[Plugin] ImageTrimmer
Re: [Plugin] ImageTrimmer 20101217
Postby Oxer » Mon Dec 20, 2010 10:05 pm
Dave R wrote:Oxer, you might try importing the image as an image and then immediately running the plugin on it. See if that does what you want.
I have done so too, but appears a message error in Ruby Console.
http://www.oxervision.blogspot.com/
Oxer
Postby TIG » Mon Dec 20, 2010 10:13 pm
Oxer wrote:Hello TIG!
I don't know how use the plugin, i do this:
1. I import a png file like image.
2. I make a new component, its name the same like image.
3. I make a new material with the png file with the same name, and i apply this material to the face inside the component.
4. I select the image into SU and run the plugin.
Nothing happens, only the plugin creates a folder named "TrimmedImages" in the same directory that Model file, it contains the png file.
What i do bad?
I use Mac with OSX 10.6 and SU 8.
EDIT: Appears this message in Console Ruby
NO!
1. Import the Image. [no need to make other things yourself]
2. Place/Scale it like you want.
3. Select the Image.
4. Run 'ImageTrimmer' [the clue is in its name!]
5. It makes a new Component Instance that has trimmed Faces matching the Image's transparent areas with the Image now applied as a new Material.
6. You then choose to stand-up the new component, delete temporary files or 'simplify' the outlines.
7. Later, you can Select the new Component Instance and use the 'simplify' tool on its outlines...
Please run it with the Ruby Console open - there might be a MAC error.
Check that .jar files are 'executable' Java files on your OS and not inadvertently set to open with your 'Zip/UnZip' application...
From the Ruby messages it seems that the 'EdgeDetector.jar' file isn't in the correct directory ?? There should be one file called 'SKMtools.rb' in the 'Plugins' folder and then a sub-folder in the 'Plugins' folder called 'SKMtools' that contains various .rb and .jar files etc. Your error message is saying it can't find the specified .jar file. Is it there? If so does the file path contain accented characters etc [unlikely] - that can cause Ruby's File operations to fail!
Global Moderator
Postby TIG » Mon Dec 20, 2010 10:21 pm
Oxer
PS: are you sure you have your files/folders in the correct 'Plugins' ? Type/Copy+Paste this into the Ruby Console to check the correct path to your Plugins folder... Sketchup.find_support_file("Plugins")
Global Moderator
Postby Oxer » Mon Dec 20, 2010 10:28 pm
TIG wrote:Oxer
Yes, i have all file into Plugins folder
Oxer
Postby TIG » Mon Dec 20, 2010 10:33 pm
Oxer
I apologize - I have double checked my code and there was a stupid typo [for MAC users] that messed it up - two lines were 'transposed'... :oops:
Here is the updated file-zip viewtopic.php?p=293677#p293677
Please retry and report back...
Global Moderator
Postby Oxer » Mon Dec 20, 2010 10:50 pm
I have downloaded the revision and the error persists.
Oxer
Postby Humpmetwice » Tue Dec 21, 2010 6:59 am
I am getting these messages. The first one just after I click the Image Trimmer but then it says please wait then the second message appears "the edges images and data were not made". I using vista and java is up to date and I'm not sure if win zip or anything else is trying to open the .jar file or not. Not that big of a deal just thought I would post.
Humpmetwice
Postby TIG » Tue Dec 21, 2010 10:26 am
humpmetwice wrote:I am getting these messages. The first one just after I click the Image Trimmer but then it says please wait then the second message appears "the edges images and data were not made". I using vista and java is up to date and I'm not sure if win zip or anything else is trying to open the .jar file or not. Not that big of a deal just thought I would post.
To see if anything is messing with .jar files double-click on ../Plugins/EdgeDetector.jar and see what happens - if it opens with say 'WinRar' then edit that App's options to NOT open jar files... 'Jar' files should 'open' [execute] with Java...
From the message it seems that Java IS trying to execute the jar file.
