SketchUcation Premium Membership
[Plugin] Architect Tools (2.0.0) — 19 February 2013
Re: [Plugin] Plan Tools (1.2.1) — 07 February 2011
Postby dedmin » Thu Feb 10, 2011 2:30 pm
2.5.2 or 2.5.3?
dedmin
Postby thomthom » Thu Feb 10, 2011 2:34 pm
whoops! :oops:
the latest. always the latest. :)
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby arjunmax09 » Sat Feb 12, 2011 3:36 pm
I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
when you fail at something....you haven't really failed...you've found one way the thing will not work out
arjunmax09
Banned
Postby thomthom » Mon Feb 14, 2011 10:06 am
arjunmax09 wrote:I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
That's because you're using a flat plan tool. If you look at my demo video, I use 3D plan data to generate the buildings. The faces are extruded up to the lines above it. The tolerance is not the extrude height - but the tolerance for closing open gaps in the lines.
Global Moderator
SketchUp version: 8
License type: Pro
Postby cobb89 » Fri Feb 18, 2011 2:33 pm
thomthom wrote:That's because you're using a flat plan tool. If you look at my demo video, I use 3D plan data to generate the buildings. The faces are extruded up to the lines above it. The tolerance is not the extrude height - but the tolerance for closing open gaps in the lines.
I'm also having the same problem as arjun ..how can one create a 3d plan data??...Isn't there any way to automatically generated extruded faces out of such plans??
cobb89
Banned
Postby thomthom » Fri Feb 18, 2011 3:05 pm
cobb89 wrote:I'm also having the same problem as arjun ..how can one create a 3d plan data??
We get such data from surveyors.
cobb89 wrote:sn't there any way to automatically generated extruded faces out of such plans??
From 2d plans? No - how would you expect it to work?
What are you trying to do? Make a set of generic boxes at various heights? In which case you want to look at the Random Push-Pull plugin.
Plan Tools is intended to be used to help generate volumes based on accurate real world 3d data.
Global Moderator
SketchUp version: 8
License type: Pro
Postby shoeb_cars » Mon May 30, 2011 4:47 am
amazing...i wonder what more surprises are in store from you (the great ruby wizards :thumb: )
shoeb_cars
Postby jorge2011 » Sat Jun 04, 2011 6:35 pm
Sr thomthom.
Thanks for this plugin.
Would it be possible to cut smooth lines?
Please see this post
viewtopic.php?f=323&t=37716&p=333319#p333319
jorge2011
SketchUp version: 7
License type: Pro
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011
Postby thomthom » Fri Jun 17, 2011 7:01 pm
Version 1.2.2
Minor Bugfixes
Global Moderator
SketchUp version: 8
License type: Pro
Postby nektares » Sun Sep 11, 2011 8:00 pm
This is such a great plug-in, it should be on the must have visual index, it´s fantastic!
nektares
Postby thomthom » Mon Feb 20, 2012 10:03 am
Anyone got a better suggestion for a name that might describe the plugin better?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Krisidious » Mon Feb 20, 2012 10:42 am
Urban Importer? Urban Planner?
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
Krisidious
SketchUp version: 8
License type: Pro
Postby mitcorb » Mon Feb 20, 2012 2:16 pm
Here are a few words: 3d Site Plan Context Modeler Surround(s) Neighborhood Zone Focus Local. Feel free to Slice and Dice as you please.
EDIT: I forgot Lifter Extruder AutoExtruder
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free/Make
Postby utiler » Mon Feb 20, 2012 11:38 pm
How about 'Urban Morph tools'...?
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby mitcorb » Tue Feb 21, 2012 3:53 am
Whoa, that just might be sinister enough :mrgreen:
mitcorb
Top SketchUcator
SketchUp version: 8
Postby utiler » Tue Feb 21, 2012 8:46 am
mitcorb wrote:Whoa, that just might be sinister enough :mrgreen:
Only for those with a twisted mind, Tim..... 8-)
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Feb 21, 2012 9:39 am
Maybe I'm looking at it the wrong way. Maybe this plugin needs to be split into different plugins.
Global Moderator
SketchUp version: 8
License type: Pro
Postby utiler » Tue Feb 21, 2012 1:00 pm
I think you right, Thom. Your plan tools are a little different from the urban forms tool..... Maybe expand city gen and incorporate the morph thingy....?
