[Plugin] Compo Spray 1.4.2 Updated
Re: [Plugin] Compo Spray 1.4.2 Updated 13 February 2011
Postby mtriple » Sun Jul 06, 2014 4:20 am
you are welcome my friend, iam just looking for pro coder to help me with sketchyphisics to work on 2014 cuz im noob, if any one can help plz.
mtriple
Postby Oxer » Sun Jul 06, 2014 12:34 pm
It would be great to run Sketchyphisics on SU2014 but I haven't idea about ruby code or programming, sometimes I help to translate the plugins or I test the plugins on Mac.
http://www.oxervision.blogspot.com/
Oxer
Postby dtrarch » Mon Jul 07, 2014 3:20 am
Mtriple
Thanks for figuring out how to get Compo Spray to work in SU 2014
This is really a GOTTA HAVE tool from the past.
Just to make clear the fix as I understood it.
Here is what I did to make it work
1-I copied compoSprayToolbar.rb and the folder CompoSpray to Program Files(x86)/Sketchup/SketchUp 2014/Tools
2-I also copied them both to xxx/Roaming/SketchUp/Sketchup2014/SketchUp/Tools
To get it to work.
Open SU 2014
goto View/Toolbars and select select the [X]Components Spray option box.
There it was and in working order too.
This might also be a fix for other Didier plugins as well
Whew! :sketchstatic:
Thanks again Mtriple the Great.
dtr
dtrarch
Premium Member
Premium Member
Postby JamesCE » Wed Jul 09, 2014 5:34 pm
I did what dtrarch said(I am not getting an error message when launching anymore) but..
Wwhen I go to View/Toolbars and try to select the [X]Components Spray option box it is not there. I have other extensions installed but Components Spray is not listed. I can also pull up the tool bar for CompS but it does nothing when I try to use it.
On step #2 I could not locate the tools folder. I tried to find xxx/Roaming/SketchUp/Sketchup2014/SketchUp/Tools
but my file structure is set up like this xxxx/Roaming/Sketchup/Sketchup2014/Sketchup/ -- and there is only a plugins and classifications folder.
Am I looking in the wrong spot? Any suggestions?
Thanks in advance
JamesCE
Postby TIG » Thu Jul 10, 2014 11:24 am
I'm NOT sure that putting any non-SketchUp files into Tools is a good idea...
You might well have limited permissions to add files to that folder too...
However, to find ANY of SketchUp's folder use this in the Ruby Console:
Sketchup.find_support_file('Tools')
To find something else simply change what is inside the ''...
Global Moderator
Postby mtriple » Thu Jul 10, 2014 11:47 am
what dtrarch saying :
Latest files : https://www.dropbox.com/s/5sc2ghd6t5amrgh/cs.zip
for windows:
copy Latest files after unzip to :
"Program Files(x86)/Sketchup/SketchUp 2014/Tools"
dont copy the Latest file to next link unless first step didnt work :
"C:\Users\***ur username***\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
idk for mac maybe the same ask Oxer .
mtriple
Postby dtrarch » Thu Jul 10, 2014 7:37 pm
Hello mtriple
As just a marginal CodeHead I did what you recommended but could not get the Icons to show so I also just stuffed the folder and .rb into RoamingxxxxSketchup2014/Plugins/Tools.
My cut and try screen shots FYI ?
As TIG observed maybe just the CompoSpray.rb file is needed or ???
No error or problem as it stands for me.
dtr
dtrarch
Premium Member
Premium Member
Postby TIG » Thu Jul 10, 2014 10:18 pm
I am perturbed that you seem to have a mash-up in your main 'Tools' folder. :shock:
This is mine...
Everything else in the default Plugins folder, or custom-plugins folders set to load from $:...
The 'Tools' folder is reserved for a few standard SketchUp rb files, and in v2014 the Ruby Libraries...
Making another Tools subfolder elsewhere is plain weird ???
There are several old files in there too [i.e. pre-v2014!] - the v2014 dynamiccomponents loader is NOT that name etc, and the extensions, sketchup and langhandler ruby files are the ones in Tools and should never be duplicated elsewhere :o Old files like date and rational rb are also outmoded in v2014...
