[Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
• Page 2 of 2 • 1, 2
Re: Caleidos4D Ribbon Pubblic Beta 1Majid,
the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar. let's see which one's you have that are not working?
Re: Caleidos4D Ribbon Pubblic Beta 1hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
do you have organizer.rb running? have you checked to see that you have the /caleidos4d Caleidos4D_Ribbon.rb in the plugins folder?
Re: Caleidos4D Ribbon Pubblic Beta 1Hi Caleidos4D,
Its a great plug in, thanks for share it Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active Regards' Iwan
Re: Caleidos4D Ribbon Pubblic Beta 1thanxs mates for your kind helps
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
Re: Caleidos4D Ribbon Pubblic Beta 1Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: Caleidos4D Ribbon Pubblic Beta 1thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars...
Re: Caleidos4D Ribbon Pubblic Beta 1thank to all friends for help in topic :up: my english is very bad....
this is a .gif for usage and preview features in next release Please, register (free) to access all the attachments on the forums.
can't wait to try this out- in English Etch-A-Render
SU Pro 8.0.4810 Mac/ SU Pro 8.0.4811 PC Thea: (MacOSX 32bit) RV481_v1.0.7 (SU2TH .86)/ (PC 64bit) RV481_v1.0.7 (SU2TH .86) Vray: VfSU 1.49.01
Well, I appreciate this because I only know English; but I was also trying to come up with a language translation strategy in order to provide translations to any language. I think JavaScript can be used to iterate over the tooltips, and set the Text according to the tooltip id (for example.)
I'm afraid I can't even find "La risorsa richiesta è accessibile qui so I can click on "qui" Update I got it by pasting in "http://caleidos.altervista.org/Download/caleidos4d_Ribbon.zip" and it automatically downloaded. "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)Nice update. English tooltips are perfect! Any plans to add FredoScale?
Some of my 3D crap
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)I wanted insert SfedoScale and BezierSpline, already in this release, but I can not find the call for the plugins in various fredo's libraries ...
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)renderplus rpedits copy selection tool bug splatted EVERY time i ran the command - so i started removing my most recent plugins - and caledios was the culprit
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)Caleidos4D,
Thanks for the plugin. Looks interesting. Got a question. When you select the major frames on the left side (Costruction[oops,btw spelling error], Projection, 2D, Modelurs,..etc), they change to a highlighted orange color. But when you select another, any previous ones are still hightlighted orange. Wondering if this is a bug? Oh, and an off topic question. Is there a easy html editor for laying out buttons, like this, on a webpage? Or wondering what editor, you used? I mean, if a beginner wanted to make the html portion of a web UI, like this. I can make a simple one by hand, like a column of buttons, but not like this. -Kwok
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)EDIT 23-Sep-2011 New Download URL:
DOWNLOAD Caleidos4D Ribbon Pubblic Beta 1.1 ( http://caleidos4d.blogspot.com/2011/08/ ... ta-11.html )
This fun, I can be free to load the new plug-in, strong ![]() I come from China, is to learn
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)dear mate, I like your plugin , and here saw a request, that seems to be combined in your plugin:
viewtopic.php?f=10&t=46094 do you mind to play with your interface please? I guess it'd be a great step forward . درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
Re: Caleidos4D Ribbon Pubblic Beta 1Como faço para instalar o Caleidos4d
Re: [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010I think you are asking how to install this plugin?
I believe there is a link to an external website or hosting site and you must download from there. Looks like it may be "caleidos4d.blogspot.com" I take the slow, deliberate approach in my aimless wandering.
SketchUcation One-Liner AdvertsAre you a Premium Member? Get your freebies here. Are you not> a Premium Member yet? Upgrade your account to grab these freebies instantly.