Do you have appropriate access-rights to read-write-execute files in the ../Plugins/SKMtools folder/sub-folder ?
Can you edit the permissions to that folder to allow you full access.
Can you try this to see if the 'jar' is executable.
Find a simple .png file with some transparent areas and copy it to say 'C:\Temp\my.png'.
Open the ../Plugins/SKMtools folder and make two files called 'from.ini' and 'to.ini' [if they exists use them].
Edit them with 'Notepad' or equivalent plain-text editor, so the 'from.ini' contains one line of text C:\Temp\my.png [no carriage return] and the 'to.ini' contains one line of text C:\Temp\my [no carriage return].
Now double-click on the file in SKMtools called EdgeDetector.jar - you should now find two extra files in 'C:\Temp\' folder named C:\Temp\my[Edged].png and C:\Temp\my[Edged].dat.
If you open the Edged .png file you should see it is the outlines of the solid areas black-on-white, the .dat file opened in Notepad should be a lot of 01s gobbledygook...
Please try these ideas and report back... :?
Global Moderator
Postby TIG » Tue Dec 21, 2010 10:27 am
Oxer wrote:I have downloaded the revision and the error persists.
Oxer can you test the ideas outlined in my last post, regarding access and if the 'jar' will 'execute' - adjust the 'Temp' folder and 'plain-text editor' to the MAC's equivalents... :roll:
Global Moderator
Postby Dave R » Tue Dec 21, 2010 11:57 am
Hi TIG,
I have updated to the most recent version of the plugin and tried running it on my PC. I get the following in the Ruby console and it appears the plugin quietly exits.
Code: Select all
Error: #<NoMethodError: undefined method `length' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:241:in `add_edges'
C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:220:in `make_edges'
C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:170:in `process_image'
C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:147:in `initialize'
C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:618:in `new'
C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/image_class.rb:946:in `call'
Global Moderator
Postby TIG » Tue Dec 21, 2010 12:41 pm
Dave R wrote:Hi TIG,
Code: Select all
The error shows that Nil lines were read from the your_image[Edges].dat file.
First test - is it writing the original image file your_image.png, and your_image[Edges].png and your_image[Edges].dat files into a folder called 'TrimmedImages' in your Model's folder ?
Second test - if it is can you 'read' all of them ?
Open the .dat with a plain-text-editor and see if it has 01s in it...
Does the Image you are processing have transparent areas?
Even if it did not it should still make a .dat file [just random ideas at the moment]...
Do you have appropriate permissions to read/write to the SKMtools folder and Model's folder ?
Do you have 'from.ini' and 'to.ini' files left in your ../Plugins/SKMtools folder?
If so read them with a plain-text-editor does the first say path_to_model_folder\TrimmedImages\your_image.png and the second path_to_model_folder\TrimmedImages\your_image ?
If not edit them to suit, if they don't exist make them containing appropriate paths [one line - no 'carriage-return'].
Also ensure there's a folder called 'TrimmedImages' on the specified path.
If you have the two '[Edges]' 'image' files mentioned above move them out of that folder.
However, you must have path_to_model_folder\TrimmedImages\your_image.png in there.
Now double-click on 'EdgeDetector.jar' in the ../Plugins/SKMtools folder - does it make the two files from the in the
'your_image.png' ??
Please test and report back...
Global Moderator
Postby Dave R » Tue Dec 21, 2010 2:47 pm
FWIW, When I reported the problem it was on my PC at home. I tried it here at work on this machine (also XP) and got the same results.
Yes it does do those things.
Yes. I can read all of the files and the .DAT file contains a lot of 0s and a few 1s.
Yes. At least I can see the axes through the transparent areas.
It's XP and I have admin rights. An earlier version of the plugin worked fine.
No. those files aren't there.
Uh.... Can I do this in NotePad? Type, "path_to_model_folder\TrimmedImages\your_image.png" and save it as from.ini?
