SketchUcation Premium Membership
[Plugin] Solid Inspector (1.1.0) — 30 June 2011
Re: [Plugin] Solid Inspector (1.0.0) — 01 September 2010
Postby Dave R » Fri Jun 03, 2011 12:47 am
Marcus. I'll send one with yours. ;)
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby thomthom » Fri Jun 03, 2011 7:11 am
Cookies!!! :D :berserk:
Global Moderator
Name: Thomas Thomassen
License type: Pro
SketchUp use: architecture
Postby mariocha » Fri Jun 03, 2011 1:01 pm
Cookies!!! :enlight:
Mario C.
Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
mariocha
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby jgb » Fri Jun 03, 2011 1:36 pm
Can't tell you TT how ecstatic I am with SI. :sketchstatic: :sketchstatic: :sketchstatic: :sketchstatic:
Although I have some suggestions for improvement, it still amazes me how it can find tiny random elements that SU says are "~0 in" in length that prevent a solid from forming, that would be simply impossible to find without SI.
When Google upgraded SU to form solids, something like SI should have been a native function, far more important and useful than merging solids that are only available with Pro. But Google has always displayed excellent software for internally identifying errors, but rate a serious :thumbd: :thumbd: :thumbd: :thumbd: for telling us exactly what the error is and where to find it to fix.
My only suggestions to improve SI are;
1- allow it to function INSIDE the group/comp. Right now it is a repetitive set of operations to
* select the group/comp,
* call-up SI (which is my "S" key shortcut),
* hit <return> to locate the next error,
* zero in on it and place the cursor on the red highlighted object,
* press <spacebar> to exit SI,
* enter EDIT mode and
* select the offender and then
* delete it, which is 99.999% of the time the required fix.
* Then, exit edit mode,
* reselect the group/comp and, IF the solid has not formed (Entity Info box),
* do it all over again.
This gets tedious. :bounce:
If SI worked INSIDE the group/comp, you would only need to
* call-up SI,
* then hit <enter> to select the first offender,
* then <delete> to fix it,
* <enter><delete> <enter><delete>
etc.
:arrow: I would not want SI to automatically delete offenders, as in rare cases this is not the desired fix.
2- If the group/comp is already or finally a valid solid, paint a green circle around it, and if in edit mode, exit the solid.
__________________
jgb
jgb
SketchUp version: 8
License type: Free/Make
SketchUp use: engineering and mechanical design
Postby thomthom » Fri Jun 03, 2011 3:01 pm
Yup - I want SI to work inside the active group as well. On the todo list.
I just haven't had much time lately for plugins. :(
Global Moderator
License type: Pro
Postby commandercup » Sat Jun 11, 2011 9:29 pm
This is the greatest thing I have ever used. :berserk:
Thanks for making this!
commandercup
Re: [Plugin] Solid Inspector (1.1.0) — 30 June 2011
Postby thomthom » Thu Jun 30, 2011 9:37 am
Version 1.1.0
If nothing is selected then the current context will be inspected.
Global Moderator
License type: Pro
Postby Rich O Brien » Thu Jun 30, 2011 9:39 am
:thumb:
Thanks Thom
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby d12dozr » Thu Jun 30, 2011 1:27 pm
Thanks, Thomthom
:mrgreen:
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: product design
Postby Jim » Sat Jul 02, 2011 4:20 pm
Just noticed the update. Thanks, thomthom.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Sat Jul 09, 2011 3:07 pm
It seems natural that when using Solid Inspector for nested models, that when I click on nothing it should go to the parent context and start checking that. And conversely, double-clicking a Group/Component while using ST could enter that context (except I know it's not possible in the current API :( ) What do you think?
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Sat Jul 09, 2011 3:26 pm
Ah - navigate the current context like the native Selection too does. Yes - not bad idea. Closing is doable, but it does have a nasty bug where the event is not added to the undo stack when you use Ruby - which cause geometry havoc when you do try to undo/redo anything. :/
( wouldn't mind if more peope, besides me, went nagging to Google about the open/close context issue.) ;)
Global Moderator
License type: Pro
Postby bogmusic » Mon Jul 11, 2011 2:39 pm
In a hurry and just got to get this one out....
doh! What do you mean not a solid you stupid machine, aaaaagh!
Thanks thomthom, you have saved me so much trouble.
