SketchUcation Premium Membership
[Plugin] Compo Spray 1.4.2 Updated 13 February 2011
Re: [PLUGIN] Compo Spray 1.4.1 Updated 08 January 2011
Postby charly2008 » Mon Feb 07, 2011 4:36 pm
Now that I have understood correctly, it excites me to return to the experiment.
Charly
More dangerous than ignorance is the illusion of knowledge
charly2008
Operating system: Windows
SketchUp version: 7
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby simon le bon » Tue Feb 08, 2011 2:26 pm
Now I see what it is possible to achieve with Charly, I'm one step more contrite that Compo Spray doesn't work for me :(
-s
simon le bon
Postby Didier Bur » Tue Feb 08, 2011 8:07 pm
Patience Simon... je vais publier la v 1.4.2 bientôt.
With an experimental directional spray:
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby simon le bon » Wed Feb 09, 2011 12:58 am
Ah c'est chouette!!
et le directional spray va décupler les possibilités. :)
(ça mérite la patience ;) )
:fro: :freehand: simon
simon le bon
Postby pep75 » Sun Feb 13, 2011 5:15 pm
Hey Didier!
I really can't get it working...I see the dialog still, I read your manual, pressed Spray but It doensn't do anything....What is wrong?!
Thanks!!
Grtz
Pep
pep75
Postby Didier Bur » Sun Feb 13, 2011 5:43 pm
@pep75: the only thing I can tell is that there is "something" wrong. :D
Seriously, please open the ruby console, launch the tool, and copy-paste-post the error message(s) here, so I can figure out what's wrong.
Or download the version 1.4.2., see top of thread
Didier Bur
SketchUp version: 8
License type: Pro
Re: [PLUGIN] Compo Spray 1.4.2 Updated 13 February 2011
Postby tpstigers » Tue Feb 15, 2011 5:12 am
Top-Down spray works fine. When I try the perpendicular spray, though, I consistently get this error ("This shape is not available yet"):
“I have an existential map; it has 'you are here' written all over it”
tpstigers
Postby Didier Bur » Tue Feb 15, 2011 9:32 am
@tpstigers: Perhaps you didn't red the doc: it is said that this experimental tool only works with the point tool and spray shape tool ;)
Didier Bur
SketchUp version: 8
License type: Pro
Postby tpstigers » Tue Feb 15, 2011 2:11 pm
Didier Bur wrote:Hi,
Thanks. I did read the doc. I guess I should have read it with my brain turned on.
- Terry
tpstigers
Postby Pilou » Tue Feb 15, 2011 2:40 pm
Ah very cool! :fro:
Thx for the resizable Dialogue box! :thumb: :thumb: :thumb:
for the next release : does it possible to have 24 #components?
(it's the 24 possible positions of a "cubic volume")
If you are interested I have yet the script for generated these components
(In python for Blender made by zeauro for 2.56 Blender) :fro:
So import these 24 objects in SU from Blender, then run CompoSpray :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Didier Bur » Tue Feb 15, 2011 10:16 pm
Je n'ai toujours pas capté de quoi tu parles :shock:
Didier Bur
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Feb 15, 2011 10:28 pm
Instead of a limited set of combo boxes, why not have a single listbox where you can select multiple list item? And have any selected in SketchUp also appear selected in the dialog when you open it?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Didier Bur » Tue Feb 15, 2011 10:36 pm
@TT: as said in the doc: "I could have made multi-select lists, but I didn't because you wouldn't have that possibility to "balance" the amount of each component."
Nice idea !
Didier Bur
SketchUp version: 8
License type: Pro
Postby Pilou » Tue Feb 15, 2011 10:55 pm
C'est curieux parce que c'est hyper simple :)
Si j'ai un module cubique (je prends un dé à jouer à 6 faces pour bien figer le concept)
Ce dé à 24 positions possibles dans une boîte cubique de sa taille!
ça c'est évident :)
Si maintenant avec ton plug, je fais tomber ces 24 cubes dans une colonne à base carrée de la taille du dé, et d'une hauteur quelconque(x*le dé) j'ai une colonne composée de modules superposés de façon aléatoire.
