SketchUcation Plugin Store
[Plugin] Select by Material, and Hide All Unselected
Re: [Plugin] Select by Material, and Hide All Unselected
Postby Bob James » Tue Oct 05, 2010 6:34 am
Karen,
Thanks for the offer to look at my model, but I think I have it now:
So the sequence is to make the material active, use "Material Selection" and then use "Hide All Un-selected".
CadFather: I did not see the other entry in the plugin list: "Hide All Un-selected".
That's sort of an unusual approach. I would suggest that the "Material Selection" entry have a fly-out menu for the Hide option.
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
Premium Member
Premium Member
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Advanced
Postby kwalkerman » Wed Oct 06, 2010 1:45 pm
Bob (and CadFather),
I wanted to leave them separate because I thought 'hide all unselected' could be useful for other applications... But I think I can figure out a fly-out.
Karen
kwalkerman
Postby CadFather » Wed Oct 06, 2010 4:22 pm
i for one prefer them separate
Quarr-IT - SketchUp Training from the Master.. . ;) .
CadFather
Name: Max Coppoletta
Postby McGyver » Thu Oct 07, 2010 5:21 am
You rock!! I'm finishing up a huge model and just this morning I was thinking I wonder if there is anything that could... well, do what this ruby does!! THANK YOU!! :berserk:
McGyver
Postby Bob James » Thu Oct 07, 2010 5:38 am
CadFather wrote:i for one prefer them separate
I yield to the power :D (As long as they stay together in the plugin list)
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby ahnvtk » Thu Dec 23, 2010 3:01 am
This is useful, thanks. :thumb:
One limitation: it seems as if this will only select faces with a material if both sides of the face contain the material. For inconsistently textured scenes that would mean the material is overlooked.. Maybe it could have two modes: one where it will select only faces with the material on both sides, and another that selects faces if the material is on either side?
ahnvtk
Postby kwalkerman » Sat Feb 12, 2011 8:17 pm
Right now it looks only at the front side. I could do another run that looked at the back side, if that would help?
kwalkerman
Postby ahnvtk » Fri Jul 08, 2011 10:06 pm
kwalkerman wrote:Right now it looks only at the front side. I could do another run that looked at the back side, if that would help?
(Extremely late in reply - sorry)
Yeah, that would help - and then two options or modes depending on the result. 1) If the material on the back side is the same as the front, group it with everything else that has that material. or, 2) If the material on the back side is different, group it separately (in a group with all faces that have this back/front combination). That would be great.
ahnvtk
Postby OG1 » Sat Aug 06, 2011 12:38 am
I know it's been a while since this topic was started and posted in, but I just had to say THANK YOU!!! This plugin has saved me from going more mental! The meshes I make need to be low poly, so using both sides of a face is mandatory! It usually has a different texture on each side. After I export my mesh, the editor I work in reports if I have unpainted faces and prevents me from continuing with my submission. I sometimes go bonkers trying to find the unpainted faces. They are usually small faces, faces that shouldn't even be on the mesh, or like the post in the other thread, "couldn't see the forest through the trees"! :)
The one thing I couldn't do, was to unhide the faces I hid, without doing the 'Undo'. (unless I missed something?) Anyways, not a problem doing that, since this plugin has just saved me hours, if not days, trying to find those little buggers.
Sorry for the long reply, but I am extremely grateful and thankful for this plugin, as with all the others in here that make my life easier. This one just made me saner! Thank you!!!
I got my bill for paying attention. I got robbed!
OG1
Postby dereeei » Mon Oct 31, 2011 8:45 am
Nice one! And useful !
It would be neat to have some visual clues about where is the selected "thing", like thomthom's Solid Inspector. In this way, it would me much easier to navigate in the place. On a large model, to hide everything is a time-consuming operation. Also, to unhide everything after that is nasty, if there are a lot of nested entities.
dereeei
Postby McGyver » Thu Nov 24, 2011 5:50 pm
I probably should of mentioned this a year ago... this is probably a Mac issue. Following the above directions, I can not get this plugin to work. Big models (over 16 MB) crash SU 8 and 6 when activating "Hide unselected"... and in general the plugin either only highlights the edges of the wrong material (randomly) or hides the entire model with a randomly chosen material deselected, but still hidden.
I'm guessing this is a Mac (intel core 2 duo running OS 10.5.8 ) issue, since nobody else has reported anything similar in over a year.
I'm not complaining, I just thought you might want to know about it... sorry I did not post this earlier, I was very busy when I had tried it and when it did not work... I sort of moved on and forgot about it... Sorry.
McGyver
Postby sauerkrauten » Wed Feb 13, 2013 10:06 am
McGyver wrote:You rock!! I'm finishing up a huge model and just this morning I was thinking I wonder if there is anything that could... well, do what this ruby does!! THANK YOU!! :berserk:
+1 :D
Great plugin Karen, very useful on large models.
Huge thanks :enlight:
sauerkrauten
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Plugins
Users browsing this forum: bricofranck59, mohamedhassan, pierino, rayersneo and 11 guests
