SketchUcation Plugin Store
[Plugin]BuildingStructureTools1.92 Apr 28, 2013
Re: [Plugin]Building Structure tools0.2(beta-corrected)
Postby tocthieuso83 » Tue Mar 29, 2011 2:45 pm
Thank you very much! :sketchstatic:
tocthieuso83
Postby tak2hata » Tue Apr 05, 2011 4:31 am
Thanks for a lot of people cheers us!
Japan still seriously,
but we will revive surely,thanks to everyone's assistance.
Thank you really.
I move to the west of Japan now, and am working.
So correcting this plugin seems for a while.
To become more convenient, I want to devise it.
Thank you for you ..true...
by TAK2HATA
tak2hata
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby thomthom » Tue Apr 05, 2011 8:12 am
Take care - all the best!
Global Moderator
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby Elibjr » Fri Apr 08, 2011 5:18 pm
tak2hata wrote:Thanks for a lot of people cheers us!
Thank you really.
Great to see that you are alive and well. take your time with the plugin. Your well being is much more important! Thanks again for it. :enlight:
Elibjr
Premium Member
Premium Member
SketchUp version: 8
License type: Free
SketchUp use: interior design
Postby tulacong » Fri Apr 08, 2011 8:29 pm
tak2hata wrote:Building structure tool for Sketchup
Draw Structures and Modify Easy.
v0.2--solved probrem about reading default first time by TIG.Thanks.
building_structure_tool.zip
This is still a beta version.
It released it though it was early for a moment.
The animation of the operation explanation is here. http://www.youtube.com/watch?v=nr6CXOk1p3s
A very huge earthquake hit Japan.
It made a lot of miserable.
If you feel this tool useful then I want you to donate for 2011 Japanese Earthquake and Tsunamim,please.
It will cheer us strongly.
Thanks.
:sketchstatic: thanks verymuch
tulacong
Postby Uguzzone » Tue Apr 12, 2011 10:44 am
I just made the donation for save the children for japan.
Thanks for the plugin
Uguzzone
Postby Gaieus » Tue Apr 12, 2011 11:34 am
Uguzzone wrote:I just made the donation for save the children for japan.
:thumb:
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby tibet » Sun May 01, 2011 1:28 pm
hi guys,
from some odd reason i can´t recover BST icons.
any idea how to fix it please?
i reinstalled it again without success.
maybe, i miss something, because everything seems to be fine.
thanks!
SU8 Pro + VRay 1.49.90 on Win7 x64
tibet
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Level of SketchUp: Beginner
Postby glro » Mon May 09, 2011 12:55 pm
[quote="tak2hata"]Building structure tool for Sketchup
very efficient
a limitation, though, that makes it useless when you have to draw steel beams that are not parallel to the global axis
changing to a provisional axis system doesn't help
in addition to girder, beam, column, which a re horizontal or vertical, ... would it be possible to draw a structural member in any direction?
glro
Name: Georges LE ROUX
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby alexdobras » Mon May 16, 2011 2:08 pm
a very big thanks for the plugin!
alexdobras
Postby costa » Thu May 26, 2011 8:02 am
a very very good plug-in,. thank you and congratulations
costa
Name: costantine Kyrkitziotis
Postby angel3wijaya » Sun Jun 05, 2011 4:04 am
but its tools not work on my mac.... :roll:
angel3wijaya
Postby angel3wijaya » Sun Jun 05, 2011 4:06 am
Thank you very much
angel3wijaya
Postby millzye71 » Fri Jul 01, 2011 3:07 pm
Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
Cheers
Millzye
millzye71
Postby adiwinardi » Tue Aug 09, 2011 3:30 am
thanks for sharing, this is very helpful. I'm sure the people of Japan will be stronger for the future...
adi
indonesia
adiwinardi
Re: [Plugin]Building Structure tools0.3 update Sep19
Postby tak2hata » Mon Sep 19, 2011 7:44 am
I corrected this script.
