[Plugin] Compo Spray 1.4.2 Updated
Bug!!!
Postby unclex » Fri Jan 21, 2011 8:22 am
if { mx_hidemanager.rb (C) 2010 by Henry Schorradt } this plugin was loaded,
when set [Allow Collision] no, run CompoSpray
SU8Pro crashed.....
unclex
Re: [PLUGIN] Compo Spray 1.4.1 Updated 08 January 2011
Postby dcrites » Sat Jan 29, 2011 1:10 am
Does anyone have a solution for the problem which Pilou posted earlier? I have a 15" HP Laptop running windows 7, with Google Sketchup 8 -
I'm a Landscape Architecture student, so spraying trees rather than placing them individually would be an absolute godsend. But if I can't get to the bottom of the screen, I can't do much. I've tried using the 'tab' key to get to the 'spray' icon, but it doesn't seem to work (though tabbing over to the 'close' icon does. Arg.
768 pixels is the maximum height on my monitor.
dcrites
Postby Didier Bur » Sun Jan 30, 2011 10:51 am
I'll release an update soon with settings for low res screen that will set up scrollbars and modal/non modal dialogs. Easy and quick translation files will be supported as well.
Regards
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby charly2008 » Sun Jan 30, 2011 4:16 pm
Hi Didier,
Thank you for this plugin.
I have a question. I have two entries in the Draw menu, Components and Component Spray. But I do not know what I can delete in the plugins folder. Can you help me please.
Charly
charly2008
Postby charly2008 » Sun Jan 30, 2011 5:23 pm
Problem solved!
I have found it. It is the compo_spray.rb.
Charly
charly2008
Postby Didier Bur » Sun Jan 30, 2011 9:42 pm
Yes compo_spray.rb was an older version. Never have more than one install at a time :lol:
Didier Bur
Didier Bur
Postby arjunmax09 » Sun Jan 30, 2011 10:30 pm
component spray doesn't allow spraying while editing inside a group..how can i do that...??...i have to copy paste the sprayed components inside the group separately...
when you fail at something....you haven't really failed...you've found one way the thing will not work out
arjunmax09
Banned
Postby Didier Bur » Sun Jan 30, 2011 11:36 pm
@arjunmax09: of course you can spray while editing a group or component: double-click on the group/component, click the compoSpray icon and here you go.
Didier Bur
Didier Bur
Postby arjunmax09 » Mon Jan 31, 2011 5:41 pm
yes....i also tried at my home pc..it worked fine...i was working at my groupmate's place on his pc when i posted this question..there i wasn't able to do so :roll: I haven't downloaded this version yet...i.e. the 8th jan 2011 version...
arjunmax09
Banned
Postby charly2008 » Wed Feb 02, 2011 9:07 pm
I installed this update and all is working fine. But i miss the drop down menue i couldn't find (See Image below).
Charly
charly2008
Postby tulacong » Sat Feb 05, 2011 6:41 pm
Great start for 201x :sketchstatic:
tulacong
Postby Didier Bur » Sun Feb 06, 2011 9:48 pm
Hi Charly,
To get this menu, you must select faces PRIOR to click on the icon.
Do you still miss this menu when doing that ? :shock:
Didier Bur
Didier Bur
Postby charly2008 » Sun Feb 06, 2011 11:16 pm
Hi Didier,
the problem still exists.
Charly
charly2008
Postby Didier Bur » Mon Feb 07, 2011 12:35 am
Charly,
I don't see any problem here: the face is selected, so the dropdown list contains "selected faces" and "vertices of faces".
Close the dialog box, unselect all, re-launch compoSpray, it should now display the usual dropdown list , right ?
charly.swf
Didier Bur
Didier Bur
Postby charly2008 » Mon Feb 07, 2011 3:34 pm
Hi Didier thanks,
I tried it again, now I have understood it.
If in the dialog box the component is selected, but no face is selected, than the pull down menu with the shapes is shown.
If in the dialog box the component is selected and the face is selected than the spray type menu is shown.
Charly
charly2008
Postby charly2008 » Mon Feb 07, 2011 4:36 pm
Now that I have understood correctly, it excites me to return to the experiment.
Charly
charly2008
Postby simon le bon » Tue Feb 08, 2011 2:26 pm
Now I see what it is possible to achieve with Charly, I'm one step more contrite that Compo Spray doesn't work for me :(
-s
simon le bon
Postby Didier Bur » Tue Feb 08, 2011 8:07 pm
Patience Simon... je vais publier la v 1.4.2 bientôt.
