[Plugin] Roof.rb v3.7 20110926
• Page 3 of 4 • 1, 2, 3, 4
Re: [Plugin] Roof.rb v3.5 20110612I have 8 pro and the plugin works perfectly. There must be something else...
Re: [Plugin] Roof.rb v3.5 20110612wingkingcc
Your 'error report' is pretty useless I what way 'can't you use it' ? Do you have the latest version [v3.5] ? Are there menu items that don't work? Do they appear to work but fails? Is the result not what was expected? Have Window > Ruby Console open and post any errors that appear there... It works fine on all platforms and recent versions of Sketchup... There are no known clashes with other scripts after recent version changes [and a most unusual 'clash' between the new tool 'Artisan' and the older roof 'Roof' was quickly noticed - caused by them both being 'packed' - recent versions of Roof are not 'packed' to avoid this... as if one loaded the other didn't!] TIG
Re: [Plugin] Roof.rb v3.5 20110612thank you so much for this sir.
Re: [Plugin] Roof.rb v3.6 20110918Here's v3.6 viewtopic.php?p=17156#p17156
Errors minimized. Speed greatly improved. Roof-Slope reported in Angle, 1:B and A:12. TIG
Re: [Plugin] Roof.rb v3.7 20110926Here's v3.7 viewtopic.php?p=17156#p17156
A longstanding error/glitch with the 'Gable by Width' option has been fixed [thanks to Mariocha's report by PM!] TIG
Re: [Plugin] Roof.rb v3.7 20110926keep share...
nice,,, ![]()
Re: [Plugin] Roof.rb v3.7 20110926Hipped roof doesn´t work form me. Some bug? I got a error message.
Probably not a bug since it works for others. What was the error message? Inspecting mirrors is a job I could easily see myself doing.
What error ? I'm not psychic... There is a known limitation, it's explained in the Usage Guide and several error messages. It's possible to devise a shape - 'crooked star' etc - than can never have a hipped roof of equal pitches - it's a physical impossibility! Also sometimes the edges of a face get messed up in their order when returned as a 'face loop' [especially after lots of editing] - then it can fail to make a roof that would otherwise have worked - again there are tips on fixing this - e.g. by re-creating the face, or copying it off as a group, exploding it etc, so Sketchup reorders the edges properly and moving it back into place... TIG
Re: [Plugin] Roof.rb v3.7 20110926Your selected face is at z=0... AND it's facing downwards [top face is looking down] !
It's a limitation that a lone face at z=0 will fail... So try moving it up from z=0 [even 1mm will do!] ... [AND you can also try Reversing it using the context-menu]. It should then work OK... TIG
WOW this works for me thanks a lot
