SketchUcation Premium Membership
[Plugin] Guide Tools (1.3.0) — 21 October 2010
Re: [Plugin] Guide Tools (1.2.0) — 11 October 2010
Postby thomthom » Tue Oct 12, 2010 9:29 am
Pilou wrote:
Where edges are split where they intersect? Or where they overlap - like they often do in SU6 and older?
I don't know, on the face I suppose :oops:
Something is lost in translation here - I mean should there be a CPoint only when two edges cross each other but doesn't split each other?
Pilou wrote:So there are 2CPoint overlaped
or they are automatical merged as one by SU as having same coordinates ?
(same than you draw 2 lines ovelapped)
I don't know - I haven't tested it. The plugin just adds a CPoint blindly.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Pilou » Tue Oct 12, 2010 9:45 am
I have just tested seems there are really 2 CPoints! :o
Maybe some annoyous ;)
click image if scrool bar!
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Tue Oct 12, 2010 10:14 am
I think Pilou's issue with 'duplicated Cpoints' - i.e. at the same location in 3D space - is if they are used to place Instances later it will duplicate the Instances etc.
When adding the new Cpoints it'd be relatively easy to test to see if there was a Cpoint already there.
First make a collection of Cpoints in the current context [entities] and make an array of the 'position' of each one: then only add the new Cpoint if it's not already there - code-example...
Code: Select all
there=false
cpoint_positions.each{|p|(there=true;break)if p==new_point}
entities.add_cpoint(new_point) if not there
You should still add coincident Cpoints if they are in different contexts [entities-sets]...
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Oct 12, 2010 10:31 am
Slightly trimmed variant:
entities.add_cpoint(new_point) unless cpoint_positions.any?{|pt|pt==new_point}
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Mon Oct 18, 2010 9:37 am
In fact that must be 6 points! :roll:
1 Center of circle
1 Intersection of lines
4 Intersection Lines Circle
Here I have a lot of more ;)
I have made Intersection before launch the plug Edge/edge (V 6)
Edit I have found a Process
General Intersection
Hide Circle
Call the Plug Guides Tool - Edge/edge
Show Circle
Select Circle
Call ad Cpoint to Circle
I have my six points :fro:
Easy for not numerous circles but for many ? ;)
Ok I can use Selection Toys Circles :enlight: ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Mon Oct 18, 2010 9:51 am
Why do you hide and show the circle?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Mon Oct 18, 2010 9:58 am
Yes see my edit text ;)
In fact that must be Selection Toys "Arcs"
Hide
because the interections are made before ;)
Process must be
Ad CP Circle(s)
Hide
Add CPoint Edge /Edge
Show Hidden
:fro:
When Edge / Edge Cpoints are they "Doubled" between 2 segments of a same lines or not? (like my lines above after the intersection)
(at the commune extremities)
Seems not! :fro: (I have verified with the outliner) :enlight:
You have just the problem of same arc centers of my previous old post ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby watkins » Mon Oct 18, 2010 4:02 pm
Dear Thomas,
Could the following be added to the suite of cpoint functions?
To place a construction point at the intersection of three orthogonal planes.
Thanks,
Bob
watkins
Postby TIG » Mon Oct 18, 2010 7:08 pm
watkins wrote:Dear Thomas,
Thanks,
Bob
Should be straightforward...
Get line of the intersection of two of the planes.
get the intersection of the third plane and the line.
Add a cpoint...
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Tue Oct 19, 2010 10:46 am
@ Thomthom
Does it possible to have an option for DWG export?
Problem is: Tocad don't import CP POINT !!! :o
So circle center oe arc circle center info are losted!
So a possibility is to replace CPoints by 2 or 3 lines crossed.(3 axis)
(as "component" even Tocad lost the "component" it draw the lines! :enlight:
And each circle is tranformed in disc by ToCad.
So Replace CPoints by crossed lines will be fine for DWG export :)
Of course the replacement can be made by Selection Cpoint/Put Component at Cpoints.
(problem of mutiple same CPoints must be also resolved) :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Re: [Plugin] Guide Tools (1.3.0) — 21 October 2010
Postby thomthom » Thu Oct 21, 2010 7:53 pm
Version 1.3.0
CPoint at Camera Eye - Adds a construction point at the Camera eye.
Global Moderator
SketchUp version: 8
License type: Pro
Postby utiler » Thu Oct 21, 2010 11:27 pm
Great addition Thom! All your work with rubies are very much appreciated!!!
:thumb:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby lapx » Fri Jan 07, 2011 8:54 pm
Tom,
Thanks! I've been searching for this for a while.
