[Plugin] OBJexporter v3.0 20130131
Re: [Plugin] OBJexporter v1.1 20110106
Postby krash88 » Mon Jan 24, 2011 7:14 pm
Ok, I just remembered that Whaat's UV Tools exports to OBJ and all is good!
krash88
Re: [Plugin] OBJexporter v1.2 20110224
Postby TIG » Thu Feb 24, 2011 5:57 pm
This is v1.2 viewtopic.php?p=294844#p294844
Distorted textures are exported as distorted 'unique texture' files and re-UV-mapped - just like the Pro OBJ-exporter.
Global Moderator
Re: [Plugin] OBJexporter v1.3 20110225
Postby TIG » Fri Feb 25, 2011 5:37 pm
Here's v1.3 viewtopic.php?p=294844#p294844
I recommend you upgrade - it fixes a glitch with some distorted textures 'flipping'.
Materials and textures that are applied within and on to Groups or Instances are now properly defined and UV-mapped.
Global Moderator
Postby agamemnus » Sun Feb 27, 2011 5:43 am
Your object exporter is better than Google's.
My ship model, with completely exploded pieces and 8 materials: Sketchup exports 35 groups making 35 materials in my program. Yours works correctly and exports 8 groups making 8 materials.
Just 3 (edit:4) items:
* No dialog to set the name/directory or progress bar when it does so makes it a bit involved when I need the name to be different from the sketchup file name.
* Your exporter rotates the object 90 degrees on the .. Y axis, I think.
* I think for proper usage anything with a " " in the filename needs to be converted to "_".
* Wellllllllllll ok, some things may not export properly. I'll pm you a link for a model that does not.
agamemnus
Postby TIG » Sun Feb 27, 2011 11:30 am
agamemnus wrote:Your object exporter is better than Google's.
A dialog is next on the to-do-list... As are some other things like setting 'units', or 'selection only' versus 'all'.
The default is to swap Y & Z axes as many apps expect that from their OBJ import. My OBJimporter even has an option to swap them back as many 3rd party OBJs are swapped like this. The swap could become an option...
It's easy enough to remove the space in the file name...
I've looked at the SKP you PMd me... I can see that some triangulated faces on the sides of the 3D text are 'reversed' - which is perverse since the mesh is made from one bit of face initially. Also a few of the rectangular wall panels at the front aren't getting a material assigned to them - weird... I'll investigate further to see what's up... Anything major I've missed otherwise...
Global Moderator
Postby agamemnus » Sun Feb 27, 2011 7:31 pm
Sent you a pm.
It is a bit of effort to rename " " parts of the file to "_", especially if I want to keep the source filename without spaces.
Another very good thing to add (which the Google one doesn't have) would be a way to specify the source directory. Sometimes I need the source directory to be the same for a set of models (because they use the same texture), and manually editing the material files after every model edit is a chore.
agamemnus
Re: [Plugin] OBJexporter v1.4 20110228
Postby TIG » Mon Feb 28, 2011 1:39 pm
Here's v1.4 viewtopic.php?p=294844#p294844
It is recommended you upgrade to this version asap...
The new Filename now has spaces etc squeezed out.
Startup dialog added to allow Filename/Folder to be changed.
Glitches with reversals of some smoothed faces and materials occasionally missing from complex faces now addressed.
General speed and Status-Bar progress-reporting improved.
Global Moderator
Postby agamemnus » Tue Mar 01, 2011 5:58 am
Thanks, TIG.
agamemnus
Postby McGyver » Fri Mar 11, 2011 4:33 pm
As a user of SU's free version I thank you TIG, for this VERY helpful plugin! I had forgotten about it and the other day someone suggested I try it (a while ago I PMed TIG asking about it when in another thread he had mentioned he was working on it).
I tried it out and I have to say that based on what I used it for it seems to work BETTER than SU's native obj exporter! Thank you very much for spending your valuable time and efforts on making and sharing so many brilliant plugins. In this terrible economy many of us can not afford even the simplest things and these gifts of yours are priceless to those of us on a tight budget.
