[Plugin] Bitmap To Mesh
Re: [Plugin] Bitmap To Mesh (0.2.0b) — 03 October 2010
Postby thomthom » Sun Oct 03, 2010 5:18 pm
Yea - the last texture I tested was 512x512 - heavy mesh. And I'd forgotten that Autosave was on - every 5 mins. x_X
PluginStore Author
PluginStore Author
Postby dedmin » Sun Oct 03, 2010 5:20 pm
dedmin
Postby dedmin » Sun Oct 03, 2010 5:30 pm
:berserk: :berserk: :berserk: :berserk:
dedmin
Postby shura » Sun Oct 03, 2010 10:30 pm
Why don't I get the Curve Simplification to work?
shura
Postby thomthom » Sun Oct 03, 2010 10:41 pm
hm... possibly you have a version where it failed on closed loops. I might not have uploaded a corrected version...
PluginStore Author
PluginStore Author
Postby david_h » Mon Oct 04, 2010 4:26 pm
So I notice these wonderful meshes created. How is one controlling the height of the extrusion?
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby pichuneke » Tue Oct 05, 2010 4:30 pm
The pieces on the roof (above the pediment) are made with your plugin :)
Reconstrucción del Templo de Artemis Agrotera 4 by Egocentrico, on Flickr
Click here to see it in bigger size (1024 px):
http://www.flickr.com/photos/28798115@N ... otostream/
Forgive my spanglish...
pichuneke
Postby Ghalko » Wed Oct 06, 2010 5:19 am
So I read the posts and then thought nothing of trying a 2048x2048 heightmap produced by L3DT (terrain generating program.) :shock: Maybe I should try a bit smaller at first. Then I won't just freeze sketchup and make my patience run out... :?
I will try with a smaller (much smaller) one first and post the results.
Bryan
Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
Ghalko
Postby solo » Wed Oct 06, 2010 6:12 am
Color, the darker the black and brighter the white will produce the greatest crests and troughs.
http://www.solos-art.com
solo
Global Moderator
Postby Ghalko » Wed Oct 06, 2010 6:57 pm
After letting a 384x384 (meters) heightmap simmer:
Ghalko
Postby david_h » Wed Oct 06, 2010 7:13 pm
solo wrote:Color, the darker the black and brighter the white will produce the greatest crests and troughs.
I get that easy enough. its all based on contrast. . .so One must go into PhoShop and manipulate and lessen those contrasts before putting it into the plugin? Because when I down loaded the scrolly motif lintel thing, I got all kinds of mess. I just couldn't get my model to look like others were doing. . .
I'll keep playing with it.
david_h
Top SketchUcator
Postby jeff hammond » Wed Oct 06, 2010 7:26 pm
David,
Use the scale tool to compress it vertically.
dotdotdot
jeff hammond
Global Moderator
Postby david_h » Wed Oct 06, 2010 8:14 pm
oh well. . . there's one for the duh thread.
Thx :oops:
david_h
Top SketchUcator
Postby thomthom » Thu Oct 07, 2010 6:20 pm
With version 0.2.0 you specify the height your self - either by using the cursor or entering a length in the VCB.
PluginStore Author
PluginStore Author
Postby spence » Thu Oct 07, 2010 8:31 pm
thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE! :sketchstatic:
Spence
spence
Premium Member
Premium Member
Postby david_h » Tue Oct 12, 2010 10:50 pm
Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. :mrgreen:
david_h
Top SketchUcator
Postby thohan » Wed Oct 13, 2010 11:21 pm
Thank you for this great plugin. :D
I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
I think with some more effort, one can achieve much better results.
It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
thohan
Postby jamalito » Sat Oct 23, 2010 10:12 am
wow wow wow
where have you been ? man
I looking for such as plug-in
thank you so so much thomthom :berserk:
you helped me
because I have a lot pictures I want to do it
Albert Einstein:
((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
jamalito
Postby thomthom » Sat Oct 23, 2010 10:37 am
thohan wrote:It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
Nice coin by the way. :D
PluginStore Author
PluginStore Author
Postby marcomartim » Mon Oct 25, 2010 1:21 am
This plugin is great!
I use Sketchup with Phlatscript plugin to generate code G (2.5 D) to use on my CNC Router, lack a 3D plugin for editing G code on Sketchup.
For 3D and 4D, still use the Artcam,; Now with this plugin can create 3D models from photos, right in Sketchup.
Thank you.
marcomartim
Postby Christmended » Mon Oct 25, 2010 3:59 pm
Thanks for the awesome plugin!
Here is a test result I did.
Christmended
Postby Dave R » Mon Oct 25, 2010 5:16 pm
Shaun, that almost looks like a lithophane. Cool.
Global Moderator
Postby Heven7_floor » Tue Oct 26, 2010 3:36 pm
Great Plug-in, thank your gift to make SU plugin to display the thing happen :thumb: :thumb: :thumb:
Heven7_floor
Postby pichuneke » Tue Oct 26, 2010 4:30 pm
The plugin works with bump mapping. I have no idea about what I am saying, but could it work with normal and displacement maps?
I have no idea about programming, except an unfinished Interactive Fiction game 5 years ago in the "popular" inform 6 language :shock: :lol: :lol:
pichuneke
Postby thomthom » Tue Oct 26, 2010 4:35 pm
pichuneke wrote:I have no idea about what I am saying, but could it work with normal and displacement maps?
Displacement maps are the same as bump maps - grayscale heightmaps. As for normal maps, I don't really know how they work...
PluginStore Author
PluginStore Author
Postby pichuneke » Tue Oct 26, 2010 5:49 pm
I have found a lot about normal maps here:
http://www.google.com/search?hl=es&q=+s ... CBsQrQIwAA
but it's written in chinese, or C++ ... :lol: I don't know if it may interest you, I was spending my time a bit (as I don't understand a single word :D )
pichuneke
Postby arquitectomaracucho » Tue Oct 26, 2010 6:44 pm
excuse my English, Greetings :knockout:
Thomtom greetings, very good tool for many functions :thumb: . be possible to add option mesh, giving a percentage between simple and complex mesh, thanks :thumb:
arquitectomaracucho
Postby thomthom » Tue Oct 26, 2010 6:51 pm
arquitectomaracucho wrote:be possible to add option mesh, giving a percentage between simple and complex mesh, thanks :thumb:
That would be simply resizing the bitmap down - which is much more efficient to do in your favourite image editor than via a Ruby plugin.
PluginStore Author
PluginStore Author
Postby Scott M » Sun Oct 31, 2010 5:01 pm
Just downloaded the plugin an gave it a try.I folowed the promp but nothing is showing up it is saying generating mesh but continues to thnink as if unresponsive.Is my system just too slow or am I doing something wrong. Could someone outline the process.The images you guys posted look great.I allso operate a cnc and would lke very much to use this plugin.
Scott M
Postby thomthom » Sun Oct 31, 2010 5:07 pm
What image are you feeding it?
How large?
If you keep the Ruby Console open, do you get error messages?
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: Anderfs, cotty, Huzzar, vladimir0295 and 24 guests
