, is unreasonably worrying
Not really - it's not hard - just didn't want to reinvent the wheel. But alas, I never got around to make anything myself... :oops:
PluginStore Author
PluginStore Author
Postby CadFather » Tue Jul 17, 2012 6:52 pm
ok, i feel better now... (at least there's no intellectual property on the wheel!)
CadFather
PluginStore Author
PluginStore Author
Postby JClements » Tue Jul 17, 2012 8:19 pm
I think it would be useful, but tricky to do in 3D.
For instance, equal spacing between objects/groups/components that have a depth, height, and width. Do you use the model axes or the axes of the group/component to determine the spacing in between them (assuming the measurements are taken orthogonally to the axes)?
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
Postby thomthom » Tue Jul 17, 2012 8:35 pm
JClements wrote:For instance, equal spacing between objects/groups/components that have a depth, height, and width. Do you use the model axes or the axes of the group/component to determine the spacing in between them (assuming the measurements are taken orthogonally to the axes)?
If I had made it I would have had toggles for setting the axis it would work in: World, Local, Custom (Tool defining a custom working axis)
PluginStore Author
PluginStore Author
Postby pilou » Tue Jul 17, 2012 11:53 pm
Why do you want not use my little "undrop" plug above? :mrgreen:
Very rustic but works very well :)
First "Align" (or not), "Drop" your objects selected with any plugs existing
Then "undrop" them with my little plug with any measures :enlight:
And then rotate if wanted a special orientation "line" of them as you want !
All takes only seconds ;)
Speedy Galerie
Top SketchUcator
Postby sexypox69 » Fri Sep 12, 2014 1:03 pm
Im kind of late to this topic but has anyone come up with a solution to this.....I come acroos this senerio almost every day with what i do. It would be wonderful to have a plugin which aligns selected objects along a path plus the option of along the axis, be able to specify the distance and have it spaced equally or at a given distant.....like in layout you can align, space and center selected objects......
sexypox69
Postby function » Wed Sep 17, 2014 2:59 am
sam da mitch makes exactly this.
http://sdmitch.blogspot.com
Align&Distribute - Align and space selected objects along an axis.
Haven't spent much time with it, but it wasnt the most intuitive interface, looks great if you follow the console
function
Postby joshuabrew » Wed Feb 14, 2018 10:23 am
hey!
any leads on a plugin for this?? looking for the same... basically the sketchup equivalent of the distribute and align tools common in adobe indesign and illustrator, but for 3D objects in sketchup.
thx!
j
joshuabrew
Postby Dave R » Wed Feb 14, 2018 2:03 pm
joshuabrew wrote:hey!
thx!
j
Hey! Did you try the link in the post immediately above yours from 2014?
Global Moderator
Return to Plugins
Users browsing this forum: No registered users and 6 guests