Thanks!
McGyver
Postby stefkeB » Sun Mar 13, 2011 10:24 pm
Nice plugin. It does work to get SketchUp Free models into Unity3D. At work I have SketchUp Pro with good FBX export, but at home, for the kids, I am learning them to use the free version of SketchUp. This is a good script, although with some models there are waaay to many materials. I assume that the UV mapping is the culprit. But I can not complain, as this was a model from the 3D Warehouse.
stefkeB
Postby TIG » Mon Mar 14, 2011 11:22 am
stefkeB wrote:Nice plugin. It does work to get SketchUp Free models into Unity3D. At work I have SketchUp Pro with good FBX export, but at home, for the kids, I am learning them to use the free version of SketchUp. This is a good script, although with some models there are waaay to many materials. I assume that the UV mapping is the culprit. But I can not complain, as this was a model from the 3D Warehouse.
OBJexporter creates one material & texture file for each material.
If that material has UV mapping it should only make the one file and map it within the code BUT if a texture has been UV mapped AND distorted then there insufficient points on a triangular face to cope so it makes a duplicated material using a distorted texture image file and normal mapping in lieu. The Pro exporter does a similar thing. If you have several distorted textures then you get one extra material for each one. It is possible to have a textured material that looks virtually the same as one that's not been mapped, BUT if there is the slightest distortion you will get a duplicated distorted material being exported... If you want to attach or PM the SKP [or point to the actual file] then I can check it out too.... :?
Global Moderator
Re: [Plugin] OBJexporter v1.5 20110323
Postby TIG » Wed Mar 23, 2011 12:43 pm
Here's v1.5
It addresses a 'smooth-normal' issue where smoothed surfaces weren't getting exported properly.
Global Moderator
Postby McGyver » Thu Mar 24, 2011 2:40 am
Thank you for the update!!
McGyver
Postby Alienizer » Mon Mar 28, 2011 5:55 am
Thanks for this great plugin. Way better than Sketchup OBj Export.
I have one request, is it possible to also export back faces that have a color or material, and not those that don't? Say, instead of creating a new face for the back like SKP export do, can yours assing a new OBJ command? For example...
usemtl White
bf 9/9/9 10/10/10 11/11/11
bf for backface!
That way, we can load the obj and detect any back faces as oppose to treat them as a new face and have duplicate triangles!
I don't know if I make any sense?
I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
Alienizer
Postby TIG » Mon Mar 28, 2011 10:34 am
Alienizer
The Pro OBJ exporter has a 'two-sided' face option BUT when you bring these into many app's the faces 'fight' as they are coplanar.
What happens is each face is effectively duplicated and one is reversed with the Back material applied to it.
An OBJ file must use 'f' to define a face, there's no 'bf' coding...
I've no plans to make a 2-sided version any time soon...
I suspect that you actually want a quick and lazy way to fix a sloppily modeled SKP, where you have some reversed faces with materials on their backs instead of their fronts... :roll: I have already written the very tool to fix that for you - 'FixReversedFaceMaterials' - it flips any faces with materials only on their backs and sorts out the material's mapping back onto the 'now-correctly-oriented-face' front etc... Read this and then download the script viewtopic.php?p=264134#p264134 :ugeek:
Global Moderator
Postby Alienizer » Mon Mar 28, 2011 11:26 pm
Great! Thank you. I will use your other tool. What about a face with 2 materials where front and back are visible, say, the back is visible from a mirror when rendered?
FYI I found a simple model that does not convert properly. All faces are oriented correctly and it export fine with SKP obj export...
http://sketchup.google.com/3dwarehouse/ ... evstart=24
Thanks again TIG
Alienizer
Postby TIG » Tue Mar 29, 2011 9:01 am
An OBJ file contains data for a face with a material.
If you want a back material you must make a second face that's reversed.
As most renderers etc expect 'solid' objects it is wise to model your SKP this way - e.g. make a window glass with two outward facing faces ~10mm apart as it would be in the real world [there are never 'single planes' in reality - all things, no matter how thin they are, have two faces each with a front, not one face with a front and a back!]