:thumb:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Feb 21, 2012 1:51 pm
Yea, I was thinking that parts of City Gen could be merged. And some parts of this plugin could go into other, or new plugin. Just to make the plugin more defined. Because it's clear that it has an identity crisis.
It's been a collection of tools I've built to just get the job done - so it's not as polished as the rest. And I think many don't realize what it does - where in fact it is one of the most time-saving plugins I got.
Working on new tools for it, making layered terrain. Started to clean up the plugin as I go along.
utiler wrote:morph thingy
Whatismajiggy? :? :?:
Global Moderator
SketchUp version: 8
License type: Pro
Postby utiler » Wed Feb 22, 2012 2:48 am
That sound logical, Thom.
I've been working on urban renewal project of late where I cam provided with all types of GIS data from property boundaries, roads, contours, even elevation data points on buildings... here's a few screenshots....
I import all aerial photo's, CAD lines into SU and set particular layers to I can manipulate scenes in LO efficiently.... Particular to note I find it best to layer scenes with linework in Vector mode over scenes of aerial photography in Raster mode as Hybrid just doesn't cut it yet.
Morph:
Cheers, :thumb:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby DareDevil » Wed Feb 22, 2012 11:20 pm
I dont know how the remaining time is computed, but when the Generate Buildings sequence started it was 20 minute ; finally the works take 2 hours and 30 minutes !
Fortunately, it made what I was waiting :D
DareDevil
Postby thomthom » Thu Feb 23, 2012 9:50 am
The estimated remaining time is based on how much time it has taken to process the current set of entities vs the remaining. The problem is that adding geometry to SketchUp gets slower the more geometry there is - which is problematic to estimate. I haven't even tried to account for that.
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Feb 23, 2012 11:06 am
Why not use a '% complete' report ?
It changes to show it's working and the user then knows how much is left to do...
If THEY assume the second 50% will take as long as the first 50%, then that's their issue not yours.
All you will have done is told them how much has been processed so far, and that it is actively continuing...
Global Moderator
SketchUp version: 2013
License type: Pro
Postby thomthom » Thu Feb 23, 2012 11:21 am
I was reusing some generic code - which for linear time code works well.
I am working on a version 2 where I am cleaning up lots of stuff. Everything has so far just been quickly assembled to automate tasks I've been working on.
Global Moderator
SketchUp version: 8
License type: Pro
Postby DareDevil » Thu Feb 23, 2012 12:51 pm
thomthom wrote:The estimated remaining time is based on how much time it has taken to process the current set of entities vs the remaining. The problem is that adding geometry to SketchUp gets slower the more geometry there is - which is problematic to estimate. I haven't even tried to account for that.
I dont know if it's many or not, the process made 7,000 groups. My computer is a i5 @2.4 GHz with 3 Gb RAM. It's not a race computer but is not a Minitel...
For this job, the problem was'nt the time but just my wife asking me "when you will be back home ?"... "SU says in fifty minutes..." and half an hour later "SU says in one hour...". SU is a liar !! :lol:
DareDevil
Postby thomthom » Thu Feb 23, 2012 2:35 pm
Many or not many - doesn't matter. The time it takes to add geometry in SU slows down every time more geometry is added.
Global Moderator
SketchUp version: 8
License type: Pro
Postby guanjin » Sun Feb 26, 2012 2:46 pm
Help loading error!
I come from China, is to learn
guanjin
SketchUp version: 8
SketchUp use: interior design
Postby thomthom » Sun Feb 26, 2012 8:10 pm
That's strange - can't quite pin-point where the error is. "eval" error..
Exactly what SketchUp version do you have?
And what TT_Lib2 version?
Did you just install Plan Tools and got the error on first run? Or did it suddenly appear?
Can you open the Ruby Console and type:
load 'tt_plan_tools.rb'
post back any error-messages.
Global Moderator
SketchUp version: 8
License type: Pro
Postby guanjin » Mon Feb 27, 2012 5:03 am
thomthom wrote:That's strange - can't quite pin-point where the error is. "eval" error..
Starts running, and later has been an error
sketchup8M2
Latest
Reason: Fixed the quote tag
guanjin
SketchUp version: 8
Postby thomthom » Mon Feb 27, 2012 9:29 am
guanjin wrote:Starts running, and later has been an error
Can you explain more. It's very hard to debug with so little info.
And did you try the Ruby Console command?
Global Moderator
SketchUp version: 8
License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: tantofaz and 12 guests
