Thom, have you generated docs for this lib? I appreciate that you are thinking in terms of re-use, and your code is clean and clear. Is this licensed so that other people can use it also?
Jim wrote:Thom, have you generated docs for this lib? I appreciate that you are thinking in terms of re-use, and your code is clean and clear. Is this licensed so that other people can use it also?
I have some docs generated. But the comments are not complete. It's still taking shape and some things will be changed. I'll try to make a note on the modules that are WIP and include more examples. If you have questions about particulars just let me know and I can push them up on the update list.
When I made Vertex Tools I had a similar system for the toolbar system. A set of classes that acted as wrappers for the controls. The main classes where Container and Control - they would have most of the code. From there it was easier to create sub-classes like toolbars and buttons. I then had a very nice abstract layer where I created a toolbar class - where I added Button objects. Complex systems though - but I hope to have a base system by the new year.
Hello, I'm having a problem with the program crashing at 49% when exporting as a vrml. I've imported my bmp image, sized, indexed points and generated the mesh. Any suggestions?
jeffschaid01 wrote:Hello, I'm having a problem with the program crashing at 49% when exporting as a vrml. I've imported my bmp image, sized, indexed points and generated the mesh. Any suggestions?
TT, I got this message while overwriting the old library (meaning that the file I marked is write-protected). When I wanted to overwrite anyway, it wanted a password so I could not.
Is it an issue if I do not update that particular file?
Gaieus wrote:TT, I got this message while overwriting the old library (meaning that the file I marked is write-protected)
It's not write protected on my computer. Nor in the zip file.
Gaieus wrote:When I wanted to overwrite anyway, it wanted a password so I could not.
I have no idea what this can be. I've never seen Windows ask for that. Are you using some third party applications to manage files? What did you use to extract the files? Did you extract directly over the files? What if you delete, then extract?
It's simply Win XP "extract (or open?) all files" when I enter the zip archive (yes, I was simply overwriting the existing install). Here is the dialog that asks for the password:
I then tried to delete the file but it said omething was using it. It was obviously SU as when I closed it, I could delete it and install the library correctly. This made me think however so I tried to reinstall it (now as it had been installed the file again) and with the SU window closed, it allowed me to.
So maybe a line in the front post to "close SU before installing" would be useful (people need to restart SU anyway).
Csaba, I got a similar message about that .so file when I extracted the ZIP file to the Plugins folder. SketchUp was open. So I closed SketchUp and tried again. It worked fine then. I wonder if that file is write protected when SU is open and the file is in use.
Inspecting mirrors is a job I could easily see myself doing.
I do love this plugin and use it a lot in complex models.
What I would love is for the 'smooth angle' feature to have an 'ignore materials' checkbox, so that coplanar faces of different materials do not merge. E.g I have an organic surface with paths, lawn and garden beds on it. It would be great if the plugin smoothed the surface but left the edges between surface finishes.
bitslapped wrote:I do love this plugin and use it a lot in complex models.
I assume you are referring to the CleanUp plugin? (This is the TT_Lib thread...)
bitslapped wrote:What I would love is for the 'smooth angle' feature to have an 'ignore materials' checkbox, so that coplanar faces of different materials do not merge.
That would make it smooth the edge.
bitslapped wrote:E.g I have an organic surface with paths, lawn and garden beds on it. It would be great if the plugin smoothed the surface but left the edges between surface finishes.
Thanks for considering ThomThom, and yeah the 'ignore materials' was just using your existing terminology to add the feature. Ideally it would be something like a "maintain material edges" checkbox.
ThomThom I am running 8 Pro and am trying to install "solid inspector." I have TT_Lib2 installed in the plugins folder and "tt_solid_inspector" installed in the "plug ins" folder.
When I start 8 I can not find any indciation of the programs existence. Any ieas of where I can begin looking for the problem?
Roger wrote:ThomThom I am running 8 Pro and am trying to install "solid inspector." I have TT_Lib2 installed in the plugins folder and "tt_solid_inspector" installed in the "plug ins" folder.
Thanks.
It saids the following, in the description. Did you check there?
Thanks.
Access Tools > Solid Inspector
I had to do a complete system restart before it appeared. Thanks Kwok