I am testing your problem Allosaurus SKP - it is complex with over 800,000 lines of code in the OBJ file. The OBJexporter isn't foolproof - I'll try to see where it might be failing... :?
Global Moderator
Postby TIG » Tue Mar 29, 2011 10:59 am
I found that my OBJexporter did make a correct OBJ version - which imported OK into other packages. It took ages to finish and the OBJ file was 22Mb! The Pro OBJ exporter is quicker because it's compiled etc... BUT mine is 'free' ;)
There is a problem with my old clunky OBJimporter - it will import some of the faces flipped - it's an issue with smoothed normals.***
I suggest you try this quite new and free 'compiled' OBJimporter - it is much faster, and after some initial tweaking this version is now stable and it gave me a perfect re-import back into a SKP of Allo'... see here viewtopic.php?p=316470#p316470 - read the thread to see how it's evolved... It could probably do with some better reporting in the Status-Bar, but otherwise I like it...
***As we now have this free 'compiled' OBJ 'FluidImporter', I probably won't bother doing any more work on my clunky version...
Global Moderator
Postby Alienizer » Tue Mar 29, 2011 8:50 pm
I know you are right, and I do make my models that way, but, in the 3D warehouse, you are not going to find many that follows that rule! They all use an electron thin wall, and don't even know about front/back faces! Let alone paper thin glass (no thickness)!! That's why I try to get some 3ds files, then use AccuTrans3D to convert it to KMZ so that I can load it in SKP.
However, you're obj importer is by far the best of all! Thank you, and it's free! :ecstatic:
Your renderer looks fantastic too. Great job, and thanks for taking the time to answer my post.
Alienizer
Postby aapur » Thu Mar 31, 2011 10:18 am
i cannot get it into sketchup.
OS: Win 7
SU: 8
what should i do. (be detailed please)
aapur
Postby TIG » Thu Mar 31, 2011 12:03 pm
Put the .rb file into your ../Plugins folder and restart Sketchup.
Use Menu > File > OBJexporter
Otherwise please be more specific with your problem's description...
Global Moderator
Postby Alienizer » Fri Apr 01, 2011 1:17 am
TIG, I have another one for you. I created a simple Cornell box with a sphere in the middle. Sketchup OBj exporter rendered perfectly, yours seems to have not soften it! See screen shot...
Alienizer
Postby Alienizer » Fri Apr 01, 2011 4:05 am
I have another one for you...
http://sketchup.google.com/3dwarehouse/ ... revstart=0
This guy did this by the book. It renders fine when exported using SKP obj exporter, but not when using yours!
Alienizer
Postby TIG » Fri Apr 01, 2011 9:07 am
Are you using the latest version of my exporter [v1.5] ?
This was updated to correct some smooth-normal issues, and it seems to work on exports tested by others.
Please download it from the first post and retry your sphere/box...
[It is also very similar to my Octane exporter which renders smoothed faces as expected too]
When re-importing it into a SKP you need to use this viewtopic.php?p=318928#p318928 new tool - my old OBJimporter is now surpassed [and it never imported 'smoothness' anyway]...
Global Moderator
Postby TIG » Fri Apr 01, 2011 10:04 am
Here's a quick test.
The SKP has two spheres one smoothed [dotted edges] and the other faceted.
It is exported as an OBJ and then used in a quick Octane render, which shows the smoothed sphere as a rounded pearl and the faceted one exactly as they are the SKP ?
Are you sure you have the latest version of OBJexporter ?
Global Moderator
Postby TIG » Fri Apr 01, 2011 11:30 am
I also tested the 'Mullaghmore' house.
The roof carpentry [first scene] exported to OBJ fine and here's a render in Octane
compared to the original it seems perfect ?