Et bien si à la place du dé j'ai un module cubique légèrement plus compliqué, du genre se raccordant sur chaque face mais non symétrique à l'intérieur j'obtiens des métas structures pavant l'espace de manière non périodique! :enlight:
C'est pour cela que j'ai besoin de 24 composants au lieu des 8 actuellement :)
Toute cette bidouille pour simuler ce que je demandais ailleurs, une affection d'une famille de composants (complexes) à un un ensemble de composants "simplex" :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Wed Feb 16, 2011 8:18 am
Didier Bur wrote:@TT: as said in the doc: "I could have made multi-select lists, but I didn't because you wouldn't have that possibility to "balance" the amount of each component."
Global Moderator
SketchUp version: 8
License type: Pro
Postby Didier Bur » Wed Feb 16, 2011 10:06 am
Say you have filled 3 dropdown lists with component named 'A' and filled the other lists with components 'B' 'C' 'D'.
The scripts randowmly selects what component to drop in a list that is, in our case [A,A,A,B,C,D].
That's-to-say, component 'A' has three times more chances to be selected than components B,C, and D.
A multiselect list would only provide a list in which a component appears once.
Didier Bur
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Feb 16, 2011 10:37 am
Gotcha!
Global Moderator
SketchUp version: 8
License type: Pro
Postby zunkian » Sun Feb 20, 2011 8:12 am
Hi Didier!
First of all, thanks for a cool plugin for SketchUp.
Unfortunately, when I am adjusting the dials for altitude, steepness, scale, etc., the dials won't move!
It is sort of locked in their position.
What do you think is wrong?
Andy
zunkian
Postby Didier Bur » Sun Feb 20, 2011 3:40 pm
Several users reported such a weird behaviour of sliders.
I'm still wondering why this happens sometimes.
Please post here what your OS is, what web browser do you use, what version of Javascript is installed on your machine.
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Postby TIG » Sun Feb 20, 2011 4:12 pm
Regards,
I have had terrible problems getting consistency with sliders in webdialogs - what slider are you using ? I use 'tigra' [no connection!] and that seems the simplest and robust...
Global Moderator
SketchUp version: 8
License type: Pro
Postby mitcorb » Sun Feb 20, 2011 6:12 pm
I don't see how French kids ever learn to spell :mrgreen:
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby JClements » Sun Feb 20, 2011 8:26 pm
Hi Didier:
Any chance you could add a "Help" button to the toolbar which would open the PDF file?
Regards, John
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Didier Bur » Sun Feb 20, 2011 11:57 pm
Why not, good idea.
@TIG: I'm using a custom slider programmed in js by K. Gilbert http://kegisiteweb.com/presentation.php. It's copyright free but rather old, that's maybe why it freezes under some specific configurations os/web browser/javascript version ?
It is in the JS folder in CompoSpray folder, and I've only added some trivial functions at the end of the file.
Didier Bur
SketchUp version: 8
License type: Pro
Postby gistman » Mon Mar 14, 2011 8:53 pm
"Plugin downloaded 12179 times" I just wanted to say thank you for all of your work. You and others here have made SU such a great tool.
gistman
Postby mra » Thu Mar 24, 2011 3:41 am
Anyone else getting the error "Cannot place component on selection" when it is just a basic ground mesh and assigning using the "point" method?
mra
Postby manwe » Thu Mar 24, 2011 12:56 pm
I've huge problem with using this plugin. Properties of this plugins is quite high & I've wide screen display so I can't reach the accept button...
manwe
Name: Paweł Czarnopyś
Postby Didier Bur » Thu Mar 24, 2011 4:53 pm
@mra: check your altitudes settings in the dialog, possibly a bug in there :oops:
or did you select anything that isn't face(s) ?
@manwe: click on the Settings icon and tell the script to use sliders in the Style dialog list.
Hope this helps,
Didier Bur
SketchUp version: 8
License type: Pro
Postby rpinkham » Tue Mar 29, 2011 2:57 pm
I'm having some trouble with this tool not covering the selected face completely. It works on most but there are a handful of faces on this triangulated surface that clump my grass proxy together. I am pre-selecting the face and using the "selected faces" option.
Any ideas?
rpinkham
Postby Didier Bur » Thu Mar 31, 2011 10:51 am
@rpinkham: maybe do you have some other faces hidden ?
Didier Bur
SketchUp version: 8
License type: Pro
Postby rpinkham » Thu Mar 31, 2011 2:24 pm
Didier,
Thanks for the reply. There is no hidden geometry. It happens in a few locations in this larger scale site model...
rpinkham
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: arko, boerenkool, Occlusionstudio, ptysiak, S Shepherd, xalocs and 12 guests
