SketchUcation Plugin Store
[Plugin] Superglue (1.1.0) — 07 July 2010
Re: [Plugin] Superglue (1.1.0) — 07 July 2010
Postby Free Agent » Thu Sep 23, 2010 1:30 pm
hey thom thom just tried this ruby and works great. thanx alot :thumb:
Free Agent
Postby thomthom » Thu Sep 23, 2010 1:33 pm
Sean! :bounce:
Long time no see. How are you?
What have you been up to? Are you completely Max person now? Got some new work to show off?
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Free Agent » Thu Sep 23, 2010 2:40 pm
Im good, you? and nope, i speak max and sketchup :) sketchups just too easy to completely throw out of ones workflow.
check out the company blog http://www.constructmedia.co.uk/news :) will post some new stuff soon
Free Agent
Postby ellen_leung » Thu Feb 24, 2011 9:45 am
i dont understand how to use it, can anyone help explain to me?
ellen_leung
Postby Gaieus » Thu Feb 24, 2011 11:41 am
Hi Ellen,
Here is a short video with captions:
YouTube - Superglue Plugin for SketchUp by ThomThom
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby dereeei » Tue Sep 27, 2011 8:04 am
It seems to not work for me :(
I made a component that makes a hole in a face, when I take the component from Components window, it cuts hole, if I copy it from model ( :move: + Ctrl), it doesn't cut hole. I used Superglue on it, it doesn't cut hole. Am I misusing the plugin? Why that components don't cut hole when I copy them?
dereeei
Postby thomthom » Tue Sep 27, 2011 8:10 am
dereeei wrote:It seems to not work for me :(
Can you post sample model?
Global Moderator
SketchUp version: 8
License type: Pro
Postby dereeei » Tue Sep 27, 2011 9:03 am
can't explain myself. I saved the model as new file, it worked there. In the original one doesn't want. I copied the model in a new sketchup window, it doesn't work.
It looks like is a sketchup glitch, rather than model-related.
dereeei
Postby thomthom » Tue Sep 27, 2011 9:34 am
Are you trying to clue the component onto a face directly, or is the face wrapped in a group/component?
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Tue Sep 27, 2011 10:02 am
When you place a component from the Component-Browser it is put onto your cursor at that component's origin, this is necessary because the origin [axes] must be put down snapped onto a face so that the instance will be assigned that face which it can then 'glue' and 'cut'.
If you copy an already placed instance using Move+Ctrl you need to pick a point on the face that the instance is glued to [or a corner of the instance that is on that face]; then when you pick a new face the component will again find a face to glue/cut. BUT if you pick a point that's off the original's glued face then you won't be able to snap the copy onto another face because it'll always be placed non-planar to a face.
Similarly, if your cutting component has geometry [like a frame/surround or a projecting-sill] that projects in front of the plane of the wall face [and therefore the cut hole] when you use Edit>Copy and then Edit>Paste the cursor that's locked on to the copy is placed NOT always at the copy's 'origin' BUT sometimes at its bounding-box minimum extents, which isn't then going to be the component's 'origin' [especially if the source instance is itself not glued to a face] - so when you snap it onto a face it will not find any face that is coincident with its origin, so there's no gluing and therefore no cut. I suspect that SuperGlue - like other '[re]gluing' tools - looks for a face below the instance's origin and if it can't then find one then there's no gluing and therefore no cutting. A component that's located with its origin a few mm away a face is just as 'unconnected' to that face as if it were placed meters away in empty space.
Conversely, if you have a 'flush' cutting component with no projections in front of the wall face it will Copy/Paste quite satisfactorily, as in this case the cursor will be in the same plane as the component's origin [even if it's perhaps not on the origin itself] and so subsequent snapping of it onto a face will this time find that face coincident with the origin, and which it can then use to glue/cut...
Hence you can get seemingly odd behavior across different types of gluing/cutting components when they are copied, IF you fail to appreciate what is happening with the object's geometry and the cursor...
To see it in action try making a completely flush cutting component and also another version with very large projecting sill [500mm!], use the Component-Browser to place instances of both into a wall and then watch where the cursor is located during subsequent copy/paste operations and the success/failure to glue/cut for the copies, and copies of copies, or copies of non-glued instances etc :geek:
Global Moderator
SketchUp version: 8
License type: Pro
Postby dereeei » Tue Sep 27, 2011 11:18 am
My last thought is that in original model was some small deviation from "coplanar" ... because as i said before, I wrapped everything in a component, I saved as new file, then opened and it cut hole by copying and by placing from Component Browser.
In original model it did not cut hole by copying, just by placing new component from Component Browser. When I copied I was on face with the cursor. I tested that by exploding the component and it merged with the face.
dereeei
Postby TIG » Tue Sep 27, 2011 11:23 am
If the component has non-coplanar parts you might get the cursor no longer being in the face when the copy is snapped.
Can you save_as the component and post it so we can have a better idea of what's going on... :?
Global Moderator
SketchUp version: 8
License type: Pro
Artisan Organic Toolset - a set of powerful organic modeling tools.
Previous
Return to Plugins
Users browsing this forum: affinlove, cham, kazucooper, meocram, nemm, salleex, xmano90 and 12 guests