When I exported the whole house and its site [house] to OBJ it took a while and it then loaded into Octane but after all of the materials loaded it crashed it [it does have 90 textures and then other materials, although the OBJ itself is relatively modest]. When I re-imported it into a SKP after some considerable wait I got it to import. Clearly all smoothing was lost [currently all OBJ importers to SKP ignore smoothed normals]. I could have then quickly re-smoothed and got back to something like the original. There was considerable redundancy with interior structure, furniture etc that's 'on' in the exported scene but never visible in a 'site' view - luckily the SKP is very well layered, so switching those unneeded things' layers 'off' let it be exported quickly to OBJ and then it rendered nicely in Octane too... The 'tiling' is a function of the original texture mapping rather than the export or render - just compare it with the original SKP view
I'm not getting any real issues here - only that I can't expect a renderer to cope with a zillion unneeded hidden things in the model line floor joists and WCs as it needs to calculate all of them unnecessarily... :?
Global Moderator
Postby Alienizer » Fri Apr 01, 2011 7:58 pm
Thanks TIG, but I do have the latest. I think I found the problem. It is that in some instances, your exporter export some faces as back face, that is, in the obj file, f 1/1/1 2/2/2 3/3/3 is f 3/3/3 2/2/2 1/1/1. Here is how I found out. Check this model...
You see the first brown door on the right? Erase everything except that door, then remove the frame and the back door (it's a bifold). Now you are left only with the 3d rect (6 faces, not paper thin). Now, the last two line foe example, is the front...
f 21/21/21 22/22/22 23/23/23
f 22/22/22 21/21/21 24/24/24
and it is reverse. a ray bouncing of the normal goes inward, not outward. Now, it I modify it like this...
f 23/23/23 22/22/22 21/21/21
f 24/24/24 21/21/21 22/22/22
it now renders fine and the face if oriented properly.
Most render such as yours may not be affected by this, but mine is! The fact remain that the face is not oriented properly.
Or is it just me that's going nuts?
Alienizer
Postby TIG » Fri Apr 01, 2011 11:19 pm
I've checked your linked SKP.
It isn't modeled perfectly - there are a few reversed or missing faces [showing as blue or 'nothing' here].
My Octane render seems much like the SKp.
My Twilight render is too [although it does auto-correct the rubbish modeling [reversed face on the end of the stone-wall and a triangle pane in particular].
This crap render from AC3D also mimics Octane's output with the expected problems
Finally here's it exported to OBJ, re-imported into an empty SKP and a Twilight render
They all seem to cope quite well with the original SKP - TW even forgives the reversed faces :roll:
What's your renderer that seems to be causing this weirdness ? :?
Global Moderator
Postby Alienizer » Fri Apr 01, 2011 11:47 pm
I was only using a simple raytrace to verify the orientation of the faces. When I click on a face, it shows me the reflected vector (also shows the normals etc), and it shows it correctly with the skp export, but with yours, it shows the reflected vector to go inwards. Not for the whole model, only for the 2 brown doors to the right. When I reverse the face (f #/#/#...) as I explained, then the reflected verctor is proper. The same thing happens with the body of the allo dinosaur, but not the head.
I know the renders takes care of that, but imho I think it's better to have a flawless obj than one the render has to fix, so I present you my findings. It seems that for those 2 doors, the triangles are CWW instead of CC (or CC instead of CCW). This makes a big difference when you do a ray/troiangle test and test for face culling or want to know if it hit the back face or not.
Alienizer
Postby TIG » Sat Apr 02, 2011 12:25 am
Thanks for the analysis...
The tool's 'triangulation' method is built in to the Ruby API's face / mesh methods.
There's little control over it, other than telling it what extent of detail the mesh will include - like back face UVs...
...except that there are some arcane face / edge methods 'reversed_in' etc that are used to orient faces that share an edge but face opposite directions [i.e. one is reversed].
At the moment I can't see how... BUT perhaps you could reverse an edge's vertices on a particular face that is 'wrong' before making the triangulated mesh... I wonder if the problem 'door' face has some small facets - fluking it? I'll look more closely...
As it is, I see this glitch as a shortcoming of the API mesh method that is making occasional glitches in the mesh that the OBJ is then using in its exporting... :?
Global Moderator
PreviousNext
Return to Plugins
Users browsing this forum: net201 and 14 guests