If it's inside the Plugins folder nothing within it will auto-load, unless it is explicitly added to $: :?
Global Moderator
Postby dtrarch » Fri Jul 11, 2014 7:37 pm
Understood re /Tools
The SU2014 & updates were per download installs.
The only thing I did copy to the /Tools folder was the CompoSpray folder & .rb
You figure where the other stuff came from.
Does not seem to cause an error or interrupt other plugins.
Hmmmm?
dtr
dtrarch
Premium Member
Premium Member
Postby JamesCE » Tue Jul 15, 2014 5:22 pm
I am having the same problem as I had before.
If I copy the latest compspray files to my plugins folder here:
I get this error when opening SU. Also the toolbar isn't listed and CS isn't there.
If I copy the latest files here:
I am able to pull up the toolbar for compspray but the only thing that works are the CS settings. I also could not find compspray in the SU system preferences/extensions window.
Any ideas on what I'm doing wrong?
JamesCE
Postby TedVitale_CG » Mon Jul 21, 2014 5:51 pm
I'm having the same problem on my end as well.
Ted Vitale
3D Artist|Trainer
Chaos Group USA
http://www.chaosgroup.com
TedVitale_CG
Vray Support
Vray Support
Postby dtrarch » Sat Jul 26, 2014 7:57 pm
Hi mtriple
Thanks for the new fix
Now OK to install in SU 2014 in xxx/Roaming/(SEE SCREEN COPY)
Works now in SU 2014 Plugins folder. :thumb: :thumb: :thumb:
dtr
dtrarch
Premium Member
Premium Member
Postby JamesCE » Tue Jul 29, 2014 2:24 pm
It was a permissions error for me, but it is working now. I also didn't know much about using the ruby console. Thanks!
JamesCE
Postby TIG » Tue Jul 29, 2014 6:46 pm
JamesCE wrote:It was a permissions error for me, but it is working now! I also didn't know much about using the ruby console. Thanks!
Permissions to folders within the Programs Files tree is limited by default.
As has been said before... you should never need to put ANYTHING into the Tools folder.
The default 'User' Plugin folder for v2014 has suitable permissions...
I am still at a loss as to see what is improved by this fiasco... :roll:
Global Moderator
Postby mtriple » Wed Jul 30, 2014 5:08 am
JamesCE,
dont use my first fix, its contain a bad fix, it will cuz bug and crash at a phase of running. go to the last one.
TIG,
its not totaly true, if u used find supported file with parameter "tools" its works.
when i start using su 14 i didnt know where is plugins folder so i thought they name it "tools".
so first fix i change that in the code "plugins" to "tools". and that works in v14 but not with any other version.
but u r right, its not good may cuz su crash because the folder contain some su rb files as default. what i mean is u can put ur plugins anyplace if its got the same path inside the code.
also i have seen some plugins copying it self automatic to "plugins" if u place it inside "tools" after loading su.
all of this just because there is alot plugins need to be RBZ instead of rb.
srry TIG i didnt understand waht u mean by this "I am still at a loss as to see what is improved by this fiasco..."
even google didnt give me the meaning. xd
mtriple
Postby TIG » Wed Jul 30, 2014 10:50 am
In v2014 SketchUp auto-loads any rb/rbs plugin files it finds in two folders in its $: [aka $LOAD_PATH].
By default that is the main C:/Users/.../Plugins folder and the C:/Programs Files/.../Tools folder.
These load in that order - there should only be SketchUp supplied files in that folder: currently that's only sketchup.rb, extensions.rb and langhandler.rb, that's why you'll see "require('sketchup.rb')" and so on in other scripts which load from the default User's Plugins folder earlier but need the code which would otherwise load too late...
The $: also includes two other folders for Ruby2.0 access, but their content is not auto-loaded - authors must include code like "require('zlib')" to access these additional functions.
