by sahi » Tue Aug 03, 2010 2:02 pm
njh wrote:Hi Sahi / Guys,
Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
points.jpg Brick_9.zip
sahi
- Operating system: Windows
- SketchUp version: pre-6
- License type: Free/Make
- SketchUp use: architecture
- Level of SketchUp: Beginner
by njh » Tue Aug 03, 2010 2:23 pm
Hi Sahi,
Fast comeback!
Just downloaded the "brick 9" update and now the ctrl key does nothing. Was that the plan?
The mirror buttons at the top of the screen work but the object goes off screen during the mirror process so it is not as intuitive to use and not as obvious to see what what is happening to the object during the mirror.
Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
Cheers
NJH
njh
- Name: Neil Hodgson
by sahi » Tue Aug 03, 2010 2:36 pm
njh wrote:Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
What are the keys you are free ???? What are the keys create one??
sahi
by sahi » Tue Aug 03, 2010 3:13 pm
njh wrote:Hope someone can help.
NJH
sahi
by njh » Tue Aug 03, 2010 3:23 pm
Sorry - I don't understand your last response.
What I was originally trying to say was the keyboard shortcuts shown on your keyboard picture for "home" and "end" don't appear on an apple keyboard and I can't / don't know how to re-map the shortcut for those commands within your plugin in preferences/shortcuts.
Cheers
NJH
njh
by sahi » Tue Aug 03, 2010 3:35 pm
njh wrote:Sorry - I don't understand your last response.
key.jpg Key A - ?? B - ?? C - ?? .... ..... .... What are the keys to choose ?
sahi
by njh » Tue Aug 03, 2010 3:51 pm
Hi Sahi, Thanks or your patience. I can get to the shortcut menu like you show but I can't locate your plugin tools in the "function" list. The only item listed is to view the Brick pallett. Thats my problem. Voila_Capture39.jpg
njh
by sahi » Tue Aug 03, 2010 3:57 pm
njh wrote:Hi Sahi,
NO no no...... Keys "1" >> mirror red axis Keys "2" >> mirror green axis Keys "3" >> mirror blue axis klafa-10.jpg Brick_10.zip
sahi
by njh » Tue Aug 03, 2010 4:10 pm
Thank you, thank you, thank you..............
Works fine with Brick 10 now.
Great plugin!
Cheers
NJH
njh
by Ken » Tue Aug 03, 2010 5:55 pm
Is one ever satisfied?
Your mirror does mirror, however this to me is more like a "flip", an actual mirror should also be able to copy the selection.
So would that be possible? And if not, I will be pleased that so many people take the time to add improvement to Sketchup and their plugins.
Again, thank you
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
- Premium Member
- SketchUp version: 8
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Advanced
by Ben Ritter » Fri Aug 06, 2010 4:26 pm
First off, thank you for the script and for sharing.
Second, I cannot get the mirror function to work. Any suggestions?
Third, can this work on SU 6?
Thanks. Ben
Ben Ritter
by sahi » Fri Aug 06, 2010 5:39 pm
Ben Ritter wrote:Second, I cannot get the mirror function to work. Any suggestions? Brick_8.zipKeys "Ctrl" >> mirror red axis Keys "Home" >> mirror green axis Keys "End" >> mirror blue axis Brick_10.zipKeys "1" >> mirror red axis Keys "2" >> mirror green axis Keys "3" >> mirror blue axis Brick_9.zipmirror administrated mouse Ben Ritter wrote:Third, can this work on SU 6?
Yes. and SU 7 and SU 6 and SU 5
sahi
by Nick2010 » Tue Aug 31, 2010 6:51 am
Thanks for this Plugin. i like the rotate tools!
Nick2010
- Name: Nick Quesada
by SUFractal » Fri Oct 15, 2010 6:48 am
Why doesn't this plug-in download as a .rb file?
It downloads as a .rbs file and does not seem to open or operate properly?
SUFractal
by Gaieus » Fri Oct 15, 2010 8:45 am
It's an encrypted rb file. The author may not wish to reveal the code. It works just like a simple rb file however.
- Administrator
- Name: Csaba Pozsárkó
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
by SUFractal » Fri Oct 15, 2010 11:49 am
Hmmmmmm. That's understandable, but I have the ruby placed properly, but do not see for the life of me the "tool" anywhere w/in SU?
