[Plugin] Architect Tools
Re: [Plugin] Architect Tools (2.0.0) — 19 February 2013
Postby leot » Thu Feb 28, 2013 10:46 am
Thanks but not working on SketchUp Mac version
leot
Postby tulacong » Sun Mar 03, 2013 8:36 am
thank you very much
tulacong
Postby rv1974 » Sun Mar 03, 2013 9:22 am
Thomthom, I love the stylish look of your scripts (both toolbars and execution).
P.S. May I request 'split face by grid' feature please?
rv1974
Postby thomthom » Wed May 01, 2013 5:46 pm
Uploading a bunch of videos on how to use Architect Tools:
http://www.youtube.com/playlist?list=PL ... FUqJHgB-Z4
More to come!
PluginStore Author
PluginStore Author
leot wrote:Thanks but not working on SketchUp Mac version
What isn't working? No toolbar, menus? A particular function not working?
PluginStore Author
PluginStore Author
Postby utiler » Fri May 03, 2013 12:36 am
thomthom wrote:Uploading a bunch of videos on how to use Architect Tools:
More to come!
Many thanks, TT!!!! It always helps enormously how the toolset functions when videoed but the author.... :thumb: :thumb:
utiler
Top SketchUcator
Postby thomthom » Fri May 03, 2013 8:49 am
This particular toolset is quite idiosyncratic to my own workflow - and not so polished - so it really needs some explanation before anyone can really use this. :s There is much that could be improved - but for the time being I'm happy I finally got around to make the videos.
PluginStore Author
PluginStore Author
Postby bobpineo » Wed May 08, 2013 4:55 pm
Good day Thomthom,
Working my through this plugin, looks awesome.
Can you by any chance post a drawing (perhaps the base drawing for the video you posted) here?
I would like to see the condition of the drawing you started which allows you to run the plugin successfully.
Most of the CAd I get is so complicated and poorly put together that I am having trouble replicating what you do in your video. I would like to practice on a better base to see if I can modify what I am getting to work better.
Best
BP
Bob Pineo, Design Develop LLC http://www.designdevelop.org.
bobpineo
Premium Member
Premium Member
Postby thomthom » Thu May 09, 2013 1:52 am
The imported map datas I used as foundation to generate the models?
PluginStore Author
PluginStore Author
Postby sepo » Sun May 26, 2013 1:22 pm
Hi Thomas
Used extension warehouse to install the plugin. I can see it in plugins folder but I do not have toolbar. It is checked under toolbars but does not appear anywhere.
sepo
Postby TIG » Sun May 26, 2013 2:53 pm
This is a painful known issue with first version of v2013, with random problems with new toolbars seemingly 'invisible'...
It is probably stuck underneath a docked toolbar or two in the top bar.
Drag the top bar toolbars off so they are floating, and if you see the required toolbar below then double-click it a few times to try and 'unglue' it.
Then you should be able to drag it off so it's floating, and then relocate it where you want...
Then relocate the moved toolbars as desired.
It that doesn't work there is a registry hack... I've posted that in a few threads... do a search...
Global Moderator
Postby sepo » Sun May 26, 2013 4:28 pm
thanks Tig....it worked. It was hidden behind top tool bars....how bizzare.
However shadow fix toolbar is nowhere to be found....
sepo
Postby TIG » Sun May 26, 2013 5:21 pm
When a new plugin makes a toolbar for the first time it ought to be made floating in the top left quadrant of the screen. That is the default. Scripters can't affect how it works. But for some yet to be fathomed reason SketchUp 2013 occasionally decides to dock it in the top-bar, which would be so bad BUT it puts it under existing toolbars - which isn't allowed as docked toolbars must always have their own 'space' :roll:
I know Trimble are striving to fix it - it's an embarrassing glitch...
Global Moderator
Postby isbelcia » Fri Jan 10, 2014 11:57 am
I use Sketchup 7 and I want to install architect tool. My question is how to install the necessary TT_lib2.rbz on sketchup version lower than 7?
