[Plugin][$] Vertex Tools
Re: [Plugin][$] Vertex Tools
Postby Box » Sat Feb 09, 2019 4:49 pm
So true, I didn't mean anything by it. Just noting that we all tend to read what's in front then scroll on rather than following the story.
Postby algorad88 » Mon Feb 25, 2019 2:10 pm
Hi Thomas,
Thank you so much for the great plugin.
Is there a chance to add some features to VT:
1st: to extrude with scale similar to the move tool by holding the Ctrl key?
2nd: Furthermore moving only in one direction at a time is time consuming, I've seen you've got another type of gizmo which has three planes which you can move in two direction by clicking on each of them?
3rd: Also, the soft selection selects vertices in a sphere shape, could you add a feature to firstly choose which vertices to select and then continue to soft select?
algorad88
Postby thomthom » Mon Feb 25, 2019 11:04 pm
algorad88 wrote:1st: to extrude with scale similar to the move tool by holding the Ctrl key?
Yes - in fact, it's already added to the upcoming v2.
algorad88 wrote:2nd: Furthermore moving only in one direction at a time is time consuming, I've seen you've got another type of gizmo which has three planes which you can move in two direction by clicking on each of them?
Also coming in v2. :D
algorad88 wrote:3rd: Also, the soft selection selects vertices in a sphere shape, could you add a feature to firstly choose which vertices to select and then continue to soft select?
Can elaborate on this? Screenshots? Example model?
PluginStore Author
PluginStore Author
Postby algorad88 » Fri Mar 01, 2019 4:12 pm
Thanks for the great news :thumb: :thumb: :thumb:
thomthom wrote:Can elaborate on this? Screenshots? Example model?
This is how Vertex Tools selects vertices if I type 30 for soft selection:
But I only want the bottom quads selected. So, firstly I have to group those quads and then modify the vertices:
But this method has some deficiencies:
first, we will have separated quads by modifying vertices.
second, to join them again, we need to move those vertices which both takes much time and may not be accurate
third, we need to explode the group to join the parts again.
But if there were an option just like grouping which let you choose which vertices to affect the soft selection, then we could eliminate those steps
3
algorad88
Postby thomthom » Fri Mar 01, 2019 11:39 pm
I see now. I got plans for that as well - to add an option to apply soft selection by connected edge distance.
5
PluginStore Author
PluginStore Author
Postby SpookyChick1013 » Thu Apr 11, 2019 2:39 am
Thom, I love the plugin, but there is a problem I keep running into, and I'm not sure if it's just a missing feature, or if it's a PEBKAC error. Is it possible to scale things unidirectionally?
For example, select group of vertices, and then scale with gizmo tool only in the positive direction on the chosen axis, instead of what it currently does, which is scale in both positive and negative on the chosen axis?
If there is a way to do this, it would make me very happy, :) as currently, this is not as useful to me as it could be for shaping terrain, which is my main use for VT.
In order to avoid this being a Pebkac error, I have already looked over the manual, and read back through the thread. So far, I haven't found a way to do this. Basically, I just want hte scale function to work the same way SU's native scale tool does, or Fredo's scale tool. As it is right now, it acts like Fredo's scale tool after you press CTRL, with no way to turn that off.
Arigato!
https://kuromatsudriveyards.com
Fo-su to tomo ni aran koto o...
SpookyChick1013
Postby thomthom » Thu Apr 11, 2019 6:07 pm
You can scale in the choose axis by holding down Shift. But it doesn't stop at 0. (But v2 will stop at 0 so it's easier to scale to zero.)
PluginStore Author
PluginStore Author
Postby SpookyChick1013 » Thu Apr 11, 2019 8:08 pm
Hmm. I guess I didn't do a very good job of explaining the problem. :? The Scale tool in VT seems to scale both up and down on whatever axis, from the centerpoint of the tool, or the selected geometry. It's not a matter of trying to scale to 0. :) Maybe if I put it this way; If I have a mesa in a piece of flat ground, and I select only the pillar portion of the mesa, and try to scale it upward in height by a factor of three, I should only have vertices moving upward. Instead, I get some vertices moving upward, and some moving downward, leaving the pillar of the mesa, now sitting in a narrow crater. :shock: How do I alter settings so it only scales upward from the lowest point of the selected geometry? I keep thinking I remember it working this way once upon a time... :?