What/where should I be looking?
Thanks.
SUFractal
by cmeed » Fri Oct 15, 2010 11:52 am
I'm having trouble finding the mirror functions and short cuts
I have downloaded brick14
on a mac
one of the pictures before has three coloured axis squares at the top and bottom of the rotate protractor where i only have them at the bottom. i can't also get any of the short cuts to work, i saw an earlier post answering a mac question to this but i can't seem to get it to work.
I press 1,2,3 nothing happens, i have nothing assigned to these keys, nothing other than what the previous post highlighted is in my shortcuts - view brick pallette
any help
(do i need to download brick 10? which is not the latest version?)
cmeed
by tfdesign » Fri Oct 15, 2010 12:48 pm
Pardon my ignorance, but I'm trying to see how this plugin improves on the tools already available in SketchUp for adding copying and rotating. What I was really hoping to see was a wall creation tool, where you define the number of bricks needed, and at what dimension in h,w and d, then the height and width of the wall. But it seems that this plug-in doesn't do that? Or does it? Or am I just missing the plot altogether? I'd also very much like to see a plugin that randomly chooses textures from a predefined texture pool (folder). This would mean that the wall would at least have some sort of irregularity to it, rather than each brick just looking the same. Is that doable? best, Tom
My book " Let's SketchUp!" Download from here
tfdesign
- Top SketchUcator
- Name: Tom
by SUFractal » Fri Oct 15, 2010 3:15 pm
After countless attempts, it is now working.
Odd.
SUFractal
by tfdesign » Fri Oct 15, 2010 4:16 pm
 WOAH! Thanks for that link Adam! I'm stunned. Almost the perfect reason to switch software! No.....must....resist.....!! Yes! Something just like that!!!TIG, Fredo6 We know you can do it! I'll happily pay you too!
tfdesign
- Top SketchUcator
- Name: Tom
by Chris Fullmer » Sat Oct 16, 2010 5:18 am
Ooh I liked that thing
- SketchUp Team
- Name: Chris Fullmer
- License type: Pro
- SketchUp use: landscape architecture
by Pixero » Sat Oct 16, 2010 7:52 am
While we're at 3dsMax scripts, what about this one. Free node based procedural building generator. http://forums.cgsociety.org/showthread. ... e=50&pp=15
Pixero
- Premium Member
- Name: Jan Sandström
- License type: Pro
by EarthMover » Sat Oct 16, 2010 12:57 pm
Nice Jan. Here's the latest release of Building Generator. - http://forums.cgsociety.org/showpost.ph ... tcount=786I'm sure this is something that the talent here could whip up pretty easily for sketchup. TIG has the roof and windows already. Starting from a footprint, it would just be a matter of extruding walls via ruby and adding the other features. The node generator part, on the other hand, probably not doable. Good find though...I'm playing with it now.
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller Some of my 3D crap
EarthMover
- Top SketchUcator
- Name: Adam Hails
by tfdesign » Sat Oct 16, 2010 1:44 pm
I'll PM TIG about the brick generator idea, that's if he doesn't get here first.
tfdesign
- Top SketchUcator
- Name: Tom
by EarthMover » Sat Oct 16, 2010 2:03 pm
Tom, he is currently working on something per this request of mine - viewtopic.php?f=323&t=31376&hilit=brick+tile
EarthMover
- Top SketchUcator
- Name: Adam Hails
by tfdesign » Sat Oct 16, 2010 4:12 pm
Excellent!
tfdesign
- Top SketchUcator
- Name: Tom
by Caleidos4D » Thu Oct 21, 2010 10:09 pm
WonderFULL!!!!!!
Caleidos4D
- Name: Never
by Builder Boy » Thu Nov 18, 2010 11:48 pm
It won't work! Every time I try to use it, I get this in the ruby console: - Code: Select all
Error: #<NoMethodError: undefined method `entities' for nil:NilClass> (eval):79:in `initialize' (eval):911:in `new' (eval):911 (eval):79:in `call' (eval):79
Builder Boy
- Name: Michael
by sahi » Fri Nov 19, 2010 1:05 am
Fixed Upgrade plugins First Message Brick_14a.zip
sahi
Not a Premium Member yet? Check out the great time-limited deal we are offering.
- Robot
Return to Plugins