Thanks Iza
isbelcia
Postby TIG » Fri Jan 10, 2014 1:10 pm
isbelcia wrote:Hi,
Thanks Iza
To Auto-Install the contents of a RBZ you need v8M2 or newer.
Assuming the plugin will work in say v7 [many do] then you can use the old-way...
Change the filetype suffix from the .RBZ file to .ZIP.
An RBZ is actually a ZIP with another ending.
Extract the ZIP's contents to a temporary folder, you should have a loader rb and a main folder, within that keep all of the files within their respective subfolders etc, where applicable. NEVER move files out of the subfolder that they are shipped in...
Before installing the plugin - as an Admin, ensure you have FULL read/write permissions set for all users/groups listed in Properties > Security > Edit...
NOW move the contents of the temp folder - in this case the TT_Lib... folder with its subfolders intact and its 'loader' rb into the Plugins folder...
Restart SketchUp...
Global Moderator
Postby tt_su » Fri Jan 10, 2014 3:35 pm
isbelcia wrote:My question is how to install the necessary TT_lib2.rbz on sketchup version lower than 7?
http://www.thomthom.net/thoughts/2012/0 ... -sketchup/
tt_su
SketchUp Team
SketchUp Team
Postby rv1974 » Tue Jul 21, 2015 7:25 am
Thomthom, would it be possible to add some tiny but important option to flatten entities by current UCS (not only restricted to the World XY plane as we got it now)?
I did not quite followed the changes in you politics concerning your tools maintenance after relocation to Olympus. Hope it sounds relevant to you now.
Thank you in advance.
rv1974
Postby Krisidious » Tue Jul 21, 2015 3:04 pm
rv1974 wrote:Thomthom, would it be possible to add some tiny but important option to flatten entities by current UCS (not only restricted to the World XY plane as we got it now)?
I think that function is covered by JQS Align.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby rv1974 » Wed Jul 22, 2015 2:09 pm
this one:
http://sketchucation.com/pluginstore?pln=jsAlign
it won't work with user defined direction of flattening unfortunately.world UCS axis only.
rv1974
Postby becker84 » Wed Nov 25, 2015 8:02 pm
bug splat in sketchup pro 2016+win 10 pro x64... :(
becker84
Postby thomthom » Tue Dec 15, 2015 5:07 pm
becker84 wrote:bug splat in sketchup pro 2016+win 10 pro x64... :(
How can you reproduce that?
PluginStore Author
PluginStore Author
Postby rombout » Wed Mar 16, 2016 2:10 am
Is it possible to add hover/tooltip info? When i havent used it in a while i tend to forget some icons :)
rombout
Postby thomthom » Wed Mar 16, 2016 11:18 am
No tooltips are showing up? What OS are you on?
PluginStore Author
PluginStore Author
Postby becker84 » Thu Mar 17, 2016 3:55 pm
I do not know what caused it, but I know I did the test by removing the plugin and the problem disappeared, when I put the plugin again the bug splat appear!
becker84
Postby applemango85 » Mon Aug 13, 2018 10:03 am
hi
I'm having a problem flattening my cad import. Ive made faces but whatever I do I can't flatten this part of the road. Ive tried this app but still no joy.
any tips on this type of problem
applemango85
Premium Member
Premium Member
Postby Pixero » Mon Aug 13, 2018 1:09 pm
There is a easy manual way of flattening anything.
Set camera to top view.
Set camera to parallell projection.
Export as 2d dwg.
Import that flat dwg again.
Done.
Pixero
Postby boofredlay » Mon Aug 13, 2018 2:07 pm
Pixero wrote:There is a easy manual way of flattening anything.
Export as 2d dwg.
Done.
Simple and effective.
boofredlay
Global Moderator
Postby juju » Mon Aug 13, 2018 3:27 pm
Export as 2d dwg.
Done.
juju
Premium Member
Premium Member
Postby applemango85 » Mon Aug 13, 2018 4:22 pm
That is genius pixero - I totally forgot about that method.
the only thing is that for some reason it scales at 1/10th scale but thats a really easy sort
applemango85
Premium Member
Premium Member
Previous
Return to Plugins
Users browsing this forum: aliaysu, filipasousa85, Teor and 15 guests
