by TIG » Fri Sep 30, 2011 4:27 pm
Don't do it you fool! "Just step away from the tree... put your mouse down where I can see it..." But seriously though folks Spend time up front getting the PNG right. Crop it tightly so there's minimal transparent background. Make sure that the outline isn't too complex, e.g. any thin leaves, twigs, branches etc, that are less than ~2pxs wide will be ignored because the edges they define will be considered 'coincident' and therefore won't make a face, BUT they'll still clog up the processing time if they are included in the pixels to look at - so either erase them so they are not considered OR fatten them up so they are used. The edges of every 'hole' in the PNG have to be individually processed, 'smoothed' etc - so the more holes the longer it'll take to complete. Be patient - if it whites-out it's almost certainly still working away on things, but it's just taking its time - so have a coffee [or a glass of beer!] or two and chill out... This palm took too many hours to process in the background while I did something else [>7!]... Palm14x.png It has a lot of thin 'fronds' to process...
Please, register (free) to access all the attachments on the forums. TIG
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by leminilab » Fri Nov 18, 2011 10:48 pm
Alright, I might be a little ambitious there but I have this logo which is a perfect example of things I usually would want to outline. Usually I open these vector logos in Illustrator, export it to dwg, import in SU and make faces et voilà. But with this one, I get a bad export from Illustrator which I don't know how to clean: messy dwg export from Illustrator.jpg So I turned to ImageTrimmer and blessed TIG and all the ruby programmers one more time (  ). But, believe it or not, when I open this png logo as an image in SU, save the file and launch ImageTrimmer, the statusbar appears and at the same time it opens my Nokia Ovi Store app (  ), then stops and nothing happens... What do you think f that (especially the Nokia part  )?
Please, register (free) to access all the attachments on the forums. Live every day as if it were your last and then some day you'll be right.
leminilab
- Name: Nicolas
by Rich O Brien » Fri Nov 18, 2011 10:55 pm
Is this Nokia thing a Java launcher? I know this plugin is heavily reliant on Java so it could be related to that? Anyway I'd add any Ruby Console messages here if there are any showing. The thing I've noticed with ImageTrimmer is that it's doing something even when it appears nothing is happening.
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
- SketchUp use: engineering and mechanical design
by leminilab » Fri Nov 18, 2011 11:02 pm
Rich, It is an app I'd installed to backup my phone's contacts onmy computer... It's called NOkia Ovi Suite. Made me laugh a while Here's the Console message from my other computer (which doesn't have the Nokia suite installed... You never know...  ): Error: #<Errno::ENOENT: No such file or directory - C:\Users\le miniLab\Desktop\TrimmedImages\logo-nb[Edges].dat> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:238:in `readlines' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:238:in `make_edges' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:187:in `process_image' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:164:in `initialize' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:769:in `new' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:769 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:238:in `call' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:238 I think this time Image Trimmer didn't do anything while it looked like it didn't do anything!
leminilab
- Name: Nicolas
by TIG » Fri Nov 18, 2011 11:32 pm
Nicolas
Seems you might not have Java enabled correctly... Look back through this thread about how it needs to be installed / control-panel etc... and that any .jar files must be executables, and NOT opened by other apps, like zip apps etc...
If Java is properly set up the .jar files will fire and thereby make the files needed for ImageTrimmer to work...
- Global Moderator
- Name: TIG
- License type: Pro
by leminilab » Fri Nov 18, 2011 11:44 pm
Thank you very much TIG, I'll check that tomorrow!
leminilab
- Name: Nicolas
by leminilab » Sun Nov 27, 2011 11:22 am
Hi! It works. I had to create an admin account with a password ot get it to work but it worked perfectly. I also understood what created these unwanted lines on dwg export from Illustrator: There was a clipping mask with a gradient applied to the shape... I ungrouped the shape and the gradient, re-exported and it came out perfect and could use my usual workflow. Anyway: thank you very much for your time and thanks a lot for this very valuable tool!
leminilab
- Name: Nicolas
by unclebim » Tue Nov 29, 2011 4:12 pm
I have been using this plugin and I am very happy with it. But lately I am having problems with some, not all, images, that when processed appear like that. Just very few pixels are included in the component made by the plugin. What could be the reason?
unclebim
- License type: Pro
- SketchUp use: interior design
by JMdesigns » Tue Nov 29, 2011 4:42 pm
unclebim wrote:Hi,
HI, how did you change your Java settings? I have windows 7 pro 64, and cant seem to get this plugin to work?