Best, Lapx.
lapx
Re: [Plugin] Guide Tools (1.1.0) — 06 September 2010
Postby Bob James » Sun Jan 30, 2011 10:12 am
Pilou wrote:Drilling Milling[/url] by Menfin (French and English version) :enlight:
This looks like it would be very handy, but the forum is in French (only) and doesn't allow download without being a member of the forum. :(
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby dedmin » Mon Feb 07, 2011 9:52 pm
Is it possible to add "CPoint at Insertion Point" for groups also?
dedmin
Postby thomthom » Mon Feb 07, 2011 10:17 pm
dedmin wrote:Is it possible to add "CPoint at Insertion Point" for groups also?
I'll add it to the list.
Global Moderator
SketchUp version: 8
License type: Pro
Postby dedmin » Mon Feb 07, 2011 10:18 pm
:bounce: :bounce: :bounce:
dedmin
Postby Larsen » Wed May 11, 2011 12:51 pm
Amazing tools!
Thanks thomthom for your generosity.
[Every form of thinking perish by excess of its basic principles.
Larsen
Postby baiduaiya » Fri May 20, 2011 10:26 am
thank you very much.
baiduaiya
Postby matt.gordon320 » Wed Nov 02, 2011 2:20 am
Thank you so much! Amazing Tools as always...
matt.gordon320
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby carlm » Thu Feb 09, 2012 6:49 pm
Hi Thom-
Just downloaded your Guide Tools and TT Lib2; they seemed to be working fine, then I tried adding CPoints to the circles in the attached file. There's one circle that the tool refuses to work on (top, far right).
The odd thing is that your tool had no trouble adding a CP to the other end of the same hole (see bottom side), and I made the row of holes by drawing one circle on face, move+ x2, then pushed them through...
I tried both selecting the face and then using Guide Tools, and just selecting the circle and using Guide Tools, both with CPoint at Circle Center and CPoint at Arc Center.
Thought you'd want to see it.
SU8 (pro-expired)
MacOS 10.5.8
Thanks, -carl-
carlm
Postby carlm » Thu Feb 09, 2012 7:02 pm
Never mind?
After encountering this problem, the plugin wouldn't install guide points in other files either.
Quit SU, reopened, seems to work fine, even on the file I just posted...
It does seem that SU is less stable since installing Selection Toys and TT Lib1 this morning, but could be the moon -- this is not a report yet.
Sorry! -carl-
carlm
Postby Anton_S » Sun Mar 11, 2012 9:52 am
Very, useful tool... Thanks :!:
Anton_S
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby guanjin » Wed Mar 14, 2012 3:18 am
[quote="carlm"]Hi Thom-
You want to set the coordinates of the components
I come from China, is to learn
guanjin
SketchUp version: 8
License type: Free
SketchUp use: interior design
Postby thomthom » Wed Mar 14, 2012 10:32 am
From that animation I don't see what the problem is. It seem to create CPoint where it should ... :?: :?:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Mar 14, 2012 11:30 am
Hello Thomthom
I had given your wonderful plug Guide Tools as answer for this question :fro:
Maybe you can add an option for give an orientation to the component ? (Insert Components at CPoints)
That will be very useful in a lot of cases! :enlight:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Wed Mar 14, 2012 12:18 pm
Pilou wrote:Maybe you can add an option for give an orientation to the component ?:
Orientation is defined by the component axis. Or did you mean something else? Image example?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Mar 14, 2012 2:08 pm
Assuming the original component has these axis and keep them
and of course that you make a different selection for each "plan" of Cpoints
(here 3 selections with call of the pluging at each time) the more easy to code ;)
The input box could be for a selection for the first result:
Insert Components at CPoints with
(No rotation so default parameters = 0°) :)
Rotate Components on X = 0°
Rotate Components on Y = 0°
Rotate Components on Z = 0°
The input box could be for a selection for the second result:
Rotate Components on Z = 270°
The input box could be for a selection for the third result:
Rotate Components on Z = 90°
Seems useful no ? :enlight:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby ZFRPS » Wed Mar 14, 2012 3:03 pm
Thank you very much!
your pluhins give me a lot of help!this plugin is great! wish more powerful!
sketchup is bim
ZFRPS
Postby scott216 » Thu Mar 21, 2013 8:11 pm
Is there a way to add a guidepoint to the center of an exploded circle? I tired exploded arc and just circle tools, but neither of them worked on an exploded circle.
scott216
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: Ceiras, chrislbj, Google Feedfetcher, haakonn, ken chen, Krisidious, nikusknx and 13 guests
