[Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
Re: Caleidos4D Ribbon Pubblic Beta 1
Postby caleidos4d » Sat Oct 23, 2010 10:05 am
Krisidious wrote:the hover tips are in Italian? French?
is there a way to change the resolution size of the ribbon? mine doesn't fit inside of 1024?
is there a way to make your own ribbon preset?
Italian :) in the next release, all tooltips in English :D
caleidos4d
Postby dizain » Sat Oct 23, 2010 12:18 pm
Ciao Caleidos4D,
Ti ringrazio per il tuo lavoro,
ho istallato il plugin ma non riesco a farlo funzionare come dovrebbe.
Puoi aiutarmi?
Allego immagine della schermata dove non si vede l'area del disegno.
Ciao e di nuovo grazie.
David
Hello Caleidos4D,
Thank you for your work,
I installed the plugin but I can not get it working as it should.
Can you help?
I attach a screen shot where you see the drawing area.
Hello and thanks again.
David
dizain
Postby thomthom » Sat Oct 23, 2010 12:26 pm
Did you resize the window?
PluginStore Author
PluginStore Author
Postby caleidos4d » Sat Oct 23, 2010 12:29 pm
dizain wrote:Ciao Caleidos4D,
Puoi aiutarmi?
David
Hello Caleidos4D,
Can you help?
David
Hi :)
you have to resize the ribbon and the SketchUp window, to match your monitor ;)
caleidos4d
Postby caleidos4d » Sat Oct 23, 2010 12:31 pm
Work in progress:
in next release I will fix it the size of monitors in 1024 and the iframe, They will also be floating ;)
caleidos4d
Postby charly2008 » Sat Oct 23, 2010 1:02 pm
I wanted to try out as a precaution in Sketchup 8. But can not find this plugin. Am I doing something wrong?
Charly
charly2008
Postby charly2008 » Sat Oct 23, 2010 2:04 pm
Solved, found it in the plugin menu. It is very interesting extension. Many thanks to Caleidos4D.
Charly
charly2008
Postby caleidos4d » Sat Oct 23, 2010 4:15 pm
charly2008 wrote:Hi,
Charly
:thumb: :D
caleidos4d
Postby tfdesign » Sat Oct 23, 2010 5:37 pm
solo wrote:
One reason I'll never switch to Windows is
.... You like shiny things? :mrgreen:
Like this?
:P
Is that a handle on the front, to remove the beer? :shock:
My book "Let's SketchUp!" Download from here
tfdesign
Top SketchUcator
Postby tfdesign » Sat Oct 23, 2010 5:43 pm
But hey, so far, so good! 8-)
tfdesign
Top SketchUcator
Postby Burkhard » Sun Oct 24, 2010 11:07 am
Just a question. The whole thing does not make really sense when there is no way to stop starting the toolbars while starting Sketchup.
When I disabled the tools in the preferences, the toolbars in the ribbon does'nt work. If they are enabled the toolbars floating my window again ( on Mac ) so I have to enable all Toolbars manually.
Is there a way to force the Toolbars to disappear/quit at once?
Burkhard
Premium Member
Premium Member
Postby majid » Sun Oct 24, 2010 7:52 pm
thanx for your job, but still nothing is happenig at my side!!! plz help
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby Krisidious » Sun Oct 24, 2010 8:46 pm
what seems to be the issue Majid?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby thomthom » Sun Oct 24, 2010 9:13 pm
Majid: it looks as though you have maximized the toolbar window - just resize to back to a fitting size.
PluginStore Author
PluginStore Author
Postby majid » Sun Oct 24, 2010 10:04 pm
almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue :D
majid
Top SketchUcator
Postby Krisidious » Sun Oct 24, 2010 10:08 pm
Majid,
the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
let's see which one's you have that are not working?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Mon Oct 25, 2010 3:23 am
hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
do you have organizer.rb running?
have you checked to see that you have the
/caleidos4d
Caleidos4D_Ribbon.rb
in the plugins folder?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby iwanwidjaja » Mon Oct 25, 2010 7:11 am
Hi Caleidos4D,
Its a great plug in, thanks for share it :berserk:
Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active :lol:
Regards'
Iwan
iwanwidjaja
Postby majid » Mon Oct 25, 2010 5:11 pm
thanxs mates for your kind helps :) .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
majid
Top SketchUcator
Postby EarthMover » Mon Oct 25, 2010 6:40 pm
Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby majid » Tue Oct 26, 2010 5:15 am
thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars... :( (as I saw a black screen on some screenshots above) . maybe it could be an option for next update ,plz . :) it workes fine in way you described. thanx again
majid
Top SketchUcator
Postby caleidos4d » Tue Oct 26, 2010 6:53 pm
thank to all friends for help in topic :up: my english is very bad....
this is a .gif for usage and preview features in next release
caleidos4d
Postby troyhome » Tue Oct 26, 2010 8:29 pm
Caleidos4D wrote:thank to all friends for help in topic :up: my english is very bad....
can't wait to try this out- in English :)
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
troyhome
Postby Jim » Tue Oct 26, 2010 11:52 pm
Caleidos4D wrote:For translate:
in the next version, I will translate the tooltips in English but I also accept suggestions :D
Well, I appreciate this because I only know English; but I was also trying to come up with a language translation strategy in order to provide translations to any language.
I think JavaScript can be used to iterate over the tooltips, and set the Text according to the tooltip id (for example.)
Jim
Global Moderator
Postby Bob James » Fri Oct 29, 2010 5:42 am
troyhome wrote:
Khai wrote:all I'm getting at the link is
"alterVista
La risorsa richiesta è accessibile qui
you have to click "qui"
I'm afraid I can't even find "La risorsa richiesta è accessibile qui so I can click on "qui" :( :oops:
Update
I got it by pasting in "http://caleidos.altervista.org/Download/caleidos4d_Ribbon.zip" and it automatically downloaded.
Bob James
Premium Member
Premium Member
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
Postby caleidos4d » Fri Oct 29, 2010 8:05 pm
Update: 1.1 ;)
caleidos4d
Postby EarthMover » Sat Oct 30, 2010 3:36 am
Nice update. English tooltips are perfect! Any plans to add FredoScale?
EarthMover
Premium Member
Premium Member
Postby caleidos4d » Sat Oct 30, 2010 4:45 pm
I wanted insert SfedoScale and BezierSpline, already in this release, but I can not find the call for the plugins in various fredo's libraries ...
caleidos4d
Postby tony bombata » Wed Nov 03, 2010 1:07 pm
renderplus rpedits copy selection tool bug splatted EVERY time i ran the command - so i started removing my most recent plugins - and caledios was the culprit :(
tony bombata
Premium Member
Premium Member
Postby kyyu » Tue Jul 12, 2011 8:48 pm
Caleidos4D,
Thanks for the plugin. Looks interesting. Got a question. When you select the major frames on the left side (Costruction[oops,btw spelling error], Projection, 2D, Modelurs,..etc), they change to a highlighted orange color. But when you select another, any previous ones are still hightlighted orange. Wondering if this is a bug?
Oh, and an off topic question. Is there a easy html editor for laying out buttons, like this, on a webpage? Or wondering what editor, you used? I mean, if a beginner wanted to make the html portion of a web UI, like this. I can make a simple one by hand, like a column of buttons, but not like this.
-Kwok
kyyu
Next
Return to Plugins
Users browsing this forum: dexboisu, DmitrijOtdelKa, nhocchemthue and 12 guests
