[Plugin] Axo + Iso View v1.2 20101117
• Page 2 of 3 • 1, 2, 3
Re: [Plugin] Axo + Iso View v1.2 20101117Sorry but I don't understand how to do it
Can you make an example? Re: [Plugin] Axo + Iso View v1.2 20101117Sorry for the bump
But I still can't figure out how to get this to work with shadows correctly shown.. Re: [Plugin] Axo + Iso View v1.2 20101117
I don't know how to get the shadows to look right either... that's up to you by adjusting location, north, date time etc. Once you have that save a scene with the only thing fixed as the shadows [as explained]. Then later you can use that tab to reset shadows to those values again... TIG
Re: [Plugin] Axo + Iso View v1.2 20101117I think we are not on the same page here , Lets make it a simple question :
Is it possible to show the model ( even just exporting an image it doesn't matter) with axo_scale , but with shadows shown correctly as if it wasn't scaled? If so , can you please make an example? Thanks in advance Re: [Plugin] Axo + Iso View v1.2 20101117
No. Shadows come from the geometry, if you've scaled it the shadows won't be the same. You could make the axo, export an image with shadows then. Switch off shadows. Now Scale the axo and re-export an image. Use an image editor like Gimp to overlay the scaled image over the [now incorrect] shadows??? I fail to see how how the 'wrong shadows' will look right on the scaled skp's image. Can you explain why you need to do this? If you want shadows then shading the scaled version will look right... IF you set the location/date/time appropriately... TIG
Re: [Plugin] Axo + Iso View v1.2 20101117Thanks for the answer , I'll deal with that
Its for school ( uni. ) assignment ( 1st year architecture ) , will be pretty hard to explain hehe.. ![]() But thanks again ![]() Re: [Plugin] Axo + Iso View v1.2 20101117I need to produce axon45/45 drawings of the Casa Bianchi.
But it doesn't work. I typed axo4545 and it said Error: #<NameError: undefined local variable or method `axo4545' for main:Object> (eval) I have both 7Pro and 8pro licensed on mac and pc Please help.. Re: [Plugin] Axo + Iso View v1.2 20101117
The version shouldn't be an issue. Have you definitely got a file called 'axo+iso.rb' in the ../Plugins/ folder ? To see where your ../Plugins/ folder is copy paste this line into the Ruby Console + <enter> Sketchup.find_support_file('Plugins') That is the correct folder... You should be able to type in the Ruby Console any of these commands... axo3060 which sets the camera to a 30/60 axonometric view and zooms extents axo6030 which sets the camera to a 60/30 axonometric view and zooms extents axo4545 which sets the camera to a 45/45 axonometric view and zooms extents iso3030 which sets the camera to a 30/60 isometric view and zooms extents The current view changes to the axo/iso format desired and model-extents are zoomed, now zoom in/out and pan BUT DON'T orbit - that would loose the axo/iso-ness; then save that view to a Scene-tab. If you have a 3d axo it needs 'distorting' so that it prints or exports as an image and looks correct. The whole model needs scaling - particularly in the Z axis. There are two tools to do this for you. Use with care and remember to undo the temporary scaling to continue modeling. After setting an axo view type in the Ruby Console + <enter>: axo_scale to scale the whole model, so it is distorted but looks correct. axo_scale_restore TIG
Re: [Plugin] Axo + Iso View v1.2 20101117Thank you for your fast response!
the Sketchup.find_support_file('Plugins') works and it said > Sketchup.find_support_file('Plugins') /Users/ja/Library/Application Support/Google SketchUp 7/SketchUp/Plugins But it still say the same when I type axo4545... Anyway, I copy my model and paste it in your example.skp and use the saved scene and then scale it blue/red/green as suggested in
and it works! the scale is super correct when I export .pdf to adjust lineweight in Illustrator. So, Thank you very much TIG and Luke for including the example file and amazing info! ![]() ![]() Re: [Plugin] Axo + Iso View v1.2 20101117Hi TIG
I can't get the axo_scale command to work for me. My sketchup just bug splats after i hit enter. I'm using Sketchup pro 7.1.... any ideas what might be going wrong? Cheers Joel Re: [Plugin] Axo + Iso View v1.2 20101117Any error messages in the Ruby Console ?
It should work in all versions of Sketchup... ![]() How complex is your model ? Are you in the model's active_entities rather than inside an 'edit' context ?? Puzzling............ TIG
No error message. just instant bug splat. The model isn't complex, just a box. Joel Re: [Plugin] Axo + Iso View v1.2 20101117
Can you post your problem SKP... ![]() TIG
Re: [Plugin] Axo + Iso View v1.2 20101117This is absolutely brilliant!! thanks for this!!