JMdesigns
- Name: JD
by unclebim » Tue Nov 29, 2011 4:46 pm
JMdesigns wrote:unclebim wrote:Hi,
I did not change Java settings, I run SU as administrator and it works. The only problem I have lately is as quoted.
unclebim
- License type: Pro
by JMdesigns » Tue Nov 29, 2011 5:17 pm
JMdesigns
- Name: JD
by TIG » Tue Nov 29, 2011 5:23 pm
unclebim
Looks to me like your PNG has lots of semi-transparent areas. The way the tool works is the find all transparent pixels and then use them to determine the 'outlines' of the image that will remain. If a pixel is even slightly transparent it's taken as one to be considered when forming the 'outlines'! So typically when editing the image out-side of Sketchup 'pre-trimming' you need to ensure that firstly there are NO transparent pixels - i.e. you need to 'Merge' any layers and 'Flatten' it. Then add back a transparent alpha layer. then select all of the outer 'white' areas [sometimes the pixels are 'black'!] perhaps using a magic-wand tool [depends on you ImageEditor] and delete them. So now you should have a solid image with just the 'background' showing as transparent. Save the PNG and [re]import into your SKp as an Image and try ImageTrimmer on it again... This time what you want to be left behind should be...
- Global Moderator
- Name: TIG
- License type: Pro
by dannielstevanus » Thu Apr 19, 2012 8:18 pm
dear TIG :
I've try image trimmer plugin, but after the process it nothing happened to my png image.. can you explain whats wrong with that??
dannielstevanus
- Name: Danniel
by TIG » Fri Apr 20, 2012 12:12 pm
dannielstevanus wrote:dear TIG : I've try image trimmer plugin, but after the process it nothing happened to my png image.. can you explain whats wrong with that??
If I saw the PNG image it might help I suspect you haven't got any transparent pixels in it [as the 'background'] to be erased, so it doesn't change, except it becomes a component? ... Are there any error messages or anything shown in the Ruby Console [open it before processing an image]. Post the PNG so we can at least start to see what the issue might be...
- Global Moderator
- Name: TIG
- License type: Pro
by dannielstevanus » Sun Apr 22, 2012 1:08 pm
It finally worked when i try to run sketchup as an administrator.. its a great plugins TIG, i want to appreciate your work for it.
it can work fine with people's image, but unfortunately when i try it to trees image it can't work properly and cause my sketchup stop working.. I think its because the complex transparent image in tree object so this plugins should process all of them one by one that cause this program run too heavy
I think this will be better if this plugins can process trees image, maybe it don't need too details, just enough trimming an outline of the tree. I hope I can choose an option whether I need a details trimming or just a basic trimming
I hope you can do some upgrade for this great plugins to become an excellent perfect image trimmer plugins in sketchup (just for suggestions).
i will upload my tree object that can't be processed with this plugins so you can try it TIG..
thanks for your great plugins best regards
- Danniel Stevanus -
dannielstevanus
- Name: Danniel
by Gaieus » Sun Apr 22, 2012 2:04 pm
Danniel, Complex geometry is just complex geometry no matter how you create it; as a 3D tre or as a 2D, face me component with extremely detailed cutouts for realistic shadows. Both will be handled with issues in SketchUp. For such plants, a much more rough, simple manual outline is fine most of the time. Or use some technique Alan Fraser describes here: viewtopic.php?p=48726#p48726
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by TIG » Sun Apr 22, 2012 3:04 pm
After it's trimmed you need to simplify the outline [built-in] BUT you need to offer it a sensible image with reasonably sized areas/holes and distinct transparent/opaque areas - I'll look at the image and reply shortly...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Sun Apr 22, 2012 5:44 pm
Your tree png will fail to give a good/quick result because many of its pixels have slight transparency. The Trimmer removes all transparent pixels, even semi-opaque ones. So Edit the png [with say Gimp]. Flatten it so there is no transparency. Add back a transparent alpha-channel layer. Magic-wand select and then delete all of the 'white' background pixels. There are many <=2x2 pixel 'holes' and leaves which will be ignored anyway [after being 'inspected'], so a little image-editing to avoid these would be advisable too - re-scale/size, or manual edit pixels, or both... Also crop it to remove unneeded transparent background pixels, which contribute to processing time unnecessarily as they will be ignored, but still need considering... Images with more than ~1,000,000 pixels can take ages [depending on their complexity]. I made a ~20,000px version... It then takes about 15 minutes to trim it into this very complex form... If Sketchup becomes unresponsive it doesn't mean it's crashed/hung; it's just busy process - the Task Manager will show it is still hard at work... If you were to trim around a face using the image as a texture/guide it will take some time. ImageTrimmer does it for you - it's probably not too much quicker, but you can do something less tiresome as it works in the background... You can't simplify the 'quality' of the trimming until after all pixels are considered because how else might we know what we have to do ?
- Global Moderator
- Name: TIG
- License type: Pro
by pololo » Mon May 14, 2012 10:39 am
pololo
- Name: pololo
by charly2008 » Wed May 23, 2012 11:49 pm
It's a really good tool.
Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
charly2008
- Name: Karlheinz Hauser
- SketchUp version: 7
- License type: Pro
by charly2008 » Sun Jul 29, 2012 1:45 pm
So far I had no problems with this tool. Now I wanted to trim the Romans PNG and get the result shown below. I have no idea why.
