Sorry, but there are time constraints for working on these 'free' extensions...mariocha wrote:Pity that LanguageHandler is not there.
It was all done.![]()
with fr strings file also.
[Plugin] MirrorRe: [Plugin] MirrorTIG
Re: [Plugin] MirrorOk then,
I re-did it. Here is the fr localized version. Signed. Very easy to add any other language. (mirrored entities are selected at the end) I would be honoured if next upgrade could stem from this one. ![]() Mario C.
Certified SketchUp Trainer, QC CA. Every rule has exceptions, but some.
Re: [Plugin] MirrorComing from the VFX community, the Mirror Object/Face tool is common across all 3D packages (be it Lightwave, Max, Maya, Etc...). I found it bizarre the SU doesn't have this native function (weird). You really miss the "Mirror Tool" when hopping into a packages that don't offer it.
Thank you for you're development time and great little plugin, and, preventing me from loosing my mind, because I'm soooo used to having this tool! Works great in SU2017, does what it claims (simple and sweet). Wink.... -Terry Re: [Plugin] MirrorHere's v8.0
It sidesteps the glitches some PC users get when they have accented-characters in their user-name. TIG
Re: [Plugin] MirrorHere's v9.0
It restores compatibility with v8, which was inadvertently lost in the last update.
Re: [Plugin] MirrorAwesome plugin. SketchUp probably should have this tool/feature built in but this plugin feels the need and it works great. Much easier than having to copy, scale (-1) and then move into position.
Re: [Plugin] MirrorMr. TIG
What about another version of this tool ? Let's call it '1-click Mirror' Cursor snaps to nearest selection bounds plane (or if 'Ctrl' or 'Shift' pressed to worlds x, y or z planes at pick point), Click and .. that's all. No prompts, no questions. Just 1 click. As option: Cursor as transparent rectangle for visual presentation of mirror plane. In 2d projections cursor is a line presenting a plane perpendicular to view plane. New mirrored object is selected after operation and eventually move tool activated for additional positioning.(?) Similar to current 3point Mirror mode but plane is predefined by bounds of selection. No additional angles, only pure mirror in local (&/or world) x, y, z.( Even z-mirror is rarely used in my opinion and can be omitted-???) May be I can do it by myself, but it will take me few weeks or months, a lot of digging inside incomplete documentation and few hundred SketchUp testing restarts. Re: [Plugin] MirrorI don't know why selection is lost when I mirror entities and don't erase original selection. On the video tutorial selection skips to newly-created geometry which is expected behaviour. In my SU after mirroring, nothing is selected.
![]() Re: [Plugin] MirrorIf you choose to NOT keep the original object[s], then the selection transfers to the mirrored objects. Currently if you choose to keep the original object[s] nothing is selected afterwards. I appreciate that in the usage movie the mirrored object[s] remains selected in both cases. I had not noticed the change ! I suspect that it's due to the way newer versions of SketchUp handle references to exploded entities... I'll look at the code and see if it's easy to reinstate the original behavior. TIG
Re: [Plugin] MirrorHere's v10.0
The original highlighting behavior has been restored. The mirrored-copy now remains highlighted, irrespective of the user's choice to keep/delete the original. Note: after installing the update you need to restart SketchUp to see the changes... TIG
Re: [Plugin] MirrorThis is a great plugin. It could be even better (for me anyway) with a couple of tweaks. It would be great to be able to set some defaults. For example, I often work in 2D. If you use a single line as a mirror "plane", the default is that faces get reversed. I never want that and would like it to operate the way it does if you select a vertical third plane (bit without having to do so in 2D drawing). Secondly, I almost never want to erase the original object and would like to set that as the default instead of having to confirm it each time.
Re: [Plugin] Mirror
viewtopic.php?p=471262#p471262
Re: [Plugin] MirrorTwo clicks rotate the object. There is no mirror reflection.
![]() Robert Re: [Plugin] MirrorThe usual usage for this tool is "3-point", which then defines a 'plane', about which a 'mirror' [reflection] occurs.
A "2-point" transformation, 'about a line', cannot do what you seem to consider to be a true 'mirror' [reflection] - although technically I suspect that it is - because the object is rotated around the line, but keeps its original orientation otherwise. e.g. If you were to try to do this manually, then you could not expect an arbitrary 2-points to set in train what you wish, because a third point is needed to determine the 'plane' about which the hoped-for mirroring can be done... TIG