Come to Yorkshire UK and I will buy you a pint!
bogmusic
Postby jgb » Sun Jul 17, 2011 6:35 pm
Just discovered a shortcut (sort of) to getting at those tiny fragments buried deep inside a complex solid. :idea:
I many cases you cannot easily get to see a fragment inside a solid due to short sightlines and clipping when getting up close, or the red circle seems to be disconnected visually from the fragment.
Pan/zoom till the red circle is around mid screen and then zoom in as close as you can but still outside the solid.
Switch to WIREFRAME view and now you can see the red fragment clearly. Put the pointer ON the fragment and exit SI by pressing the SpaceBar. Double click to enter edit mode. The cursor should still be on or very close to the fragment, click on the fragment to select and then delete it.
Go back to a solid view to make sure you did not open a face. Continue on to the next fragment.
You can also engage SI in XRAY, but you cannot select fragments through the transparent faces.
__________________
jgb
jgb
SketchUp version: 8
Postby xiombarg » Sun Aug 07, 2011 4:49 am
thomthom, I can't even begin to thank you enough for this tool. You rock.
xiombarg
SketchUp version: 8
License type: Pro
SketchUp use: game and/or sci-fi modelling
Postby monsterzero » Mon Aug 08, 2011 9:10 pm
Just downloaded this after pulling my hair out trying to find why something wasn't solid. This found the problem right quick! Awesome!
monsterzero
Postby Helmholtz » Wed Aug 10, 2011 6:53 pm
ThomThom, once again your plugins have saved me from exploding out of frustration. THANK YOU FOR THIS!!!!!!!!!!!
:berserk:
- Helmholtz
Helmholtz
Postby Fumaru » Fri Sep 23, 2011 12:16 pm
Using this with fix solid is great viewtopic.php?t=33471
Thanks for the awsome plugin,
I dont know why SketchUp does not have this feature included in it.
Fumaru
Postby jgb » Sun Sep 25, 2011 4:43 pm
jgb wrote:Can't tell you TT how ecstatic I am with SI. :sketchstatic: :sketchstatic: :sketchstatic: :sketchstatic:
After using SI extensively over the last few months, I wish to modify my statement above.
I have yet to have a failed solid where deleting every single fragment or duplicate face or lines failed to solve the problem, or worse, partially undo a solid.
Therefore, as an option, I would have SI delete every found element, either all automatically when hitting the <del> key, or sequentially by hitting the <del> key after the <enter> key cycling through the found bits. I think the very rare occurrence of "damage" to the solid by just deleting offenders (never happened to me yet) would also be very easy to fix.
So, yes, delete automatic is my vote. :thumb: :thumb:
__________________
jgb
jgb
SketchUp version: 8
Postby thomthom » Mon Sep 26, 2011 8:42 am
There are cases where a solid has tiny holes, where SketchUp fails to create a face because the edges are too small.
Global Moderator
License type: Pro
Postby TIG » Mon Sep 26, 2011 11:32 am
thomthom wrote:There are cases where a solid has tiny holes, where SketchUp fails to create a face because the edges are too small.
But aren't these then capable of 'healing'... any !edge.faces[1] can be tested for tiny length [say <= 0.5mm ?] and then its end vertex transformed to be over its start vertex so it then ceases to exist...
a long thin hole with one or more tiny sides becomes an edge with no hole, a hole with all tiny sides simply ceases to exist at all.
I have tested some code and I admit that making the ends of a tiny edge coincident isn't working - as you are left with an edge of zero length [!] with two coincident edges too! Moving vertices to become coincident must be possible - the TT-vertex-tools ? I am stumped :?
Global Moderator
License type: Pro
Postby thomthom » Mon Sep 26, 2011 11:46 am
TIG wrote:I have tested some code and I admit that making the ends of a tiny edge coincident isn't working - as you are left with an edge of zero length [!] with two coincident edges too! Moving vertices to become coincident must be possible - the TT-vertex-tools ? I am stumped :?
The only way I found, was a method similar to how you heal edges, you make a temp edge and then erase it. That will merge the vertices located at the same position and remove the zero length edge.
