[Plugin] bim-tools 0.13.4(june 22, 2015)
Re: [Plugin] bim-tools 0.13.0(may 21, 2015)
Postby unclex » Wed May 27, 2015 3:04 pm
0.12.4 work fine
but 13.0 cannot work like 12.4 @su2015x64pro
such as several box could be converted to wall&floor by just one click using 12.4
but 13.0, some faces cannot be converted
unclex
Postby brewsky » Wed May 27, 2015 3:11 pm
unclex wrote:0.12.4 work fine
Can you send me an example model (PM?), then I'll check it out.
In my own tests the new 0.13.0 worked on more faces than 0.12.4, so I'm curious... :)
Thanks for posting the issue!
brewsky
PluginStore Author
PluginStore Author
Postby unclex » Wed May 27, 2015 4:26 pm
Now I Know What Happened
12.4 can work under customized catalogue, 13.0 not
and 13.0, if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
BimToolBoxTest.7z
unclex
Postby brewsky » Wed May 27, 2015 9:14 pm
unclex wrote:Now I Know What Happened
Thanks! You're probably right, I also had some trouble changing between models without restarting SU a couple of weeks ago, I thought I fixed that. I will check it out!
brewsky
PluginStore Author
PluginStore Author
Postby brewsky » Mon Jun 01, 2015 10:35 pm
unclex wrote:if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
Okay, I completely uprooted the observers that keep track of the active entities, and it seems much more solid now :D
Can you give it a try before I upload it into the PluginStore?
Thanks!
brewsky
PluginStore Author
PluginStore Author
Re: [Plugin] bim-tools 0.13.2(june 11, 2015)
Postby brewsky » Thu Jun 11, 2015 8:43 pm
New version 0.13.2 online!
Feels much more solid due to improved observers :-D
brewsky
PluginStore Author
PluginStore Author
Postby twillm » Sat Jun 13, 2015 8:38 am
Is bim-tools compatible with mac version of sketchup 2015.
I attempted to install using sketchucation plugin store v2.6.1
Received error messageError Loading File /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb
Error: #<NoMethodError: undefined method `strip' for nil:NilClass>
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:40:in `block in parse_config'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:34:in `each_line'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:34:in `parse_config'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:23:in `initialize'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/clsBtProject.rb:43:in `new'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/clsBtProject.rb:43:in `initialize'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:44:in `new'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:44:in `<module:BimTools>'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:19:in `<module:Brewsky>'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:18:in `<top (required)>'
/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:48:in `register_extension'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:48:in `<module:BimTools>'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:35:in `<module:Brewsky>'
/Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:31:in `<top (required)>'
Any suggestions would be most welcome
twillm
Premium Member
Premium Member
Postby brewsky » Mon Jun 15, 2015 10:05 pm
twillm wrote:Is bim-tools compatible with mac version of sketchup 2015.
Thanks for posting this issue!
I believe it used to work on Mac, but have never been able to test it myself.
I will try to borrow a Mac and check it out ;-)
The error is related to reading the config file, did you by any chance modify that file?
brewsky
PluginStore Author
PluginStore Author
Postby twillm » Tue Jun 16, 2015 5:37 pm
Thank you for the response.
I didn't make any changes to files.
Deleted plugin this morning and reinstalled through sketchucation plugin with similar error message.
twillm
Premium Member
Premium Member
Postby steve69 » Wed Jun 17, 2015 3:52 pm
Unpacked files in plugins folder..
bim-tools.rb
bim-tools folder
@ Sku 7.1 startup
Error Loading File C:/Program Files/Google/Google SketchUp 7/Plugins/bim-tools/bim-tools_loader.rb
No such file to load -- pathnameError Loading File bim-tools.rb
No such file to load -- pathnameError Loading File bim-tools_loader.rb
steve69
Postby Dan Rathbun » Wed Jun 17, 2015 5:19 pm
steve69 wrote:@ Sku 7.1 startup
Really? 6 year old version and 15 releases behind ? (Trimble has long stopped supporting v7.x.)
Does BIM-Tools even support v7.1 ?
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Wed Jun 17, 2015 5:32 pm
    @Jan:
    Single argument String subscripts are one of the breaking changes from Ruby 1.8 to 2.0.
    The workaround is line[0,1], ie., [position, length] or give a range [0..0]
    The single argument will definitely not work in SU2013 and earlier, as Ruby 1.8 returns an integer for the character's position in the ASCII character set.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby brewsky » Sun Jun 21, 2015 8:47 am
      Hmmm I have not been testing on old versions, I'll check it out, maybe it's easily fixed... ;)
      brewsky
      PluginStore Author
      PluginStore Author
      Postby brewsky » Sun Jun 21, 2015 9:08 am
      Dan Rathbun wrote:Single argument String subscripts are one of the breaking changes from Ruby 1.8 to 2.0.
      Hi Dan, thanks for helping out! :) That fixes one error! ;)
      SketchUp even seems to drops out here before the strip-string, on requiring the "pathname" module.
      I guess that's one of the modules that was missing in the old 1.8 stripped ruby environment.
      still some more warnings to wade through I see ...
      brewsky
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Sun Jun 21, 2015 12:02 pm
      brewsky wrote:
      Dan Rathbun wrote:SketchUp even seems to drops out here before the strip-string, on requiring the "pathname" module.
      Yes well it is a Standard Library class (derived from String, I believe.) And the Standard Ruby Library was not included until SketchUp 2014 (when it was released with Ruby 2.0.0.)
      Before that, SketchUp was released with only the Core interpreter.
      SketchUp 7.1 for Windows users can copy the Ruby 1.8.6-p287 DLL from v8 or v2013, back to the v7 program folder, or get it here at SketchUcation:
      ruby-1.8.6-p287-i386-mswin32-dll.zip
      (SketchUp 6 & 7 for Windows was released with the ancient Ruby v1.8.0 [initial release] of the Ruby interpreter.)