The $: can also include other folder paths. A 'custom-plugins-folder' can be added using Fredo's Additional Plugins Folder tool - e.g. a 'DropBox' folder used for syncing your plugins across several PCs.
Again, the scripts in such an included folder-path are not automatically loaded by SketchUp as it starts: however, Fredo's tool WILL auto-load any rb/rbs files found in that specified custom-plugins-folder...
The 'AutoInstall' function accessed through the Preferences > Extensions > Install... button... ALWAYS extracts a RBZ archive's files into the default User's Plugins folder.
However, the outwardly similar 'AutoInstall' and 'Archive-Installer' tools used through the 'SketchUcation PluginStore Toolset' options will offer you a choice of destination folder, if one is defined in $: - like a 'DropBox' folder etc - and load those installed file[s] too.
In addition, if you have also made a 'shared' folder setup in C:/ProgramData/...SketchUp 2014/ named 'Plugins'... then that is automatically included in the $:, and any scripts in that folder are also auto-loaded as SketchUp starts - this optional setup allows you to have one version of a plugin installed which is loaded for every user on that particular PC. BUT unless there are multiple SketchUp users on your PC, then that folder is not normally needed, made or used...
The security permissions to the default User's 'Plugins' folder are automatically setup appropriately, to allow that user to install/manage plugins etc.
Similarly a User can set security permissions to any custom-folder they might setup.
BUT, the default security permissions for the main 'Tools' folder [and indeed any folder within the 'Plugins Files' tree] are restricted by Windows - even if you are an admin - and need elaborate recasting to ensure ready access - which of course you should never need anyway !
That security restriction is the very reason that SketchUp v2014 now defaults its Plugins folder in a user-accessible location, and no longer parallel with the 'Tools' folder - like it used to be in earlier PC versions, which caused endless installation problems ! [MACs had the user-accessible setup for some time!!]
Using the Ruby Console:
Sketchup.find_support_file('Plugins')
Tells you where your own User's 'Plugins' folder is - BUT unless you are manually installing files you don't need to worry, the readily available 'AutoInstall' tools will always put RBZ content in the right place... In addition to RBZ, the SketchUcation PluginStore submenu tool also allows ZIP archive installation. 99% of scripts now come as installable archives, so unless you have a lone RB to manually install you need never open your User Plugins folder...
Scripts in 'Tools' will auto-load, BUT they are not copied into the default 'Plugins' folder.
Any scripts in the 'ShippedExtensions' folder DO get copied into the 'Plugins' folder, BUT again why would you want to do this? That folder also has the same security permission issues as the 'Tools' folder !
A few older scripts hard-code the path to 'themselves' using Sketchup.find_support_file('Plugins'), and then look for their helper files within their subfolder in that location.
This is fine IF the installed script is located in the default User's 'Plugins' folder.
BUT this inevitably causes issues when the script's installation in elsewhere - because then the subfolder is not found - but 99.9% of newer/updated scripts use File.dirname(__FILE__) to find where the plugin is installed and then get its subfolder from there...
My 'throw-away' comment about 'fiasco' was referring to the many recent posts in this thread - where bad installation practice was being advocated, and could leads to all kinds of mis-installations, and ensuing problems that we can avoid.
Installing RBZ/ZIP contents is quite simple when the correct tools are used...
There is no need to mess around with any 'system' folders within 'Program Files' at all... :ugeek:
Global Moderator
Postby Bob James » Wed Jul 30, 2014 9:31 pm
Thank you mtriple. :thumb: The file downloaded from the website just kept giving loading errors.
Bob James
Premium Member
Premium Member
Postby mtriple » Thu Jul 31, 2014 4:07 am
thx TIG,
i'm still learning (i'm noob), u guys helped me alot.
i'm waiting ur cloth simulation xd.
mtriple
Postby JamesCE » Thu Aug 07, 2014 6:39 pm
TIG wrote:Permissions to folders within the Programs Files tree is limited by default.
I assumed that the permissions were changed by the company I work for. I didn't realize it is like that by default. To fix it I actually downloaded the latest link and installed it the correct way. I didn't realize that mtriples other link was a bad fix, and I'm still confused to how dtarch got it to work..