For the to.ini file is there an extension on your_image?[b]
[b]The .dat file stays or goes? I've moved the one image file with [Edges] in the name out of the folder but haven't continued because I need to make the INI files.
Global Moderator
Postby Dave R » Tue Dec 21, 2010 2:58 pm
I beg to report that I tried with a different PNG image and it work. There must be something wrong with the other image I used. Is there a way to tell what that something is?
Global Moderator
Postby Humpmetwice » Tue Dec 21, 2010 3:42 pm
It doesn't do anything once I click on it.
By everything I can tell I have full permission to the folders. Far as for all the other, I'm not sure I've done it right but nothing happens.
Humpmetwice
Postby Oxer » Tue Dec 21, 2010 4:14 pm
TIG wrote:First test - is it writing the original image file your_image.png, and your_image[Edges].png and your_image[Edges].dat files into a folder called 'TrimmedImages' in your Model's folder ?
'your_image.png' ??
Hi TIG again,
I have probed the before instructions and now the two files ( my_image[Edges].dat & my_image[Edges].png) appear into TrimmedImages folder with the original image my_image.png, what i do now?
Thanks TIG.
Oxer
Postby TIG » Tue Dec 21, 2010 8:56 pm
'your_image.png' ??
Hi TIG again,
Thanks TIG.
OK... so we now know that the 'EdgeDetector.jar' file IS working when it's double-clicked - as it does 'execute' and it makes the files we need.
We now need to find why it isn't 'executing' with UI.openURL() like it should.
Please try this in the Ruby Console...
Move the two '..[Edges].png' and ..[Edges]'.dat' files out of the 'TrimmedImages' folder temporarily.
To get a file to 'execute' on a MAC it's usual to change to the appropriate directory first - type
Dir.chdir(path_to_SKMtools) [you add the full path to the SKM folder]
To check where you are type Dir.pwd - it should now show you are 'in' the 'SKMtools' folder.
and then use
jar="EdgeDetector.jar"
File.chmod(0777, jar)
- to make sure it is 'executable'.
then type
UI.openURL("file:///"+jar)
The jar should 'open' - execute - and make the two '[Edges]' files we need.
If not can you try other options like
UI.openURL(jar)
or
UI.openURL(full_path_to_SKMtools/EdgeDetetcor.jar)
where the 'path' is the 'full path' to the required jar-file in the SKMtools folder...
any other permutations you can think of for trying to 'run' the 'EdgeDetetcor.jar' file would be appreciated... :?
I am a bit at a loss to sort out MAC problems like this direct - I don't have access to a MAC... BUT if you can help resolve this I'm sure lots of other MAC users will be grateful, as will I... :)
Global Moderator
Postby TIG » Tue Dec 21, 2010 9:10 pm
Dave R wrote:I beg to report that I tried with a different PNG image and it work. There must be something wrong with the other image I used. Is there a way to tell what that something is?
There's a 'time-out' for making the two 'Edges' files so it might simply be taking too long and exiting - I tweaked the time-out so that it waits longer [60secs] before giving up - please try this alternative with the problem file and see if it helps... viewtopic.php?p=293677#p293677
Any one else getting the files made but the tool not completing try this new version... :roll:
Global Moderator
Postby TIG » Tue Dec 21, 2010 9:11 pm
Please try the newest version and report back viewtopic.php?p=293677#p293677
Global Moderator
Postby Humpmetwice » Tue Dec 21, 2010 10:57 pm
Does the same as before. It adds a folder on my desktop called trimmedimages with the image I imported into SU in it but nothing has been done to it and I still get those two messages with nothing being done to the image in SU.
Humpmetwice
Postby TIG » Tue Dec 21, 2010 11:07 pm
Your 'Java' installation can't access the 'jar' file... Have you tried updating your Java installation ? It might be 'old'... :?