![]() ![]() IOviz.com
SU Pro 2017 PC Thea: latest vray4SU latest Re: [Plugin] Axo + Iso View v1.2 20101117Hello TIG,
found the script late last year. It's really great - thanks! I've been using it occasionally, and it worked fine until last night - the axo_scale command suddenly went rogue. Everything works fine until i type that command, and then nothing else works - I can't change the axo views, I can't use axo_scale_restore. and if I try to restore the scale by using ctrl-z, sketchup will encounter a bug splat. As long as i don't use that scale command, switching between views work fine. So what I've been doing is save file -> get axo view -> export image -> let it crash -> reopen saved file to continue modeling, but as you can imagine it's not exactly efficient. I'm just wondering if you have any ideas why this happens or have encountered this problem before? I'm using Version 8.0.3117 if that makes any difference. Re: [Plugin] Axo + Iso View v1.2 20101117Unknown problem
![]() Is there anything weird about your model if you zoom extents etc ? Is it a long way off the origin ? Have you run Model > Statistics > Fix... etc ? ![]() TIG
Re: [Plugin] Axo + Iso View v1.2 20101117To answer your questions...
1) nothing weird ![]() 2) no... 3) Yes... The only thing I can think of is that it's really huge... (its a model of a city) Anyway, some updates... in the exact same skp model, it sometimes work and it sometimes doesn't. I've tried to discover what is it that makes it work and what makes it not work, but so far it just seems completely random. There must be something though... anyway all it really does is to make me save more often which is a good thing i guess ![]() Re: [Plugin] Axo + Iso View v1.2 20101117Hi m8 very nice plugin! Do you know (or anyone else
![]() ty for your help and efford to create this plug in ![]() Re: [Plugin] Axo + Iso View v1.2 20101117ok my bad...I just realised (after some years!
![]() ![]() Re: [Plugin] Axo + Iso View v1.2 20101117I have managed to install the Axo plugin detailed in your comment below, but am looking to alter the viewing angle on the view so I get more of a front view of the buildings... but still with Axo4545 properties. At the moment you see too much of the roof, its near top view on.
Is there anyway you know of to alter this? Or do you know anywhere I might be able to find this out? Re: [Plugin] Axo + Iso View v1.2 20101117Hey TIG,
I've done many many many exports with this doing architecture at uni, also loads of other people use it because of me too. I was wondering if it would be possible to make some buttons for it I can put on my toolbar which would be very useful!? Thanks again ![]() Luke www.lukeriggall.co.uk Re: [Plugin] Axo + Iso View v1.2 20101117Making a toolbar is relatively straightforward. Write a separate .rb file that has an initial 'require' to this tool's .rb file. Define a toolbar. Define a 'command' referring to a tool - this already seen in the console code that runs it... A 'command' can also have tooltips, status_bar_text, buttons assigned to it etc [make the button's PNG icons in a subfolder [AxoIsoPNGs?] and you path to those]. Now add the 'command' to the new toolbar. Repeat as needed... As well as making buttons for the various view changers you might want to have ones for the scale/restore options... When your file auto-loads as Sketchup starts up it will make the toolbar... Here's a start... require 'axo+iso.rb' ### toolbar=UI::Toolbar.new("Axo+Iso") toolbar.restore if new_toolbar.get_last_state==TB_VISIBLE ### cmd1=UI::Command.new("axo3060"){axo3060()} png1="AxoIsoPNGs/axo3060.png" if File.exist?(png1) cmd1.small_icon=png1 cmd1.large_icon=png1 toolbar.add_item(cmd1) end ### Repeat for each command, changing the text/png/command-name etc to suit... Get it working with one command, and then copy the working code down, edit and retest till all functions have working buttons... TIG
Re: [Plugin] Axo + Iso View v1.2 20101117The scaling is incorrect with this plug in. I used it to export a .dwg, and found that angles were not true and scaling improper. Is there a newer version with the bugs worked out?
Re: [Plugin] Axo + Iso View v1.2 20101117Yes ![]() Just try it and see... it's not like you are "buying it"! TIG
Re: [Plugin] Axo + Iso View v1.2 20101117Sorry, I have a question about this plugin, run on MacOS? I need help. Please. Thanks.
Re: [Plugin] Axo + Iso View v1.2 20101117If the question is, "Does it run on a MAC?" then the answer is 'Yes'.
However, you need to read and understand how to activate/use the tool - explained in the download page... TIG