The version changes to 0.3.
A very huge earthquake hit Japan. 2011.3.11.
This script was exhibited for that encouragement.
And Japan is becoming fine gradually, thanks to your aid.
Thank you very much.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Re: [Plugin]Building Structure tools0.3 update Sep19n Sep 19
Postby mwm5053 » Thu Sep 22, 2011 4:43 pm
Great plugin, Thanks :berserk: :bounce: needed this for a contractor that builds steel buildings. Maybe some sort of corrugated sheet metal for walls :bounce: plezzzzz.
Will make a donation to children of Japan
mwm5053
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby Edson » Thu Sep 22, 2011 5:44 pm
mwm5053 wrote:Great plugin, Thanks :berserk: :bounce: needed this for a contractor that builds steel buildings. Maybe some sort of corrugated sheet metal for walls :bounce: plezzzzz.
try the metal deck feature in 1001bit pro:
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
SketchUp version: 8
License type: Pro
Postby 66searcher » Fri Sep 30, 2011 9:23 am
well done!
http://hamidtoliat.deviantart.com/
66searcher
Postby tak2hata » Sun Oct 02, 2011 10:37 am
Hi ,mwm5053 and Edson.
I updated BST version to v0.4.
Using "[SHAPE]" for header of profile name.and the skp filename after that.
The skp file for profile must saved in the foleder "plugins¥building_structure_tool¥shapes".
See the animation about addin new profile.
But I think 1001 bit pro is better,because the openning to wall like sheet metal wall is difficult on my tool.
please try them.
thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Re: [Plugin]BuildingStructureTools0.4 updateOct 02, 2011
Postby ptsdr » Tue Oct 11, 2011 10:45 am
Excellent Thk for Post
ptsdr
Name: pinyo tappasarndamrong
Postby raymond » Sat Nov 12, 2011 4:53 am
Can't download it.But it looks good... :(
raymond
Postby Gaieus » Sat Nov 12, 2011 2:01 pm
Raymond, you should be able to download it. What's the problem?
Note in order for the board to work properly, you need to allow browser cookies.
Administrator
SketchUp version: 8
License type: Pro
Re: [Plugin]BuildingStructureTools0.5 updateNov14, 2011
Postby tak2hata » Sun Nov 13, 2011 4:50 pm
Hi,raymond and gaieus and all.
I update this plugin to v0.5 in Nov13.2011.
Raymond..
I will upload on my webpage.(Now still uploaded older version)
Visit there If you do not able to download here.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby raymond » Sat Nov 19, 2011 11:48 am
Thanks a lot. :berserk: :berserk: :berserk: :berserk: :berserk:
raymond
Postby lukestar » Sun Nov 20, 2011 12:44 am
hi,
where do you download the Building Structures Tool from???
lukestar
Postby Dave R » Sun Nov 20, 2011 4:03 am
In the first post of the thread. :roll:
Before you download it, read at least that entire post.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby lukestar » Sun Nov 20, 2011 9:31 am
The Building Structure Tool does not load properly. I go to WEBDIALOG and I do not get any icons???
What's the GO?
Lukestar
lukestar
Postby tak2hata » Sun Nov 20, 2011 3:22 pm
lukestar wrote:Hi
What's the GO?
Lukestar
Hi lukesatr.
I'm sorry.I see that on mac.
I will recover it to work on mac.
Please wait.
I update files.
It will show webdialog with icons on mac.
But can not restore size of webdialog.
I will improve it.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Re: [Plugin]BuildingStructureTools0.5.1 updateNov21, 2011
Postby lukestar » Mon Nov 21, 2011 12:57 pm
I cannot get this Pluggin to work in that there are no tools displayed. I have to install it again, but the same result. Yes went to WEBDIALOG to load the tools but I get a blank panel.
Help?
Luke
lukestar
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Plugins
Users browsing this forum: agmavil, bart82, cdauscher, Gábor, libeskiano, Lil Real and 5 guests