With an experimental directional spray:
Didier Bur
Didier Bur
Postby simon le bon » Wed Feb 09, 2011 12:58 am
Ah c'est chouette!!
et le directional spray va décupler les possibilités. :)
(ça mérite la patience ;) )
:fro: :freehand: simon
simon le bon
Postby pep75 » Sun Feb 13, 2011 5:15 pm
Hey Didier!
I really can't get it working...I see the dialog still, I read your manual, pressed Spray but It doensn't do anything....What is wrong?!
Thanks!!
Grtz
Pep
pep75
Postby Didier Bur » Sun Feb 13, 2011 5:43 pm
@pep75: the only thing I can tell is that there is "something" wrong. :D
Seriously, please open the ruby console, launch the tool, and copy-paste-post the error message(s) here, so I can figure out what's wrong.
Or download the version 1.4.2., see top of thread
Didier Bur
Didier Bur
Re: [PLUGIN] Compo Spray 1.4.2 Updated 13 February 2011
Postby tpstigers » Tue Feb 15, 2011 5:12 am
Top-Down spray works fine. When I try the perpendicular spray, though, I consistently get this error ("This shape is not available yet"):
“I have an existential map; it has 'you are here' written all over it”
tpstigers
Postby Didier Bur » Tue Feb 15, 2011 9:32 am
@tpstigers: Perhaps you didn't red the doc: it is said that this experimental tool only works with the point tool and spray shape tool ;)
Didier Bur
Didier Bur
Postby tpstigers » Tue Feb 15, 2011 2:11 pm
Didier Bur wrote:Hi,
Thanks. I did read the doc. I guess I should have read it with my brain turned on.
- Terry
tpstigers
Postby pilou » Tue Feb 15, 2011 2:40 pm
Ah very cool! :fro:
Thx for the resizable Dialogue box! :thumb: :thumb: :thumb:
for the next release : does it possible to have 24 #components?
(it's the 24 possible positions of a "cubic volume")
If you are interested I have yet the script for generated these components
(In python for Blender made by zeauro for 2.56 Blender) :fro:
So import these 24 objects in SU from Blender, then run CompoSpray :)
Speedy Galerie
Top SketchUcator
Postby Didier Bur » Tue Feb 15, 2011 10:16 pm
Je n'ai toujours pas capté de quoi tu parles :shock:
Didier Bur
Didier Bur
Postby thomthom » Tue Feb 15, 2011 10:28 pm
Instead of a limited set of combo boxes, why not have a single listbox where you can select multiple list item? And have any selected in SketchUp also appear selected in the dialog when you open it?
PluginStore Author
PluginStore Author
Postby Didier Bur » Tue Feb 15, 2011 10:36 pm
@TT: as said in the doc: "I could have made multi-select lists, but I didn't because you wouldn't have that possibility to "balance" the amount of each component."
Nice idea !
Didier Bur
Didier Bur
Postby pilou » Tue Feb 15, 2011 10:55 pm
C'est curieux parce que c'est hyper simple :)
Si j'ai un module cubique (je prends un dé à jouer à 6 faces pour bien figer le concept)
Ce dé à 24 positions possibles dans une boîte cubique de sa taille!
ça c'est évident :)
Si maintenant avec ton plug, je fais tomber ces 24 cubes dans une colonne à base carrée de la taille du dé, et d'une hauteur quelconque(x*le dé) j'ai une colonne composée de modules superposés de façon aléatoire.
Et bien si à la place du dé j'ai un module cubique légèrement plus compliqué, du genre se raccordant sur chaque face mais non symétrique à l'intérieur j'obtiens des métas structures pavant l'espace de manière non périodique! :enlight:
C'est pour cela que j'ai besoin de 24 composants au lieu des 8 actuellement :)
Toute cette bidouille pour simuler ce que je demandais ailleurs, une affection d'une famille de composants (complexes) à un un ensemble de composants "simplex" :)
Speedy Galerie
Top SketchUcator
Postby thomthom » Wed Feb 16, 2011 8:18 am
Didier Bur wrote:@TT: as said in the doc: "I could have made multi-select lists, but I didn't because you wouldn't have that possibility to "balance" the amount of each component."
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: keziamelia and 13 guests