The reason I said that I fixed it by fixing the permissions issue is because I assumed it wasn't like that by default and assumed it could be just changed to get it to work for people that were having that same issue. I was trying to be helpful but it ended up being wrong and more confusing :shock: sorry
JamesCE
Postby paul.wacko » Sun Sep 21, 2014 11:47 am
I tried placing the files into Tools and Plugins without success
However when I placed them in Tools and ShippedExtensions folders, where the tools folder is it fired up. But not in the plugins folder.
Paul J
paul.wacko
Postby keithswd » Mon Sep 22, 2014 11:52 am
Does anyone know how to get this plugin working on a Mac install of SU2014? I get this error after installation:
Error: #<SyntaxError: /users/keithpocock/library/application support/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:511: Invalid break
/users/keithpocock/library/application support/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:520: Invalid break>
Error Loading File compoSprayToolbar.rb
Error: #<NoMethodError: undefined method `compSpray_env' for main:Object>
/Users/keithpocock/Library/Application Support/SketchUp 2014/SketchUp/Plugins/compoSprayToolbar.rb:7:in `<top (required)>'
keithswd
Premium Member
Premium Member
Postby Oxer » Mon Sep 22, 2014 1:14 pm
On Mac & SU2014 you have to place the compoSprayToolbar.rb file and ComproSpray folder is this path:
/Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools
Go to Applications folder select SketchUp app and right click Show package content
Oxer
Postby keithswd » Mon Sep 22, 2014 2:07 pm
Thanks Oxer. I have just tried putting the file & folder as you suggest but still get the error. I have double checked that there is no longer a copy in either user Application Support../Sketchup subfolders, or in the system support folder, but up pops the error when I start up.
The error has changed to the updated path for the script, so maybe something else is wrong:
Error: #<SyntaxError: /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:511: Invalid break
/applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:520: Invalid break>
/Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/compoSprayToolbar.rb:7:in `<top (required)>'
keithswd
Premium Member
Premium Member
Postby solo » Mon Sep 22, 2014 3:47 pm
So, any solution? I tried downloading it with the SCF plugin store but that did not work well, in fact it installs but nothing, no tool bar not in plugin menu, anyone?
http://www.solos-art.com
solo
Global Moderator
Postby Oxer » Mon Sep 22, 2014 3:57 pm
KeithSWD and Solo, try with this version updated by MTriple, it works fine for me on Mac OS X & SU2014, remember the path on OS X:
CompoSpray.zip
Oxer
Postby keithswd » Tue Sep 23, 2014 3:49 pm
Many thanks Oxer (and MTriple) this version is working for me too!
Glad to have this very useful tool back in operation.
keithswd
Premium Member
Premium Member
Postby ruriglen » Wed Oct 01, 2014 4:23 pm
The file MTriple uploaded to dropbox is offline, does anyone else has it, that kindly could uploaded again for sharing? Thanks!
ruriglen
Postby penumbra » Wed Oct 01, 2014 10:09 pm
I give up on this plugin. Does not work on 2013 even the Mtriple fix. It won't accept a second point on the shapes (circle, square you name it). The developer has gone MIA...
penumbra
Postby Box » Wed Oct 01, 2014 10:28 pm
It does work on 2013 and 2014 with some tweaks.
Make sure you have the properties set to what you need and remember it needs a surface to spray on.
As for the developer being MIA, Didier has never said he supports this free plugin in perpetuity.
Postby chon » Thu Oct 09, 2014 1:57 pm
Hello,
no match for me with CS modified and given by Oxer few posts above. I've tried to install the plugin in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools" (even then we should'nt use this folder as explained by TIG) and in "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins" but no success.
Cherry on the cake, i would like to install this plugin in an additional plugin folder using the Fredo6 tool (doesn't work in this folder neither of course).
Any one to help me ?
Thanks a lot !! ;)
SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
chon
PreviousNext
Return to Plugins
Users browsing this forum: Bep, jsteacy, ParKaTuS and 13 guests