I'll try to post some illustrations of the problem soon.
THanks
Ok. Pics. :fro: THis is what I'm trying to do is scale the selected portion to be 3 times the current height.
And this is what I get. :shock: Note the geometry around the pillar is scaled downward. I need to know how to turn that off, if it's possible. I hope the pictures help. :D
SpookyChick1013
Postby thomthom » Thu Apr 11, 2019 8:23 pm
I see.
I don't recall if Gizmo scale uses the Gizmo origin as scaling origin. If so then setting a custom position for the gizmo might help. (from the context menu on the Gizmo).
But that's probably somewhat awkward workflow. The Vertex Tools Scale tool might be the better choice with the current version.
I logged an issue to look into better scaling control for future versions.
PluginStore Author
PluginStore Author
Postby SpookyChick1013 » Thu Apr 11, 2019 9:04 pm
I thought that was the VT scale tool...? I'm confused now...Maybe there's something I'm missing? If there is something I'm missing, I do apolgise for being an ID10T error. Apparently that's a sin to some people around here, (not talking about you by the way,Thom) as I've found in the past.
I do appreciate you logging this though. A solution that would make it work more like Fredo's scale tool would be awesome.
SpookyChick1013
Postby thomthom » Fri Apr 12, 2019 9:09 am
There are two ways of scaling in Vertex Tools, via the Gizmo;
and via the Vertex Tools scale tool:
Which one of these were you referring to?
PluginStore Author
PluginStore Author
Postby SpookyChick1013 » Fri Apr 12, 2019 2:31 pm
The Gizmo, because that was the only thing I had ever seen in VT. I found out why I thought that was the only method of scaling. I apparently had settings tweaked so the Gizmo would show up anytime I clicked on scale. Even so, neither the Gizmo, nor the scale tool does what I need at the moment. The scale tool keeps tapering things for some reason...
I guess I'll just have to find some other way to do things. A shame really, because in many other ways VT is great for Terrain forming.
Thanks!
SpookyChick1013
Postby Box » Fri Apr 19, 2019 2:32 am
Have you considered using soft select and just pulling up.
Postby AndreaFryett » Thu May 16, 2019 8:16 pm
FYI. I can't purchase.
I tried both through sketch-up extensions warehouse and now through this website.
The error I get on this site is "nothing to see here" when I try to follow the purchase link
in sketch-up extensions I can not submit a payment, and If I go back and try again, it keeps adding quantity but I can't undo that.
Andy
AndreaFryett
Postby SpookyChick1013 » Sun May 19, 2019 6:10 pm
@ Box: Hai, I use that methosd in some circumstances, but it doesn' work so well when trying to scale a mountain range, or something of that nature. I appreciate the suggestion though! :fro:
SpookyChick1013
Postby thomthom » Sun May 19, 2019 7:36 pm
AndreaFryett wrote:FYI. I can't purchase.
Andy
The only place to purchase Vertex Tools is at its website: https://evilsoftwareempire.com/vertex-tools
It cannot be bought from Extension Warehouse.
If you are having problems from https://evilsoftwareempire.com/vertex-tools - can you send me a screenshot of what you see?
PluginStore Author
PluginStore Author
Postby Pixero » Mon May 20, 2019 7:17 am
@Thomthom
Why can't SketchUp incorporate the way your vertex tools don't destroy texture UVs when moving vertices?
Pixero
Postby thomthom » Mon May 20, 2019 10:38 am
Pixero wrote:@Thomthom
It's a matter of priorities of infinite amount of improvement requests vs a finite amount of time.
PluginStore Author
PluginStore Author
Postby optimaforever » Mon Aug 26, 2019 3:48 pm
Vertex tools is really a must have in my toolset, it's so handy to have when dealing with complex geometry...