Charly
charly2008
- License type: Pro
by TIG » Sun Jul 29, 2012 2:59 pm
The issue is that the PNG image has transparency associated with most of its pixels. 'ImageTrimmer' only keeps 100% opaque pixels. If you edit the PNG [with say Gimp]. Flatten it [the background goes white]. Add a Layer with transparency [alpha-channel]. Use the magic-wand to select the background [here it's two clicks to include the 'hole' between the men]. Then auto-crop the image to minimize the background size - every pixel has to be inspected so the fewer there are the quicker the trimming. It then ImageTrims OK... vexill2bCapture.PNG vexill2b.skp vexill2b.png Incidentally - I recently undated my compression software... and when I just tried to use ImageTrimmer it failed [hung] - this was because for it to work .jar files must open with their default application [Java] BUT by default my compression software has .jar set as one of its file associations and so it opens the file rather than Java executing it... It was easily fixed by resetting the compression tool's preferences NOT to include .jar as one of its file formats... So remember... ensure .jar files execute with Java and don't open with your compression software. Even I get tripped upnow and again...
- Global Moderator
- Name: TIG
- License type: Pro
by charly2008 » Sun Jul 29, 2012 7:08 pm
Hi TIG,
thanks for your detailed explanation. I learned something again.
Charly
charly2008
- License type: Pro
by picky1958 » Fri Feb 08, 2013 9:48 pm
Sorry! I am NOT getting it! I tryed everything, but I can't get it to work. I don't know much about Java. I see those two files from/to get created as well as a copy of the image in the TrimmedImages folder, but nothing else happens. I tryed to run SU as admin, at least from/to got created... but i did't get any futher. Any "simple" (for dummies) suggestions? Thanks
picky1958
- Name: Ralf
- License type: Free
- SketchUp use: hobby
by TIG » Fri Feb 08, 2013 11:59 pm
Please fill in your user-profile so that we know your versions, OS etc... Help us to help you.
This tool uses some Java functionality that is not built into the Ruby version shipped with Sketchup. It uses some '.jar' files which are small 'executables' that do a single specific job - in tis case in manipulating images and their data etc. It works on PC and MAC, but you must have Java 'enabled'. I think more recent MACs have this as 'optional', but most PCs have it set up by default. Another issue is that these '.jar' files are small 'executables' - like an '.exe' file - and some [de]compression software hijack this file-type extension [along with many others, without asking, as it is installed] and it will try to 'open' the .jar itself so that you can see its contents. If so, then you must remove '.jar' from that app's list of 'associated file-types'. A '.jar' file must always be set to 'execute' - i.e. open with Java...
Also the tool writes temporary 'ini' files to a subfolder in the Plugins folder so you must ensure that you personally have FULL read/write security permissions to the Plugins folder and all of its subfolders and files...
Many hundreds of users get this tool to work 'out-of-the-box'... so you need to check your system settings and retry... We know it is making copies of the image etc, but the timing of the stall suggests that the next step with the .jar file is the thing that is failing...
- Global Moderator
- Name: TIG
- License type: Pro
by picky1958 » Sat Feb 09, 2013 6:39 am
Hi TIG! I know some people are getting the tool working "out-of the-box"... and this drives me crazy!  I mean, until now I never had any problem with anything installed on my PC, but this time I really can't find out what I am doing wrong. So... my PC runs Windows 7 Home Premium SP1 64 Bit. I got Java set to open .jar files. I am not sure about the read/write stuff. I tryed to change the settings of the folder but once I wanted to save them, it didn't do it. So I retried again and again, but every time it didn't save the changes. That's where I started SU as admin and it did create at least the from/to.ini files, which it didn't before. After that nothing else happened. No warning, no message, nothing. Thanks for your help! Cheers from Germany. Ralf
picky1958
- Name: Ralf
by TIG » Sat Feb 09, 2013 10:59 am
It looks like a permissions issue: especially since you get different results as yourself and as an Admin. Being an Admin is not sufficient to allow you to have full access to things within a folder if its permissions are inherently limited. Log in as an Admin. You'll have to translate the following 'titles' into German if your locale is not 'EN'... Highlight the Plugins folder's icon and use the right-click context-menu > Properties > Security > Edit set permissions to that folder to FULL for everyone, including yourself! Apply and OK to save. Check that the permissions have filtered down and that FULL also applies to the Plugins folder's contents - both files and subfolders, and their contents etc. Retry using the tool.
Tip: you might from time to time want to add files/subfolders into other Sketchup folders... I recommend you also fix the permissions of the Components, Materials and Styles folders...
- Global Moderator
- Name: TIG
- License type: Pro
by picky1958 » Sun Feb 10, 2013 9:35 am
Ok, now I really tryed every single combination and I'm still not able to make it work. I guess I am giving up on this one  Is there any other tool I can use just to trace around the transparent part of a png without having to do it manually? Probably not, ha? Thanks for your help. Ralf
picky1958
- Name: Ralf
by leminilab » Sun Feb 10, 2013 10:26 am
Adding a Windows Admin account with a password (don't know if it has something to do with it...) did the trick for me.
leminilab
- Name: Nicolas
by picky1958 » Sun Feb 10, 2013 10:29 am
Hi leminilab, that's worth a try! Did you run SU from that account then?
picky1958
- Name: Ralf
Return to Plugins