Global Moderator
Postby Dave R » Tue Dec 21, 2010 11:29 pm
TIG wrote:There's a 'time-out' for making the two 'Edges' files so it might simply be taking too long and exiting - I tweaked the time-out so that it waits longer [60secs] before giving up - please try this alternative with the problem file and see if it helps... viewtopic.php?p=293677#p293677
I downloaded your updated file and gave it a try. Still no go with that image file. And it was much less than 60 seconds before it quit so I doubt it is a timeout issue. Curiously, I downloaded another and much simpler PNG with a transparent background and had the same problem. Then I tried it with an SU toolbar icon PNG and it worked perfectly. There must be something wrong with some PNG files.
Global Moderator
Postby TIG » Tue Dec 21, 2010 11:46 pm
The 'transparent' areas need to be 100% transparent and the 'solid' areas need to be 100% solid ?
Can you post a problem png image - or PM it if it's 'sensitive'..... ;)
Global Moderator
Postby Dave R » Tue Dec 21, 2010 11:52 pm
Here's the second PNG I tried that didn't work. The other one is too large pixel-wise so I put it here instead.
Global Moderator
Postby Dave R » Wed Dec 22, 2010 12:00 am
FWIW, I opened the wreath PNG (the one in the link) in my image editor, selected the background and made it transparent. I couldn't see any difference in the image, though. I got the same results with the revised version as I did before.
Global Moderator
Postby Humpmetwice » Wed Dec 22, 2010 12:04 am
I am using vista so who knows?
Humpmetwice
Postby Oxer » Wed Dec 22, 2010 3:57 am
Hi TIG,
I have probe different combinations and to make it works this is the process in Ruby Console:
1. Type jar="EdgeDetector.jar"
2. Type UI.openURL("file:/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/plugins/SKMtools/"+jar)
With these two commands EdgeDetector runs and creates the 2 files into TrimmedImages folder.
Note that the path to EdgeDetector is to my User Account, on Mac you can place the Sketchup plugins in two locations:
a) /Users/User Name*/Library/Application Support/Google SketchUp/SketchUp/plugins
or
b) Library/Application Support/Google SketchUp/SketchUp/plugins
I hope this help you.
Oxer
Postby TIG » Wed Dec 22, 2010 12:52 pm
Strange I too run Vista with that version of Java... and have no problems!
Can you post screen-shots of your 'Java settings'...
Do you have full read/write/execute access-rights to the SKMtools folder and its contents?
I have a fix for a MAC problem that I'll post asap - this might also help you... watch this space...
Global Moderator
Re: [Plugin] ImageTrimmer 20101222
Postby TIG » Wed Dec 22, 2010 1:27 pm
Here's an update - viewtopic.php?p=293677#p293677 - it addresses some glitches with the MAC file paths [I hope! Thanks for the assistance Oxer et al]...
Global Moderator
Postby Dave R » Wed Dec 22, 2010 1:42 pm
Thanks TIG.
Have you had an opportunity to look at the two images I was having difficulty with? They were randomly collected off the web and I'm guessing that if I could find two problem images that easily, others would also come across them. Maybe it has to do with images saved from websites?
Global Moderator
Postby TIG » Wed Dec 22, 2010 3:24 pm
Dave R wrote:Thanks TIG.
You need to ensure that all sold areas are 'solid' with no transparency - edit the png, merge layers, flatten and select area of the transparent color and delete so transparency is only applied to the 'holes'...
I also tried and made the wreath image smaller so it processed faster...
But it still fails - must be something in the 'form'
As a result of your report I'm revisiting the Java in the EdgeDetector.jar as it had a glitch on the image's edge pixels.
I'm also adding a timed wait [3secs] for the 'dat' file to complete, as I found that 'dat' file was getting made BUT the Ruby was reading the file too soon so it wasn't getting the data...
I'll post updates when they are tested.... :roll:
Global Moderator
PreviousNext
Return to Plugins
Users browsing this forum: daotrungdung, hiteshpkhot and 11 guests