Global Moderator
License type: Pro
Postby thomthom » Mon Sep 26, 2011 11:47 am
Actually, there is some more to it. Here are a few methods I use in Vertex Tools 1.1 to heal geometry after manipulating vertices:
Code: Select all
# Heal geoemtry
  # (i) When vertices are merged into one point it one end up with zero size
  # faces and edges. These produce a messy mesh and cause errors to be
  # reported when Su validates the model.
  # If one draw a dummy edge with SU's native edge tool it heals the
  # geometry. But if one does the same with the Ruby API it doesn't.
  # Thanks to Gulcan Ocali from Tgi3D for suggesting a workaround where
  # the edge is created in a dummy group - then exploded. This appear to
  # make SU heal the geometry. The dummy edge is turned into a zero length
  # edge before exploding so it's automatically cleaned up when the group
  # is exploded.
  # http://forums.sketchucation.com/viewtopic.php?f=180&t=35470#p312814
  # This does however feel too much like a dirty hack. Would be nice to
  # know how to correctly do this.
  # (?) Turn into a reusable method accepting an array of vertices to heal.
  # (?) Is it nessesary to also do the same to soft-selected vertices?
  # @since 1.1.0
  def self.heal_vertex( entities, point )
    point = point.position if point.is_a?( Sketchup::Vertex )
    temp_group = entities.add_group
    temp_edge
= temp_group.entities.add_line( point, point.offset( Z_AXIS ) )
    temp_group.entities.transform_by_vectors( [temp_edge.end], [Z_AXIS.reverse] )
    temp_group.explode
# @since 1.1.0
  def self.heal_vertices( entities, points )
    if points.is_a?( Enumerable )
      for point in points
        self
    else
      self
.heal_vertex( entities, points )
# Tries to heal all zero length edges in the given set of entities. This
  # should also heal zero size faces since they are bound by zero length edges.
  # @since 1.1.0
  def self.heal_entities( entities )
    return if entities.length == 0
    parent
= entities.first.parent
    for entity in entities
      next unless entity
.is_a?( Sketchup::Edge )
      if entity.length == 0
        self
.heal_vertex( parent, entity.start )
Global Moderator
License type: Pro
Postby TIG » Mon Sep 26, 2011 11:55 am
So that method[s] run after any tiny [0.5mm?] edges are shrunk to be zero by transforming the end vertex to be over the start vertex will then heal any 'small [zero width] holes' ?
Global Moderator
License type: Pro
Postby thomthom » Mon Sep 26, 2011 11:58 am
TIG wrote:So that method run after any tiny [0.5mm?] edges are shrunk to zero will heal the 'small [zero width] holes' ?
Any zero length edge and zero size face should be healed (read: removed by SU's auto-merge feature).
Global Moderator
License type: Pro
Postby TIG » Mon Sep 26, 2011 12:04 pm
But if you find some edges ~0.5mm long and merge the vertices that edge still exists as a zero length edge - SUp doesn't auto-merge them - also the previously separated other sides of the hole are now coincident and not auto-merged either!
So your code would remove the zero length edge by forcing an auto-merge BUT do the coincident edges then merge too? I don't have time to test it - but if it works it's the basis of having a tool to 'make solid' groups etc that have tiny holes :?
Global Moderator
License type: Pro
Postby VeniVidiVici » Sun Oct 02, 2011 3:56 am
OMG, THANK YOU THANK YOU THANK YOU! :berserk:
I cant wait to use this too...combined with Artisan...OMG...FINALLY, I can do 3D
modeling without countless hours of error fixing (even when working large scale).
This is going to save days of my life...lol. :)
CHEERS!
<---swigs a brewski in your honor!
VeniVidiVici
Postby PapaBear60 » Sat Oct 08, 2011 4:29 pm
OK, I'm having the same problem as another user, Solid Inspector doesn't show up in the menu. I'm using Sketchup 8 (7 is gone), put the .rb in the plugins folder and also the library2 folder in the plugins folder. (In fact, now that I look at it, several plugins don't show up?) What am I doing wrong:
PapaBear60
Postby thomthom » Sat Oct 08, 2011 5:21 pm
PapaBear60 wrote:What am I doing wrong:
You ain't looking at the description of the plugin. ;) Not all plugins add menus to the Plugins menu. Check the info in the first post for how to use.
Global Moderator
License type: Pro
Postby TIG » Sat Oct 08, 2011 5:22 pm
As TT said... not all scripts appear in the Plugins Menu - this one is set to load in the Tools Menu as explained on the tool's download page
that is UNLESS the "ThomThom's Plugins" menu is loaded by the script tt_0000_menu.rb - then that submenu is added in Plugins and TT's tools all collect there ! [but that's academic as you don't appear to have file that in Plugins folder, or the submenu it would make...]
So look in the Tools Menu...
If it's still not there come back to us...
Global Moderator
License type: Pro
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Plugins
Users browsing this forum: awhite344, guaucorreo, MOZURUI, stefano950, Thunderbreeze and 15 guests
