[Plugin] C of G Reporter 1.3
Re: [Plugin] C of G Reporter 1.2
Postby Bertier » Sun Oct 10, 2010 9:05 pm
there is no accent in my path ....
cofgreporter
undefined method `definition' for #<Sketchup::Group:0xe005344>
CoG Report File:
'F:\neo batitrad\Bar_Ka/console_CofG_Report.csv'
Cannot be written - it's probably already open.
Close it and try making the Report again...
Exiting.
nil
Bertier
Postby pilou » Sun Oct 10, 2010 9:31 pm
Have you save your file SKp in the samme path?
Speedy Galerie
Top SketchUcator
Postby TIG » Sun Oct 10, 2010 11:50 pm
Bertier
Did you install v1.2
Although it might still fail you should get more error messages... :?
Global Moderator
Re: [Plugin] C of G Reporter 1.3 20101010
Postby TIG » Mon Oct 11, 2010 12:01 am
Heres's v1.3 viewtopic.php?p=278046#p278046
It corrects the glitch that a few users might get with 'group.definition' - OK if you have some of my other tools installed but not this one alone - now sorted...
Please try and report back... :?
Global Moderator
Postby Bertier » Mon Oct 11, 2010 4:39 am
hooray !
it's working :
cofgreporter
CofG Report written to
nil
nice.
Bertier
Postby Bertier » Mon Oct 25, 2010 11:43 am
for some reason, using CoG makes SU "not responding"....
any clues ?
Bertier
Postby TIG » Mon Oct 25, 2010 12:26 pm
Bertier wrote:for some reason, using CoG makes SU "not responding"....
any clues ?
There's a lot of intensive stuff needed to 'integrate' possibly hundreds of slices through the selected object and find their common centroids...
You should get a 'count-down' 'nnn of mmm' report in the VCB and then a '...processing ......' ?
It will finish eventually...
Global Moderator
Postby ksjoern » Fri Sep 23, 2011 9:11 am
Hi, this is a very interesting plugin. I'm going to try it.
Two things struck me.
1st The rounding of numbers (but this is something I can work with ... )
2nd Hollow objects (pipes, etc.) are calculated as full volumes.
Can this be repaired with the hollow objects? That would be great.
ksjoern
Postby TIG » Fri Sep 23, 2011 9:30 am
You can edit the number of dp's in the code - in the lines around the first half of the 300s...
I'm unsure about your comment - objects that are individual 'solids' are reported correctly - even when there are hollows. However, if you combine objects into a group it will by its nature cease to be a true manifold solid as there are internal 'partitions' - therefore sometimes the volume calculations can be awry. You should take the CofG of the parts and then make a combined CofG - this is also important if the parts have different densities...
Can you supply an example where manifold solid objects are returning incorrect values.
This one returns proper results even if the two groups are nested into one, as the 'slices' needed to calculate the CoG are maintained - but it is not always possible...
Global Moderator
Previous
Return to Plugins
Users browsing this forum: 3008mirror, carly2k, firtonento and 19 guests