      I have packaged the Ruby 1.8.6-p287 Standard Library up for Windows ONLY, as a normal RBZ SketchUp Extension archive. (It installs into a sub-folder as a plugin would.)
      It only loads for SketchUp version 8..13 (or 7.x if the DLL is manually upgraded.)
      https://github.com/DanRathbun/sketchup-ruby186-stdlib-extension/releases/tag/1
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby brewsky » Sun Jun 21, 2015 12:33 pm
        I've been able to remove the dependency on pathname and it's running now on SU7 and SU8.
        Although one (probably showstopper) problem remains. Auto-updating of modified objects does not work on SU7 because the "EntitiesObserver.onElementModified" method was added in SU8.
        That means updating geometry must be done manually by disabling and re-enabling the observers (red/green button).
        New version added to this post, I will add it to the plugin store when I also fixed the MAC issue, but that has to wait a little until I get my hands on a MAC ;)
        brewsky
        PluginStore Author
        PluginStore Author
        Postby brewsky » Sun Jun 21, 2015 12:40 pm
        Hi Dan,
        I also removed a "tap"-call because it was added in ruby 1.9.
        Would you consider this a good substitute? Or would it be much slower?
        Code: Select all
        hash = {}.tap{ |r| bt_entities.each{ |ent| ent.properties_editable.each{ |k,v| (r[k]||=[]) << v } } }
        Code: Select all
        hash = bt_entities.inject({}) {|h,ent| ent.properties_editable.each{ |k,v| (h[k]||=[]) << v}; h}
        something I borrowed from:
        http://stackoverflow.com/questions/5490952/merge-array-of-hashes-to-get-hash-of-arrays-of-values
        brewsky
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Sun Jun 21, 2015 3:44 pm
        Well the 1st thing I had to do is proper indentation:
        Code: Select all
        hash = {}.tap {|r|
          bt_entities.each {|ent|
            ent.properties_editable.each {|k,v|
              (r[k]||=[]) << v
        and
        Code: Select all
            (h[k]||=[]) << v
          h
        Then the 2nd thing, is that Ruby is designed for easily read and understood code. (Why I like it so much.)
        I do not understand why some coders go out of their way, to write minimalist hard to read and understand code. Come back 3 years from now and see if the coder remembers what the code is supposed to do, without spending a half hour consulting method documentation, etc.
        3. Re., inject(), in the past in pre-YARV Ruby, it was notoriously slow. But things have gotten better.
        4. My opinion of tap() is that it might be nifty, but it will serve mostly to contribute to ugly code.
        5. I'd just do it simple like this:
        Code: Select all
        hash = Hash::new {|h,key| h[key]=[] }
          ent.properties_editable.each {|k,v| hash[k] << v }
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby brewsky » Sun Jun 21, 2015 4:04 pm
          Dan Rathbun wrote:.
          LOL Thank you very much! I totally agree with you. It indeed seemed a nifty piece of code I found on stackoverflow, but every time I needed to edit it, it took me half an hour to re-interpret it(and I'm still not 100% sure how the tap works).
          Now you write it out it does not seem so difficult anymore :D
          I should have added the indentation myself the moment I tried to understand what it did :?
          brewsky
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Mon Jun 22, 2015 10:43 am
          brewsky wrote:... and I'm still not 100% sure how the tap works :?
          It is very similar to the map! / collect! methods for Enumerable objects. So you could use map! in place of tap for arrays.
          But, in Ruby 2.0, tap is defined in Object, not just enumerable classes, so every object can "tap" into a block of code that can change and then return itself.
          So tap is kind of like a general purpose "bang" method, but designed for especially for chaining so it always returns it's receiver object, whether it made changes or not. ("Bang" methods usually return nil when they do not make changes to the receiver, making them unsuitable for method chaining.)
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Re: [Plugin] bim-tools 0.13.4(june 22, 2015)
            Postby brewsky » Mon Jun 22, 2015 10:17 pm
            Fix for mac! Menu layout needs some work still.
            Check out the plugin store :-)
            brewsky
            PluginStore Author
            PluginStore Author
            Postby twillm » Tue Jun 23, 2015 7:27 pm
            Thank you for Mac fix.
            Successfully loaded and working.
            twillm
            Premium Member
            Premium Member
            Postby brewsky » Tue Jun 23, 2015 8:16 pm
            twillm wrote:Successfully loaded and working.
            Great! :D
            brewsky
            PluginStore Author
            PluginStore Author
            Postby awadrummer » Fri Jan 18, 2019 1:09 am
            Does anyone know if this plugin is compatible with Sketchup Pro 2018? I'm looking to upgrade, but can't live without this one.
            Thanks,
            Chris B.
            awadrummer
            Postby brewsky » Sat Jan 19, 2019 9:28 pm
            awadrummer wrote:Does anyone know if this plugin is compatible with Sketchup Pro 2018?
            I did a little test and I ran into some issues for su2018 :(
            I will try to find some time to look into them...
            awadrummer wrote:I'm looking to upgrade, but can't live without this one.
            Great to hear you like it!
            brewsky
            PluginStore Author
            PluginStore Author
            Postby awadrummer » Tue Feb 05, 2019 10:04 pm
            Thank you Brewsky! The only issue I've found with 2018 is it freezes/takes a long time to process, but I generally have ALOT of lines. With that being said it is still usable. Thanks for your help and designing this awesome plugin!
            awadrummer
            Previous
            Return to Plugins
            Users browsing this forum: congcusket123, cosmohome, fujihara7033, Google Bot, virus8xx and 12 guests