Is V2 allowing easier placement of gizmo for scaling/rotating/moving? By default, the scale/rotate uses a gizmo position centered on the selection. But sometimes I'd like to manually move the gizmo to define another center for the scaling/rotating, like on a vertex or the edge of the selection.
A quick and dirty way, like Ctrl + move along the axis would move the gizmo without altering the geometry... or something like that.
And what about a 'smart' offset of a loop/ring? Kind of SU offset tool but that works in 3d space too.
Imagine a curved road (in XY but also in Z too) and you'd need to quickly offset the rim edges to add the shoulder, curbing, drainage, walkway, etc.
In 2d space it's easy as SU offset tool works but if the site is not flat it's another story...
I suppose it's similar to the extrude with scaling demand I saw earlier in the thread...?
If the selection is planar I usually create a face and use FREDO JointPushpull's Follow pushpull which takes into account the connected faces, but it would be handy to be able to do that with a non coplanar edge selection.
optimaforever
Premium Member
Premium Member
Postby turbodizayn » Sat Nov 16, 2019 1:39 pm
Hi, I think feature to get softselection within preselected choice of objects will be most important thing of all other vertex tool features. I wrote about it many times ago. https://sketchucation.com/forums/viewto ... 23&t=70985
turbodizayn
Postby optimaforever » Thu Nov 21, 2019 4:29 pm
Hi Thom!
One thing that annoys me is the fact that I need to quit Vertextools mode to select quad loops or rings with QFT... Is it not possible to get loop/ring selections while in Vertex tool ?
Just wondering... ;)
optimaforever
Premium Member
Premium Member
Postby summerson1990 » Sat Nov 23, 2019 6:53 pm
Can’t activate my license. Suppose the problem with site’s server (evilsoftwareempire.com) it doesn’t work. Please fix it
summerson1990
Postby turbodizayn » Sun Nov 24, 2019 12:15 pm
Here is how soft editing realized in Rhino
http://docs.mcneel.com/rhino/6/help/en- ... ftmove.htm
If tt_vertex tool has this feature ...!!!
turbodizayn
Postby jukkoo » Sat Dec 21, 2019 7:20 pm
Is this in the picture what you were talking about?
I just got vertex tools and was hoping this was already an option. IT is actually an extremely useful tool when modeling with quad geometry.
When do you plan to complete v2? :)
Don't get me wrong, I am extremely grateful for your efforts. Sketchup without your plugins would be half the program it is.
jukkoo
Postby pipinek » Mon Apr 06, 2020 7:12 pm
Greetings,
Is there any possibility to have the toolbar kept on the screen instead of activated it each time one clicks on the empty screen?
Thank you in advance.
pipinek
Premium Member
Premium Member
Postby Einstein » Wed Apr 08, 2020 11:42 am
Hi!
It seems that among Vertex Tools' shortcuts there's no one to call the general toolbar. There are only hotkeys for particular operations but I'd like to press V and activate the plugin toolbar. It would be cool to add such an option I think. Just a suggestion :)
Einstein
Postby pipinek » Wed Apr 08, 2020 4:53 pm
Einstein wrote:Hi!
Thank you for the suggestion.
I have been using a shortcut to activate the toolbar.
I find it annoying to have to recall it every time using a single tool.
I wish it could be an option to keep the toolbar permanently on the screen.
pipinek
Premium Member
Premium Member
Postby Einstein » Wed Apr 08, 2020 7:54 pm
pipinek wrote:I have been using a shortcut to activate the toolbar.
How did you do this? I'm looking for just this option.
Einstein
Postby pipinek » Wed Apr 08, 2020 8:36 pm
Shortcuts:
Tools/Vertex Tools/Edit Vertices
Here you can associate a shortcut. The Vertex Toolbar will appear.
pipinek
Premium Member
Premium Member
Postby GD3Design » Sun May 24, 2020 2:40 pm
thomthom wrote:Yes - in fact, it's already added to the upcoming v2.
Any news on v2? :) :) :)
Maybe a pre-sale 'crowd-fundy' thing to help production...? :)
GD3Design
PreviousNext
Return to Plugins
Users browsing this forum: Sierra333 and 12 guests
